The "official" The Onkyo TX-SR706 Owners Thread - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2701 of 2850 Old 06-18-2011, 07:34 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
Originally Posted by primetimeguy View Post
True, but can that built in sub really handle 20hz or lower LFE?
Probably not at the location that the speaker will need to produce the higher frequencies optimally. Compromise will have to be made at the expense of clarity or bass reproduction.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #2702 of 2850 Old 06-20-2011, 09:54 AM
nosfed2's Avatar
I am getting ready to buy a 3D tv and a 3D Blu ray player and just wanted to know if this receiver will still work with all my HDMI cables going to it and than to the TV??
nosfed2 is offline
post #2703 of 2850 Old 06-20-2011, 01:11 PM
thx5150's Avatar
3D takes hdmi 1.4 this receiver is hdmi 1.3. You will have to bypass the receiver with the hdmi straight to the monitor and add an optical digital audio cable for sound.
thx5150 is offline
post #2704 of 2850 Old 06-23-2011, 12:04 PM
efotonik's Avatar
I have an Integra 6.9, was told that it is the same as the Onkyo SR706....sorry if I'm in the wrong place
I'm having an issue where I cannot get the audio listening modes to display (and potentially output) correctly from the receiver when using the PS3 as blu-ray/dvd player. I have the PS3 setup to bitstream but all I get out of the receiver is "multichannel".
Is this correctly processing the audio and giving me the best listening condition?
Another question - I noticed in the receiver settings I can only set the speaker type to either 4ohm or 6ohm....do these receivers not support 8ohm speakers? Do I just set to 6 and not turn things up?
efotonik is offline
post #2705 of 2850 Old 06-23-2011, 12:23 PM
thx5150's Avatar
I'm having an issue where I cannot get the audio listening modes to display (and potentially output) correctly from the receiver when using the PS3 as blu-ray/dvd player. I have the PS3 setup to but all I get out of the receiver is "multichannel".
To check what is being processed use the display for the ps3 and it will say 5.1,6.1,or 7.1. I have the same problem with the onkyo receiver. I set my receiver on thx and leave it. I look at the speaker display to see what is being processed whether it's 5.1 or 7.1. if it is a 5.1 i use a dts matrix to decode ton7.1. The manual I think states that the multi-channel display is all your going to get. It won't say dts hd or dd.
As far as 6 or 8 ohms go, I can't really remember what the manual says except that if you have 8 ohm speakers set to 6 ohms. I can check when I get home and make sure.
thx5150 is offline
post #2706 of 2850 Old 06-23-2011, 12:25 PM
Tony Chick's Avatar
No it won't, I just went through this and ended up reluctantly retiring my 706. I replaced it with the HT-R360 (NR609 minus PC input and THX cert) and the 3D works fine now.
Tony Chick is offline
post #2707 of 2850 Old 06-24-2011, 04:41 AM
Quoted: 76 Post(s)
Liked: 58
Maybe. Maybe not.
http://www.avsforum.com/avs-vb/showthread.php?t=1234061
http://en.wikipedia.org/wiki/HDMI#ref_3dJ
post #2708 of 2850 Old 06-24-2011, 06:31 AM
thx5150's Avatar
I don't have 3d just know what I read somewhere that the new hdmi 1.4 was for the 3d signal. And judging what member Tony chick said it wouldn't.
thx5150 is offline
post #2709 of 2850 Old 06-24-2011, 07:15 AM
thx5150's Avatar
I read wikipodea. An hdmi 1.3 cable at a high frequency can display 3d information but if the receivers output is only at a lower frequency, I'm thinking that's where the problem comes in. If you don't want go upgrade to a higher receiver then you have to just bypass the hdmi on the receiver and connect directly to the monitor. Then connect a digital audio cable from the 3d blu ray player to the receiver input.
thx5150 is offline
post #2710 of 2850 Old 06-24-2011, 01:26 PM
efotonik's Avatar
Thanks for the info. This works fine during a movie or Netflix playback but there is no on screen display from the PS3 during games which is a tad unfortunate. It's not a HUGE deal, just one of those things you pay for and would like to see on the read-out if possible
Thanks again!
efotonik is offline
post #2711 of 2850 Old 06-30-2011, 08:30 AM
efotonik's Avatar
Does anyone know the specifications for the "Phones" output on the front end of the receiver?
I'm looking to get nice headphones and have been reading up on those and ability to drive comes up quite frequently with some of the phones. Any idea what output levels are?
efotonik is offline
post #2712 of 2850 Old 06-30-2011, 09:57 AM
thx5150's Avatar
Don't know. I don't use headphones.
thx5150 is offline
post #2713 of 2850 Old 06-30-2011, 10:33 AM
efotonik's Avatar
Does anyone know if there is any Dolby processing that happens out of the port?
Is "Dolby Headphone" applied or some other matrix/3D interpretation of the 5.1/7.1 signals?
efotonik is offline
post #2714 of 2850 Old 07-01-2011, 08:39 AM
efotonik's Avatar
Another question:
Per the manual the receiver is capable of passing audio OUT through the Optical Out port on the backside. Is this only available when the audio is sent via optical IN or would it pass audio received over HDMI to the Optical Out?
The wording in the manual is a bit confusing and I don't have any optical cables around to try sadly
efotonik is offline
post #2715 of 2850 Old 07-01-2011, 08:51 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Another question:
Hi efotonik, optical out will not work with HDMI in. Only works with optical in or coaxial in.
