The "Official" Onkyo TX-SR876 Owners Thread - Page 169 - AVS Forum
post #5041 of 5068 Old 02-11-2014, 01:54 PM
thebuzzer's Avatar
also what baud rate should i be using?
thebuzzer is offline
post #5042 of 5068 Old 02-14-2014, 11:34 AM
TStreet's Avatar
Hello,
My 876 is not sending audio to the left front channel. I have swapped out speakers and cables, and done a factory reset... still no sound on left channel.
Any ideas on what would cause this issue?
Sorry if this has been covered before, but a search didn't yield any relevant results.
Thanks for the assistance.
TStreet is offline
post #5043 of 5068 Old 03-09-2014, 07:41 AM
eaayoung's Avatar
Quoted: 23 Post(s)
Liked: 50
Here's a Youtube video on repairing a Onkyo 606 HDMI board. Excellent video on how to repair the board and the techniques to use. Repairs to a 876 will be somewhat different, especially the number and location of the capacitors compared to a 606 HDMI board. But, shows how easy it is to make the repair.
eaayoung is offline
post #5044 of 5068 Old 03-22-2014, 08:25 AM
siggy11's Avatar
Originally Posted by krahulec View Post
Were you able to fix your problem? Our power went out last night, and when power came back on, the sound no longer worked. I get the same uninformative DSP1st ?????? ?????? in Debug mode.
Krahulec, I have the same issue after a power outage. My 876 has no audio and it displays DSP1st ?????? ??????. Did you managed reinstall the DSP firmware? Have you been able to find a solution?
siggy11 is offline
post #5045 of 5068 Old 03-30-2014, 12:49 PM
crakarjax's Avatar
Quoted: 37 Post(s)
I purchased my 876 second hand, and noticed that the HDMI switching is much slower than on my 607 -- can some of those who bought it new comment on whether this is normal or is it due to capacitor deterioration on the HDMI board? I replaced all the 100uf caps but of course the others could be bad as well.
crakarjax is offline
post #5046 of 5068 Old 03-30-2014, 01:10 PM
audio4life's Avatar
Liked: 67
I can say that my 876 has never been fast, an HDMI handshake takes up to 8 seconds.
audio4life is online now
post #5047 of 5068 Old 03-30-2014, 08:43 PM
eaayoung's Avatar
Quoted: 23 Post(s)
Liked: 50
Mine is about the same.
eaayoung is offline
post #5048 of 5068 Old 03-31-2014, 10:56 AM
crakarjax's Avatar
Quoted: 37 Post(s)
Thanks guys, no need for me to fiddle with it then! A minor annoyance but one that I can live with.
post #5049 of 5068 Old 04-07-2014, 03:33 PM
Alexandro77's Avatar
Dear all,
I have an Onkyo 876. All of a sudden lost all connectivity to HDMI ports while I still have OSD visualized on the TV .
There are no "clicks" from the relay, while I switch between the different ports and "No signal" is displayed.
The 100mf capacitors were exchanged as described. Unfortunately this brought no results.
What may I try next? There is no official Onkyo support in my area.
Thanks for your help in advance.
Alexandro77 is offline
post #5050 of 5068 Old 04-28-2014, 05:58 AM
mrbeevers's Avatar
Anyone able to help with this?
Hi new user and need help if possible?
My HDMI board of my 876 has been acting oddly takes ages to sync video and occasionally I get sparklies then the output goes to just a noisy grey screen so I have to switch inputs or turn amp off and on.
Anyhow I decided to change the caps to see if that would work and in my haste I've managed to lift the tags from the board with the old cap so now have nowhere to solder to (yes I feel a complete fool) is there anywhere I could solder another one to or make a repair or have I just broken it?
The cap taken off is on input 1, it still works but there is video noise on the picture.
Hopefully
mrbeevers is offline
post #5051 of 5068 Old 04-28-2014, 06:43 AM
crakarjax's Avatar
Quoted: 37 Post(s)
You can probably just scrape the top of the trace past where you lifted it and solder to that. A pic would help greatly with the assessment.
post #5052 of 5068 Old 04-28-2014, 08:50 AM
mrbeevers's Avatar
Thanks for replying, will get a photo up when I get home.
Here's a picture of my stupidity
and now I'm at work with a good magnifying lens and the zoomed in picture I've fixed it.
post #5053 of 5068 Old 04-29-2014, 06:11 PM
bmoorhouse's Avatar
I have an Onkyo 876 that I bought a few years ago. This summer I am moving from the US to Europe. Will the Onkyo work over there if I use an adapter for the plug? How about the speakers? If the Onkyo will not work overseas, would the speakers work with a european AV receiver?
bmoorhouse is offline
post #5054 of 5068 Old 04-30-2014, 04:02 AM
mrbeevers's Avatar
IIRC the amps are not multi voltage so yours will be 110v only.
I'm based in Europe but work world wide and carry one of these with me which would work for you http://salestores.com/powerb41.html#.U2DVZeZdVUs as would this http://salestores.com/powerb33.html#.U2DV5OZdVUs only thing I don't know if it would work would be the HD radio tuner.
