"Official" Onkyo TX-SR806 Reciever thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
post #1831 of 1857 Old 04-28-2014, 12:09 PM
SergioElChingon's Avatar
Dr.2K, did you ever get your receiver fixed? If so what did you end up doing?
SergioElChingon is offline
post #1832 of 1857 Old 04-28-2014, 05:27 PM
Dr.2K's Avatar
What I ended up doing was replacing ALL the 22u capacitors as well about 13 100u capacitors (I looked closer and I did find the rest of the 100u's). However, it did not work and I also do not have audio anymore as well. I am going to just go ahead and replace the unit with a new receiver. I don't want to waste anymore time on this fix. I do appreciate everyone's posts in this thread as the was a great learning experience!
Dr.2K is offline
post #1833 of 1857 Old 05-05-2014, 11:48 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
Uggghhh... My son's perfectly functioning 806 went up in flames (literally!) yesterday dues to an errant screw piercing the SR speaker cable.  Now it fires up with normal display for about 10 seconds then goes into protection mode.
That's the bad news... the silver lining is that I have been seriously contemplating an upgrade to my (also perfectly functioning) 876, so now I have more incentive knowing that the 876 might have a good home as a replacement for his 806.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #1834 of 1857 Old 05-05-2014, 09:48 PM
HerbieK's Avatar
Here is my "Official" TX-SR806 tale of woe:
I bought my 806 in December of 2009 from Crutchfield. Right away I gave up trying to use the HDMI switching as my Motorola STB did not like it and the signal would be fine for about 10 minutes, then nothing. After a couple of hours with Comcast techs, I was told the box had compatibility issues with Onkyo and to run the HDMI directly to the TV so that the signal would be "purer". So much for upscaling! I was able to connect my Sony Bluray through the 806 and this allowed me to do on-screen setup. After reading about the HDMI failures due to heat, I installed cooling fans at the unit and at an exhaust vent in the cabinet. All was well until I decided to go to a Samsung Plasma Smart TV.
The move required a whole new approach, since to use the apps on the TV you had to bring the audio back to the receiver. I ran digital audio out from the TV to the 806. That worked like a champ and I was a happy camper. I had to rewire the front right speaker, and after doing so I decided to recalibrate the 7.1 setup with the Audessey microphone. It completed the calculations and showed no subwoofer installed. Wrong!
I pulled the subwoofer cable from the receiver and when I did, it hummed, telling me that the subwoofer and cable were operating. I went into the setup menu and manually turned the subwoofer back on, then turned up the gain to +12db and did a speaker check. Nothing.
So now I am totally bummed. I planned to upgrade this receiver next year as I am not impressed with the 828 (a step backwards from the 818). I want to get a feel for the 838 before seriously considering it. As an alternative I am looking at the Yamaha lineup of 9.2 models, such as the 2020 or 2030, Which would give me comparable power, but perhaps better reliability.
In the meantime, I need to try to get the subwoofer out jack to work so I don't have to listen to sound that reminds me of cheap TV speakers. My question is this: Have any other 806 owners experienced a similar problem, and if so, were you able to correct it?
I hope so. Otherwise I have a 40lb. boat anchor.
HerbieK is offline
post #1835 of 1857 Old 05-06-2014, 04:27 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
This may or may not apply to your 806, but it's free and relatively easy enough to try...
Twice in the 5 years I've had it, my 876 has had it's center channel output go away.  In both cases, doing a factory reset restored the center channel output.  You'll have to redo your Audyssey setup, and reconfigure any listening mode presets, input reassignments or input labels you had.  Also, it's a good idea to disconnect the unit from AC power for a minute or so both before and after the factory reset.
With just about any misbehaving piece of microprocessor controlled electronics these days, a factory reset should always be tried before relegating it to boat anchor status.
Good Luck!
post #1836 of 1857 Old 05-06-2014, 06:02 AM
HerbieK's Avatar
I will certainly try to do a reset, but I'm not sure how to do it other than unplugging the receiver and reconnecting it. Has anyone done a factory reset on the 806?
HerbieK is offline
post #1837 of 1857 Old 05-06-2014, 10:43 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
806 Manual... Page 117 "Troubleshooting":
...again, no guarantees... but if you have tried everything else and are about to give up, it can't hurt to try.
post #1838 of 1857 Old 05-06-2014, 11:23 AM
HerbieK's Avatar
Thanks for the info. Did the factory reset and unfortunately, it did not restore the subwoofer output. Any other ideas?