JChin is offline
post #2716 of 2850 Old 07-01-2011, 09:29 AM
lvtdude's Avatar
The receiver only outputs stereo signals through the headphone jack. If you are listening to any other setting it automatically switches to stereo when you plug in the phones. Also, the headphone output is very good. It drives my Sennheiser HD-540's very well, and I saw another person had very good results with his Beyerdynamic phones. My cousin tried out his Grado Signatures on my receiver, and they did quite well, too. Unless you get some ridiculous phones, I don't think you'll have any problems.
The specs on the headphone jack should be in the manual. I'd look, but I'm at work right now.
lvtdude is offline
post #2717 of 2850 Old 07-05-2011, 06:24 PM
efotonik's Avatar
Thanks for the verification, was doing a bit of brainstorming with a few other AVS'ers and the thought was to have the PS3 do video over HDMI and force audio over Optical. I would drop out the HD audio formats from Blu-ray media but I don't have a ton of that so it seems like an acceptable compromise.
Optical in(to) the receiver should let me run Optical out into another device (Mixamp or otherwise) to gain Dolby Headphone or whatever else.
Thanks for the feedback on the phones output, very useful! (and confidence inspiring ).
It has been driving my dad's HD595's very well (to my ears) so it's cool to know that it has to gusto to push a few others too
I paged through the manual but couldn't find an actual specification output for that port, I may have missed it.
efotonik is offline
post #2718 of 2850 Old 07-05-2011, 07:33 PM
lvtdude's Avatar
I looked in the manual, and it isn't there. I'm a bit surprised.
lvtdude is offline
post #2719 of 2850 Old 07-06-2011, 06:01 AM
efotonik's Avatar
Glad I didn't just miss something obviously printed. With my luck it would have been its own chapter heading in bold, 36 font
Despite not having the actual specs it certainly sounds like the output is sufficient for even large, high-ohm headphones so I'll take that to heart and enjoy.
Thanks for all of the help!
efotonik is offline
post #2720 of 2850 Old 07-09-2011, 04:33 PM
jlm86's Avatar
Quoted: 23 Post(s)
I have had this unit for about 2 years. My paradigm monitor fronts/sub, klipsch center/rear have never given me the "huge" theater sound that i would like.
Good sound, but not the enormous ground shaking i crave....
Have 52" Samsung LCD....
What are some good 5.1/7.1 packages i could get for around 1200.00 or so?
thanks
jlm86 is offline
post #2721 of 2850 Old 07-11-2011, 12:27 PM
thx5150's Avatar
thanks
You could try definitive technology. I put together used and new speakers for about that price.
thx5150 is offline
post #2722 of 2850 Old 07-11-2011, 12:37 PM
thx5150's Avatar
thanks
I have 2 def tech. Bp 2002TL's and CLR2300 center and 4 bp 1.2x surrounds. The center and towers are powered with subs in them. They give very big sound. You can search on eBay or craigslist for the older models speakers.
thx5150 is offline
post #2723 of 2850 Old 08-01-2011, 02:40 PM
Hatboy's Avatar
What 2.1 setting is everyone using to listen to music? What do you find works best?
TIA
"We chase misprinted lies"
Hatboy is offline
post #2724 of 2850 Old 08-01-2011, 06:00 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
TIA
stereo
primetimeguy is offline
post #2725 of 2850 Old 08-01-2011, 07:33 PM
Hatboy's Avatar
Easy enough. Thank you.
Hatboy is offline
post #2726 of 2850 Old 08-11-2011, 07:19 AM
junyab's Avatar
I have an Onkyo 706 receiver with video problems.
Any video source (TV, PS3, BR Player) that runs through the receiver (via HDMI) while it is on shows as a foggy/fuzzy/white/washed out picture. I can kind of see the screen behind the fogginess, but can't really make the picture out.
If I turn the receiver off, the picture still seems to be able pass through the receiver and comes out clean.
I tried switching out the HDMI cables, but to no avail.
Is this the same kind of HMDI board failure others have experienced? I ask because this fogginess seems to be a different symptom than the video/audio cutting out sporadically.
junyab is offline
post #2727 of 2850 Old 08-11-2011, 08:19 AM
Quoted: 76 Post(s)
Liked: 58
You might try a hard reset.
Unfortunately, it sounds like it may need to be serviced.
post #2728 of 2850 Old 08-22-2011, 02:09 PM
junyab's Avatar
Hard reset worked! *phew*
Thanks WTF!
junyab is offline
post #2729 of 2850 Old 08-22-2011, 02:14 PM
Quoted: 76 Post(s)
Liked: 58
Thanks WTF!
Sure - no problem.
Enjoy.
post #2730 of 2850 Old 08-31-2011, 10:27 AM
moverdear's Avatar
Is there a way for me to update the firmware on the ONKYO TX-SR706? I had my LCD go bad, and when they replaced the main board, it had a newer version of firmware on it. My ONKYO has problems with that version and they told me I can not go back on the TV. Was wondering if I could try and update the ONKYO.
thx
UPDATE: I guess I should specify what issue I am having. It started out that the video would go away on the TV and not come back. The audio stayed on. I would have to turn the TV off for a few minutes and then it would work again. Did this a lot. After the power supply was replaced, same thing. Switched the main board on the TV and it fixed it, but created a hand shake problem. The video will go away for about 5 seconds and then come back. So, was wanting to update firmware if possible.
moverdear is offline
Onkyo , Onkyo Tx Sr706 7 1 Channel Home Theater Receiver Black , Onkyo Tx Sr605 Receiver , Toshiba , Toshiba 52hm84 120 Watt Tv Lamp Replacement
