NAD M15HD Surround Sound Processor - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Old 04-02-2011, 09:39 AM
markabuckley's Avatar
Quoted: 95 Post(s)
Liked: 33
I know this is the M15HD thread - but I guess a lot of you owners on here may have had a M15 previously - would you say a M15 is still a good 2nd hand bet if you don't mind missing out on HD-audio ? just I was offered one 2nd hand for 20% of the cost of a M15HD (about 900 dollars)
I was having a look at the service manuals for both varients that I found online and both look equisitly built - very high specced parts in both cases I thought
markabuckley is offline
Old 04-02-2011, 01:06 PM
ddingle's Avatar
Quoted: 43 Post(s)
I would buy the Am200 upgrade board. Around $1000 as I recall. So for $1900 or so you can own the noticeably better sounding M15HD.
ddingle is offline
Old 04-02-2011, 02:05 PM
Quoted: 95 Post(s)
Liked: 33
^^ thanks for advice unfortunately I don't think that card is compatible with M15
but I have seen a cheap ex-dem NAD 765 - which does take that card, and I've seen the upgrade card as cheap as 500 dollars !
anyway after finding AVS archive forum I've now discounted the M15 - to my sadness as hadn't realised tone control was only for L/R speakers, resets to 0 on power on, and lip-sync settings aren't saved - too quirky for me for everyday use in my system unfortunately
Old 04-21-2011, 04:01 PM
Lic265's Avatar
Does this do HDMI 1.4 ? Cannot find on the NAD website
Lic265 is offline
Old 04-22-2011, 03:46 AM
iNetRunner's Avatar
Quoted: 12 Post(s)
No. 1.3 only at the moment - also not sure about extended color spaces.
But since it uses MDC construction (though not compatible with other NAD pruducts) it will be updated to 1.4... Someday. Good luck getting any information about schedules or future features/products from NAD. About as easy as getting information out of a black hole..
iNetRunner is offline
Old 05-11-2011, 01:25 PM
Lic265's Avatar
I am going to purchase the m15HD. I have the Rotel 1095 200 x 5 amplifier, but have expanded to a 7.1 setup. Would anyone use the Nad M3 to drive the front 2 speakers ( B and W 803's) and the Rotel for the center and surround? Or just go with the NAD M25 ?
Not sure why the M3 is 3K and the M25 is 3.5K list, given the specs
G
Lic265 is offline
Old 05-11-2011, 02:50 PM
jbua5150's Avatar
I would buy the M25. Just a cleaner look. If u listen to alot of two channel music then there may be an advantage to getting the M3.
jbua5150 is offline
Old 05-11-2011, 03:39 PM
golfugh's Avatar
If it were me and IMO, and the funds are not an issue and like mentioned by jbua (2 channel is important to you), then I'd use the M3 for the fronts, keep the Rotel for center and surrounds.
This would allow you to have a dedicated 2 channel setup, realizing you can't use the A-Pro in the M15HD for 2-channel in that case.
Additionally the M25 is a great amp, so can't go wrong either way.
golfugh is offline
Old 05-11-2011, 10:38 PM
astep's Avatar
G
M3 has a preamp built in, hence the price. As for the SQ, both ways are great. I use M25 for both music and movies and it sounds excellent. But if I were you, I would prabably buy M3 for the fronts which may or may not be slightly better for music but I am sure it will not be worse.
astep is offline
Old 05-16-2011, 12:52 AM
astep's Avatar
Do you people know if M15HD is able to process Full range RGB input over HDMI? It seems to me that it clips blacks and whites when fed with full range RGB thinking it is RGB limited. Any info on that?
astep is offline
Old 05-17-2011, 07:05 PM
Lic265's Avatar
If my laptop has an HDMI port, can i run it to the M15 to display via a projector?
Lic265 is offline
Old 05-17-2011, 10:18 PM
astep's Avatar
Yes, you can.
astep is offline
Old 05-18-2011, 12:19 AM
Quoted: 1393 Post(s)
Liked: 587
Lic265....which laptop??
JimP is offline
Old 05-18-2011, 06:02 AM
Lic265's Avatar
It is a HP elitebook 8350 running windows 7.
Lic265 is offline
Old 05-18-2011, 06:34 AM
Liked: 587
It is an output port so should be able to be fed through the prepro onto your projector.
Only question in my mind has to do with handshake issues.
