The "official" The Onkyo TX-SR706 Owners Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 2850 Old 11-28-2008, 08:06 PM
Zygon's Avatar
What settings do you guys have for the 706 while using the ps3?
I pcm sound from ps3 to my 706 displaying multichannel. Is this the right set up for hearing dolby trueHD and dtsHD-ma?
Xbox Live GT: xxx COKE UP xxx
Zygon is offline
post #182 of 2850 Old 11-28-2008, 08:08 PM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
Originally Posted by Brettcp View Post
i got my 706 last week from shoponkyo, $522 shipped after the 10% rebate. Arrived in 2 days and is in perfect shape - looks brand spankin' new actually.
you can get it cheaper than that for a new one with better return service at amazon.
Goatse is offline
post #183 of 2850 Old 11-28-2008, 09:30 PM
Century Frac's Avatar
Hello, quick question, I can buy either a H/K 354 or a Onkyo 706 for the same price. Which one should I buy and why?
Century Frac is offline
post #184 of 2850 Old 11-29-2008, 01:37 PM
heatstor's Avatar
Why is the refrubished sr706 silver $200 cheaper than the refurbished sr706 in black at shoponkyo
Same case for the 806 refurbished. Silver is $200 cheaper.
Anyone know why?
heatstor is offline
post #185 of 2850 Old 11-29-2008, 02:16 PM
adb280z's Avatar
Anyone know why?
The black looks better, probably easier to sell.
adb280z is online now
post #186 of 2850 Old 11-29-2008, 05:40 PM
kevdc's Avatar
I just hooked the Panasonic BD35 with my new Onkyo 706 receiver and while watching Journey to the Center of the Earth Blu Ray disc, I noticed that the receiver does not display the "HD" mode. It just displayed Dolby Digital and Dolby Digital EX along with other modes. I have a hdmi cable going from BD player to receiver and receiver out to TV in. Is the correct hookup? Should the receiver display the "hd" signal? or do I just simply have a defective receiver? Help! Thanks.
kevdc is offline
post #187 of 2850 Old 11-29-2008, 06:01 PM
Imac Convert's Avatar
I helped my dad put together the same set up. Make sure the BD35 is set to bitstream. This ensures that the receiver is doing the encoding.
You can access the option to bitstream in the setup menu of the player when you have no movie in the tray.
Samsung LN-T3242H
Onkyo SR-706 A/V Receiver
XBOX 360 w/HD DVD add-on
PS3 for Blu-Ray
Imac Convert is offline
post #188 of 2850 Old 11-29-2008, 06:18 PM
kevdc's Avatar
Thanks. It's already setup to Bitstream on the BD35. Does your receiver say "TrueHD" on the panel display? Do I need hdmi from the receiver out to the TV?
kevdc is offline
post #189 of 2850 Old 11-29-2008, 06:31 PM
I have the player going to the receiver through HDMI and the receiver out to the T.V. through HDMI also. My receiver does say True HD or DTS MA depending on the movie.
Samsung LN-T3242H
PS3 for Blu-Ray
post #190 of 2850 Old 11-29-2008, 07:43 PM
revslick's Avatar
what speakers would you suggest for the 706 with a budget of $300-400?
thanks,
revslick is offline
post #191 of 2850 Old 11-29-2008, 10:31 PM
SkiSmuggs's Avatar
thanks,
Cambridge Soundworks MC155 fronts and MC105 or S105 surrounds www.hifi.com but this won't include a subwoofer. Or Newton Ensemble M55 Music System that is a 2.1 setup
http://www.amazon.com/Polk-Audio-Cha...8023150&sr=1-1
is a 5.1 choice that does include a subwoofer
SkiSmuggs is offline
post #192 of 2850 Old 11-29-2008, 10:36 PM
ffk_pennywise's Avatar
If your Blu ray player is doing the decoding, the Onkyo wont display TrueHD or HD MA. It will only say that if its the one doing the decoding. It's playing the HD audio, but it wont say it.
ffk_pennywise is offline
post #193 of 2850 Old 11-30-2008, 06:20 AM
revslick's Avatar
thanks. i found a review of the mirage nanosat.
how do they stack up against the polk or cambridge?
revslick is offline
post #194 of 2850 Old 11-30-2008, 06:56 AM
SkiSmuggs's Avatar
They sound like a good value, especially with a little shopping around.
Here is a comparison of the Nanosats with similar Polks:
http://www.hometheatersound.com/equi..._dswpro400.htm
Here are the polks described above:
http://www.amazon.com/Polk-Audio-5-C...054173&sr=1-26
If you read further down in that page, you'll see you can add the PSW10 subwoofer for free.
post #195 of 2850 Old 12-02-2008, 11:12 AM
PureNHL's Avatar
When I navigate to the setup screen I get a lot of flickering and random interference across the entire tv screen. Also, when I set the receiver to upconvert my Comcast HD DVR there is again a lot of the same interference (but no flicker). I'm connected Box --HDMI--> Receiver --HDMI--> Samsung 67" LED DLP. When I set to HDMI through I don't have any problems. Is this normal for these units or should I send it back? Unit was direct from Onkyo and was a refurb. Setup mic worked fine.
PureNHL is offline
post #196 of 2850 Old 12-02-2008, 01:52 PM
Zygon's Avatar
I get little blue specs of data running over the left side of my tv when using this receiver. Sometimes it spreads across the tv during darker scenes.
LNT4671F
PS3
XBOX 360
Toshiba XA2
ONKYO 706
(all connected hdmi v1.3)
Any info on this would help alot
Zygon is offline
post #197 of 2850 Old 12-02-2008, 04:46 PM
skalata's Avatar
Can the EQ be assigned to a input or is it global?
skalata is offline
post #198 of 2850 Old 12-03-2008, 08:47 AM
bak_phy's Avatar
Originally Posted by Dugout Doug View Post
Went to the gym.
