"Official" Denon AVR 2809CI/989 Thread - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 09-10-2011, 09:39 AM
ck42's Avatar
Unless you want to wait for 6Ave to get it back in stock, give Electronics Expo a call as they've got it in stock now and at a great price.
Not familiar with them, but I've seem them mentioned a few times here on the site so I'm assuming they're reputable. Thanks for the tip. I'll give them a shout and see what they can offer.
ck42 is offline
Old 09-10-2011, 10:48 AM
jdsmoothie's Avatar
Quoted: 12142 Post(s)
Liked: 5531
Very reputable ... in fact, they've likely been an authorized Denon reseller longer than 6Ave.
jdsmoothie is offline
Old 09-18-2011, 07:35 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Anyone having issues with audio dropouts with StarWars: The Complete Saga BluRay?
Esp in Episode II, one of the most notable ones happens at timestamp 31:26 and 31:32....upgraded firmware in BDP, and no improvement, exchanged for new set of discs and no improvement.
Any chance a firmware upgrade to the AVR could fix this?
JSS
maxmercy is offline
Old 09-18-2011, 10:39 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
JSS
At least the drop-outs aren't on the original series. Phantom Menace would've been no big loss!
What Blu player are you using?
Any telltale lights changing or flicking on & off on the Denon's front display?
Are you bitstreaming audio or decoding in the player? Trying switching that over.
Electric_Haggis is offline
Old 09-19-2011, 05:27 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Haggis,
I am using a Sony BDP-BX2, no lights flicker on the Denon front display, and as far as I know, the receiver is decoding the audio, sent via HDMI from the player to the receiver, with no multichannel decoding done by the player. The player is a very 'bare bones' model, and may be my problem. The main reason I checked here was that another Denon owner (2311) playing back thru PS3 had the same thing happen.
Unfortunately, I get dropouts throughout Episode IV as well...
Thanks for your help!
On another AVS forum, there is a report of another person using a 2809 that runs through PS3, and his audio is fine, so it may be the BDP that is the culprit, or a bad batch of pressings.
JSS
maxmercy is offline
Old 09-19-2011, 10:23 AM
brunofagundes's Avatar
Yeah, I'm having the same issue with EP 2 and 4. My receiver is a Denon AVR-890, Blu ray is Panasonic DMP-BD35. I also tried with my neighbor's PS3 and the same thing happens, the audio cuts off when the BD players output bitstream but is fine when they output PCM.
From this thread http://www.avforums.com/forums/blu-r...roblems-3.html people are suspecting a problem with the new security encoding. It looks like it is more particular to Denon and in this case I'm out of luck as my receiver can't be updated unless by a Denon service technician . I really hope it's a Fox issue and that they will do a replacement program.
brunofagundes is offline
Old 09-19-2011, 11:30 AM
EricST's Avatar
Quoted: 63 Post(s)
Liked: 45
JSS
Yes, Only fix .. I replaced the Denon with a New Yamaha V571 and it plays like a champ. I still cant figure out what was wrong with my 2309. It played everything else I put through it but the Saga ..no can do. ESB and ROTS played fine but all the rest of them..audio drop outs and static at the beginning.
60" Samsung KS-8000
Oppo 203 UHBD
Denon 2200X receiver
PSB X series 5.1.2
The Force will be with you ...always.
EricST is offline
Old 09-19-2011, 12:50 PM
Another "fix" is to get the BD player to output PCM instead of bitstream.
Old 09-19-2011, 03:04 PM
Quoted: 24 Post(s)
Haggis,
JSS
Look up how to switch the player to bitstream output so the Denon decodes.
Your player should be able to do it, and there's a good chance this will solve the problem.
(I have it set this way anyway, as the midrange is slightly warmer if the Denon decodes.)
If it still happens, try different soundtracks (Dolby Digital +, foreign language, etc) to see how they're affected.
For the record, I can recommend the PS3 (with bluetooth remote) as a phenomenal player, media server and more. Cheap now, too.
Old 09-19-2011, 03:51 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
When the player is bitstreaming, I get audio dropouts. When the player is outputting LPCM, no dropouts, but I am no longer playing HiDef audio per my BDP's documentation, only the lossy cores.
The other lossy soundtracks on the disc (French, Spanish, Portugese, and descriptive audio), have no dropouts.
With people starting to report different players but still dropouts, it sounds like the Denon may be the culprit. I have an e-mail in at Fox, to see if anyone else has reported this issue.
