The "official" The Onkyo TX-SR706 Owners Thread - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2821 of 2850 Old 11-08-2013, 07:46 AM
peter273's Avatar
For what it's worth, and if not described here earlier (didn't go through all 94 pages of postings here, sorry):
My tx-sr706 lost HDMI completely after about 4 years of flawless operation, no earlier warning signs, just gave up from one day to the next.
All audio was still ok (is going over optical input), though intermittent if a hdmi plug was still inserted in the activated (selected) channel.
I saw several threads of other types of receivers suffering the same, if not intermittent or temperature related, and several mentioning capacitors on the HDMI board.
The intermittent sound (if HDMI plug inserted) together with the posts on other types I saw made me assume the HDMI chips were still ok, and intermittently and briefly recognized the HDMI signals but mostly failed due to too much noise on the boards supply voltages.
What I did to solve it:
Replaced many of the surface mount capacitors with same capacitance "through hole" types (leaded types) 5000H/105°C low ESR, some with slightly higher voltage types.
All runs smooth again.
Be very aware: if not having soldering experience it's very easy to damage the board while removing the smd capacitors!
Also, soldering leaded capacitors on smd pads requires at least soldering experience and a steady hand.
Keep an eye on replacement capacitors diameter, if the replacement is "too fat" it might get difficult to get it on the board next to other parts. That's why I also put the diameters in my listing below (column "dia").
Don't worry about jacket color or things like that, just try and find 105°C low ESR type capacitors. Most manufacturers make them and they cost next to nothing.
I selected 5000H types (5000hours) since by experience it looked about right to me, but I know you can even find 20.000H types too which are of course more expensive.
Selecting 2000H/105°C types will also do the trick just fine, but they may/will fail somewhat sooner in the future.
Keep an open eye on polarity!
The top of the SMD types is blackened on the "minus" side, and leaded capacitors usually have the shortest lead and a fat white or black line on their "minus" side.
Now why didn't I replace SMD capacitors with SMD capacitors?
Simple: when removing the onboard capacitors you'll soon notice the leads for them are mostly UNDER the capacitor, making removal a tedious job and soldering new ones practically impossible.
Using wired types (leaded types) facilitates soldering alot, because you can leave 1-2mm underneath while re-soldering them on the SMD pads.
Make sure you can tilt the capacitors to a flat onboard position afterwards, not to exceed the available space above and especially below the board.
Best tips to give:
- take your time
- use a temperature controlled soldering station
- make sure to take proper precautions with respect to static electricity by grounding the soldering iron to the HDMI-board
The list of capacitors I replaced:
The 5 first columns is mostly information directly out of the service manual I found on the net some time ago, see link at the end in this post
The only columns of real interest to you are the first column and the last three columns : which capacitor, where is it situated on the HDMI board, what max diameter, and what replacement value I used.
Code:
silkscreen      description     part n°       elco marking     schematicvalue   location   dia(mm) new type
c8602           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           top        5       100uF/10V
c7204           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           top        5       100uF/10V
c7304           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           top        5       100uF/10V
c3302           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           top        5       100uF/10V
c8043           CEWX4V-220M     3981G2217R2     c3-220-4v       220/4           top        6       220uF/10V
c3477           CEWX4V-220M     3981G2217R2     c3-220-4v       220/4           top        6       220uF/10V
c7206           CEWX4V-220M     3981G2217R2     c3-220-4v       220/4           top        6       220uF/10V
c3577           CEWX4V-220M     3981G2217R2     c3-220-4v       220/4           top        6       220uF/10V
c7306           CEWX4V-220M     3981G2217R2     c3-220-4v       220/4           top        6       220uF/10V
c8956           UCD1A471MNL1GS  396634717R2     c2-470a-cd      470/10          top        8       470uF/10V
c8957           UCD1A471MNL1GS  396634717R2     c2-470a-cd      470/10          top        8       470uF/10V
c8958           UCD1A471MNL1GS  396634717R2     c2-470a-cd      470/10          top        8       470uF/10V
c8994           UCD1E221MNL1GS  396652217R2     y2-220e-cd      220/25          top        8       220uF/25V
