The Official Integra DHC-9.9 Pre/Pro - Page 97 - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2010, 04:46 PM
MrHifi's Avatar
The 9.9 does not communicate well with many HDMI devices. It is a fact of life.
Art Neill
a.k.a.
Mr. HiFi
MrHifi is offline
Kal Rubinson's Avatar
Quoted: 690 Post(s)
Liked: 471
That's a surprise since my 9.8 seems to be compatible with everything I've tried. Of course, you seem to be more critical than I am.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 02-15-2010, 05:52 AM
MrHifi's Avatar
Perhaps I am more critical Kal but when a piece of gear does not function when connected to another, this is not a matter of criticality but rather a question of functionality. The 9.9, as wonderful as it is and as beautiful as the music that comes out of it is, sometimes interacts in an unexpected manner with attached devices. My latest "problematic" connection is with a Brite View HD transmitter/receiver. It sends HD material from one location to another wirelessly. It works perfectly when the source device (like a cable box or HD DVD player) is plugged in directly to the Brite View's HDMI input. Unfortunately, when the signal is routed though the 9.9, a "Format" error light appears on the Brite View. Brite View Engineers are baffled by this and said they would try to obtain a 9.9 and test the device. I have also experienced incompatibility issues with my LG LST-3410A's causing me to bypass the 9.9's video section. These issues are only present when connecting digitally.
Just to be clear...I love my 9.9 but it does have connectivity issues due to the HDCP albatross that is part of our digital world.
Art Neill
a.k.a.
Mr. HiFi
MrHifi is offline
Old 02-15-2010, 01:30 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 37
Originally Posted by nater View Post
A few work arounds you might try have to do with the HDMI interface. In my system I have compromised with fixed output from the Tivo to the 9.9 and from the 9.9 to my display device. In an ideal world where the HDMI interface was as predictable as the com-posit (more accurate in HDMI but not unstable) then one could choose a combination that delivered the best picture. In my case this results in a picture that looks less than ideal. If i have a priogram that I want to display in the best manner I have to go into both the TIVO, and 9.9 and the panel or projector to set up this. In most cases I just tolerate the poor display rather than take the time to change the settings each time. Unfortunately I have found that the HDMI blinks off then on then off several times when the TIVO or the 9.9 changes the resolution. There may be something wrong with your unit but there should be a combination that results in a stable picture.
What firmware? I did extensive testing on 1.01, 1.04, and 1.05 and found the 1.04 most stable. Also reading on platform sibling groups for the PR-SC886P, TX-NR876, and TX-NR906 and on the "Onkyo/Integra Direct Firmware Updates" groups i found that several users recommend the 1.04 as the most stable across platforms.
Major issues like blinking, blue screens, "Unrecognized Resolution" with 480i to HDMI upconverts with 1.05 on both my TX-NR906 (Wii) and DHC-9.9 (Escient), gone with 1.04.
FYI i run my DHC-9.9 on Onkyo PR-SC886P firmware without a glitch, as 1.04 for the 9.9 has been deleted from Gurkey's link.
Hope this helps.
bobpaule is offline
Old 02-18-2010, 03:06 PM
Rudy81's Avatar
Is there a way to use a/the digital output of the DHC 9.9 while still allowing the use of the Integra's volume control? I am actively filtering my speakers and use the Behringer DCX2496, which has a digital input. I would like to be able to use the DCX's digital input so as to avoid a double AD/DA conversion.
Ideas?
Rudy81
Rudy81 is offline
Old 02-20-2010, 07:54 AM
martinoo's Avatar
I had HDMI communication issues with my new Panasonic G10 Plasma. On checking the Panny website I found a firmware upgrade address in "HDMI issues with Integra processers". I downloaded to an SD card...plugged in to the TV..an bingo..they have had a beautiful relationship ever since.
Check the websites or email the companies of your other components, maybe they have a fix too.
Martin
martinoo is offline
Old 02-20-2010, 08:16 AM
martinoo's Avatar
I was considering connecting my 9.9 to a wireless bridge via ethernet. However I am reconsidering based on the fact the unit in itself does not stream any web content.
I do not see any firmware upgrades on the Integra site.I f there are any updates, can those be installed via this hookup?...I am interested to hear from folks...this is a simple question...any feedback is appreciated.
Martin
martinoo is offline
Old 02-20-2010, 10:05 AM
alanl715's Avatar
updates are via the rs232 on the rear via your desktop or laptop...fyi the only FW upgrade on this unit was on 1/23/09.
alanl715 is offline
Old 02-20-2010, 09:54 PM
tzucc's Avatar
Just installed a DHC 9.9. Hooked it up to Sony BluRay with MJ's "This is It", which says that it has DTH Master HD audio.
I have HDMI from Bluray player to the 9.9, select HDMI as the digital audio input. No other cables from the Bluray to the 9.9, other than HDMI. I hear audio just fine.
However, on the status display of the 9.9, I see "Multich" as the audio format, cycling through the status, I see it's 48kHz PCM. Well if it's 7 channels of 48kHz PCM, that sure seems like DTS HD audio, is it not?
If this is DTS HD audio I am getting, then why isn't there a nice little indicator on the DHC 9.9 to tell me it's getting DTS HD audio? Or am I not getting the right audio stream from the Bluray disc (there are no options to select audio formats.... ).
THoughts?
rotary subwoofer install blog ultimate subwoofer install : http://bassment.wordpress.com/ ... c
tzucc is offline
Old 02-21-2010, 05:38 AM
12nrow's Avatar
THoughts?
