"Official" RX-V1900/RX-V3900 Thread - Page 202 - AVS Forum
post #6031 of 6056 Old 06-01-2014, 02:38 AM
tv tweaker's Avatar
Receiver Manager Software RX-V1900.
Would anyone be kind enough to post a copy of the receiver manager software they might have or send me a message with it please?
I have tried the old links and they no longer function and have spent some time googling without success.
I used to have a copy on another laptop however it has failed and the backups have saved documents etc but not applications.
tv tweaker is offline
post #6032 of 6056 Old 06-01-2014, 08:16 AM
kriktsemaj99's Avatar
Quoted: 242 Post(s)
Liked: 184
I just uploaded the 1900 Receiver Manager here: link
It's version 1.02, I don't know if there's a more recent version.
tv tweaker and Avgass like this.
kriktsemaj99 is online now
post #6033 of 6056 Old 06-01-2014, 03:38 PM
tv tweaker's Avatar
Thanks kriktsemaj99 !
downloaded and working, very much appreciated.
post #6034 of 6056 Old 07-06-2014, 07:02 AM
Liked: 0
Hello sorry for this question if it has already been answered.
I have a rx-v3900, about every other day I loose my center channel when in any surround mode. When I go to enhanced stereo the center works fine, but going back to a surround mode for movies I get nothing out of the center.
The only fix is if I run the speaker set up with the ypao mic, and it will be good for a day.
any ideas?
Doug Potter is offline
post #6035 of 6056 Old 07-06-2014, 08:48 AM
sevenz's Avatar
Quoted: 17 Post(s)
Liked: 24
any ideas?
Seems strange. Did u check ur speaker config if anything is wrong?
Suggest to redo calibration. If not, do a factory reset, and recalibrate.
sevenz is offline
post #6036 of 6056 Old 07-06-2014, 05:37 PM
Liked: 0
Thanks for the reply. I did a factory reset and a speaker calibration, this time I was good for about 3 hours, then I lost all the center again. I had to run the calibration again to get it back to normal. No errors while running the calibration. Might be time to start looking for another receiver.
post #6037 of 6056 Old 07-06-2014, 07:14 PM
sevenz's Avatar
Quoted: 17 Post(s)
Liked: 24
do u know of any freelance technicians or shops who can help to take a look at it at a small fee? This is still an awesome amp
sevenz is offline
post #6038 of 6056 Old 07-06-2014, 07:39 PM
Quoted: 242 Post(s)
Liked: 184
Maybe a quicker way to get the center speaker back is to go into manual setup and enable the center. That's not a real fix, but if it works at least it's a lot quicker than running YPAO again.
post #6039 of 6056 Old 07-07-2014, 09:45 AM
Liked: 0
Thanks for the suggestion. I tried that also, its almost like the center is severely muted. I would think it would try to put the center stage through the mains, but the entire system sounds like crap. Is there a battery inside that keeps the settings that anyone knows of?
Thanks again for the reply.
post #6040 of 6056 Old 07-07-2014, 11:47 AM
Quoted: 242 Post(s)
Liked: 184
There's no battery inside.
What if you go to manual setup and say that you don't have a center speaker? Then it will create a phantom centre using the front L/R, and since the real center is not being used maybe the problem won't be noticable. Not ideal, but quite a usable solution if it works.
post #6041 of 6056 Old 07-07-2014, 12:30 PM
JChin's Avatar
Quoted: 125 Post(s)
Liked: 140
any ideas?
Hi Doug Potter, just a thought and you may have done so already to isolate it a receiver problem. Suggest to double check and reconnect the center speaker wires at both ends. Even try speaker swap with front to see if problem still exist with the center channel.
JChin is offline
post #6042 of 6056 Old 07-07-2014, 06:59 PM
Liked: 0
Thanks JChin, I went ahead and rewired all the speakers. So far so good, it has been sounding good for several hours. Crossing fingers I will let you know tomorrow.
*been running good for a few days I think it's good thanks for all the help.
post #6043 of 6056 Old 08-06-2014, 02:22 PM
gajego's Avatar
Hello there,
I have a RX-V3900 for aprox 5 years and worked fine until last night. The unit shut's off itself. I've unplug it several times, however as soon as I turn it on - press the master switch, and then the on/off button it shuts off itself.
I've disconnected all speakers, cables, all connections, pulled the unit from my rack and it still does the same.
Any idea?
gajego is offline
post #6044 of 6056 Old 09-09-2014, 11:50 AM
ira_l's Avatar
I'm having a problem with my RX-V3900. On the front panel, it will display "View GUI Menu" every 30 seconds or so. When you press MENU,
the screen asking you to input your User Name appears. This started happening way back when Sirius Internet Radio had a trial going. I signed
up for the trial online, but when I tried to provide the User Name and Password to the RX-V3900, the text input screen didn't stay on long
enough to input the User Name/Password, and so it fails. Sure, you can press 'Cancel,' but then 30 seconds later "View GUI Menu" appears.
The RX-V3900 is working properly, but this annoying problem remains. I solved this a while back by downgrading the firmware. Today, I
upgraded to V1.21, and the problem is back.
Does anyone know how to fix this? FWIW, I no longer have the trial Sirius Internet Radio account. I'd just like to make it go away and stop asking.
WOULD SOMEONE BE GOOD ENOUGH TO PLEASE POST FIRMWARE v1.20?
