The "Official" Onkyo TX-NR906 Owners Thread... - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 2790 Old 08-30-2008, 10:57 AM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Originally Posted by jeux_1 View Post
Could you tell us how long does it take to switch beetwen sources ? ordered mine but might cancel it :-(
currently I only have one HDMI source.. I will connect another HDMI player this weekend to see how long it takes to switch.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #92 of 2790 Old 08-30-2008, 11:07 AM
ezervoud's Avatar
How is the Reon performing, have you had the chance to check it?
ezervoud is offline
post #93 of 2790 Old 08-30-2008, 11:15 AM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I will try and do some comparisons today when i connect my second HDMI player up...
I am not sure if users are aware of this... I just found out that the TX-NR905 limits the power supply when switched to four ohm loads... according to a sound and vision review, switching the amp to four ohm loads drops power output down to 55 watts per channel... I assume the TX-NR906 would have the same behavior.
Jon S is offline
post #94 of 2790 Old 08-30-2008, 12:12 PM
avfan428's Avatar
Originally Posted by Jon S View Post
'fraid not... all the options are displayed... there is no CMS capability, only grayscale (RGB brightness and contrast level adjustments) and gamma. This will not correct the color points like CMS would.
That's a shame, but perhaps it was unrealistic even to think it. It seems that that line in the manual would be better translated as 'the setting from Resolution to B Contrast becomes alterable' rather than '...is changed'.
Thanks for the answer though.
avfan428 is offline
post #95 of 2790 Old 08-30-2008, 02:56 PM
jeux_1's Avatar
Thx Jon S.
jeux_1 is offline
post #96 of 2790 Old 08-30-2008, 03:02 PM
ezervoud's Avatar
Thanks for your efforts Jon
ezervoud is offline
post #97 of 2790 Old 08-30-2008, 04:03 PM
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
Secrets Of HT-High FI, said for 4ohm speakers, you should keep your receiver (ASSUMING IT CAN COMPETENTLY DRIVE 4ohm) set up for 8ohm loads.
The 905/8.8/906 is THX Certified to drive speakers with dips to 3.2ohm without having a problem.
Secrets and S/V test 4ohm output with the unit in it's 8ohm setting.
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is online now
post #98 of 2790 Old 08-30-2008, 08:53 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I hooked up another Sony DVD HDMI player to the Onkyo... the bad news is... it takes several seconds to switch from the player to the PS3 and vice versa...
Regarding the Reon processor, I could not see any differences when switching it in or out from the feed.
Jon S is offline
post #99 of 2790 Old 08-30-2008, 09:15 PM
myz350's Avatar
Quoted: 13 Post(s)
why buy the NR906 over the SR876?
myz350 is offline
post #100 of 2790 Old 08-30-2008, 09:22 PM
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
Because it's heavier.
post #101 of 2790 Old 08-31-2008, 12:04 AM
myz350's Avatar
Quoted: 13 Post(s)
I can put my PS3 on top of the 876 to make it weigh more, would that make it better than the 906?!!
myz350 is offline
post #102 of 2790 Old 08-31-2008, 08:13 AM
12thgear's Avatar
Mainly for its ethernet streaming features and playback from USB devices.
Upstairs: Epson 8500UB | Onkyo TX-SR805 | DVDO Edge | DefTech PowerMonitor 700 | ProCenter 2000 | BP2X | AV123 MFW-15 | Onkyo DV-HD805 | Sony PS3 | Pro-Ject 1Xpression III
Downstairs: Panasonic TC-P60VT60 | Onkyo TX-NR818 | Pioneer SP-FS52 | SP-C22 | SP-B22 | MartinLogan Dynamo | Sony BDP-S5100 | Xbox 360 S
12thgear is offline
post #103 of 2790 Old 08-31-2008, 08:57 AM
ezervoud's Avatar
Check out this post ! A guy at the 906 anticipation thread has created a chart with both receivers. You will find there similarities and differencies
ezervoud is offline
post #104 of 2790 Old 08-31-2008, 09:56 AM
akopperl's Avatar
Quoted: 34 Post(s)
Does the 906 have any issues locking onto the sound format? For example, if you go to watch a program recorded on a DVR - do you miss the first 3-5 seconds? Also, if you skip back on a program are there any issues locking? I saw a thread that stated there were no issues with lip sync - but I didn't see a response for delay.
Also, does the unit make any pops/cracking sounds when you change sources or when the sound format changes?
One more questions, does anyone have any opinions on Audyssey Dyanamic Volume? I've heard Audyssey with Dynamic EQ and wasn't thrilled with the results.
akopperl is offline
post #105 of 2790 Old 08-31-2008, 11:08 AM
sethk's Avatar
Anyone with a 906 have a chance to try it with games? Does it have input lag like the previous models (not input switching lag)?
sethk is offline
post #106 of 2790 Old 08-31-2008, 11:52 AM
bearchan's Avatar
3 to 5 seconds? 10 to 15 seconds?