Is your Denon handling the Saga well, Haggis? If so, what BDP are you using?
JSS
maxmercy is offline
Old 09-19-2011, 04:16 PM
I thought that when outputting PCM that it was still High Def resolution. It is just that the player does the decoding instead of the AVR.
Old 09-19-2011, 05:38 PM
Quoted: 24 Post(s)
I'm using a PS3, which as I mentioned, is unbeatable.
I haven't bought or tried the saga (I'll get around to renting them eventually )
With the PS3, and indeed most modern Blu players, you can set uncompressed PCM output so that hi-def audio track is decoded in the player and output as uncompressed with the hi-def audio left intact. You shouldn't be getting the lossy core tracks.
Outputting PCM is actually what many people prefer, as all the menu/button sound effects, etc are mixed in as well.
(As I mentioned, I only use bitstream because I slightly prefer the sound when the Denon decodes. But that's me.)
Old 09-19-2011, 05:42 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
My receiver and player never had any problems playing DTS-MA or DolbyTHD until this release. I don't think this is my receiver or player, unless it is a firmware issue.
Lots of the same problems in the UK:
http://www.avforums.com/forums/blu-r...roblems-7.html
It may be a firmware issue, but how do we update firmware on the 2809ci?
JSS
Anyway, until this gets sorted out, I'm returning the discs. I'll let Fox know this, as they have not responded to the question that I sent to them several days ago.
maxmercy is offline
Old 09-19-2011, 07:23 PM
ccotenj's Avatar
Liked: 101
it is...
- chris
ccotenj is offline
Old 09-19-2011, 07:41 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Not for my player. It downmixes to 5.1 in LPCM mode, and only sends the cores, IIRC.
I hope that this is simply a firmware update issue like the folks over in the UK think it is.....so I'll wait for things to sort out before I buy new equipment.
My receiver has played many DTS-HDMA discs before without a hitch. No reason it shouldn't play these....and specifically, have two discs give more errors than the rest....]
Discs have been returned, hopefully Sony will put out a firmware upgrade for my BDP or Denon will do similarly for the 2809ci...
JSS
maxmercy is offline
Old 09-19-2011, 08:40 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi maxmercy, curious what are your BD player audio settings? Check if the player BD Audio is set to MIX (it should be DIRECT).
JChin is offline
Old 09-20-2011, 02:23 AM
jdsmoothie's Avatar
Liked: 5531
Correct. Uncompressing an HD lossless file to PCM is no different then unzipping a PC file .. doesn't matter which device does it .. it's the same HD lossless file regardless.
Old 09-20-2011, 04:00 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
When audio is set to Direct, I only bitstream, as far as I can tell. No LPCM option is available to the best of my knowledge. Sony BDP-BX2.
JSS
maxmercy is offline
Old 09-20-2011, 09:32 AM
EricST's Avatar
Quoted: 63 Post(s)
Liked: 45
As I said I have a SONY BDP 370 and it most differently is the Denon. I switch the Sony out with a LG player with the same result. Its something in the Denon that is having trouble with the encoding of the DTS MASTER track. My new Yamaha V571 plays all the Saga disk perfectly. And for ..Just changing the Sony's Audio out to PCM..um no I didnt want to switch it back and fourth every time I wanted to go from the Saga to any other movie. Plus I am real anal about seeing that pretty little light saying DTS MASTER . I hate the ugly Muit Channel input effect on the front display.
60" Samsung KS-8000
Oppo 203 UHBD
PSB X series 5.1.2
EricST is offline
Old 09-20-2011, 12:47 PM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Although there should be no difference between decoding in the player and decoding in the receiver the capabilities of some players are unclear when decoding internally, particularly when secondary audio is present.
In fact, I'm not sure I've ever seen a player other than the PS3 where it was confirmed that it can internally decode lossless audio while mixing in secondary audio. You wouldn't think this is a problem as who cares about the quality of secondary audio but in the case of discs such as those by Universal, whether you turn on ther UControl feature or not most players if set to be able to mix secondary audio will decode the lossy track.
EVT is offline
Old 09-20-2011, 12:57 PM
ccotenj's Avatar
Liked: 101
the player has to decode internally to mix in secondary audio...
now, some players may be forced to use the lossy encode in order to do so (i don't know), but you can't mix secondary audio into a packed codec... it must be unpacked first...
- chris
ccotenj is offline
Old 09-20-2011, 02:04 PM
ccotenj's Avatar
Liked: 101
also anyone having this issue should see the bluray software subforum... this isn't unique to denon equipment...