*** SOLVED! ***
I found the addendum describing how to configure Sirius Internet Radio, noticed it gave you the ability to delete your account.
I did so, and now the "View GUI Menu" messages are gone! I am continuing to run Firmware v1.21.
ira_l is offline
post #6045 of 6056 Old 09-28-2014, 08:35 PM
loma's Avatar
I am able to change the input in my receiver from V-Aux to Tuner but cannot find the YNC command or YNCA ircode to do so for CBL/SAT input. Can anyone help? Thanks.
loma is offline
post #6046 of 6056 Old 09-28-2014, 09:44 PM
hdtvluvr's Avatar
What does the command look like that you are using to get to the Tuner?
CBL/SAT may be referenced in the code as cbl_sat. Not sure if it will work though.
hdtvluvr is online now
post #6047 of 6056 Old 09-29-2014, 07:05 AM
Quoted: 242 Post(s)
Liked: 184
I answered the question in the other thread where you also posted it.
post #6048 of 6056 Old 09-29-2014, 07:22 AM
loma's Avatar
Thanks for your response.
loma is offline
post #6049 of 6056 Old 09-29-2014, 07:24 AM
loma's Avatar
Thanks will respond here after checking AV1, AV2 etc.
loma is offline
post #6050 of 6056 Old 09-29-2014, 07:59 AM
loma's Avatar
Model is RX-V3900. The inputs are CBL/SAT, DVD, TV etc. I have used the ir code to get V-Aux to work but could not find the codes for the others.
The code that worked for Tuner is: 7A8516E9
loma is offline
post #6051 of 6056 Old 10-25-2014, 04:06 PM
Breathing Borla's Avatar
Quoted: 77 Post(s)
I have a 1900 and a PS3 and have a pn64f8500 On the way
Will I be able to play 3d bluray from the PS3 then out to the plasma? Or is there an hdmi version issue?
Breathing Borla is offline
post #6052 of 6056 Old 11-19-2014, 08:04 AM
519audiofan's Avatar
I picked up an NAD M25 yesterday and hooked it up last night. My issue is as follows:
Prior to adding the NAD, I was bi-amping the surround back channels with no issues. However, after connecting the surround back pre outs to the appropriate inputs on the NAD and connecting the speaker wire, I had no sound from the tweeters (which are connected to the bi-amped surround back channels). All connections were checked and I checked that the receiver still had Bi-amp set to on.
It seems that surround back pre outs do not recognize that the unit is in bi-amp mode. I turned bi-amp off and reconnected the speakers appropriately and everything sounds as it should. Am I missing something?
The manual states "Each PRE OUT jack outputs the same channel signals as the corresponding SPEAKERS terminals". So if Bi-amping works with the internal amplifiers, it should work with an external amp.
I don't want to turn this into a debate on the benefits of bi amping - I am just wondering if the receiver supports Bi-amp mode when using an external amp.
519audiofan is online now
post #6053 of 6056 Old 12-29-2014, 07:46 PM
MUMFORD's Avatar
Question Yamaha RX-V3900BL Tuner No Longer Working :(
I've had my RX-V3900 for about 5 years and the unit has worked flawlessly for the most part. Of all of the features on this unit, I've probably used the Tuner the least (I doubt that I've played the radio on this device more than 4 hours in 5 years!) For some reason, the Tuner function is no longer working --- both AM and FM. I'm simply using the factory wire antenna inputs and haven't made any settings changes (at least that I'm aware of) that would nullify the tuner output.
Should the tuner function on such a unit "go out" within 5 years with so little usage? Any suggestions on how to troubleshoot this issue? Admittedly, I'm a noob from an audiophile perspective, but I do have a technical background. Thanks!
MUMFORD is offline
post #6054 of 6056 Old 01-02-2015, 03:14 PM
DavidMP's Avatar
Quoted: 12 Post(s)
My first thought is to troubleshoot the antenna. Remove/replace or try another. Try FM first. Are you in metro area tuned to a known station? Do you get a signal strength indicator? If you are getting the strength indicators and maybe even the stereo indicator, then it is probably another setting. Maybe stereo mute or something.
DavidMP is offline
post #6055 of 6056 Old 01-02-2015, 07:25 PM
MUMFORD's Avatar
Unhappy
Thanks for the reply. Yes, I do live in a large metropolitan area and have attempted to tune to several strong and well known stations. I removed/replaced both the the FM & AM antennas to no avail. I will need to check the manual, but what appears to be the signal strength indicator does show that I'm receiving a signal. I've noticed when I turn the volume all the way up, I do hear a slight "hiss". However, there doesn't appear to be any type of "mute" activated.
Again, this is strange and rather troubling, given the limited use of the Tuner function during the time that I've had this unit.
MUMFORD is offline
post #6056 of 6056 Old 01-15-2015, 02:50 PM
Tungx2's Avatar
Liked: 0
Hi Folks.
Some say Rx-v3900 support hdmi - cec.
I got a new smart tv, samsung UN55H6203AFXZA
Supposinly, the TV supports HDMI cec (anynet+)
But someone I can't get my rx-v3900 to work with it. It won't shut off or recognize it.
Can anyone comment on this? I've had this receiver for years and I wasn't able to get to to work with my last tv that also has hdmi-cec (anynet+) capabilities.
Tungx2 is offline
