"Official" Denon AVR 2809CI/989 Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #31 of 5816 Old 08-19-2008, 12:37 PM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
Originally Posted by 16x9enhanced View Post
john--thanks for the info.
btw: I thought part of the idea behind going for higher wattage was to allow your speakers to be pushed more efficiently, and allow them to produce the sound they are capable of. Is this correct?
I understand that the actual volume may be no different.
Yes, the quality of the amplifier is more important than just the wattage output. Also better amplifiers can deliver their full power continuously, not limited to a specific length of time. Higher wattage amp's usually offer the necessary dynamic headroom to output power at a significantly higher level for short periods to accommodate musical peaks or extreme sound effects in films.
BTW here's a nice article Decoding Amp Power Specs that covers output power spec's.
Thus the 2809 is a bit better sounding then the 2309, just as the 2309 sound a bit better then the 1909, and you can hear this at identical volume levels with the same music if you compare them.
Oppo Beta Group
JohnAV is offline
post #32 of 5816 Old 08-19-2008, 02:30 PM
QZ1
QZ1's Avatar
Originally Posted by JohnAV View Post
The sound quality I would say is on par with the 3808.
The receivers sound better as you go up in price, because of better power supply's and amp's used in more expensive receivers. On the older Denon line I listened to you could hear a less dynamic sound environment as you went downward from the 2808 to the 2308 to the 1908. There's not much difference between the 2808 and the 3808. Now the 2809 has been bumped up to 115 watts from 110 watts that the 2808 provided.
I have read of several people over the years here at AVS that have heard a dynamics difference between 28XX and 38XX series AVRs. The wattage specs. going from 110W to 115W on 28XX or even the 130W on 3808 is negligible. The key is the 3808 is 11 lbs. heavier, so the amp. is able to provide better dynamics at high volume, which becomes increasingly more apparent the higher the volume. Of course, it depends on the quality of one's speakers and the volume range used, as to whether one can hear an appreciable difference.
QZ1 is offline
post #33 of 5816 Old 08-19-2008, 04:40 PM
penngray's Avatar
Liked: 47
Im confused, How does weight dictate performance?
I have a 100lb Emotiva amp and a 50lb sunfire amp.....which amp do you think has more power and which one would be a better amp.
110 to 130Watts means nothing in terms of audible differences.
penngray is offline
post #34 of 5816 Old 08-19-2008, 04:41 PM
penngray's Avatar
Liked: 47
Does J&R sell the 989 version?
Wouldnt it be a little less then the 2809 version?
penngray is offline
post #35 of 5816 Old 08-19-2008, 06:01 PM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
They do, but be prepared to wait. Eventually they will sell for less.
The three digit Denon models usually ship to major distributors or chain stores (BB & CC for example) after the four digit models have already shipped to regular authorized Denon dealers.
The 2809CI uses the better remote, and offers additional CI features, but both list at same $1199 price? The 989 looks better appearance wise then the previous 988 model IMHO.
Oppo Beta Group
JohnAV is offline
post #36 of 5816 Old 08-19-2008, 06:06 PM
16x9enhanced's Avatar
JohnAV--again thanks for the info, and the link.
I have a question about the upconversion/scaling.
I have the Oppo 983. So when I have that connected into this receiver, is there some setting that I turn on or off to make it so that the signal sent by the Oppo is not given any processing, and are there ways to add processing to the signal if I want to. This is one aspect of these receivers that offer upconversion, etc. etc. that I have never understood very well. Any help in understanding this would be greatly appreciated.
I really want to understand the various options one has regarding the various signals that you send via hdmi including my hd cablebox. I have 4 components to connect--cable box, HD DVD player, Panasonic bd-30 bd player, and the Oppo 983 all via hdmi.
16x9enhanced is offline
post #37 of 5816 Old 08-19-2008, 07:25 PM
jlaavenger's Avatar
Quoted: 25 Post(s)
I'd like to know that answer as well. I'll have the Oppo 983H, a PS3 and a Dish 722VIP DVR all going to an AVR and then a Kuro. The only thing I might want the AVR to up-scale or up-convert might be the DVR or a VCR if I connect it. It's also possible the Kuro might up-scale better than the AVR.
jlaavenger is offline
post #38 of 5816 Old 08-19-2008, 08:17 PM
penngray's Avatar
Liked: 47
As long as the 989 has serial I do not care about the remote. I have to set it all up with my home automation system.
penngray is offline
post #39 of 5816 Old 08-19-2008, 09:28 PM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
See pages 9, 36 and 37 of manual. It is not possible to select HDMI input signals for conversion. Separately you can turn off conversion or/and i/p scaler for analog video input sources. (Component Video, S-Video, Video)
I also use a Oppo 983H and saw no additional artifacts or video noise when going HDMI -> HDMI through receiver at 1080P.