- chris
ccotenj is offline
Old 09-23-2011, 09:18 AM
jdsmoothie's Avatar
Liked: 5531
Denon has resolved the Star Wars: The Complete Saga BD audio dropout issue with a firmware update. Although the firmware update will be made available at authorized repair facilities for all models as an "in warranty" repair, regardless of whether actually beyond the 2 year warranty period, for those 2809CI/989 owners that feel comfortable doing their own installation I have the update which will require a PC laptop and USB to RS-232 cable. Note that this update is being provided as a courtesy and as such is not supported by Denon should you have any problems with the installation (ie. you cannot call Denon for assistance). If you don't feel comfortable with doing the installation on your own, simply submit it to an authorized repair facility that is able to do the update for you, or the work around is to simply set the Blu Ray player to LPCM, or otherwise "not" bitstream. Please PM me with your model # and non-gmail email address to receive the firmware update and instructions to install the update. For more information on firmware installation (in general), refer to post #2013 in the 2310CI thread.
Please note that this update applies to the USA and CA models only.
Old 09-23-2011, 10:42 AM
Kanaris's Avatar
My 989 has a RS 232 jack...
Kanaris is offline
Old 09-23-2011, 11:00 AM
jdsmoothie's Avatar
Liked: 5531
Oops .. my mistake .. good catch ... haven't worked with this model in quite some time. The update will apply to both the 2809 and 989.
Old 09-26-2011, 12:17 PM
trailergod's Avatar
Denon has resolved the Star Wars: The Complete Saga BD audio dropout issue with a firmware update. Although the firmware update will be made available at authorized repair facilities for all models as an "in warranty" repair, regardless of whether actually beyond the 2 year warranty period, DenonJeff will be providing the update to me in the next day or so for those 2809/989 owners that feel comfortable doing their own installation which will require a PC laptop and USB to RS-232 cable. Note that this update is being provided as a courtesy and as such is not supported by Denon should you have any problems with the installation (ie. you cannot call Denon for assistance). If you don't feel comfortable with doing the installation on your own, simply submit it to an authorized repair facility that is able to do the update for you, or the work around is to simply set the Blu Ray player to LPCM, or otherwise "not" bitstream. Please PM me with your model # and email address to receive the firmware update and instructions to install the update. For more information on firmware installation (in general), refer to post #2013 in the 2310CI thread.
Just checked the EU site of Denon, and the latest update is from 30.04.2010.. with this change log...
changelog of AVR2809
30.04.2010
Main: 00.65
Crackling noise on surround back speakers during playback of DTS-HD-MSTR 6.1 disc (BD "The Descent")
18.11.2008
V0071
When A/V amplifier is connected with ""ASD-11R"", ""iPhone 3G"" cannot output Video signal by "Remote mode".
The sound of Center is not emitted when assuming, ""Center None"" with Speaker Configuration when ""DTS-HD 192kHz 3/0/.1"" signal is input."
The noise like the metronome occurs from a central channel when ""DTS
EXPRESS Band Limitted 3/2/.1"" stream signal is reproduced.
does this mean there is no Star Wars fix for the EU Denon receivers yet... ?
trailergod is offline
Old 09-26-2011, 12:30 PM
jdsmoothie's Avatar
Liked: 5531
Apparently not ... give them a little time though. At least now you know where to go when there is one and luckily there is a very easy work around (ie. setting the BDP to PCM).
Old 09-27-2011, 01:03 AM
private Angus's Avatar
Has anybody tried the european FW from 2010, does this help with the SW issue or not?
And if not, can i put the us firmware on a european machine?
private Angus is offline
Old 09-27-2011, 03:42 AM
trailergod's Avatar
found this info from the other thread...
I will update my Denon 2809 with the April 2010 firmware and will give a feedback...
Denon has resolved the Star Wars: The Complete Saga BD audio dropout issue with a firmware update. Although the firmware update will be made available at authorized repair facilities for all models as an "in warranty" repair, regardless of whether actually beyond the 2 year warranty period, . Please PM me with your model number and email address to receive the firmware update and instructions to install the update. For more information on firmware installation, refer to post #2013 .
An owner of a European 2310 has noted that with the 3rd update (from 2/10) there is no audio dropout issue. Can a US 2310 owner with that update comment whether they are experiencing the issue? Thanks.
Old 09-27-2011, 04:21 AM
Cool... please keep us posted !!!