Speakers will be fine with a European amp
post #5055 of 5068 Old 05-01-2014, 06:21 PM
bmoorhouse's Avatar
Thank you for the response. Looking at the links you provided, they appear to only have one 110V output. Would I be able to plug a standard US pronged, six plug power strip into it and connect more than one device to the transformer?
In a perfect world, I would plug in the following...
1. Onkyo 876
2. Samsung 40" LCD
3. Toshiba HD-A2 HD-DVD Player
4. Infinity 10" sub
Obviously, I would need to confirm the combined wattage is less than the wattage provided by the transformer.
Thanks for the advice.
post #5056 of 5068 Old 05-02-2014, 01:46 AM
mrbeevers's Avatar
1. Onkyo 876
2. Samsung 40" LCD
4. Infinity 10" sub
You could and as you pointed out you would have to look at the combined wattage, I use the one in the first link which has a little grub screw for bringing the voltage up if needed.
You would need to check that your TV is multi region too in that after a factory reset it will tune to the frequencies of the european country your going to but I would advise to get a european model as it will work over all of europe if you move around plus they'll generally play NTSC material.
post #5057 of 5068 Old 06-09-2014, 09:18 AM
aharami's Avatar
My 876's front left channel is not working. Anyone manage to repair it themselves? Wondering how hard it is. I'm fairly proficient at soldering. Just need to know what/how to fix. Thanks.
aharami is offline
post #5058 of 5068 Old 06-20-2014, 12:15 PM
Kermee's Avatar
I apologize in bringing up an old thread, but looking for some information for my Onkyo TX-SR876 that has been rocking since 2008 when I purchased it 'Open Box' from Newegg.com...
#1 . What is the latest firmwares for the TX-SR876 and would anyone be able to point me to them? I believe it's 1.07 and since I haven't updated it since I received the unit back in 2008, also looking through the thread it looks like I need to update to at least 1.04/1.05 before updating to 1.07.
#2 . There has been no firmware update that allows HDMI 1.4 (3D) to work through the HDMI switcher. Correct?
Thanks in advance!
Cheers,
Kermee
Cheers, Kermee
Kermee is offline
post #5059 of 5068 Old 06-29-2014, 08:41 AM
dea
dea's Avatar
Thanks for that link, I replaced all of my 876's 100uf caps with 105C rated 100F10V ones and it works flawlessly again. No longer waiting for hours to be able to get image through HDMI, it is instant as it should be.
dea is offline
post #5060 of 5068 Old 06-29-2014, 10:41 AM
eaayoung's Avatar
Quoted: 23 Post(s)
Liked: 50
Glad it helped. I'm lucky..., my 876 is continues to work as designed. But, I'll probably need repair it one day.
eaayoung is offline
post #5061 of 5068 Old 07-04-2014, 07:20 AM
hdmi4ever's Avatar
I've had an Onkyo 876 for a few years and now I'm looking into buying a projector. I intend to connect it to the HDMI-SUB output of the Onkyo.
Is there a discrete command for switching HDMI outputs with a single button press? Currently the only way I know to switch outputs is to go through the menus with several button presses, and having to power on the TV first so I can navigate the menus.
hdmi4ever is online now
post #5062 of 5068 Old 07-04-2014, 12:33 PM
jcalabria's Avatar
Liked: 34
Absolutely... along with dozens of other discrete commands not available with the OE remote. I attached the Onkyo spreadsheet with the discrete Pronto hex codes at the bottom of the post you can find here:
Onkyo PR-SC886P Pre/Pro Official thread
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.2.0_11
jcalabria is offline
post #5063 of 5068 Old 07-05-2014, 06:55 PM
hdmi4ever's Avatar
From that thread, it appears that you got the Harmony folks to include those codes in their database, including the HDMI Out switching. Is that correct?
I don't have a Harmony remote, but was planning on buying one now that my old remote by URC is frustratingly flaky. If they really have a discrete HDMI Out selection in their database for the Onkyo 876 and it is available to the under-$100 Harmony remotes, problem solved.
post #5064 of 5068 Old 07-06-2014, 08:50 AM
crakarjax's Avatar
Quoted: 37 Post(s)
Careful -- URC remotes are much more powerful, so be sure the Harmony provides the functionality that you currently have.
post #5065 of 5068 Old 07-06-2014, 10:34 AM
hdmi4ever's Avatar
I have all the remotes for my devices, and those remotes have all the important functions I want (except HDMI Out switching which isn't on the Onkyo remote), so as long as the Harmony can learn from existing remotes I should be fine as far as existing functionality is concerned.
It looks like the Harmony 650 has learning capability, and it's under $100, so it's at the top of my list right now.
post #5066 of 5068 Old 07-17-2014, 01:55 PM
Liked: 0
Hi All,
My 5 year old TX-SR 876 has been acting up. It doesn't seem to be exactly like the HDMI problems I've been reading, although it probably is the caps on the HDMI board. On occasion, the sound goes out. This is usually while watching TV, but that's because it's usually in that setting. At times hitting all the selections (tuner, DVD, Aux, etc.) will fix it. Sometimes just shutting it down and powering back up will do it. Not having HDMI handshake problems (long delays), just the usual few seconds to connect.