You can constrain the conversion and i/p scaling to just those inputs. See the manual pages 36 and 37. The Kuro might do a better job, worth comparing the two.
Oppo Beta Group
JohnAV is offline
post #40 of 5816 Old 08-19-2008, 10:04 PM
T2k
T2k's Avatar
That's 110%!
T2k is offline
post #41 of 5816 Old 08-20-2008, 04:15 AM
JohnAV--thanks again for the info.
sounds good.
so I'm assuming these new Denon receivers don't have any of the issues that have plagued some of the earlier 1.3 receivers--i.e. "bitstream bomb", not passing BTB or WTW, etc. etc.
I have been amazed how many issues have popped up, and like I said previously, have been trying to do all I can to buy an issue-free receiver.
Also, was wondering if one can connect another amp to boost the power and how that works. I have an ancient Yamaha integrated amp, and wasn't sure if that was possible. I'm still not 100% educated on the "pre/pro" terminology, although I'm thinking you can add a pre/pro to this receiver that could provide a power boost. Could certainly be mistaken, so that's why I'm asking. sorry for the ignorance. still trying to get up to speed regarding audio knowledge.
thanks in advance!
post #42 of 5816 Old 08-20-2008, 08:32 AM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
sounds good.
thanks in advance!
The AVR-2809 can serve as a pre-amp so the output can drive one or more external power amplifiers connected to its 7.1 outputs, see page 17 of manual.
So far no one has reported that a 1909 or 2309 fails BTB or WTW, I assume the 2809 will pass also. This has been a issue with latest Yamaha and HK receivers.
The "bitstream bomb" was a DTS-HD Master Audio problem with some recent Onkyo, Integra, and Yamaha models. I believe Onkyo and Yamaha provided firmware updates for this issue. Marantz and Denon AVR's use a different IC chip for bitstream processing and do not have the problem.
Oppo Beta Group
JohnAV is offline
post #43 of 5816 Old 08-20-2008, 08:41 AM
cstmstyle's Avatar
Quoted: 14 Post(s)
Just placed my order with crutchfield for the 2809 this morning hopefully I will have it on friday or monday at the latest. Just a quick question my TV doesn't have an HDMI input just DVI. I will be hooking up a Panasonic DMP-BD50K, a Time Warner 8300HD DVR and an Xbox 360 to the 2809 so I would be using just the one cable to the TV. Will using an HDMI to DVI cable from the 2809 to the TV affect anything? What will become limited if anything?
Xbox Live- DragonsLee
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine." - Bruce Lee
cstmstyle is offline
post #44 of 5816 Old 08-20-2008, 08:59 AM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
Originally Posted by LowellG View Post
Thanks, but what about when going to commercials or explosion sceens in movies. I am constantly grabbing the remote before I hear TURN IT DOWN. :-)
Regarding three different levels of Dynamic Volume and EQ: The Day mode sounded almost identical to Dynamic Volume OFF with Dynamic EQ ON. But explosions were slightly reduced. Evening mode the explosions were less noisy. Night mode the explosions were barely louder then a actors voice, but yet still retained the correct tonal balance of sounds.
The DYN VOL button on the receiver will cycle through Dynamic EQ/Vol ON = green light, Dynamic EQ = red light, Dynamic EQ/Vol OFF = no light
Oppo Beta Group
JohnAV is offline
post #45 of 5816 Old 08-20-2008, 09:24 AM
penngray's Avatar
Liked: 47
Good deal?
penngray is offline
post #46 of 5816 Old 08-20-2008, 09:27 AM
cstmstyle's Avatar
Quoted: 14 Post(s)
Good deal?
Just free shipping and the usual 6 months no payments no interest when you use or sign up for the Sony Card. Still the same price as I've seen most other places.
post #47 of 5816 Old 08-20-2008, 09:35 AM
batpig's Avatar
Quoted: 3721 Post(s)
Liked: 3592
There are occasionally issues that pop up with DVI-HDMI connections, but chances are you'll be OK.
