Official Pioneer SC-05 and SC-07 Owners Thread - Page 572 - AVS Forum | Home Theater Discussions And Reviews
post #17131 of 17154 Old 01-11-2016, 08:49 PM
gene c353's Avatar
Quoted: 133 Post(s)
Liked: 97
I have an SC-25 and a vsx-23 and except for the occasional handshake issue they both work fine. Have you tried using the second HDMI output?
gene c353 is offline
post #17132 of 17154 Old 02-07-2016, 03:19 PM
fastliferider's Avatar
After re calibrating my HT on the SC-05. It's showing all speakers set to large with my sub 'grayed out'. How do I manually adjust them to small so my sub will get the LFE <80Hz?
fastliferider is offline
post #17133 of 17154 Old 02-16-2016, 03:38 PM
jarablue's Avatar
Is the SC05 still a viable receiver for a 5.1 setup? Or is the new stuff just too good? I'd hate to throw away 800 bucks if I do not have too. Upgrade or keep?
Sent from my SM-N920P using Tapatalk
jarablue is offline
post #17134 of 17154 Old 02-17-2016, 06:44 AM
jasonheyd's Avatar
Biggest issue I have with my SC-05 is that HDMI doesn't work when connecting to my media center PC. Otherwise, no complaints and no issues, although the supported HDMI is a bit dated. With 4K and soon 8K video coming out, it's not going to keep up much longer.
ETA: The PC issue is that the receiver doesn't pick up the HDMI signal from the PC if there's any sort of switching happening, so I just get "No signal". The only other issue with the the SC-05 is the cost of adding sufficiently high quality surrounds. ;-)
jasonheyd is offline
post #17135 of 17154 Old 02-17-2016, 06:50 AM
jasonheyd's Avatar
Should be able to go into the audio menu system and just turn the sub on.
post #17136 of 17154 Old 02-29-2016, 10:14 PM
MindlessCorpse's Avatar
on your remote in the center section of buttons, press Home Menu, go to option 4, system setup, go to option a, Manual SP Setup, select option 2, speaker setting and set your surrounds to small. This will give you Sub output from the rear of the sc05. If you want to get more hz range to your surrounds, and still run sub's, set the surrounds to large and run a jumper wire from the speakers in to the line level inputs on your sub's. The latter is how I had to run mine..... I placed the surrounds as rear speakers, then ran patch cables from speakers to subs (which sit under the surrounds/Polk monitor 75 series ll to two powered sub's)
Panasonic SMART VIERA 60" Class GT50 Series Full HD 3D Plasma HDTV/TC-P60GT50
Panasonic 3D Blu Ray DVD player
Pioneer Elite SC-05 AVR
2 x Polk Audio TSX550T front channels/2 x Polk Audio Monitor70 Series II rear channels
1 x Polk Audio CS2 center /2 x Polk Audio PSW505 Subwoofer
XBOX 360 (MindlessCorpse)
MindlessCorpse is offline
post #17137 of 17154 Old 03-01-2016, 10:31 PM
ON IN II's Avatar
If I remember correctly I just changed my subwoofer setting to "Plus" and then everything also goes to the sub plus whatever speakers are set to large. Now if you run direct mode all the EQbsettings are removed but the sub will still kick in but under pure direct it will just be your speakers and again no EQ or tone controls.
I liked the plus setting personally as I think it sounds best but I run an Epik Conquest 18" and their Empire dual 15" sub.
I like BASS:stuck_out_tongue_winking_eye::smiling_imp:
I hope this helps. I may be wrong as I don't have my 05 any more but If I am these guys will get you right!!
I miss my 05!!??
ON IN II is offline
post #17138 of 17154 Old 04-01-2016, 07:37 AM
mjfoster77's Avatar
I've had my SC07 since about 2009. I love it but I wonder if I'm missing out on anything? I'm debating about going from 5.1 to 7.1. What will the SC07 do with 7.1 audio....will I need to take advantage of newer receiver that's atmos capable?
xbox live:sixsec assassin
mjfoster77 is offline
post #17139 of 17154 Old 04-01-2016, 08:28 AM
a_ok2me's Avatar
Quoted: 33 Post(s)
I have an SC-99 and don't notice any power difference. The only thing I notice is the sound fields are calibrated different. The center channel sounds better and less hollow. It was unbearable for me to use the center with the SC-07.
I don't use any other features that are different.
a_ok2me is offline
post #17140 of 17154 Old 04-07-2016, 05:52 AM
rcupka's Avatar
Quoted: 14 Post(s)
I have a question about audio output for BluRay discs.
My Sc-07 outputs audio as PCM on the new Star Wars and Concussion movies. I assume this is because the AVR does not support the new DTS Master? When I play an older DVD like Gladiator it outputs DSD.
Am I correct in my assumption that newer audio codecs like DTSMaster, DD True etc. will only output to PCM if the AVR does not support the codec? I was hoping they would convert to older DTS or DD formats.
I have the audio input set to automatic in settings.
rcupka is offline
post #17141 of 17154 Old 04-07-2016, 07:11 AM
a_ok2me's Avatar
Quoted: 33 Post(s)
I've seen DTSMaster and DD. I'm not sure why it's not working for you. Try switching the audio parameter to Pure Direct.
a_ok2me is offline
post #17142 of 17154 Old 04-07-2016, 08:02 AM
b curry's Avatar
Quoted: 292 Post(s)
Liked: 151
If you're seeing PCM at the SC-07 you're decoding using the Blu-ray player.
