The "Official" Onkyo TX-SR876 Owners Thread - Page 170 - AVS Forum
 1Likes
post #5071 of 5086 Old 07-25-2014, 06:14 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 604 Post(s)
Liked: 200
Originally Posted by punkwax View Post
Hey everyone, sorry to quote an old post but I too have an issue with my TX-SR876 producing very low volume. Currently in stereo mode as I'm in a new house and haven't run 7.1 yet. Just front towers and a sub. The chap I quoted simply reset his as it was a 2nd hand unit whereas mine is brand new out of box (sat in storage for 4-5 years )
When I play with db settings, the tone out of my JBL Studio 10 towers is very loud and my subwoofer literally shakes my house. However, when I watch tv or listen to music on my cable box I can literally crank it all the way to +4 and it doesn't produce anything like my Harman Kardon did. I couldn't hear lyrics over my wife's vaccuuming a couple of rooms away Is +4 the max volume, or is that where my problem lies?
I'm sure there is something I can do since this is quite a complex unit. I did use the Audyssey mic to set it up, can tell the receiver and my speakers are able to produce a lot of sound, and have checked my blu ray HDMI input and the output is also quiet.
Any help would be appreciated!
Some settings to check:
1. IntelliVolume - For your sources (each individual one): Page 110 in your manual.
2. Volume Setup (Volume Display - Muting Level - Maximum Volume): Page 115 in your manual.
3. Adjusting Speaker Levels: Page 71 from your manual.
4. Using the Late Night Function: Page 109 (manual).
(5) Rerun Audyssey.
* You couldn't hear lyrics...wife's vacuuming? --> An audio cable may be picking up interference.
Try re-positioning your cables.
Good luck & Bienvenu @ AVS Forum.
punkwax likes this.
NorthSky is online now
post #5072 of 5086 Old 07-26-2014, 11:43 AM
Liked: 0
Thank you for the reply.
Did all of those and while it helped a little, there is still no way I'm hearing what this receiver is capable of. As previously mentioned, my receiver maxes out at +4 and the manual says it should reach +18 - that said, I don't think the extra 14 is going to make a big difference..
There has to be something else I'm missing?? I wanna crank it up!
punkwax is offline
post #5073 of 5086 Old 07-26-2014, 05:10 PM
NorthSky's Avatar
Quoted: 604 Post(s)
Liked: 200
Rerun Audyssey. ...That's why your Relative Volume (Master Level) maxes out @ +4.0 dB instead of +18.0dB.
Audyssey right now in your 876 is most likely set to counter-balance the amount of +EQ it has done (in your previous place?).
You have to follow the Audyssey settings: proper mic positioning, subwoofer(s) level, etc. ...Many important rules to follow in order to get the best sound performance.
* When I had my 876 my max volume was about +11.0dB, but I was never going over +3.0dB in normal listening.
Anyway check that, and if you have more to share that you forgot, it would help.
post #5074 of 5086 Old 07-27-2014, 07:45 AM
Liked: 0
Ok, I will run again for the 3rd time later today. I was following proper direction the other two times except for using a tripod as I dont have one. Just used a box to get proper height.
Not forgetting anything else, I opened the box for the first time the other day after sitting in storage so no prior settings to deal with.
Thanks again.
punkwax is offline
post #5075 of 5086 Old 07-28-2014, 07:54 AM
crakarjax's Avatar
Quoted: 41 Post(s)
There is a setting in your receiver for limiting the max volume. Perhaps it is set to +4?
crakarjax is offline
post #5076 of 5086 Old 07-28-2014, 01:09 PM
Jon S's Avatar
Quoted: 17 Post(s)
Liked: 42
Thanks again.
You should never put the mike on a box... The flat surface of the box will affect the acoustic Audyssey response big time in a bad way...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #5077 of 5086 Old 07-28-2014, 03:06 PM
NorthSky's Avatar
Quoted: 604 Post(s)
Liked: 200
Thanks again.