This weekend the sound was off and I couldn't get it to work. This was the longest stretch ever with no sound. I took the cover off just to see what everyone was talking about, but so no bulging caps at all on the HDMI board. I blew out the dust while I was at it. I also did a reset to no avail except make more work for myself.
Last night it all came on again and was fine for several late night viewing hours. Same this morning. I have left it on now for over 6 hours and it's still playing!
Yesterday I call Onkyo and they are saying it's not a known issue and suggested either I send it to the regional authorized repair center in Lincoln Park, NJ. (I live in NYC). All Tech is the repair center and they quoted $75 for the estimate (applied to repair if I choose to). It'll cost about $35 to ship UPS ground as this is about a 55 lbs unit. That's not including the box and packing material that I'll have to pay the UPS store to do. I don't own a car in NYC so I'd have to rent a car if I wanted to send it in person. They also told me that an HDMI board is about $500 for this receiver! If it's caps, it would of course be less.
The other option Onkyo offered is trading it in for a refurbished one.
Here are the prices for the refurb with trade in:
TX-NR 626 - $270
TX-NR 929 - $600
There's also the TX-NR 1010 and TX-NR 3030, at around $$900 and $1400; but I'm not sure exactly as I scribbled it down.
I would have to of course still ship my old unit to them at my cost. The units would have a warranty of either 1 or 2 years.
I haven't researched any receivers in 5 years and really don't want to spend too much time on it at this time.
I paid just under $1000 for the TX-SR 876 five years ago and don't know if the technology has gotten cheaper, or if the two units mentioned first would be a downgrade.
I also looked at the Sony STR-DN840 which Costco has for $369.99 with free shipping, although this unit doesn't have phono jacks.
What would you do? Your expert advice would be appreciated!
Fab
fabphil is offline
post #5067 of 5068 Old 07-17-2014, 03:54 PM
Jon S's Avatar
Quoted: 12 Post(s)
Liked: 41
I would seriously consider another brand over Onkyo... Every generation of Onkyo has been having some sort of widespread issue of one sort or another... Bad HDMI boards, bad IDE connectors, bad display boards... Buying another Onkyo would be a gamble right now. It appears Onkyo has been pushing newer models packed with features but sacrificing reliability.
Another issue is that Onkyo is no longer using Audyssey (sic?) to calibrate the surround sound channels. They are using their own calibration system to avoid paying royalties to Audyssey. To be fair, they are not the only ones; Pioneer uses MCACC, Yamaha uses YPAO, Sony uses their own unnamed one. I think only Denon and Marantz are the only big sellers that are still using Audyssey.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #5068 of 5068 Old Today, 08:17 AM
Liked: 0
Originally Posted by HighlandLassie View Post
I have fiddled with all of the options, and I can not get the 876 to play loudly.
It seems like it has half the power of my old Sony ES, that was only rated at 120 watts.
Will running Audyessy correct this issue?
The mic should arrive to do so today.
The on screen volume bar only goes 3/4 of the way up and stops at +10db
At full volume the unit gets slightly warm but will not get hot, so it is not putting out all of it's power it seems.
Really confused at why it does not go to full volume or even to a volume at which most would consider average for music.
I am running a Hafler amp in addition, to the front pre-outs, and it is working, but it too at a low output.
Not even sure how to set the maximum volume control setting to get full output..
Where should the speaker level calibrations be set?
This unit has so many features, some of which impede it's ability to do what it was designed to do.
From the manuel:
MAXIMIUM VOLUME
When the volume display setting is set to absolute, the maximum volume range is OFF, 99 to 50.
When it is set to Relative, the range is OFF, +17db to -32db.
To disable the setting select OFF.
Can someone translate that statement and advise how to set to be able to use full volume?
Very frustrated.
Any wise words appreciated,
Hey everyone, sorry to quote an old post but I too have an issue with my TX-SR876 producing very low volume. Currently in stereo mode as I'm in a new house and haven't run 7.1 yet. Just front towers and a sub. The chap I quoted simply reset his as it was a 2nd hand unit whereas mine is brand new out of box (sat in storage for 4-5 years )
When I play with db settings, the tone out of my JBL Studio 10 towers is very loud and my subwoofer literally shakes my house. However, when I watch tv or listen to music on my cable box I can literally crank it all the way to +4 and it doesn't produce anything like my Harman Kardon did. I couldn't hear lyrics over my wife's vaccuuming a couple of rooms away Is +4 the max volume, or is that where my problem lies?
I'm sure there is something I can do since this is quite a complex unit. I did use the Audyssey mic to set it up, can tell the receiver and my speakers are able to produce a lot of sound, and have checked my blu ray HDMI input and the output is also quiet.
Any help would be appreciated!
punkwax is offline
User Tag List
