The "Official" Onkyo TX-SR876 Owners Thread - Page 174 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #5191 of 5212 Old 02-10-2016, 01:36 PM
audio4life's Avatar
Liked: 297
If that doesn't work, guys have had success in soldering caps of another value across several regulators. I can't remember where I found that, but google should know, it's what brought back the picture in my case.
audio4life is offline
post #5192 of 5212 Old 02-10-2016, 08:24 PM
mapson's Avatar
Back in service. The two fuses were the culprit. I might have blown them when I reconnected the 5 wire cable the first time, I recall one of the leads bent, might have touched the wire next to it.
If anyone else runs into a similar issue, no hdmi video or audio after soldering or even before repairing, check the two fuses and also any other fuses. When I was looking around I saw 3 other glass fuses along with these 2, and 4 more that were white/ceramic. Not sure if there were more but for certain these 9 are what I saw in the 876.
While it would have been nice to upgrade to newer tech, I'm more happy the 876 will continue to serve our use and I don't have to spend hundreds for a new receiver.
A big thanks for everyone who documented and showed the way to repair this problem. Especially the pictures, videos, part numbers, and other little details.
mapson is offline
post #5193 of 5212 Old 02-10-2016, 08:50 PM
NorthSky's Avatar
Quoted: 6725 Post(s)
Liked: 3332
Good show ↑ ... always check the fuses first...when encountering a transmission problem...picture or/and audio.
Of course after you checked the connections and cables and if the AC power cord is connected.
~ Bob
"And it stoned me to my soul"
- Van Morrison
NorthSky is offline
post #5194 of 5212 Old 02-11-2016, 12:44 AM
Liked: 0
remote lost
Hello People and good day everyone
I bought online a 876 but surprisingly it came without remote control. Seller says it is lost and was not part of the deal (I am wondering, but yes, it was not mentioned specifically).
It is hard to find a spare one. Any tips?
Can somebody of you (prefer european countries) make me a payable copy of basic functions to a General Remote? With basic functions i mean:
on/off
input selection
Audio theme selection
Volume control
for all the rest I dont mind to get my lazy ass off the couch.
Or can I get a General Remote and set it up by any code without having the original one? Sorry my lack of knowledge...
Thanks in advanve for any help.
Pascal
Pascal Wedam is offline
post #5195 of 5212 Old 03-23-2016, 12:44 PM
Liked: 1
I have been having (No Signal) issues with my 876 for several months now, and it has been getting progressively worse, so I decided to do the capacitor replacement.
I changed the 13, 100uf 4v caps with, 100uf 16v high temp caps, but the results are the same as before, no difference.
Does anyone know what else I can do to repair the HDMI issue. I have read through the forums, but found little info on the 876 board.
russrm is offline
post #5196 of 5212 Old 03-23-2016, 01:02 PM
NorthSky's Avatar
Liked: 3332
on/off
input selection
Volume control
Pascal
Call Onkyo to get a remote. Or check online.
And yes a universal remote from Harmony (for example) will get all the main functions of the original. You simply enter the model number of your receiver in the Harmony setup page (PC). If you are not familiar with programming a Harmony remote using your computer just google Harmony remotes and setups, to learn about their features. I use a Harmony myself, it's perfect.
Universal has remotes too, another good company. Check if you can enter the code of the 876 without using a computer.
~ Bob
- Van Morrison
NorthSky is offline
post #5197 of 5212 Old 03-29-2016, 05:47 PM
aim-n-shoot's Avatar
Liked: 0
on/off
input selection
Volume control
Pascal
Hi did you get the remote issue sorted . .. If not the 606 very remote works okay. I have a spare one u can have for free. You will just have to sort out poastage .
aim-n-shoot is offline
post #5198 of 5212 Old 03-29-2016, 05:51 PM
Liked: 0
Originally Posted by russrm View Post
<font face="Arial">I have been having (No Signal) issues with my 876 for several months now, and it has been getting progressively worse, so I decided to do the capacitor replacement.<br />
I changed the 13, 100uf 4v caps with, 100uf 16v high temp caps, but the results are the same as before, no difference.<br />
Does anyone know what else I can do to repair the HDMI issue. I have read through the forums, but found little info on the 876 board.<br />
</font>
<br />
<br />
Hi mate I have just fixed a second hand one I got for free.<br />
<br />
I changed the all the 100 uf and 220 uf capacitors. 3 out of the 4 out puts works fine now.<br />
<br />
One that doesn't work is mainly due to me damaging one of the 24uf cap ( really small ones) mountinh points for one of the caps.
post #5199 of 5212 Old 03-29-2016, 09:59 PM
haloguy628's Avatar
on/off
input selection
Volume control
Pascal
http://www.electronicadventure.us/Me..._code=24140690
http://www.remotecontrols.com/product/24140690.html
http://www.remotecontrolwarehouse.co.../24140690.html
http://www.remotes-express.com/Onkyo/24140690.html
haloguy628 is offline
post #5200 of 5212 Old 05-24-2016, 02:20 PM
ferga100's Avatar
Originally Posted by Malacandra View Post
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>CBdicX</strong> <a href="/forum/post/15529384"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
The 876 sold in Europe has no power outlet on the back !<br>
Thats why i use the Master/Slave trick........</div>
</div>
<br>
That's odd. I did try Googling for master/slave A/C power strips, and pretty much exclusively got Chinese sites (which use different plugs)... or patent filings. Or porn.
