The "Official" Onkyo TX-NR906 Owners Thread... - Page 93 - AVS Forum | Home Theater Discussions And Reviews
post #2761 of 2790 Old 08-22-2013, 09:13 AM
Pablo2k's Avatar
Quoted: 24 Post(s)
Hello fellow 906 owners again.
I have a question which I think I know the answer to.
I have the opportunity of getting a NAD M25 amplifier and I was wondering what the output voltage is on the 906. I can also get the pre amp that goes with the M25, the M15 but it does not have HDMI switching. The audio would only go through its 7.1 analogue input (which would make me loose bass management) but it has the correct pre out voltage for the M25
Would I be loosing a lot sound if I use my 906? Should I use the NAD pre amp and use optical inputs loosing all new codecs? Anything els you could recommend?
Thank you for reading.
Pablo
Pablo2k is offline
post #2762 of 2790 Old 08-22-2013, 10:17 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Pablo
I suggest to use 906 until its HDMI board dies. Then look for a new preamp/processor. The only weak point of 906 as preamp - its poor A/D convertor when you feed it from analog source (like turntable), but you can always bypass it switching to Direct mode.u
ap1 is offline
post #2763 of 2790 Old 08-22-2013, 10:29 AM
Pablo2k's Avatar
Quoted: 24 Post(s)
Hi AP1 thank you for the quick replay.
I already lost my sub hdmi, main hdmi still working (it happend after a tree outside got hit by lightning)
I only use the receiver for movies, so it's only a bluray player and a laserdisc player, oh and video games, no turntable.
I was wondering about the output voltage.
Do you think I should get that other pre amp for 400 for now? It's the original nad m15 and has not hdmi audio.
Thanks again.
Pablo.
Pablo2k is offline
post #2764 of 2790 Old 08-31-2013, 04:27 PM
DBacksFan5205's Avatar
Originally Posted by digitalsafari View Post
Updating the TX-NR906 and TX-SR876
To help new owners of pre-owned TX-NR906 here is what I used to update my unit, all in one place. Should also work for TX-SR876.
Upgraded from 1.01 to 1.4 then to 1.5 without any issue apart from having to use an old WinXP system with an RS232 port.
All main firmware updates done via RS232 no need to use the custom port mentioned in the firmware thread.
http://www.avsforum.com/t/1016297/the-onkyo-integra-direct-firmware-updates/
The thread makes it sound like that going to 1.4 then to 1.5 was safer than going straight to 1.5, it might be a different model that has issues but I had the time to do it.
Used the firmware from here:
http://www.avsforum.com/t/1016297/the-onkyo-integra-direct-firmware-updates/4110#post_22467762
Thanks to all the contributors to the above.
J
Hi!
I’ve got an Integra DTC-9.8 that has no HDMI video out. My firmware reads as follows:
MAIN: 87 1.08 / 0841AA
DSP 1st: SR8051 08214A
DSP 2nd: SR8052 07518A
DSP 3rd: SR8053 07820B
HDMI: 1.01 / 07706A
VIDEO: (BLANK)
NET: 1.00
If I find and install the Main firmware, will my Video firmware be “refreshed”?
I have Loader version 1.0107615L, so I think if I could get the Main firmware, I’d be good to go.
Will the TX-NR906 Main firmware work on my Integra DTC-9.8?
Does anyone know what caused the Video firmware to be cleared out?
Will reinstalling the Main firmware bring back the Video firmware?
Does anyone have the Main firmware (1.08 or 1.09) that they could provide to me?
I don’t see it available out there any more.
digitalsafari - Do you have the TX-NR906 Main firmware and if so, could you please provide it to me? None of the links I’ve found are still active.
Any assistance would be greatly appreciated.
Best Regards,
DBacksFan5205
DBacksFan5205 is offline
post #2765 of 2790 Old 09-01-2013, 02:35 PM
Pablo2k's Avatar
Quoted: 24 Post(s)
Questions about firmware update
I got my receiver when it first came out from JR in NYC
So I'm sure I have the original firmware.
So I know there are two, 1.04 and 1.05
I never experienced the "Bomb" thing.
I did loose one hdmi in storm, main still working.
Does anyone have a list that discribes what these two
Firmwares would do for me?
Thank you.
Pablo2k is offline
post #2766 of 2790 Old 09-10-2013, 03:20 AM
Ticko's Avatar
Anyone having the firmware files for the 906? Upgrade guide? Please..:-)
Ticko is offline
post #2767 of 2790 Old 11-06-2013, 12:36 AM
cdrov's Avatar
Can you pls tell me what is this special Jig cable that the onkyo support consider necessary in order to update the 906?\
Thank you all
cdrov is offline
post #2768 of 2790 Old 11-06-2013, 10:09 AM
trekguy's Avatar
You don't need the jig. Main verssions 1.04 and 1.05 install using the rs-232 port on the 906. If I recall correctly one uses a wave file on a CD player. Instructions are included in the update files. If you need them and send my your email I can send you 104 or 105 and a DSPU update.