Ran.
Got home, took 2 hours to hook it up and guess what???
From Shoponkyo.com, refurbished, the Audyssy setup did not hear my speakers.
Ahhhhhhh yes!
I am a little pissed.
I had the same problem with mine. The mic wouldn't hear the first speaker (although I certainly did.)
The next day I tried to switch the polarity on the speaker as I was out of sensable options. Somehow this made it work. I was pretty sure that I had it hooked up correctly the first time around and in any case I can't believe that this would make a difference. But it did. Or maybe it didn't and it was just a strange coincidence.
bak_phy is offline
post #199 of 2850 Old 12-03-2008, 11:20 AM
Dugout Doug's Avatar
I have used Audyssy several times since that first night too, and it works perfectly every time now.
Odd, but I'll take it.
And I didnt change any wires around, 12 hours later, it just decided to work.
Dugout Doug is offline
post #200 of 2850 Old 12-03-2008, 12:45 PM
Barkingspider's Avatar
Anyone have a problem with the subwoofer distance being calibrated incorrectly with Audyssey? All other speakers are reading correctly but the sub always shows 7.5' when I know it's about 11'. Have done the setup 3 times and always get the same thing. If it's any help the sub is an M&K MX350. Thanks, Joe
Barkingspider is offline
post #201 of 2850 Old 12-03-2008, 07:10 PM
spartacus_33's Avatar
I've actually read through all of these and it seems that there are less problems with the more recently purchased units. It also seems that many of the issues are with referb units.
I just ordered mine from newegg.com ($479), but it's a TX-SR706B. Does anyone know the difference, if any? I'm hoping it's a newer version that has all these issues resolved.
I'm still a little concerned about the heat issue. I will have basically no clearance on top of the 706 unless I raise the shelf above it. I can't raise the shelf above it due to the height of my center channel speaker, (7"). I may need to get a new shorter center channel speaker, so I can raise the shelf. Any suggestions? All components sit on a "2 shelf" stand underneath my 65" Mitsu. My fronts are Definitive Technology BP 10s and am running a 15" Velodyne sub. Rears are pretty typical.
I'm expecting delivery of my 706B in a couple days. Will post back whatever happens good or bad.
Steve
Spartacus_33
My HT
spartacus_33 is offline
post #202 of 2850 Old 12-03-2008, 07:32 PM
PureNHL's Avatar
I believe the B is for black. Can anyone confirm?
Any advise on my video processing issue above? Should I send it back and try another?
PureNHL is offline
post #203 of 2850 Old 12-03-2008, 10:17 PM
n8manAfter's Avatar
My refurbished 706 showed up today. It's beautiful. Except...
I've just spent the last couple hours dismantling my old setup. Now that I have this thing connected I'm getting BLUE streaks/noise on all inputs. If I set the HDMI output resolution to 'Through', make sure all of the Picture Adjustments are set to their defaults (all zero), and make sure Noise Reduction is off (in SourceSetup->PictureAdjust) I'm at least able to get my HDMI inputs to come in clearly. This these settings the Wii which is hooked up over component still has the strange streak/noise issue.
Anyone have any idea? Is this unit faulty?
n8manAfter is offline
post #204 of 2850 Old 12-03-2008, 10:18 PM
n8manAfter's Avatar
What sort of interference? What does it look like?
Also, yes, 'B' is for black and 'S' is for silver.
post #205 of 2850 Old 12-04-2008, 04:35 AM
Steve
its going to get hot.
You are going to have to figure something out there. Someone a few pages back installed a fan, check it out.
post #206 of 2850 Old 12-04-2008, 09:07 AM
In my previous post where I say,"any suggestions"... I was fishing for any suggestions for a smaller (less than 7" in height) center channel speaker.
I may actually be able to raise the shelf that the center channel speaker is sitting on by one hole, thus giving some breathing room for receiver. I plan to hook up some sort of fan... just haven't started looking around for that yet. It needs to be a quiet one.... once again, any suggestions on a small fan would be appreciated.
Spartacus_33
My HT
post #207 of 2850 Old 12-04-2008, 12:04 PM
For those of you who have been holding their breath.... I was able to raise the glass shelf one notch higher above where the 706 will be placed, providing 8 1/2 inches of vertical space... still tight... but better. Center channel speaker just barely fit.
Now anxiously awaiting delivery tomorrow. Hopefully ONKYO has these bugs worked out on the more recent builds.
Spartacus_33
My HT
post #208 of 2850 Old 12-04-2008, 01:03 PM
I am thinking 8 1/2 will give you pretty good ventilation.
It will get hot, but I have NOTHING over the unit, so try not to freak about it.
post #209 of 2850 Old 12-04-2008, 01:19 PM
Well.. that leaves me about 1 1/2" of clearance between the top of the receiver and glass shelf above it. My center channel speaker is directly above the receiver and my 65" Mitsu is directly above the center channel speaker... typical set up.
I've contacted these guys for their suggestion:
http://www.coolerguys.com/
Spartacus_33
My HT
post #210 of 2850 Old 12-04-2008, 06:24 PM
Allez's Avatar
Ordered a refurb as well - it's not expected here (MD) until next week I'm a little apprehensive because of the reports of people with blue lines etc on their screens. Does this seem to be a heat-related phenomenon?
Allez is offline
Onkyo , Onkyo Tx Sr706 7 1 Channel Home Theater Receiver Black , Onkyo Tx Sr605 Receiver , Toshiba , Toshiba 52hm84 120 Watt Tv Lamp Replacement