c8995           UCD1E221MNL1GS  396652217R2     y2-220e-cd      220/25          top        8       220uF/25V
c8996           UCD1E221MNL1GS  396652217R2     y2-220e-cd      220/25          top        8       220uF/25V
c8041           CEWX16V-100M    398141017R2     c4-100-16v      100/16          bottom     6       100uF/25V
c8024           CEWX16V-100M    398141017R2     c4-100-16v      100/16          bottom     6       100uF/25V
c8021           CEWX16V-100M    398141017R2     c4-100-16v      100/16          bottom     6       100uF/25V
c8328           CEWX16V-22M     398142207R2     c4-22-16v       22/16           bottom     5       22uF/25V
c8675           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c8162           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c8607           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c8609           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c8023           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c8919           CEWX4V-100M     398141017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c3502           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c3402           CEWX4V-100M     3981G1017R2     c3-100-4v       100/4           bottom     5       100uF/10V
c8443           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c8026           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c8044           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c8605           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c3505           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c3584           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c3405           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c3484           CEWX4V-220M     3981G2217R2     c4-220-4v       220/4           bottom     6       220uF/10V
c8099           CEWX50V-2.2M    398180227R2     y4-2.2-50v      105z            bottom     3       2.2uF/50V
The cost of it all? About 50 dollar alltogether, including shipment (yes, I payed way too much for the components, but I wanted to get them really fast biggrin.gif ).
Replacing them all only took me a couple of hours of intensive work, but taking a whole day pays off if you need it so don't worry about taking your time. Just being very carefull not to damage the HDMI board is the main concern here.
And yes, I did take the trouble of replacing the larger power supply capacitors c8956-c8957-c8958 and c8994-c8995-c8996 just to make sure, since if those aren't good any more then replacing smaller capacitors further down in the circuit will not do the trick to solve any problem whatsoever.
Another thing I noticed:
On the power amplifier cooling fin a small ventilator is mounted, it is connected to connector P4501 on the board just below the HDMI board.
This fan is controlled by the onboard microprocessor and a couple of transistors.
This fan points generally in the right direction to generate at least some air circulation on the HDMI board.
Given the fact the receiver runs fairly hot, and capacitor problems are (too often) caused by running them too hot over long time, it might be a good idea to have the fan run continuously.
This can easily be done by short-circuiting switching transistor Q4502 collector to emitter. The transistor is type 2SA950-Y, data sheets for it are all over internet.
If not sure which transistor pad is what, try and find capacitor C4502, remove it and just connect (short circuit) both pads (C4502 is placed directly over collector-emitter of Q4502)
Q4502 and C4502 are located only few centimeters away from connector P4501, so they should be fairly easy to find.
Or if not willing to run the fan at continuously full speed, try and experiment some by placing a resistor over C4502 until you find the right/acceptable speed for the fan.
The service manuals consist of 2 parts.
The service manual can be downloaded at
part 1
http://www.4shared.com/office/Us6fbaCd/onkyo_tx-sr706_sa706_sm_1_1.html
part 2
http://www.4shared.com/office/DwFUNlX8/onkyo_tx-sr706_sa706_sm_2.html
and
part 1
http://elektrotanya.com/onkyo_tx-sa706_sr706_sm_1.pdf/download.html
part 2
http://elektrotanya.com/onkyo_tx-sa706_sr706_sm_2.pdf/download.html
If the links on this page doesn't work (for instance due to ad-blockers or due to the fact this forum somehow garbles it when calling it), then just copy it as text and paste it in your browser addres line.
greetz
gtlmp01 likes this.
peter273 is offline
post #2822 of 2850 Old 11-19-2013, 07:35 PM
Scolar Visari's Avatar
Can some of ya'll help me with a  decision...
Our tx sr 706 is at the repair shop (certified & seems like good dudes), they told me the board needed replaced and the cost would run $369.  The replacement board from Onkyo would be better than the original.  Ok so am I better off repairing it or buying a new receiver.  I guess I'm asking is it worth saving at that price?