what is the master /slave trick for the 12v trigger ? many thanks
as the unit runs a bit hot
ferga100 is offline
post #5201 of 5212 Old 05-24-2016, 02:20 PM
ferga100's Avatar
</div>
<br>
ferga100 is offline
post #5202 of 5212 Old 05-24-2016, 02:23 PM
ferga100's Avatar
ferga100 is offline
post #5203 of 5212 Old 06-02-2016, 01:12 PM
Liked: 0
Hello,
I'm new to AVS and I know it's been sometime since anybody posted here, but I'm looking to update my Onkyo TX-SR876' firmware from version 1.01 to 1.04/1.05.
Can anyone please help ??
Mikohay is offline
post #5204 of 5212 Old 06-02-2016, 02:01 PM
jcalabria's Avatar
Quoted: 97 Post(s)
Liked: 77
PM sent.
Originally Posted by Mikohay View Post
Hello,
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.3.1_6
jcalabria is offline
post #5205 of 5212 Old 07-07-2016, 09:05 PM
Ronman79's Avatar
Quoted: 32 Post(s)
Liked: 29
Hey folks. I have an upstairs, dedicated home theater in the works. Wasn't really even considering a different receiver until recently. Have been very happy with my 876! What's it worth to the educated person (like AVS peeps on the 876 thread...)!? Lol. Anyone interested in a very clean, powerful receiver?
Sent from my XR6P10 using Tapatalk
2016 Vizio P50 4K HDR Display (working on dedicated projection HT upstairs!)/ Onkyo TX-SR876 Rec / Polk Audio RTiA9 Towers / Polk CSiA6 Center / Polk FXi5 Bipole Surrounds / (4) Polk PSW505 12" Subs / Sony BDP-S790 Blu-ray / Dish Hopper with sling / PS4 / Harmony Elite & One / Xfinity Cable Internet & secondary TV provider / Custom AV Console Table-Stand / (Vizio E60 & Vizio Surroundbar in MBR)
Ronman79 is offline
post #5206 of 5212 Old 07-10-2016, 01:55 AM
Liked: 0
hi guys, has anybody got firmware files to upgrade my stock firmware for main, dsp and hdmi in my my 876? bought it for guestroom couple of days ago, have got usb adapter but all links on web are dead. help plz
beney is offline
post #5207 of 5212 Old Yesterday, 10:14 AM
PhanofPhunk's Avatar
Question regarding Audessy set up. I ran Audessy and it set my sub to -15 and mains to -10.
Why? Is this normal?
Speakers are Paradigm monitor 9s v.6 and the sub is a
m&k v75 I I.
Sent from my SAMSUNG-SM-G930A using Tapatalk
PhanofPhunk is offline
post #5208 of 5212 Old Yesterday, 10:40 AM
jcalabria's Avatar
Quoted: 97 Post(s)
Liked: 77
m&k v75 I I.
The -10dB on the mains is probably ok. The -15dB on the sub is a problem, though, since -15dB is the limit of adjustment and it may have needed it even lower (e.g., -17dB) to balance correctly but couldn't get there. You should lower the level adjustment on the sub itself and rerun the Audyssey setup.
post #5209 of 5212 Old Yesterday, 10:44 AM
But that seems to make the sub obsolete.
When I run stereo mode I have the sub at +3.5 and the mains at 0.
What such a.drastic change?
post #5210 of 5212 Old Yesterday, 11:13 AM
jcalabria's Avatar
Quoted: 97 Post(s)
Liked: 77
By what standard/method did you arrive at your previous settings?
The purpose of the Audyssey level adjustments are twofold... First, to balance the levels of all the speakers in the system relative to each other. For this, the absolute levels set are meaningless, only the relative levels between the channels. The relative differences between the channels ensures that they all are outputting the same level for a given input stimulus. You may prefer something different than what the calibration provides, and that's OK... but you will not be hearing the same thing that the mixing engineer heard, which is the intent of the calibration.
The second purpose of the adjustments is to calibrate your system so that 0dB on your main volume setting corresponds to reference level. There is nothing inherently good or bad about whether the settings are high or low... It just ensures that your system is outputting a predictable SPL for a given volume setting. This may not be a of huge importance to many folks, but it's also required to ensure that functions like DynamicEq and Dynamic Volume work correctly.
post #5211 of 5212 Old Yesterday, 11:49 AM
So the set up mic determines that -15 for the sub is what would be considered reference level in my room? I guess what I'm asking than is Audessy knows what is reference, and by running the set up it then sets my levels based on my room acoustics to what is reference?
I'm a Audessy noob if you can't tell. My marantz had way different Audessy results. That's why I'm a bit confused.
Ronman79 likes this.
post #5212 of 5212 Old Yesterday, 09:31 PM
Ronman79's Avatar
Quoted: 32 Post(s)
Liked: 29
Is your room small? Is the sub gain set high? Are you using the mic in your main listening positions?
It sounds like to me you need to adjust the gain down somewhat, and then re-run the setup.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Ronman79 is offline
