The "Official" Onkyo TX-SR876 Owners Thread - Page 172 - AVS | Home Theater Discussions And Reviews
 1Likes
post #5131 of 5138 Unread 03-06-2015, 02:01 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 4408 Post(s)
Liked: 1719
Originally Posted by wadetm View Post
Does anyone have any experience with repairing/replacing the door on an Onkyo TX-SR876? I just received my with the door hinges broken...and I can't find any replacement parts? I have the PN's but can't find anyone that sells the hinges.
Terry
Tough one. I would call Onkyo to see if they can accommodate you, or @ least give you the right direction in locating replacement door hinges.
If you can find them, simply glue it there as you won't need those front controls if you have a remote control. ...Better yet, use velcro tape.
Or, just remove the door entirely, and your receiver will now look like an Integra one, from the upper echelon.
NorthSky is offline
post #5132 of 5138 Unread 03-24-2015, 07:14 PM
Liked: 0
HDMI Out failure
Both HDMI Main and Sub have failed, syncing previously took minutes and pushed to hours, now unable to sync at all. HDMI in 1,2,3 all produce sound... Suggestions?
jrgotoff is offline
post #5133 of 5138 Unread 03-24-2015, 10:10 PM
NorthSky's Avatar
Liked: 1719
Did you try a reset (page 142)? ...And page 146 first [The AV receiver contains a microcomputer ...]
* Me own suggestion: Unplug all connections, unplug the AC power cord, wait ten seconds, re-plug only one source connection (BR player), then AC power cord, then press the power button on your 876's front panel face.
If that doesn't work, do the reset (page 142).
If that also doesn't work, I would start all over again, but this time using one connection (one source) @ a time and verify with it, and using only one HDMI output (main), of course. ...So that way you keep everything simple, and go only with that. If it's not working for one source only connected (Blu-ray player), then no use to connect the rest; your 876 had it. /// Contact Onkyo, and see what kind of accommodation they can offer you responsibly and generously.
NorthSky is offline
post #5134 of 5138 Unread 03-26-2015, 06:18 AM
radamo's Avatar
Quoted: 81 Post(s)
Terry
I am looking for tips on this too. My clip that keeps the door shut broke and I am now using a piece of rubber to keep the door shut.
radamo is online now
post #5135 of 5138 Unread 04-04-2015, 08:39 PM
iceman3500's Avatar
My 876 conked out today. Video all works well, but no audio on any channel. Tried the soft boot, no luck, tried the factory reset, no luck. I'm in Canada and bought this new in 2009. There has never been any issues until now. I've never upgraded the firmware. Reading some of the previous posts, things don't look good. Any suggestions? Thanks.
iceman3500 is online now
post #5136 of 5138 Unread 04-04-2015, 09:45 PM
NorthSky's Avatar
Liked: 1719
Time for a new receiver, with Dolby Atmos and DTS:X ? ...They're coming up, later on this year.
* In the interim just use an older one you have, or buy a used cheap one for a couple clams. ...Or less.
NorthSky is offline
post #5137 of 5138 Unread 04-25-2015, 01:19 PM
Bill Ball's Avatar
Quoted: 76 Post(s)
Liked: 81
Another HDMI delayed handshake repair success that I reported on the 576/606 repair thread which provides the information you need to try this fix.
How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?)
Since I only replaced one cap (C8609) I wonder if that was the fix or rather it was just reseating the 4 electrical connectors. Anyway, it's working fine. Turned the system on again this morning and it sync'd up with the TV and cable box right away.
Bill Ball is offline
post #5138 of 5138 Unread 04-25-2015, 03:48 PM
NorthSky's Avatar
Liked: 1719
Cool.
* But you/we would gain more from posting in the dedicated thread, I think.
NorthSky is offline
