HDMI Video With Optical Audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-16-2008, 04:42 PM - Thread Starter
Oneirolux's Avatar
I'm looking for a new receiver, possibly a Denon 1709 or 1909. I have one basic question... can I have it play audio from an optical source while playing video from an HDMI source (that is not providing audio)?
The main reason is because I use my computer for HTPC gaming in addition to a cable box and PS3 that would be hooked up to the receiver. On the PC I am using DVI + HDMI adapter for video, with Optical audio. This has worked well for me and I don't see why I should change it. However, on my TV it's annoying to cycle through all the different video sources when I switch between PC and cable/PS3, it switches very slowly. I'd like to have everything run through a receiver so the TV only has to deal with one input, as it's easier to switch through things using a receiver.
thanks
Oneirolux is offline
post #2 of 6 Old 09-16-2008, 05:01 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
That would work, hopefully. On my receiver, I can independently select the audio and video inputs associated with each source selection. I am not sure how Denon's routing options works though.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 6 Old 09-16-2008, 05:43 PM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
Not necessarily answering your specific question, but FYI - the 1709 doesn't do ANY audio over HDMI so you wouldn't get lossless sound on the PS3. If you want HDMI audio from the PS3 you need the 1909/789 at a minimum.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4 of 6 Old 09-16-2008, 06:05 PM - Thread Starter
Oneirolux's Avatar
Good point on the 1709, thanks. So... that means I could still use optical audio while watching video from an HDMI input, right?
post #5 of 6 Old 09-16-2008, 06:21 PM
batpig's Avatar
Liked: 3420
correct....
however, you would have to do the same thing with the PS3 also, anything you want with HDMI would have to have a separate audio cable, and there aren't THAT many optical inputs on the back... trust me, if you have a PS3 you definitely want to step up to the 1909/789.
Setup Guide and FAQ
batpig is offline
post #6 of 6 Old 09-16-2008, 09:39 PM - Thread Starter
Oneirolux's Avatar
cool... that's fine.... what I really was after was making sure I could properly use my PC/PS3 on atleast the 1909/789 using HDMI for video while the audio was coming through optical.
thanks!