You're going to need to get your HDMI setup squared away, set output to "RGB" instead of "YCbCr" and you may have to twiddle with the RGB range (ENHANCED vs. NORMAL) on both the Denon and your devices to get everything squared away. Occasionally TVs/AVRs/sources don't play nice and you might have an issue where the TV is expecting video levels and the sources is outputting computer levels or whatever.
You just want to make sure everything is your video chain is consistent, since you'll only be running one cable to the TV.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #48 of 5816 Old 08-20-2008, 09:56 AM
cstmstyle's Avatar
Quoted: 14 Post(s)
Thanks for the reply. I plan to upgrade the TV to a Samsung series 9 LCD or whatever comes out after that sometime next year just want to make sure I could still enjoy most everything I have now.
post #49 of 5816 Old 08-20-2008, 10:28 AM
javajaws's Avatar
2809 is showing up as in-stock at J&R. Anybody get a shipping notice yet?
javajaws is offline
post #50 of 5816 Old 08-20-2008, 11:01 AM
cstmstyle's Avatar
Quoted: 14 Post(s)
I got a shipping confirmation from my crutchfield order an hour ago. UPS site hasn't updated with the ETA yet but anyways J&R should be shipping them out today also if they have them on the shelf.
post #51 of 5816 Old 08-20-2008, 11:31 AM
nilsp's Avatar
Finally I got word from my local hifi asylum that the 09 series is just around the corner. I still can't decide between the 2309 and 2809... But since the price difference is just over $200, I'm leaning towards the 2809. (Price here in Norway is $1450. Ouch!)
Looking forward to replacing my ole' Yamaha 775. :-) About time, me thinks! HDMI switching in my basement is waaay overdue!
NilsP
Life is better in HD.
nilsp is offline
post #52 of 5816 Old 08-20-2008, 11:39 AM
QZ1
QZ1's Avatar
I should have said, I read that at AVS, as well. IIRC, it meant weight difference in AVRs within the same brand, meant the PSU was heavier. I am going by what I can recall, from several years ago.
Which is what I said above.
Anyway, key was about dynamics. The 'Denon 2809CI vs 3808CI differences?' thread is really the place to discuss this. There, more knowledgeable people have elucidated why the 3808 should sound better, others may not have the speakers or use the volume level to notice or care, and others may disagree.
QZ1 is offline
post #53 of 5816 Old 08-20-2008, 11:43 AM
penngray's Avatar
Liked: 47
QZ1, I understand now...
Anyways, I became trigger happy this afternoon and ordered the 2809 from J&R. It should arrive by next Tuesday!
penngray is offline
post #54 of 5816 Old 08-20-2008, 01:53 PM
jlaavenger's Avatar
Quoted: 25 Post(s)
Originally Posted by T2k View Post
That's 110%!
Am I reading you right that the kuro up-scales better than the 2809? If so I'd simply turn off up-scaling through the AVR right? I plan on connecting everything via HDMI except of course the VCR.
post #55 of 5816 Old 08-20-2008, 02:19 PM
T2k
T2k's Avatar
Correct, I'm pretty confident Kuro's scaler is better than any of these low-end Faroudja-based AVRs but you be the judge - and please, let me know if I was right...
T2k is offline
post #56 of 5816 Old 08-20-2008, 02:21 PM
T2k
T2k's Avatar
Well said.
T2k is offline
post #57 of 5816 Old 08-20-2008, 10:40 PM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
JR has them now, so check your tracking #. Perhaps you'll get lucky and receive the AVR-2809 earlier.
Oppo Beta Group
JohnAV is offline
post #58 of 5816 Old 08-20-2008, 10:49 PM - Thread Starter
JohnAV's Avatar
Quoted: 393 Post(s)
Liked: 543
Gee no discounts.
Good luck with your decision......listen to a 2308 versus a 2808 at a store to get a idea how the 2809 will sound.
Oppo Beta Group
JohnAV is offline
post #59 of 5816 Old 08-21-2008, 06:18 AM
Bayboy911's Avatar
How is the upconversion? Any one heard the difference between the 3808 and the 2809? Looks like you can pick up the 3808 for less at dakmart.
Bayboy911 is offline
post #60 of 5816 Old 08-21-2008, 06:29 AM
penngray's Avatar
Liked: 47
Yep, but it will not be shipped till today and its 3-4 days to Florida. I wouldnt get to it this weekend anyways. I have a list of 50 different things to do still in my new HT room including another Sealed sub build!
penngray is offline
