"Official" Marantz SR5003/6003/7003/8003 Thread - Page 81 - AVS Forum | Home Theater Discussions And Reviews
post #2401 of 2417 Old 09-21-2014, 09:33 PM
pwang100's Avatar
Originally Posted by grasshoppers View Post
Try a micro processor reset...post #2382 , maybe a couple
Of times. Also unplug unit for about 10 minutes.
Could be fried HDMI board...good luck and report
Back if you can.
Tried both of your suggestions. Not sure I did the reset correctly. Nothing really happened, except it made my volume REALLY loud. Almost like it reset my volume setting. But as far as HDMI issues, it didnt help.
pwang100 is offline
post #2402 of 2417 Old 09-22-2014, 05:32 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
A microprocessor reset will wipe out the Audyssey settings and restore all settings to factory defaults. Try unplugging all HDMI cables and powering off and unplugging the TV, AVR, and source device for at least 10 minutes. Plug back in the HDMI cables, power cables, then power on the TV. Wait at least 5 seconds, then power on the AVR. Wait at least another 5 seconds and power on a source device. If still no joy, as noted previously, the HDMI board may have been affected so time to call the insurance company.
jdsmoothie is offline
post #2403 of 2417 Old 09-24-2014, 07:47 PM
pwang100's Avatar
In case it is indeed the HDMI board, can anyone estimate what kind of cost I'm looking at? Am I looking at something like $100/ $400/ or $800 range? Nothing specific requested, just want to prepare myself for what I might be in for.
pwang100 is offline
post #2404 of 2417 Old 09-24-2014, 07:52 PM
jdsmoothie's Avatar
Liked: 5502
post #2405 of 2417 Old 09-25-2014, 01:53 PM
pwang100's Avatar
$500.
Yikes. Thanks for the info. I'll have to decide if its even worth repairing...
pwang100 is offline
post #2406 of 2417 Old 09-25-2014, 02:45 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
$500.
Wow, I too had no idea it would be so much!
My Marantz sr5003 is still doing fine, being
Relegated to partime bedroom use.
I've been saying for several years now that
Modern electronics are disposable...after warranty
Is expired it is simply put, too expensive to get them
Repaired.
Just my opinion.
grasshoppers is online now
post #2407 of 2417 Old 09-30-2014, 04:32 PM
pwang100's Avatar
Repaired.
Just my opinion.
Just got the estimate back from the Marantz authorized dealer. Indeed, HDMI board needs replacing. Total cost will be $400... I'm gonna think about it for a couple of days...
pwang100 is offline
post #2408 of 2417 Old 10-31-2014, 12:06 PM
HDnewbie2009's Avatar
Add mine to the list. As you note my username, I built my HT in 2009 with the SR5003. Now, about 5 years of service and its got the same dreaded fast flashing light. Tried a few things and checked the fuse which is OK, nothing has worked. Seems a new receiver is in order. Was thinking just going the OPPO route and getting a BD player and using my current Power amp without receiver. Easy way to save 700-1000. Glad I found this thread, thought I had done something wrong.
HDnewbie2009 is offline
post #2409 of 2417 Old 11-25-2014, 11:14 AM
pwang100's Avatar
Voltage Range or Specs?
Turns out my blown HDMI board was caused by a power company [Southern California Edison (SCE)] underground vault explosion. I filed a claim with SCE to have them payfor my repairs, they denied my claim. In speaking with them, I learned about their position, and reasons for denial.
They admit they had an equipment failure in my complex, on the subject date. BUT, they claim the failure did not result in any voltage spikes that caused my equipment damage. I asked how they knew there were no spikes, and I was told that BECAUSE NONE OF MY LARGE APPLIANCES SUCH AS DISHWASHER, REFRIDGERATOR, ETC WERE DAMAGED, THEY KNOW THERE WAS NOT ANY VOLTAGE SPIKES.
It seems their entire reasoning, (and justification for denying my claim) is based on a premise that any voltage spike, however small would FIRST NEED to damage large appliances before any AV equipment. Does this seem reasonable?
The power surge damaged two pieces of electronic equipment, my cable box and the AV receiver. I talked to the Marantz tech who is servicing my receiver, and he said these components are digital, so they are MORE sensitive than large appliances.
