Looking for a new home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 08-11-2008, 11:59 AM - Thread Starter
likethesoundofHD's Avatar
Hi everyone, im looking for a new home theater system for my bedroom. Im looking for a Dolby HD capable receiver with decent speakers and deep base for games and action movies. Im trying not to spend more than $400 dollars but i could swing a little more if necessary. Thank you for your help
likethesoundofHD is offline
post #2 of 23 Old 08-11-2008, 12:53 PM
wesabi's Avatar
Getting a decent set of speakers and receiver for $400 is going to be really difficult. How much could you stretch it to?
Personally, I would wait and save up a little while longer until I at least had around $800 to spend. You can pickup a decent set of 5.1 speakers for $500 on the used market and then buy a $300 receiver... but at $400, you're limited to pretty crappy HTIB options.
wesabi is offline
post #3 of 23 Old 08-11-2008, 01:10 PM - Thread Starter
yeah thats my problem i really want hd sound because i have a ps3 and play alot of bluray movies. i could save up to say $800-$1000. what do you recommend?
post #4 of 23 Old 08-11-2008, 01:13 PM
Raymond Leggs's Avatar
I agree, good sound doesn't come cheap when it comes to multichannel audio.
Raymond Leggs is offline
post #5 of 23 Old 08-11-2008, 02:19 PM - Thread Starter
yeah thats understandable. the other problem is my room isnt really set up for 7.1 surround sound so im stuck with 5.1.
post #6 of 23 Old 08-11-2008, 02:20 PM
ccotenj's Avatar
Liked: 101
nothing wrong with that.... the great majority of us out here have 5.1 and are MORE than happy with it...
- chris
ccotenj is offline
post #7 of 23 Old 08-11-2008, 03:25 PM - Thread Starter
well whats the best receiver speakers and sub would be best for a price range of $500-$1000
post #8 of 23 Old 08-11-2008, 03:31 PM
wesabi's Avatar
Good speakers should be your priority number one... not "HD sound" - since speakers will improve the sound quality a great deal more than a higher audio bitrate.
If you can spend up to $1000, you are going to have some pretty good options. I would start looking on craigslist, eBay, or Audiogon to see if you can score a sweet deal on a used 5.1 speaker setup. Brands to look out for would be Atlantic Technology, NHT, Definitive Technology, Paradigm, Energy, PSB, and many more... just don't buy Bose.
If you want to buy new speakers, check out the HTIB Alternatives thread here: http://www.avsforum.com/avs-vb/showthread.php?t=809777
wesabi is offline
post #9 of 23 Old 08-11-2008, 03:44 PM - Thread Starter
how do you feel about denon or yamaha?
post #10 of 23 Old 08-11-2008, 03:51 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Best Buy sells these Polk T15 speakers. These look a lot like the Polk R15's shown on Polk's web site (they don't have a listing for the T15s)
These seem to be only $100/pair. Worth taking a look at IMHO. You can always omit a center channel for now; the receiver should split the center channel equally to the L/R speakers.
There are a lot of good looking subs in the $400 range. But if you can't afford that, you may have to go cheaper.
You can pick up an RX-V661 for under $300 according to amazon. I think that could work well for you.
Potentially cheaper yet, and a very good receiver is the RX-V659, if you could find one. It does not have HDMI. It's a few years old. (I checked ebay, and a 97% seller said they had one new, with a low starting bid.)
"But this one goes up to 11"
MichaelJHuman is offline
post #11 of 23 Old 08-11-2008, 03:53 PM
gunbunnysoulja's Avatar
Yamaha, Denon, Pioneer, HK, Marantz, Onkyo, etc. will all offer similiar sound quality.
They are all very good quality products.
Alot of it comes down to personal preference and brand loyalty. Some offer better features.