This is probably one of those you've got to try it to find out.
JimP is offline
Old 05-24-2011, 11:25 AM
astep's Avatar
For those who are interested. I was told by NAD support that they are going to release video module upgrade for M15HD before fall 2011. I suppose it will be HDMI 1.4 with 3D.
astep is offline
Old 05-24-2011, 07:43 PM
jbua5150's Avatar
Who at NAD support told you this?
jbua5150 is offline
Old 05-27-2011, 03:17 PM
ddingle's Avatar
Quoted: 43 Post(s)
Can anyone tell me what the latest firmware version is for the M15HD?
ddingle is offline
Old 05-29-2011, 07:57 AM
Rybner's Avatar
@ddingle
I have updated my M15HD firmware in March 2011.
This is the firmware versions after the update:
MCU 1.10
VXP 1.00
Video 1.04
DSP 1.04b
To display the current software version on your M15HD press Source Left + Source Right simultaneously, use Source Left or Right to browse.
You can ask NAD support if they have a newer version, they have answered my questions within 48 hours.
Best regards / J. Rybner
Rybner is offline
Old 05-30-2011, 11:56 AM
jbua5150's Avatar
No response as to who at NAD support told you this?
jbua5150 is offline
Old 05-30-2011, 07:54 PM
ddingle's Avatar
Quoted: 43 Post(s)
Originally Posted by Rybner View Post
@ddingle
MCU 1.10
VXP 1.00
Video 1.04
DSP 1.04b
Thanks! I am pretty sure we need to update.
ddingle is offline
Old 05-30-2011, 07:58 PM
ddingle's Avatar
Quoted: 43 Post(s)
I am hoping NAD can convert the M15HD to Audyssey 32bit equalization. There isnt any bandwidth limitation,but the 32bit version has 2 woofer outs with independent equalization for both. That requires another circuit path. Thats a little more than a firmware update!
ddingle is offline
Old 08-04-2011, 06:50 AM
bisterfinnen's Avatar
M15HD2 on the way?!
Found a pdf sheet in french when i googled for M15HD2, not so detailed though...
bisterfinnen is offline
Old 08-04-2011, 10:07 AM
schwaggy's Avatar
Originally Posted by bisterfinnen View Post
M15HD2 on the way?!
Looks like they've added 3D video support. Other than that, I can't see any other significant new features.
schwaggy is offline
Old 08-04-2011, 01:42 PM
I think that pdf is old. From what i've heard the M15HD2 has:
3D support
HDMI 1.4 (audio return channel)
7 HDMI inputs
2 HDMI outputs
Old 08-05-2011, 06:09 AM
iNetRunner's Avatar
Quoted: 12 Post(s)
bisterfinnen: That pdf actually does not appear old. The file says it has been created 2011-07-20, though this does not of course say for sure that the pdf was constructed then - only the file-stamp is from that day. Also the web site in question appears to be a new NAD distributor that has started to carry the brand only quite recently. (If I understand, via Google Translate, that this happened on 2011-03-07.)
Anyway, according to the pdf in question the only difference that I can see against the M15HD as we know it, is that it looks to support HDMI 1.4. All other specs, connectors etc. look to be the same.
It really is surprising how long it has taken NAD to make any MDC modules to M15HD. Details about them where "published" or alluded to in Home Cinema Choice review in August 2010.
Old 08-19-2011, 09:14 AM
big_himey's Avatar
big_himey is offline
Old 08-19-2011, 11:37 AM
ddingle's Avatar
Quoted: 43 Post(s)
There are currenty no M15HDs available from NAD. At least that is the information I got. I am suspicious they will show a new M15 at CEDIA. I am hoping it has XT32 Audyssey along with the board upgrades.
ddingle is offline
Old 08-19-2011, 12:51 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
yeah, NAD places much emphasis on the "upgrade-ability" of their latest-generation (MDC) home theater receivers and processors in most of their advertisements, while at the same time it has taken them [years] to get this new hardware functional. However I'm glad to see they are finally releasing new MDC product (hopefully it works as designed)
WestCoastD is offline
Old 08-20-2011, 04:10 AM
iNetRunner's Avatar
Quoted: 12 Post(s)
Originally Posted by big_himey
Finally! Features look just about perfect too. Very nice!
Hopefully it works stright off the bat, doesn't cost too much.. =)
Nad