David
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
post #2769 of 2790 Old 11-06-2013, 03:17 PM - Thread Starter
Jon S's Avatar
Quoted: 925 Post(s)
Liked: 303
The firmware updates are uploaded via computer through the serial port.... The WAV files are the ones to update the DSP for the decoding chips...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #2770 of 2790 Old 12-09-2013, 10:18 AM
turnne1's Avatar
Quoted: 1991 Post(s)
Liked: 489
Question for 906 owners
I just bought a used 906 from a "donation facility"..for $160( shipped)
I suspected that it was donated because the HDMI board was dead
Well..received it today
The good news
IT WORKS!!...however I have to use the HDMI sub output to get video
HDMI produces sound...but not video
The bad news
it received some shipping damage..I had to pry the door open and the buttons on the from are pushed in a bit ...more so on the buttons on the left side
There are also some extra scratches...not really bad...but that didn't appear in the pictures I saw before I bought the unit
I am accustomed to these units and have had some 875's in the past...in fact i bought a similar "junked" 875 a couple of years ago for $80...and when I received it was functioning as well...even though the owner that sold it to me told me that a shop has told him the HDMI board was toast
anyway...it seems I can use the remote to control it as I dont like pushing buttons that are already pushed in
Does the fact that the only the HDMI sub works....is that an indicator that it will be going next
any experiences that someone can fill me in on?
thanks
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon X4300 Celestion 305 speaker system
Rm 3 Samsung 55KS8000 Yamaha A1060 Kef 2005.2 speaker system
Rm 4 Vizio P50 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #2771 of 2790 Old 12-13-2013, 03:55 PM
nartana's Avatar
Oldest question in the history: has there ever been a reliable place, online, where the DSP/.wav and Firmware update files... are stored, for download, by individuals? I've looked and looked. All links have expired over the years. We have an 886 at our theatre and a competent tech staff, and I'd love to update one or the other, or both (system and/or DSP) and we have an RS-232 cable/port, etc.
We have some definite shortcomings with our current firmware (the first, original firmware) that we need to overcome so it's a real need. And we can't send it off. We need it every other day for events.
Anyone have any leads on where to download the latest files for the SC886?
nartana is offline
post #2772 of 2790 Old 12-27-2013, 01:18 PM
crakarjax's Avatar
Quoted: 56 Post(s)
I'm hoping someone can help me diagnose this HDMI problem that I am having with my receiver. It doesn't output via HDMI, but it does recognize devices providing HDMI signal. The OSD doesn't even display when in setup mode. I replaced the 100uF caps on the HDMI board, but it didn't affect the behavior at all! I bought this used and the firmware is already fully updated.
Has anyone seen this behavior before?
EDIT: Turns out, I just needed to change from the default of analog output to HDMI output!
crakarjax is offline
post #2773 of 2790 Old 01-01-2014, 10:56 AM
ogider's Avatar
Can I ask for a link to newest DSP1 upgrade for Onkyo 906?.
I have atm 08919A and I need at last 12116A.
I was able to find file for x05 series...But that won't work with 906.
Or maybe someone can share by email.
Best regards.
ogider is offline
post #2774 of 2790 Old 01-20-2014, 12:38 PM
fourstar77's Avatar
Hi - I have what is probably a very easy question, but I've been at it a while and can't figure it out. I have Rocksmith 2014 and am trying to use HDMI for video and composite (red/white) for audio to avoid the audio lag issue. Is there a way to do this? I've tried assigning the composite audio input to the DVD setting (what I use to connect HDMI output from the PS3). Any suggestions would be greatly appreciated. Thanks!
fourstar77 is offline
post #2775 of 2790 Old 01-20-2014, 01:00 PM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
Assign the HDMI input to the same logical input (DVD) as the analog audio is connected to (you probably have already done that, although you stated it backwards.  Analog inputs are not assigned... they are permanently associated with a specific logical input.  The HDMI inputs are what get assigned).  After selecting DVD as your current input, use the [AUDIO SEL] button to select which audio source (analog, digital, HDMI or multichannel) is to be used for that logical input.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #2776 of 2790 Old 01-20-2014, 02:28 PM
crakarjax's Avatar
Quoted: 56 Post(s)
I did this recently for RockSmith, but I applied the RCA output from my PS3 to the "CD" input. As it is an audio-only input, I'm able to keep my HDMI audio set properly and just hit "CD" to switch to the analog audio. The HDMI video from DVD will persiste because CD has no video feed. Another benefit is that you can tune "CD" to minimal lag while retaining any fancy settings you like for movies etc. on DVD.
post #2777 of 2790 Old 01-20-2014, 02:50 PM
fourstar77's Avatar
That worked!! Thank you.
post #2778 of 2790 Old 02-25-2014, 12:53 PM
stay@homedad's Avatar
Quoted: 14 Post(s)
Anyone have a 906 that HDMI fried and is willing to sell cheep? I need a working tuner module from it, they can not be bought anymore
stay@homedad is offline
post #2779 of 2790 Old 08-06-2014, 01:00 PM
Liked: 0
Hello! I am looking for a replacement HDMI board assembly including the regulator for my Onkyo TX-NR906 receiver. Hoping someone here can help me find dependable and economical parts in the San Carlos area of California or nearby. Please send leads and info to Gurudev K, request-642e19@fhands.com. Thanks!