Personally, I would look at refurb for the receiver and used for the speakers.
gunbunnysoulja is offline
post #12 of 23 Old 08-11-2008, 05:13 PM
GreySkies's Avatar
Quoted: 620 Post(s)
Liked: 436
That's a nice price on the 661. It matches well with the PS3. IMO, it's not worth it going up to the 663 as the PS3 doesn't bitstream the new audio codecs. (disclosure: I've got a 661 paired with a PS3)
As I said in your other thread, though, I'd pay more attention to speakers than the receiver if your budget is limited.
GreySkies is offline
post #13 of 23 Old 08-11-2008, 05:22 PM - Thread Starter
so if i were to look at speakers im seeing polk are they the best or a there others that could fit in my budget?
post #14 of 23 Old 08-11-2008, 07:32 PM
wesabi's Avatar
Speakers are very subjective. I would definitely go used if you're on a budget, because instead of getting a new system that retails for $700... you can get a system that originally retailed for much, much more. Speakers, unlike receivers, don't go bad with age.
As I've said before, look on the used market for speakers from Atlantic Technology, NHT, Definitive Technology, Paradigm, and PSB (plus I'm sure others can recommend other good brands). Some great sub/sat systems you might be able to get on eBay are Definitive Technology ProCinema, Atlantic Technology System 920, or the Energy Take series.
wesabi is offline
post #15 of 23 Old 08-11-2008, 08:56 PM - Thread Starter
well wesabi i looked at most of those brands and they look good but unfortunately i dont think they will fit in my room.
Here is what my room looks like:[IMG][/IMG]
I will also be putting a recliner in the are where the computer chair is so i need to wall mount the rear speakers.
post #16 of 23 Old 08-11-2008, 10:39 PM
toolwarrior's Avatar
Ain't that the truth. My 5.1 is abused so badly that I blew my phase tech rears, blew one of the channels in my Marantz AVR and overdrove my Velodyne UDL-12 enough to trash the accelerometer................Life is good! Well, not so much now that I have a lot of gear to replace..... Don't belive me.........try Pink Floyd's "Dark side of the moon" on a good system.....you'll see.............
toolwarrior is offline
post #17 of 23 Old 08-11-2008, 11:28 PM
Taking your budget and bedroom into account, have you considered headphones?
IMO, $400 on a headphone setup, particularly for gaming and movies with Dolby Headphone, blows away the performance from a 5.1 setup at or near the same cost.. But then again, few love headphones.
At times, I prefer headphone sessions to a $5k+ 5.1 setup.
Anyways, I'd recommend the Denon D2000 and a Zero Dac/Amp if you have any interest in headphones.
post #18 of 23 Old 08-12-2008, 05:05 AM
ccotenj's Avatar
Liked: 101
+1 on the cans, especially since you have NO place to put your right side speakers...
- chris
ccotenj is offline
post #19 of 23 Old 08-12-2008, 05:10 AM
GreySkies's Avatar
Quoted: 620 Post(s)
Liked: 436
...and if you go cans instead of speakers, look into tactile transducers for the recliner you're putting in. An Aura Bass Pro + a plate amp will run you 50-60 bucks at Parts Express.
post #20 of 23 Old 08-12-2008, 06:09 AM
DonoMan's Avatar
You can't fit a "home theater" in a space like that.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #21 of 23 Old 08-12-2008, 07:58 AM
EnzymaticRacer's Avatar
Quoted: 12 Post(s)
I don't think there is any possible way you are going to be able to fit any kind of speakers in that space... period. I don't even think the bose cube speakers would work in that space.
I recommend just saving your money and go with headphones or just stick with the TV speakers for now until you have some real space to work with.
Television: Samsung 55" 4K UHD UN55HU7250F
Receiver: Harman Kardon AVR 354 Receiver driving 5.1 surround
Remote: Logitech Harmony Ultimate Home
EnzymaticRacer is offline
post #22 of 23 Old 08-12-2008, 11:21 AM
I've done it before.
He could go for a sound bar type deal .
post #23 of 23 Old 08-13-2008, 08:57 AM - Thread Starter
well i just hooked in my 2.1 computer speakers so i get a little better sound with some bass. but at least now i know i cant use the space and just save up for an even better system! Thanks for all your help!