That's a problem for sure right there. Putting the mic on top of a box is not the proper way.
At the very least use a camera tripod, and a microphone stand is the very best for top measurement performance.
* A mic stand (with a boom); you can get for $15-25 only. ...Get one, it's worth it.
<<>> I am quite sure that using that box to put your mic on is your main issue. Please, correct that.
post #5078 of 5086 Old 07-29-2014, 08:23 PM
Liked: 0
Thanks all - I will invest in a tripod and update the thread.
Appreciate the feedback!
punkwax is offline
post #5079 of 5086 Old 08-13-2014, 06:08 PM
Liked: 0
Took a while (busy summer) but finally got the tripod and ran Audyssey again... it helped a little, volume can go to +11 but still not getting anywhere near the performance I would expect when cranked.
Read through NorthSky's response quickly the first time and didn't notice a mic boom is best. Will return the camera tripod and try that I suppose. Going to call Onkyo support first. My Harman Kardon is sitting in the garage.. don't want to give up on the Onkyo but this is getting a little silly!
punkwax is offline
post #5080 of 5086 Old 08-13-2014, 06:23 PM
NorthSky's Avatar
Quoted: 604 Post(s)
Liked: 200
Don't expect it to go above +11.0dB, it is perfectly normal. That's what pro EQ does. ..."Relative" volume.
Turn the Audyssey off and you're back to +18.0dB without any EQuing.
Check it out, but without the music playing, or when muting (full muting).
And yes, a mic stand with a boom, and the mic two or three inches above ear level is good for the soul of the music.
* The maximum reference master volume level (control) depends of your speaker's sensitivity, the music or movie medium/recording playing, the size of your room (total cubic space), the source playing, and all that jazz.
But as a good general rule, it is somewhere between minus 4dB and plus 4dB. ...Safe area too.
...Some stuff it could be a little more, but proceed with extreme caution.
post #5081 of 5086 Old 08-15-2014, 10:26 AM
aharami's Avatar
Originally Posted by aharami View Post
My 876's front left channel is not working. Anyone manage to repair it themselves? Wondering how hard it is. I'm fairly proficient at soldering. Just need to know what/how to fix. Thanks.
any thoughts on this? is this fixable?
aharami is offline
post #5082 of 5086 Old 08-19-2014, 10:14 PM
Tallen234's Avatar
I'm a six year owner of the 876 and it has run flawlessly until today. I was watching TV (though my xbox) when a loud pop rang out. The receiver turned off and the red (I believe it is the stand by) light started to blink. I was able to turn the receiver on and it is still able to pass through a video signal through all inputs, however there is no audio.
Any ideas?
Tallen234 is offline
post #5083 of 5086 Old 08-20-2014, 12:31 PM
audio4life's Avatar
Liked: 85
A loud pop commonly means a capacitor blew. Any smoke or smell? If it's just a cap it should be repairable by a reputable electronics service center. It'll cost you plenty though, might be time to consider upgrading?
audio4life is offline
post #5084 of 5086 Old 08-20-2014, 12:38 PM
Tallen234's Avatar
Thanks for the response! There was a Strange ozone type smell. I am definitely thinking of upgrading, prob to a x4000 or 929. The funny thing is that I bought the 876 right before the 1.4 hdmi spec and now I'm probably going to buy my next one before the 2.0 (2.2) upgrade.....
post #5085 of 5086 Old 08-20-2014, 02:58 PM
Tallen234's Avatar
I just did a factory reset with no joy. The strange thing is I can get a little but of audio out of the headphones, although I can't control it with the volume controls.
post #5086 of 5086 Old 08-20-2014, 03:18 PM
audio4life's Avatar
Liked: 85
One other thing, you might want to check the fuses, I think there's at least 5 of them. You'll have to take off the hood(9 screws, then pull the hood back 1/4 inch before lifting) and check the various boards. If you have some kind of meter, use the continuity test to see if there is an open on the fuse, some may be the solid type.
User Tag List