Dorothy Perry is offline
post #2780 of 2790 Old 11-09-2014, 09:31 AM
mindnever's Avatar
Hi. I have this setup:
HTPC (i3-4340) ---> Onkyo 906 ---> Sharp Aquos TV
The problem is that I cannot output 50Hz to my Onkyo. Every other refresh rate works ok. But when the HTPC switches to 50Hz the picture on my TV goes black!
If I connect the HTPC directly to the TV everything is ok. Also, my standalone media player works fine in all refresh rates. It's the HTPC that causes the problem at 50Hz when it is connected to my Onkyo.
This must be a drivers issue because when I boot in safe mode the default refresh rate of 50Hz works! So I guess that the latest drivers don't work with Onkyo 906?
Please help...
mindnever is offline
post #2781 of 2790 Old 12-30-2014, 11:41 AM
trekguy's Avatar
Factory DSP Firmware--FAILURE
Some of you may recall a movie titled "Bad Day at Black Rock". Well around Christmas a DSP firmware CD from Onkyo USA turned my NR906 into a a Bad Day at Black Rock.
Sometime back I sent an email to Onkyo asking for the DSP firmware update CD. There was a delay, possibly because two different employees responded, but eventually I received an envelope with an Onkyo (Japan) CD, an optical cable and an instruction sheet.
Did I really need the update? Possibly not, but I was in a carefree mood. I did a couple of practice runs (those little black buttons are hard to see) and saw the expected information on the display. I inserted the CD per the instructions. Updating DSP 1, DSP 2, DSP 3, ...everything went fine.
Then the big surprise! No audio. I had successfully loaded DSP version ?????????. Well as Einstein did not say, I did it again and again and again. Each time "Updating DSP1, DSP2, DSP3" and each time getting version ????????
Too soon to panic, anger yes, but not panic. I was able to locate one of the firmware files that I had downloaded from a now dead link. I even remembered that I had also downloaded a freeware program to write the file to a CD-R and I remembered the name of the that freeware.
I went on line found it and installed it, or tried to. Running setup disabled Norton, Task Manager and Ctrl-Alt Delete and F4 no longer worked. The network connection went down.
What fun, first I brick the 906 then I download malicious software. I was able to stop the setup program, but a mysterious program called bigupdate-iu.exe was in memory. It reloaded on restart but was not using any CPU time or writing to the drive. It could not be deleted or renamed. More fun. Well what the heck, perhaps it was my final warning to put my XP box out to pasture. Anyway I got it all running again (thank the gods for the command line) and by searching AVS found the right name for the freeware CD installer (ImgBurn). So much for my total recall.
I burned a disk, put in in the DVD player and initiated the firmware update. This time it worked. Oh yes, you have to redo all of your settings, but by that point it seemed trivial.
Did Onkyo send the wrong CD? I don't know and I am not going to ask. The CS reps probably don't know and it might bring back the old attitude that OnkyoUSA customers cannot be allowed to do updates. What I do know is that the disk from Onkyo Japan failed but the bootleg files worked. YMMV
-Bertrand Russell
trekguy is offline
post #2782 of 2790 Old 02-09-2015, 02:15 AM
Liked: 0
Hi,
I have recently bought a used NR906 as my first hifi receiver (paired them with Jamo C607 floorstanders) and I love how it sounds but I have this issue that is bugging me a little.
My main AV source is my computer, delivering all video and audio through HDMI. I use my TV as a monitor, and it is directly connected to my computer also. Video is cloned so I have two HDMI cables running from my computer. The reason behind this setup is that I had the TV calibrated by a professional (I am a photographer) and any additional video processing would mean I have to recalibrate again.
The problem is, when the video is running through AVR (when I leave it on AVR HDMI source on the TV), I get screen tearing when there are fast scenes on the screen. This happens with Youtube and locally played video too. I have also updated the 906 to 1.05 hoping it would fix this issue but it remained unchanged. I have googled and I had no luck finding anything related to 906 and screen/image tearing. I don't have this issue when I'm running video directly from the computer.
Is this normal? All the video processing options are off or set to 0.