I guess the question is: Is it locking in faster than the 905?
bearchan is offline
post #107 of 2790 Old 08-31-2008, 12:02 PM
jeux_1's Avatar
Apparently it is the same as the 905, mthinking of getting the denon 4308 instead :-( or the 5308 ( AVC-A1H over here)
jeux_1 is offline
post #108 of 2790 Old 08-31-2008, 12:50 PM
toolwarrior's Avatar
Be careful with this post. It is filled with errors.
toolwarrior is offline
post #109 of 2790 Old 08-31-2008, 01:23 PM
Horta's Avatar
Quoted: 26 Post(s)
Liked: 26
Better Amp section mainly. Those who really want that littla extra in sound quality, who have very large dedicated rooms with high end speakers. The USB and ethernet streaming I could really care less about.
Horta is offline
post #110 of 2790 Old 08-31-2008, 03:21 PM
Mod & Bluray Reviewer
Moderator
Lee Weber's Avatar
Quoted: 125 Post(s)
Liked: 355
I was told the amp section isnt "better" it can drive more power hungry speakers cleaner. If you have easy to drive speakrs you wont hear a difference. That could be wrong...any one have any ideas on this torrodial vs non issue (906 vs 876).
Lee Weber is offline
post #111 of 2790 Old 08-31-2008, 03:46 PM
vcor's Avatar
Quoted: 30 Post(s)
Originally Posted by doinit1010 View Post
VCOR, really appreciate your putting together the comparison chart. I have a few corrections based on your sources and an Onkyo 806 press release. I only include these because getting the facts right is what a comparison is all about. I welcome your comments.
11. MSRP for the 906 = $2299, 876 = $1799, 806 = $1099
Thanks! I've updated the chart with your changes, and all other comments made since I posted the prior update a few days ago, and a few other additions and corrections I found.
The price is the only area I could not confirm, partly as I couldn't locate a US press release (directly from Onkyo) on the pricing. Based on retailers who typically sell at MSRP, I see the pricing at 906 = $1999, 876 = $1599, 806 = $1099.
If anyone can confirm (with a link) to an official US Onkyo pricing, it would be appreciated!
Here's the link again for my comparison chart:
http://www.faqware.com/Receivers/Onk...ison_2008.html
If you see other errors, let me know and I'll fix it. I hate having inaccurate info out there!
vcor is offline
post #112 of 2790 Old 08-31-2008, 04:19 PM
doinit1010's Avatar
The Onkyo USA site clearly states the MSRP on this page:
http://www.onkyousa.com/prod_class.cfm?class=Receiver
906 = $2299
876 = $1799
806 = $1099
Can you get it for less, probably.
doinit1010 is offline
post #113 of 2790 Old 08-31-2008, 05:18 PM
dpalmer11's Avatar
Any reason to buy the 906 instead of the 905?
dpalmer11 is offline
post #114 of 2790 Old 08-31-2008, 05:24 PM
Unfortunately, the 876 doesn't get the torroidal transformer
post #115 of 2790 Old 08-31-2008, 06:03 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
seven to 10 seconds...
Jon S is offline
post #116 of 2790 Old 08-31-2008, 06:05 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
why buy an older model? The only differences i can really see is that the 906 has added color correction features (ISF mode), there is a new zoom mode which allows you to zoom into a non-anamorphic video to get it to fill a 16:9 screen rather than having black bars all around.
Jon S is offline
post #117 of 2790 Old 08-31-2008, 06:09 PM
akopperl's Avatar
Quoted: 34 Post(s)
Is that for when you change sources from say your DVD player to your DVR or is it the amount of time it takes to lock on to the sound format?
I'm more interested in the amount of time it takes to lock on to the sound format. Last year I owned a Onkyo 875 for a short period of time. It took the unit about 5 seconds to lock on to the audio and as a result I missed the first 5 seconds of every show I recorded. That was a deal breaker for me.
akopperl is offline
post #118 of 2790 Old 08-31-2008, 07:39 PM
buckeye83's Avatar
Thanks for all the info. on your new unit. You seem happy with the purchase and thats what's a good thing. For others, I the $500 savings would be it. If I have the info. straight, the 906 has the ISF mode that the end user can not access. Also the zoom mode mentioned above. Several have asked about the Reon implementation. The reason being that most 905 owners have bypassed the Reon due to video issues with it. If Onkyo fixed their implementation of the Reon in the 906 that would push many to the new model. If it is the same then the price difference is a player. Can someone, maybe a 905 owner come up with a good check that we could ask Jon S to perform to test out the Reon implementation issue. Thanks.
buckeye83 is offline
post #119 of 2790 Old 09-01-2008, 01:38 AM
gurkey's Avatar
Quoted: 112 Post(s)
Liked: 89
This has been remedied with the latest firmware update for the now discontinued models already. Audio sync is somewhere around 1 sec now I would say.
What people where asking, if switching between different HDMI sources takes that long for resync. Experience from other makers models seem to be, that this is still an existent "cross border" phenomenon.
gurkey is offline
post #120 of 2790 Old 09-01-2008, 10:05 AM
sethk's Avatar
Can someone describe the color correction features? Does it have individual gain and bias for R, G, B?
sethk is offline
Onkyo Tx Nr906