Scolar Visari is offline
post #2823 of 2850 Old 11-19-2013, 09:25 PM
djPerfectTrip's Avatar
Liked: 29
^^^Personally I would say it's not worth it. This thing is 5+ years old and was only like $600 back then iirc... You could probably get something equal or maybe even better for that price, especially with black Friday/cyber Monday around the corner.
Looks like this happened with mine too. I can get it to work by unplugging the hdmi and plugging back in and turning the PS3 off and on a couple times. Huge Bummer as this thing has been going good for quite some time. Luckily I don't really need this avrs hdmi in/out as its only on bedroom duty and I only have one thing to hook in, but still super lame =^/
Turn it up!
djPerfectTrip is offline
post #2824 of 2850 Old 11-20-2013, 10:08 AM
Yeah that's how I feel, but I don't have much of an idea how long a repaired unit could go on.  An extra $300 is worth a little effort.
post #2825 of 2850 Old 02-27-2014, 10:47 AM
ksmit011's Avatar
My 706 just bit the dust slowly over the last week or so....HDMI inputs began showing "no signal" so I am pretty sure it is the well know HDMI board failure. The only service center in OH. is about 40 miles away.....called them and they said they should be able to replace the board and upgrade the firmware if required for less than $100 so I sent to them today. Will see what they come back with on cost estimate....if more than $250 I will probably have them scrap it and look for a new receiver. As this problem has now become very wide spread I think ONKYO should make an effort to compensate buyers for a obviously flawed design....a rec. that list for $899 MSRP should not be failing in only 4 years in my opinion. Really doubt I will buy ONKYO for my next receiver.
ksmit011 is offline
post #2826 of 2850 Old 08-04-2014, 01:30 AM
peter273's Avatar
I agree with you ksmit, onkyo shoudn't fail after only a few years of domestic operation.
Therefor I just abandoned my unit, kicked it as far as it would fly since a couple of days ago the unit died on me (again), despite all my repair efforts earlier, including addition of a continuous air flow to keep things cool. Repairing it just postponed its death.
No more onkyo for me, that's something I'm very sure of.
Bought me a Pioneer VSX-S510K now, way cheaper and works just as well for what is needed here.
peter273 is offline
post #2827 of 2850 Old 08-04-2014, 09:16 PM
All4Tone's Avatar
FWIW, I had my HDMI problem fixed a few years ago now and the unit is working perfectly. It was the cheapest way out, because any other unit I would buy would be way more, or not have some of the features of this one. Haven't heard too much about the newer Onkyos being problematic, but this unit had a crappy HDMI board from the start. Once replaced, no problems. I'd buy another Onkyo in a heartbeat, but I sort of have my sights set on an Elite, next time around..
All4Tone is offline
post #2828 of 2850 Old 08-11-2014, 07:53 AM
swechsler's Avatar
New owner of a used 706 here. Purchased off Craigslist for $50. Thought I had gotten a good deal (even though it didn't come with a remote - but I'm using the one from my old 705), but it's running very hot, and even when it's off it uses a lot of power - too much for even my power sensing power strip to deal with when set on its highest setting. You can even feel the heat coming off it when it's off - I haven't looked that closely at it, but the heat seems to be emanating from the right rear of the top panel. So far everything else works except for the volume control knob (not a big deal since who uses the front panel?).
Any ideas?
"When everyone's out to get you, paranoia is just good thinking"
-- Dr. Johnny Fever
swechsler is offline
post #2829 of 2850 Old 11-30-2014, 09:34 AM
jlm86's Avatar
Quoted: 24 Post(s)
Favorite settings..
Using ps3 for stream and playback..
Hsu vt15" subwooofer
Bitstream to onkyo..
What are your favorite settings?
Audio
Movies
Especially Audyssey, Dynamic settings..
jlm86 is offline
post #2830 of 2850 Old 04-09-2015, 02:16 PM
CO_Bear's Avatar
Originally Posted by CHRyan77 View Post
Yes - this has been happening to me for the past couple of months. It happens every time I turn it on. It is like it makes these digi-pops while it is warming up. Have you found a solution to this yet? Thanks!<br><br><br><br><div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>lowcel</strong> <a href="/forum/post/21119116"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
Has anyone had a problem with their 706 popping and cracking through the speakers when it comes on? I am also getting a delay for the sound and the video to turn on after turning on the 706. Sometimes it takes as long as five minutes to "turn on" after turning the power on.<br><br>
I get the problem using both my ps3 and my satellite receiver.</div>
</div>
<br>
After 6 years and 2 months my Onkyo TX-SR706 also has the crackling and popping issue when I turn it on. Has anyone had their TX-SR706 repaired with this problem? If yes, at what cost?