I mean, I can use it as I normally do, running the video to my TV directly, it's just that I would like it look perfect.
Cheers.
mr.baja is offline
post #2783 of 2790 Old 04-20-2015, 06:17 PM
Liked: 0
Hello new I'm new here,
how do i find out the current firmware? and were can i get the software to update it?
also it won't work with my iPhone, is that because of an older firmware, my other onkyo nr-511 works with it?
thanks
for the help
Labas is offline
post #2784 of 2790 Old 04-21-2015, 02:01 AM
Liked: 0
Labas, to check the firmware do this
On the front panel, press 'DISPLAY' and 'Standby' to display the main firmware
I found this in the 876 thread, which almost the same as 906.
What iPhone app were you trying to use with the 906? I tried all 3 Onkyo apps, none of them worked. I also tried one app (forgot the name) that should work from the PC, that one didn't work either.
mr.baja is offline
post #2785 of 2790 Old 06-03-2015, 01:17 PM
Siddhartha's Avatar
I bought the 906 to drive my Polk LSi 15 speakers. Also I am using a Coolerguys fan system on it to help cool it. The receiver has done a good job. But recently the receiver has been shutting down when playing movies and music at low to medium sound levels.
My question is what receivers should I consider to replace the Onkyo? Keeping in mind that the Polk speakers are rated at 4 ohm and and can drop to around 3 ohms.
When I bought the Onkyo I had in mind to get a power amp and use the Onkyo as a pre-Amp. What amps should I consider?
Thanks Siddhartha.
Siddhartha is offline
post #2786 of 2790 Old 06-03-2015, 10:50 PM
dlaloum's Avatar
I use crown xls series amps with my 876, it was a noticeable upgrade on the internal amps.
dlaloum is offline
post #2787 of 2790 Old 06-04-2015, 12:57 PM - Thread Starter
Jon S's Avatar
Quoted: 925 Post(s)
Liked: 303
I replaced my TX-NR906B with a Pioneer Elite SC-67 with the digital amps a couple of years ago. It drives my LSi15s perfectly fine. The receiver is rated to work with 4-ohm speakers. The only thing I do not like with the Pioneers are the crappy remotes with the smaller buttons and micro-sized text which is impossible to read. Thank God for Harmony remotes.
Jon S is offline
post #2788 of 2790 Old 08-27-2015, 02:55 AM
FuzzyQ's Avatar
Onkyo TX-NR906 unable to process 768p
Hey guys, perhaps someone can help me out here.
I'm trying to route a 768p (1366x768 @ 59Hz) video signal coming from an Faroudja NRS video processor through my Onkyo TX-NR906. When I use a VGA->HDMI adaptor to connect the two devices, I get a picture but can't apply any advanced picture settings like zoom, noise reduction or gamma. The signal is simply passed through the amp but not altered.
Connecting the devices with component cables (which is the intended way to do it) leads to the amp showing an "unknown source" problem instead of a picture.
I double and triple checked that I assigned the right input channel in the amp's setup menu and disconnected any HDMI connection on that channel. I also made sure that the component video connections of the receiver are alright by connecting a XBox360.
The Onkyo's manual doesn't explicitly mention 768p as an unsupported resolution and what really puzzles me is that it can pass it through when inputting via HDMI. Supposedly other Onkyo amps like the TX-SR707 are able to handle 768p just fine.
Is there anything I could do to convince the AVR to recognize and process the video signal?
Can anyone shed some light on this? Thanks in advance for any helpful answer!
Best regards.
Pioneer CLD-D925, Philips BDP7700, Faroudja NRS, Onkyo TX-NR906, BenQ W1070
FuzzyQ is offline
post #2789 of 2790 Old 12-09-2015, 08:43 PM
chamolie's Avatar
TX-NR906 power loss and settings are back to defualt
I have had my TX-NR906 for 6 years now and 3 years ago, I experienced loosing the settings upon a short power failure to the unit. The unit was repaired under warranty at the time and the receiver has recently started the same issue again. I Would like to know if anyone can tell me which capacitor to replace myself as Onkyo clearly uses sub-par underated capacitors in the entire unit and not just the HDMI board.
I am able to solder and have fixed the HDMI issue myself by replacing the troublesome capacitors on the HDMI board with much better higher voltage/higher temp/better quality capacitors than used from the factory.
thank you...
chamolie is offline
post #2790 of 2790 Old 04-11-2016, 07:37 PM
mgsimmer's Avatar
Need Onkyo TX-NR906 DSP Update Firmware
Hi Trekguy,
I have also received a CD from Onkyo but don't trust it given what you experienced, its lack of any professional labeling and the fact that when I played and listened to it the data files were way to short to have the correct DSP code. Could you email the DSP update file to me? I would greatly appreciate it!
email is mike at mikesi net
Mike
mgsimmer is offline
Onkyo Tx Nr906