Does anyone know of any literature or specifications that are related to voltage ranges, etc? I'm looking for a way to refute the premise that large appliances HAVE to be damaged before an AV receiver.
Thanks in advance for any input.
pwang100 is offline
post #2410 of 2417 Old 01-03-2015, 07:13 PM
Liked: 0
Hello all,
I am new to the forum and have a quick question. Can anyone please advise if the item as per the attached link is the correct replacement microphone as relates to the Audyssey calibration feature? I can't seem to find the microphone that came with the unit anywhere...
Thank you so much!
PS. My apologies, but it appears that the forum will not allow me to post a link given my newbie status; therefore, please refer to
ASIN#B002AKKL1G
Model#ACM1
Thank you and I apologize for the extra step!!
pmar4015 is offline
post #2411 of 2417 Old 01-04-2015, 07:59 AM
Quoted: 802 Post(s)
Liked: 506
Originally Posted by pmar4015 View Post
Hello all,
Thank you so much!
ASIN#B002AKKL1G
Model#ACM1
YES, that is the correct microphone for your Marantz.
(Have the orignal Box that the mic came in)
post #2412 of 2417 Old 01-04-2015, 08:12 AM
jdsmoothie's Avatar
Liked: 5502
HDMI boards are much more sensitive. You should just make a claim on your home owner's insurance.
Hello all,
Thank you so much!
ASIN#B002AKKL1G
Model#ACM1
You can use either ACM1 or newer ACM1HB.
post #2413 of 2417 Old 01-04-2015, 08:17 AM
Liked: 0
Thank you for the help!
Much appreciated
pmar4015 is offline
post #2414 of 2417 Old 06-01-2016, 09:04 AM
BLS
BLS's Avatar
To owners of the 8003 Pre/Pro, I wanted to share something that prevented me from upgrading to the latest gear.
Had to swap out year 2006 Sony KDS-A2000 Lcos tv for a year 2011 Panny Plasma. The HDCP was blocking content with the Roku 3 and Comcast HD Dvr running through the Marantz 8003. Both would work if connected directly to the Panny, but then no Hi-res surround sound is available through the 8003. Interestingly, the Oppo BDP-95 handshakes just fine.
I thought for sure the HDCP in the 2011 Panny would never play nice with the older Marantz with HDMI 1.3. I tried many different settings and as a desperate last resort, nothing else is wrong wit the 8003, even though I dislike the mushy selector knobs intensely, I performed a reset. Low and behold it worked!
BLS is offline
post #2415 of 2417 Old 12-07-2016, 09:03 PM
BMaugans's Avatar
Trying to find the answer to question everywhere without luck... hoping there's someone left scanning this thread occasionally.
Is it possible to operate the 5003 in mono mode? I swear I remember cycling past a 'mono' setting someone in the various settings for the thing, but now for the life of me, I can't find a way to play back a stereo source in mono.
BMaugans is offline
post #2416 of 2417 Old 12-08-2016, 03:54 AM
jdsmoothie's Avatar
Liked: 5502
If you download the SR5003 Owner's manual from the Marantz website, you can do a search on the word "Mono" to see a number of different references as to how to select it.
post #2417 of 2417 Old 12-30-2016, 05:22 PM
ljnelson's Avatar
Question Meaning of the Preference|Audio option?
Hello; I own an SR6003 and have never understood the "Audio" option in the "Preference" menu.
The manual says this (in its entirety):
Audio:
In the Audio mode, Dolby Digital and DTS output
is set to either “Main” or “Sub”. Select “Audio” with
the 1 or 2 cursor buttons, then select Main ↔ Sub
↔ Main+Sub with the 1 or 2 cursor buttons.
If I read this right, it means that Dolby Digital and DTS output can either go to the mains or the mains and the subwoofer.
But of course you normally affect this with the Speaker Setup menu.
Are these two menu items affecting the same thing? Surely not. If not, what is the subtlety I'm missing?
(In case it matters, I have a subwoofer attached to the LFE output jack. I'm currently troubleshooting it (see Very quiet output out of Supercube III? for details).)
ljnelson is offline