The last time it happened it powered itself off and when I unplugged it and plugged it back in the volume was cranked way up on all the speakers. I just bought a pair of Klipsh R-26F speakers and I don't want them blown out by a faulty receiver.
Repair or pull the plug?
CO_Bear is offline
post #2831 of 2850 Old 04-17-2015, 03:48 PM
sandworms's Avatar
Quoted: 17 Post(s)
I'm looking to find anybody willing to do the capacitor repair on my hdmi board. I have removed it and can ship it anywhere and pay for your time and parts bill. Right now it's a boat anchor , so please help
sandworms is offline
post #2832 of 2850 Old 04-28-2015, 09:08 AM
Liked: 0
Can anyone help provide me with a link for the service manual (TX-SR706) ? Seems like all links are down.
Also, I'm about to re-cap my TX-SR706 and i noticed, in one of the youtube videos, it doesn't look like the guy removed the legs and he just soldered on the top of the board, instead of removing the legs and going through the board, which the latter is the correct way, yes ? Seems like it would be a lot easier to leave them in, though and if people have had success with doing it that way, should i do it. Thanks
SQL1 is offline
post #2833 of 2850 Old 05-05-2015, 11:20 AM
Liked: 0
Nevermind, The second set of links work fine... It was an error on my end.
SQL1 is offline
post #2834 of 2850 Old 06-01-2015, 06:58 AM
gossamer88's Avatar
Quoted: 112 Post(s)
Liked: 65
I have the SANUS ELM501 All-In-One IR Repeater. I use it to control the Onkyo with the sender placed in front of the Onkyo IR sensor.
Problem is that it is hit and miss. I recently noticed that the Onkyo has a IR input on the back.
Will getting a 3.5mm to 3.5mm male cable work better since the Sanus has additional outputs?
gossamer88 is offline
post #2835 of 2850 Old 06-01-2015, 07:32 AM
swechsler's Avatar
Would love to know if that works. I have an old Harmony remote (890, I think) with RF to IR bridge and I'd like to be able to control the Onkyo directly rather than gluing a sensor to the front.
-- Dr. Johnny Fever
post #2836 of 2850 Old 06-07-2015, 12:13 PM
gossamer88's Avatar
Quoted: 112 Post(s)
Liked: 65
Got the cable and installed earlier today. Works like a charm and feels more responsive!
post #2837 of 2850 Old 07-31-2015, 12:07 PM
Liked: 0
Inherited a SR 706 from a friend
The HDMI was not putting out any picture. I ended up doing what another had posted and replaced some capacitors on the HDMI board. Quick and easy. 10 caps, an hour tops of carefully soldering with a giant soldering iron not meant for such applications but I managed. Works like a charm now! Looking for new speakers since the bose speaker system it came with sounds crappy and the sub is not working. Looking at used Monitor 70s from POLK. Anyone have thoughts?
Michael Bender 2 is offline
post #2838 of 2850 Old 08-04-2015, 09:45 PM
Liked: 29
What would this be worth to sell with the HDMI going out? Worth trying to sell or just toss it? I'm not handy with a soldering iron...
Turn it up!
post #2839 of 2850 Old 01-21-2016, 12:45 PM
devo235's Avatar
Extract L+R Audio from HDMI source
Anyone know if it's possible to extract to L+R audio signal from an HDMI source? I'd like to do it through either the TAPE or VCR/DVR "out" on the 706. The intention is to extract the signal via RCA cables, input it into a mixer, and send it back to the 706 via RCA cables to the TAPE or VCR/DVR "in".
Thoughts or workarounds?