Same thing happened to me , on my sony make sure you have it set to bitstream, and if yours has BDaudio settings set it to direct you should see dts master light up on your 9.9
12nrow is offline
Old 02-21-2010, 03:36 PM
tzucc's Avatar
thanks, fiddled with a few settings in the audio area and got the DTS-HD to light up. Not sure the audio quality is noticeably different than sending the PCM over...
tzucc is offline
Old 02-26-2010, 05:13 AM
RoboRay's Avatar
If there is any quality difference, something is broken.
RoboRay is offline
Old 03-02-2010, 01:29 AM
gamelover360's Avatar
The ISF settings seem to make no difference in the picture......am I missing something here? Thanks
gamelover360 is offline
Old 03-03-2010, 07:21 AM
luketo's Avatar
Need help guys...How do I get the most out of my music with my DHC 9.9. I have a BDP-83 blu-ray player. Whats the best hook up?
luketo is offline
Old 03-03-2010, 08:13 AM
getech's Avatar
I would suggest HDMI between the two and use the decoding from the OPPO which I believe has better DAC's than the Integra.
getech is offline
Old 03-03-2010, 08:17 AM
getech's Avatar
Another option.....use two RCA stereo cables from the OPPO to the Integra and use direct or pure stereo for music from your two front mains. The other option is if you use SACD or DVD-A cd's you'll want to switch back to the HDMI for all channel decoding.
getech is offline
Old 03-03-2010, 09:18 AM
luketo's Avatar
Thanks getech.....I'll try both to see which sounds best.
luketo is offline
Old 03-06-2010, 07:40 AM
James Elvick's Avatar
Hey Guys,
Looking for a Integra DHC 9.9 to buy, send me a PM if you have one for sale or know where I can still buy one.
James
James Elvick is offline
Old 03-11-2010, 11:28 AM
I just found out that Dolby Late Night Function is set to auto with Dolby sources (True HD for example). You must turn it to off while playing a Dolby audio track. Then when you turn the pre pro off....it defaults back to auto again. So you may be listening to dolby audio tracks with late night mode engaged.
It is a form of dynamic compression.
Old 03-11-2010, 12:43 PM
Bill Mac's Avatar
Quoted: 1293 Post(s)
Liked: 1487
It is true that it defaults to the auto setting for TrueHD tracks. But when in the auto mode TrueHD tracks do not automatically switch the Late Night function to on. The setting for TrueHD is based on the source material. One BR that switched to on was the early releases of Iron Man. Not sure if any recent TrueHD BR releases have this issue as Iron Man did which was corrected in later releases.
When I watched TrueHD tracks with my 886 I always turned the Late Night feature to off as it was easy to do with the discrete code on my Harmony 688. Other wise it is a pain going into the menu of the 886/9.9 to do this everytime you play a BR with a TrueHD track. With DD or DD+ tracks you have to engage the Late Night feature as the default is off. So there is no need to worry about it coming on by default.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 03-12-2010, 12:35 AM
Baci's Avatar
I have just bought my 9.9 - I'm a late starter! One observation I have is that the volume control is not particularly sensitive (this applies to the remote as well as the knob on the front of the unit). It makes it slow and annoying to adjust the sound level quickly. I've had a quick hunt through this forum but have not seen this addressed anywhere. Does anyone have a workaround?
Baci is offline
Old 03-12-2010, 05:07 AM
RoboRay's Avatar
Hold the button down?
RoboRay is offline
Old 03-12-2010, 05:28 AM
MrHifi's Avatar
The analog amps and preamps I've used have all had logarithmic tapers. Is that the case here? I am quite happy with it but just curious.
Art Neill
a.k.a.
Mr. HiFi
MrHifi is offline
Old 03-12-2010, 05:55 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 108
Doesn't help users of "older" Onkyo/Integra gear, but the current generation added support for a second IR "fast volume" command that runs in 1dB increments instead of the .5dB increments that the standard volume commands use.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
Old 03-12-2010, 03:06 PM
Baci's Avatar
"Older gear" Eek!
Yep, I'm holding the button down a lot and the volume just creeps up or down. Checked the menus but certainly nothing there. I haven't actually sat down and tried this, but my guess is that it would be about 4 complete rotations of the front volume knob to run through the full volume range. If this was typical of the 9.9 others would have commented on it. It's a bit frustrating!
Thanks for your responses so far, though.
Baci is offline
Old 03-12-2010, 03:33 PM
alanl715's Avatar
Originally Posted by Baci View Post
"Older gear" Eek!
call Integra cust svc 800-225-1946....open SAT/Sun 11-3 est
alanl715 is offline
Old 03-12-2010, 04:18 PM
RoboRay's Avatar
I have the 885, but I imagine the volume control works pretty much the same as the 9.9. How big are the adjustments you need to commonly make?
If it's when switching between sources that have radically different output levels, you can adjust input level trims in the pre-amp setup menus to compensate for that, so that all of your sources are at about the same level. I rarely touch my volume buttons other than to make minor adjustments in the 1 or 2 dB range, unless I put in some media recorded at an odd level.
RoboRay is offline
Old 03-12-2010, 04:48 PM
Bill Mac's Avatar
Liked: 1487
I have the 886 and the volume level changes quickly with no ill effects.
Bill
Bill Mac is offline
Old 03-13-2010, 11:49 AM
Baci's Avatar
OK - thanks for your replies. I'm in Australia, but I'll drop their support staff an email.
Just as a supplementary question, when using the FM tuner nothing comes out my surround speakers when I'm using a surround mode like Neo 6 or THX. Got me baffled! The speakers are connected and do work for All Channel Stereo mode. Have I set something up wrong?
Baci is offline
Old 03-13-2010, 12:21 PM
LarryChanin's Avatar
Hi,
Perhaps you may be expecting those matrix surround processes to more aggressively extract content to the surrounds than they are capable of delivering.
Temporarily turn off the front speakers and see if you hear anything coming from the surrounds.
Larry
LarryChanin is offline
