12v Triggers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-12-2008, 08:02 PM - Thread Starter
akopperl's Avatar
Quoted: 42 Post(s)
I have two external amps that I would like to turn on using their 12v trigger capability. Unfortunately, my receiver does not have any 12v triggers to activate the amps. Is there any reasonably priced, easy to use device that I can use as a trigger for the amps?
akopperl is online now
post #2 of 5 Old 09-12-2008, 08:56 PM
RoboRay's Avatar
If your receiver has a switched power outlet in the back that's only activated when the receiver is turned on, you can probably rig up something using an AC to 12VDC converter from Radio Shack.
RoboRay is offline
post #3 of 5 Old 09-23-2008, 10:01 AM - Thread Starter
akopperl's Avatar
Quoted: 42 Post(s)
The amp I want to trigger on does not accept a plug. There is a connection on the back for bare wire with one slot for + (positive) and one for - (negative).
If I purchased a 500mA AC to 12VDC Adapter from Radio Shack, can I cut the wire and hook it up to the +/- on my amp? How would I know what wire to connect to the positive and which to the negative? Also, is 500mA safe?
post #4 of 5 Old 09-23-2008, 10:17 AM
skrubol's Avatar
Generally the positive side of the wire will have a stripe on it (assuming it's a figure-8 type wire, and not a cable made of 2 individual wires in a sheath.) You might want to pick up a cheap multimeter so you can test stuff like this.
500mA should be fine, as that's just the maximum current it can provide. I wouldn't think the trigger port would pull much. One other thing you might want to get a meter for is to test the open circuit voltage of the adapter you pick up. Some are very poorly regulated, and with very light loads may be considerably higher than 12v.
skrubol is offline
post #5 of 5 Old 09-23-2008, 10:58 AM
mdk2007's Avatar
whats the best way to set-up a trigger from the receiver to the amp? given they both have the outlets....
mdk2007 is offline
