"Official" Denon AVR 2809CI/989 Thread - Page 179 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 12-19-2011, 06:37 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Originally Posted by Kanaris View Post
Gotta a link?
Nope. It was on the shelf there, priced at $25. They had both managed and unmanaged strips from the same brand.
ap1 is offline
Old 12-19-2011, 09:43 AM
Kanaris's Avatar
Gotta a link?
Do you know what a smart strip is?
Kanaris is offline
Old 12-20-2011, 01:31 AM
collin's Avatar
smart strips must connect their switched power outlets through a relay, which must have a maximum current draw through the relatively small conductor that makes/breaks the connection.
has anybody found any current draw spec on these smart strips to see if it would be overloaded by, or limit current to, heavy current draw devices like subwoofer amps?
collin is offline
Old 12-20-2011, 06:41 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Proper relay should not have a problem switching 15 amp circuit, considering that load is not inductive in nature. My strip works for an amp, which causes lights blink at power on. If I will need to replace it once a year, it won't be a big deal for $25 I spend on it.
ap1 is offline
Old 12-20-2011, 06:53 AM
Kanaris's Avatar
I have been looking for that elusive $25.00 smart strip....
Kanaris is offline
Old 12-22-2011, 02:01 PM
Big Picture's Avatar
Can anyone tell me what kind of audio format that I should be getting from a DirecTv HD DVR over HDMI on a music channel and what should the 989 display read regarding Audio when receiving that format? Is there an audio format in the DirecTv HD DVR menu that I should make sure is activated?
Thank you.
Big Picture is offline
Old 12-22-2011, 02:42 PM
batpig's Avatar
Quoted: 3653 Post(s)
Liked: 3491
any music channel will be a 2.0 (2ch) signal, probably PCM 2.0 or possibly DD 2.0 depending on the box. I can't imagine any settings on the box will change that, generally the audio output settings will only impact whether you get 5.1 Dolby Digital on HD channels.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 12-22-2011, 04:10 PM
jdsmoothie's Avatar
Quoted: 13220 Post(s)
Liked: 6109
Thank you.
The DVR will have only two audio formats ... DD 5.1 and PCM 2.0. Once you set DD to YES/ON for the HD channel audio, the SD and music channels will automatically be set to PCM 2.0.
jdsmoothie is offline
Old 12-22-2011, 05:02 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Actually you are wrong here. It can send DD2.0, I regularly see that mode on my receiver, but music channels are likely PCM anyway.
ap1 is offline
Old 12-23-2011, 09:29 AM
I'm trying to get my 989 set up properly for Blu-ray playback. For example when playing back Jurrasic Park which has DTS HD Master Audio sound my 989 indicates its getting a "MULTI CHANNEL DIRECT" signal, is this correct?
My DVD player is a PS3 Slim and is set to PCM rather than Bitstream for audio output, correct?
I am not getting any sub woofer action and I have the 989 outputting thru the 989 SW RCA jack to my SW, how do I cure this?
My 989 display cuts off after a few seconds which is also not helping at this point, is there a setting for this?
When I press the Menu button on front of the 989 I do not get a menu on my display, what is the fix for this?
Everything is wired using HDMI connections.
My speaker set is a Def Tech SSA50 5 channnel sound bar and matching Def Tech Prosub 800 Sub woofer, no rear or side speakers and it is not practical to add any. Display is a 70" Sharp LED/LCD.
I do not have the Audessy microphone to calibrate this unit. Considering my speaker setup what should I do with the Audyssey settings for now? Would I benefit from an Audyssey calibration with the speakers I have, if so I'll get the microphone?
I do not have a 989 owners manual.
Can anyone assist with any of these issues/questions?
Thank you.
Old 12-23-2011, 09:55 AM
jdsmoothie's Avatar
Liked: 6109
You can get a copy of the Owner's manual from Denon's download website.
http://usa.denon.com/us/Downloads/Pa...ionManual.aspx
The reason for the 2Ch mode is that is what is set on your PS3 (likely because it was previously connected to a TV set directly) so reset the PS3 and make sure all audio boxes are checked including DD/DTS 5.1. If you have a fat PS3, then the PCM mode is the correct setting, otherwise if you have a slim PS3 you can set it to bitstream instead. Also, Pure Direct mode is not the best mode to use as it disables bass management and also cuts out the front panel display on the AVR. Run AUTO SETUP to enable Audyssey which should provide a much better experience for you. Press the STD button on the back of the remote to select DD/DTS or DD PLII modes.
Old 12-23-2011, 10:15 AM
Hi JD. Thanks for the nice response! I was editing my post as you were responding. I would greatly appreciate it if you could have another quick look to make sure we're still on the same page.
Thanks again.
Old 12-23-2011, 12:06 PM
jdsmoothie's Avatar
Liked: 6109
Although the audio quality will be the same whether the PS3 is set to LPCM (as it's currently set) or if set to "bitstream", if you want to see the actual decoded audio track on the front panel of the 989 (most do), then set the PS3 slim to "bitstream" via the Video Setting - BD/DVD Audio Output menu as well as ensuring all 5.1 audio codecs are checked off under the Sound Setting menu. You cannot set any Audyssey settings (Audyssey, Dyn EQ, Dyn Vol) until you run AUTO SETUP, so yes, you will want to get an Audyssey mic (avail from Denon authorized parts distributors or from ebay sellers (DM-A409 only and US sellers only)). Although if you still have the mic for your 5507 and it is a ACM1h vice ACM1, you can use that as well rather than having to buy another mic as the DM-A409 is equivalent to the ACM1h. Also, as noted in the XTR-SSA5 Owner's manual, on the 989, set all the speakers to SMALL with a 100Hz crossover if your sound bar is wall-mounted or 120Hz if it is shelf-mounted. This will then pass the lower frequencies to the sub.