You need to set your Blu-ray player to Bitstream. The SC-07 will then decode and you will see DTS-HD Master etc. light up in the SC-07's display window.
You might want to take the time to do a RTFM RESET.
Page 40 references the advanced codecs. The SC-05/07 will do a great job playing back all of the advanced codecs.
https://www.pioneerelectronics.com/S...ctions0523.pdf
b curry is offline
post #17143 of 17154 Old 04-07-2016, 10:05 AM
rcupka's Avatar
Quoted: 14 Post(s)
Thanks for the input but still no DTS Master.
I have the Pioneer BDP-05 set to "auto" audio output via HDMI (only choice is auto or PCM).I also did a complete reset on SC-07.
The system does show DTS on Gladiator DVD but on Star Wars and other BluRay it's PCM in AVR window. Interesting to note that when I select French language in Star Wars. It does output DD 5.1 as it should.
Not sure where to go from here.
rcupka is offline
post #17144 of 17154 Old 04-07-2016, 02:03 PM
b curry's Avatar
Quoted: 292 Post(s)
Liked: 151
Are you talking about DVD or Blu-ray? It's not clear from your questions.
You do realize that you only have DTS-HD, DTS-HD Master, and Dolby TrueHD on Blu-ray disc. DVD's do not support the high resolution codec's. It sounds like your expecting the high resolution codec's on DVD.
AUTO audio output should give you bitstream output from the BDP-05FD. Is your firmware up to date for the BDP-05FD?
b curry is offline
post #17145 of 17154 Old 04-07-2016, 04:49 PM
rcupka's Avatar
Quoted: 14 Post(s)
I didn't realize the DTS Master was hi-res only on Bluray. My problem has been with BD only.
I referenced the DVD only to point out DTS worked fine.
My firmware on the BDP-05 is 1.73 and looking at Pioneer site there is more current F/W ......1.74.
I'll download and install tomorrow and hopefully it solves my problem.
Thanks for your help.
rcupka is offline
post #17146 of 17154 Old 04-23-2016, 08:13 AM
rcupka's Avatar
Quoted: 14 Post(s)
No sound from Optical Input
I have a Sony 4k TV and I'm trying to use Optical output from TV to Optical input on my SC-07 for sound on the various apps that came with the Sony. My SC-07 displays 24/192 when playing Amazon video but no sound. I have the TV set for external speakers.
Any ideas?
rcupka is offline
post #17147 of 17154 Old 06-06-2016, 08:29 AM
DML85's Avatar
Is there any way for me to modify my BD HDMI port to use audio from a digital port? I just bought a smart tv and when I cast to it, it tries to use the TV speakers. I'm just looking for a way to output the tv audio to my surround sound as well.
Trying to hold off on upgrading receivers :P
DML85 is offline
post #17148 of 17154 Old 06-12-2016, 09:04 PM
xtreme777's Avatar
Hi all,
By any chance, does anyone know if Pioneer ever released any updates passed 3.7.32.7682? Anything with more networking support for better HMG?
BR,
xtreme777
xtreme777 is offline
post #17149 of 17154 Old 07-07-2016, 05:52 PM
Liked: 0
Hi Folks!
I have a seemingly silly question but I just can't find the answer and I was hoping one of you guru's could help me out.
I have a SC-05 and I want to use HDMI in for video only and analog for audio (long story why, but that's what I want to do). Is this at all possible?
Thanks in advance!
-Paul
bigfatpauli is offline
post #17150 of 17154 Old 07-07-2016, 07:44 PM
hoopsrgreat's Avatar
Quoted: 45 Post(s)
Liked: 62
youd have to use analog cables output from whatever source you are using into the receiver as well as the hdmi cable. Its possible, then assign the audio in the menu under setup.
hoopsrgreat is offline
post #17151 of 17154 Old 07-07-2016, 07:59 PM
Liked: 0
Thanks - that's how I have it. The analog output from the sound card into the RCA jacks DVR1 input and HDMI input set to HDMI1 (which is where the video is connected) but I get no audio, just video.
Is there something I'm missing?
post #17152 of 17154 Old 07-07-2016, 08:17 PM
Liked: 0
Just to add, I know things are physically set up correctly because when I have the video from the PC work via HDMI if I press the HOME MENU button on the remote it switches the display to the setup menu and I hear the analog audio correctly. When I exit the menu the video returns but the audio goes back to HDMI. On the display of the SC-05 it shows "AUTO" and HDMI is lit up. When I access the menu ANALOG illuminates and HDMI turns off. Basically, I get either the video or audio, but not both at the same time.
post #17153 of 17154 Old 07-07-2016, 08:29 PM
Liked: 0
So after 4 hours of fiddling... I discovered the "Sig Select" button...
Problem solved
post #17154 of 17154 Old 07-08-2016, 09:34 PM
jocabs's Avatar
Liked: 0
hi..
anybody here know where I can buy parts for my sc 05, specifically the audio board assembly AWX9139? came home yesterday and heard a popping sound and burnt smell from the receiver, opened it today and found multiple caps blown from the board. hoping I can still salvage this if not then time for upgrade lol.
jocabs is offline