Cheers.
devo235 is offline
post #2840 of 2850 Old 01-21-2016, 01:02 PM
swechsler's Avatar
Pretty sure you can't do this. For one, the receiver probably has no ability to send the L/R signal to the tape out jacks, and even if it did, the tape selector is not a tape monitor like you'd find in older equipment. This means that if you switch the input to tape to listen to the mixer's output you've no longer selected the HDMI source.
I think any options would require additional equipment. One way would be to connect the front preamp outputs to a mixer input, and then feed the mixer's output to a separate power amp. A second method would be using an HDMI switcher with an analog output, like this, but then you'd have to send the HDMI directly to your video display, since you couldn't use the receivers HDMI switching while you're listening to the tape monitor, as I mentioned above.
-- Dr. Johnny Fever
post #2841 of 2850 Old 01-21-2016, 01:33 PM
devo235's Avatar
Thanks for the quick reply.
Couple things:
a) I'm already sending 5 channels to my Emotiva XPA-5 using the preouts. Would putting a mixer in between the the 706 and the Emotiva cause and issues? Audyssey?
b) we know the 706 has the ability to have two simultaneous sources playing at the same time (1 audio, 1 video). Let's say I connected my HDMI source to IN 2 (VCR/DVR), then OUT via RCA cables from VCR/DVR ---[RCA]---> Mixer ---[RCA]---> IN VCR/DVR. Any thoughts on why that might or might not work? Is the bigger issue actually getting the audio signal from the HDMI source?
Thanks again.
devo235 is offline
post #2842 of 2850 Old 01-21-2016, 01:39 PM
swechsler's Avatar
I think you're still not going to be able to get the HDMI L/R audio into the tape outputs. This is directly from the manual:
Audio equipment can be connected to the AV
receiver/AV amplifier by using any of the following
audio connection formats: analog, optical,
coaxial, analog multichannel, or HDMI.
When choosing a connection format, bear in
mind that the AV receiver/AV amplifier does not
convert digital input signals for analog line outputs
and vice versa. For example, audio signals
connected to an optical or coaxial digital input
are not output by the analog TAPE OUT.
How about using the Zone 2 preouts as inputs to the mixer?
-- Dr. Johnny Fever
post #2843 of 2850 Old 01-21-2016, 01:52 PM
devo235's Avatar
What would that setup look like?
So, the HDMI source (audio & video) is going into HDMI IN 2 on the back, preouts from Zone 2 L+R to the mixer, then mixer RCA outs to TAPE IN. Select IN 2 for initial source, turn on Zone 2, select TAPE. Would that play both sources out of the same front L & R speakers? Am I missing something in the setup?
Sorry, I just got off a 15+hr flight, so I'm a bit hazy.
devo235 is offline
post #2844 of 2850 Old 01-21-2016, 03:29 PM
swechsler's Avatar
Hmm, come to think of it, I don't know if you'd be able to do it even using Zone 2. Problem is, if you set a particular input (let's say DVD) to use analog audio in and HDMI video in, that's the same for both zones, so you've effectively lost the HDMI audio. If you keep the HDMI audio then you have no way to mix in the analog left/right.
I think you're going to need the sort of device I linked to above, that lets you extract analog audio from an HDMI signal.
-- Dr. Johnny Fever
post #2845 of 2850 Old 01-21-2016, 05:54 PM
devo235's Avatar
That's unfortunate. I was hoping to get this done without needing to purchase any other components. If you can think of any other way, please let me know. I'm going to sleep on it to see if there is any other workaround solution.
Cheers!
devo235 is offline
post #2846 of 2850 Old 01-22-2016, 07:22 AM
devo235's Avatar
So I've got a couple options after looking into it. First two will require a purchase:
1. http://www.newegg.ca/Product/Product...9SIA9M93GM1207
or
2. http://store.singtronic.com/maromapr60mi.html
Seems like the cheaper option is number one, but I'm a bit concerned at build quality, and overall "cheapness" of the entire product. Mixed reviews, some love it, some say it's garbage. Option two seems like an obvious better build, but waiting to see if shipping to Canada is viable.