HerbieK is offline
post #1839 of 1857 Old 05-08-2014, 09:14 PM
HerbieK's Avatar
Solved the problem with a pair of pliers.
I tested the cable, but not the connector. After giving up and ordering a Yamaha RX-A3030 as a last resort I took a pair of electrician pliers and gently clamped the ground ears on the connector. I fired it up and away it went. Now I have a perfectly good 806 with nowhere to go. It's always the simplest thing, go figure! :)
HerbieK is offline
post #1840 of 1857 Old 05-16-2014, 06:38 PM
Peteybob35's Avatar
Quoted: 12 Post(s)
I tested the cable, but not the connector. After giving up and ordering a Yamaha RX-A3030 as a last resort I took a pair of electrician pliers and gently clamped the ground ears on the connector. I fired it up and away it went. Now I have a perfectly good 806 with nowhere to go. It's always the simplest thing, go figure! smile.gif
My subwoofer not working was one of the first symptoms of my 806 needing the capacitors replaced. Eventually the sub would hardly ever work and then the receiver would send static and crazy signals through all the speakers and the sub, scared the crap out of my wife and kids when it would do it in the middle of the night if I forgot to turn it off. All the problems went away after I replaced the capacitors. I hadn't soldered anything since high school, but it was easier than expected, only took about 45 minutes. If your sub starts not working you may want to look into replacing those. It also solved my HDMI issues.
Stu
Peteybob35 is online now
post #1841 of 1857 Old 05-30-2014, 05:03 AM
juancaca's Avatar
Hi Guys,
My AV is not passing the HDMI signal when the device is in standby it has to be on. Is there any way to do a firmware update?
TIA
juancaca is offline
post #1842 of 1857 Old 12-17-2014, 06:52 PM
voldo37's Avatar
I apologize if this has been addressed in another reply but I haven't read all 1800+ messages yet. Yesterday my 806 started exhibiting popping and static noise through the speakers when it is first turned on. It usually lasts for about a minute and then goes away. Any thoughts on what is going on?? Will this just get worse until it dies?
Also, I would like to know the answer to juancaca's question about whether this receiver will pass the hdmi signal through to the tv if the receiver is off and in standby mode?? Seems like I saw one post that said it would but when I first got the receiver I could never get that to work.
voldo37 is offline
post #1843 of 1857 Old 03-25-2015, 11:34 PM
Quoted: 23 Post(s)
Hi All
Would $75 be a good buy for this receiver?
It seems to pack some punch
Seller says it works "fine"
All animals are equal, but some are more equal than others
nextgenfmradio is offline
post #1844 of 1857 Old 03-26-2015, 05:13 AM
TonysDesigns's Avatar
Originally Posted by nextgenfmradio View Post
Hi All
I have this receiver and it works great!
Tony
3MultiMedia.com
Lead Project Manager
@www.MakeupTalk.com
TonysDesigns is offline
post #1845 of 1857 Old 03-26-2015, 07:38 AM
Quoted: 23 Post(s)
I know it doesn't have the fancy IIz height features or atoms and wireless capabilities
post #1846 of 1857 Old 05-25-2015, 08:32 PM
blastermaster's Avatar
Quoted: 498 Post(s)
Liked: 625
If you're using it strictly for sound, go for it. It has a lot of power. If you also are using it for video, then I'd pass. I have had nothing but problems with my 806 from day one from a visual standpoint. First was the blue dots which, fortunately, was fixed via warranty. After getting it back and setting the video to "passthrough" I still get an image that is vastly different from plugging in directly to my video source. Yes, the Onkyo will fiddle with, fondle with, and ultimately molest your video image in a way that is completely unacceptable. Passthrough my @$$.
blastermaster is offline
post #1847 of 1857 Old 06-24-2015, 10:25 AM
Liked: 0
As someone who has owned this received from not long after is came out, I would avoid it at all cost. At this point I would avoid onkyo at all cost.
From the blue dot issue ( that i told them how to reproduce ) to now, the HDMI board has completely failed.