Paladin97 likes this.
Old 12-23-2011, 12:47 PM
Thank you VERY much!
Can you tell me how to get the 989 menu to display on my TV, the only connection I have between the 989 and TV is the 989 HDMI Monitor output?
Old 12-23-2011, 12:50 PM
jdsmoothie's Avatar
Liked: 6109
Try resetting the microprocessor (p. 60) and see if that resolves the issue.
Old 12-23-2011, 02:08 PM
Can anyone tell me the secret to navigating the 989 Menu? I can't even get it to come on with my remote but can get it on with the front panel buttons and the remote is not very effective, up/down ok, side to side buttons not working, screen forward and back not working, certainly not intuitive, aaarrgghhh...
Thank you.
Old 12-23-2011, 02:09 PM
Got it on but navigating the menu is giving me fits, please see above post.
Also located my 5507 Audyssey mic and will give that a go once I figure out how to navigate the Menu, makes me feel like a dufas...
Old 12-23-2011, 02:21 PM
jdsmoothie's Avatar
Liked: 6109
To reset the microprocessor ...
1. Turn off the power using .
2. Press while simultaneously pressing
and (under the front panel flap)
3. Once the display starts flashing at intervals of about 1
second, release the two buttons.
Old 12-26-2011, 09:53 AM
I have my 989 producing fairly good 2 channel DD PL II Cinema audio from my DirecTv HD DVR on music channel 837 now but the center channel on voices does not seem to be as clear as it should be. Can anyone suggest what 989 settings I might look at to be sure I'm getting the best quality center channel sound?
Thank you.
Old 12-26-2011, 09:57 AM
jdsmoothie's Avatar
Liked: 6109
Have you tried using DD PLII - Music (p. 40)?
Old 12-26-2011, 11:44 AM
Thanks for the tip, made a nice difference.
Old 12-28-2011, 11:18 AM
mndoc's Avatar
Hi. I just acquired the ASD-11R. Wired to the VCR(ipod) input (default setting). Verified that ipod dock was assigned to that input. If I manually start music from ipod, it plays fine. However I cannot establish any ipod control with the remote control. I've tried an ipod nano 2nd gen (8GB), an ipod video (30GB), and an ipod (20GB) - they all behave the same. At no point can I get a "DENON" logo to appear on the ipod which would seem to indicate dock control is established (per the 2809ci manual). Also, when I've tried to switch the remote between browse / remote modes, I can't get anything to happen. Is there anything else I can try that I'm missing. It's looking like I might need to return the ASD-11R (if I can't get the remote control to work - not worth it to me...) Thanks
mndoc is offline
Old 12-28-2011, 11:23 AM
jdsmoothie's Avatar
Liked: 6109
Do you have the Dock Control cable connected from the dock to the 2809 Dock Control jack as well? Otherwise it is no different then simply connecting the i device without the dock (ie. no remote control capability).
Old 12-28-2011, 12:29 PM
afrogt's Avatar
Quoted: 1168 Post(s)
Liked: 839
Dude, just google smart strip. They're all over the place.
http://www.amazon.com/Smart-Strip-Pr.../dp/B0006PUDQK
http://www.amazon.com/Smart-Energy-S...ref=pd_cp_hi_1
They may cost more in Canada, but hey that's not our problem!
Afro GT
afrogt is online now
Old 01-10-2012, 12:49 AM
twalkman's Avatar
I have a pioneer SE-DIR800C 5.1 wireless headset that I'm trying to connect to my denon 2809. The stereo headphone jack on the front panel works but I'm trying to figure out how to use the DVR optical output connector so I can get Dolby II surround.
1) Is it true that the optical output will only output the Denon received from other optical inputs (not HDMI signals)?
2) How would I get the regular speakers to turn off while keeping sound to the optical out?
I also have an optical output connector on my TV, would it be better to use that instead? And are there any special configuration issues for the Denon (I currently don't send sound to the TV since I only use my speakers)?
twalkman is offline
Old 01-10-2012, 03:06 AM
jdsmoothie's Avatar
Liked: 6109
1. Yes, but more specifically only from OPT(2) DVR input.
2. Mute may work, but you're likely better served simply connecting the headphones directly to the source or if you want to listen to multiple sources then use a 3 way optical switch.
Old 01-10-2012, 10:29 AM
tn001d's Avatar
Quoted: 43 Post(s)
My receiver surround channels stopped working and the sound from the front 3 just sounds different. I verified the with the test tones the surround Right and left dont work. I had this in a 5.1 configuration.
For the past few weeks i noticed with DTS Master audio blu-rays the sound would change with loud passages, i can describe as someone added the "stadium" sound field. I would pause the movie and restart and it would go away.
Now i noticed the surround channels arent working. I suspect they werent working before, but i just hadnt noticed.
I am outside of warranty, and thinking i will have to send to Denon New Jersery for repair.
Anyone else have this problem ?
tn001d is offline
Old 01-10-2012, 10:51 AM
jdsmoothie's Avatar
Liked: 6109
Try resetting the microprocessor (p. 60) and see if that resolves the issue. Are you getting the surround icons on the right side of the display when playing DD/DTS 5.1 audio?
Old 01-10-2012, 06:40 PM
twalkman's Avatar
That probably is an easier solution even if it does feed the rat nest. I remember your help when I first setup this receiver a couple(??) of years ago -- thanks for still helping people.
twalkman is offline
Old 01-10-2012, 07:00 PM
jdsmoothie's Avatar
Liked: 6109
Yeh ... got help myself from here and just decided to keep paying it forward.