Option 3 is me using an old PS3 I already have, with this guy: http://www.monoprice.com/product?p_id=6884 (already own), send the HDMI video from the PS3 straight to the 706, optical out from PS3-----> D to A Audio Converter----->RCA L+R to 706, and assign the inputs correctly.
Think it will work? Thoughts? Will attempt when I get a chance after work today or tomorrow.
devo235 is offline
post #2847 of 2850 Old 02-15-2016, 07:49 PM
Liked: 0
I recently reinstalled my surround system with the SR-706 . When I turn the power on I get the second "click" and the speaker icons lights up but there is a LOT of static .. I can hear the audio that should be coming out and its faint over the static. I have checked on all inputs and I get the same thing. I have read posts about the caps going bad on the HDMI board but my problem doesn't seem to fit. Does anyone have an idea what could be the cause of the problem? One thing I do have to note is that when I had the system up last time I had gotten a very loud "scratchy-pop" from all of the speakers ... it was very rare to happen . I hope someone knows the cause to the problem ... I don't really have the money to drop on a new system.
Ingeld is offline
post #2848 of 2850 Old 03-18-2016, 06:37 PM
Liked: 0
Damaged HDMI board?
Hello,
I'm looking for a bit of help/advice. My 607 hasn't had an OSD for years now, but everything else worked as far as I could tell. I tried the resets etc that onkyo runs thru on their tech support without success. Emboldened by my recent repair of a samsung tv, I thought I'd give this an attempt at repairing before it quits on me. I removed the board, decided to only replace the 470 uf caps first and then test to see if it was a success before continuing. I replaced all 470 uf caps with the same cap regardless of whether the original was a smd or not. After replacing the caps, I plugged everything back in and I now receive no signal, even after a reset of the receiver. I fear I damaged the board while attempting repair. I created a spreadsheet of all the parts I planned to replace, and its replacement, which is linked below. I tried to include photos, but they were too large in size, so I linked the photo folder below as well. I doubled checked that the polarity is correct, and as far as I can tell it is. I re-soldered some of the joints, and replaced one cap off the board due to my iron touching its casing.
I'm not really sure what to do next besides ordering another broken board, and trying again. Thanks in advance for any help I receive.
parts
https://drive.google.com/open?id=0B71LyeHWsxt0X2toY3RCbERKdVE
photos
https://drive.google.com/open?id=0B71LyeHWsxt0ZmNwanBKNjBWTUE
TTan is offline
post #2849 of 2850 Old 03-18-2016, 08:00 PM
Liked: 0
Originally Posted by TTan View Post
Hello,
parts
photos
I'm not sure how/if its possible to edit my prior post. I thought I add more info, so that if someone doesn't have excel, they can still know what I'm talking about.
This is the replacement capacitor. Spec wise it seemed alright, but If I am wrong, please let me know.
digikey part # 732-9174-1-ND
CAP 470 UF 20% 25 V
Below is my purchase order from digikey.
Index,Quantity,Part Number,Description,Customer Reference,Available Quantity,Backorder Quantity,Unit Price USD,Extended Price USD,
1,15,732-9174-1-ND,CAP 470 UF 20% 25 V,,15,0,0.57000,8.55,
2,10,1189-1546-1-ND,CAP ALUM 220UF 20% 16V RADIAL,,10,0,0.28000,2.80,
3,10,1189-2195-ND,CAP ALUM 100UF 20% 16V RADIAL,,10,0,0.17900,1.79,
4,3,732-8279-1-ND,CAP 22 UF 20% 6.3 V,,3,0,0.19000,0.57,
Is there a way to rule out a dead/damaged board? Thanks again
TTan is offline
post #2850 of 2850 Old 03-26-2016, 10:57 AM
Liked: 0
CAP 470 UF 20% 25 V
I purchased a damaged replacement board, and the first thing I noticed is that there is an extra cable in the middle of the hdmi that isn't present on the original. Anyone know what this is intended for? Thanks!
TTan is offline
Onkyo , Onkyo Tx Sr706 7 1 Channel Home Theater Receiver Black , Onkyo Tx Sr605 Receiver , Toshiba , Toshiba 52hm84 120 Watt Tv Lamp Replacement