I went back and forth with there tech support for months after buying that receiver before anything was straitened out. Even Jack Cooper blew me off who is still listed on the Better Business Bureau web site, according to the emails going back and forth with him he is the National Service Manager. The place I bought it from would only replace it and not return it unfortunately.
jedaon29 is offline
post #1848 of 1857 Old 06-24-2015, 01:38 PM
advan24r's Avatar
Should I be hunting for a new receiver now? My no signal errors are becoming irritating. It occurs after long duration of it being on, then when I power it off and on again is when the NO SIGNAL happens.
advan24r is offline
post #1849 of 1857 Old 06-25-2015, 06:30 AM
Liked: 0
I would start hunting for a new receiver.
Mine worked fine for years but the last few months I would try and switch to different inputs and it would be no signal. It started out that the apple tv and xbox 360 wouldn't work, it would be hit or miss on certain days.
Then the last month or so when I turned everything on it would just be no signal on the tv. But if I turned the receiver off then back on it would start working for the rest of the night as long as it wasn't shut off.
Then 2 days ago nothing was working as far as HDMI. I just tested it with an iPod connected to it and it works for sound, just no video signal.
I am going with Denon this time around. After the experience I had with onkyo I wouldn't give them any more money. The first 6-8 months of owning this receiver I didn't even have it in my possession. I exchange the first one I received since onkyo didn't know anything about the blue dot issue. Sent the second one to them for evaluation, they replaced parts in it but when I received it back it still had the blue dot issue. Then after going back and forth with them and doing my own testing with 3 different tvs / different HDMI cables and the same issue still present with a playstation 3 1080P @60hz. They were finally able to reproduce it, then I had to send it off to my local authorized onkyo repair shop.
Horrible experience all around.
jedaon29 is offline
post #1850 of 1857 Old 09-22-2015, 06:04 PM
jon604's Avatar
My 806 display on the receiver is not turning on but everything is working fine. Is there a switch that turns off the display or am I Iooking at a costly repair?
jon604 is offline
post #1851 of 1857 Old 09-23-2015, 03:41 AM
wtxgringo's Avatar
Quoted: 53 Post(s)
Liked: 64
Bottom left of remote is "Dimmer", try that.
"To the journey..."
Sony KDL60W630B; Onkyo TX-NR818
Polk RTi A7 Mains; Polk RTi CSi A6 Center; Polk RTi A5 Wides & Surrounds
HSU VTF2-Mk4, Dish Network 722k, Iogear WiFi Hub
Teac PD-H600; Marantz BD7004;
Orbit TT Red Plinth, Acrylic Platter, Ortofon OM 5E Cartridge
wtxgringo is offline
post #1852 of 1857 Old 10-19-2015, 01:04 PM
Liked: 0
TX-SR806 volume problem
I see a local posting for one of these units on CL, asking price $75. Seller says "Preamp section not working. Goes to full volume output after warming up.". I've Googled this issue a bit and have found no references to that sort of problem with any receiver. I suggested to the seller that he do a factory reset, but I don't know if he took my advice. I presume since it's still being listed he either didn't try or it didn't work. Anybody heard of an issue like that? I know you can pre-set the power-on volume to maximum, but a factory reset should fix that.
10ears is offline
post #1853 of 1857 Old 03-17-2016, 05:57 AM
Liked: 0
Hello,
I'm having an issue with this receiver. Even if it's in standby mode, it loses its settings after a few days.
I know they have a capacitor (or supercapacitor) that holds the memory, but I can't find it in the schematic.
Did anyone have the same problem?
bogdan2011 is offline
post #1854 of 1857 Old 02-02-2017, 11:20 PM
wilkcards's Avatar
So, does the newest apple tv, chromecast, or amazon fire stick work with the HDMI inputs on these? I'm attempting to repair the HDMI board and have replaced 5 of the capacitors (only bought pack of 5) and now HDMI is only working for my xbox 360. I'm just wondering if anyone is using these devices successfully with this receiver or if they just don't work.
wilkcards is offline
post #1855 of 1857 Old 02-03-2017, 10:04 AM
trabbic's Avatar
I use a Chromcast with my 806 and it works fine. Sounds like you have other issues.
Did you try the xbox on all the inputs?
trabbic is offline
post #1856 of 1857 Old 02-03-2017, 10:14 AM
dduff617's Avatar
i successfully used appleTV's gen2 and gen3 for years with my old 806.
eventually started having HDMI problems. replaced some capacitors and got another 6-9 months of use out of it before i finally gave up. eventually moved on and bought a newer model receiver.
dduff617 is offline
post #1857 of 1857 Old 02-04-2017, 09:13 PM
wilkcards's Avatar
Yes, it works on all inputs. I think I will replace more capacitors and see what happens.
