Speaker Level to Line Level Converter - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jcmccorm
post #1 of 22 Old 10-26-2008, 02:24 PM - Thread Starter
pcdo's Avatar
Quoted: 31 Post(s)
Liked: 99
Has anyone here tried using a speaker level to line level converter, specifically in those receivers without preouts? Here's one for example:
http://www.crutchfield.com/S-IV8trDi...aspx?i=127OEM2
Seemingly you could use this to add an amp to your AVR that doesn't have preouts on it. Or am I totally getting this wrong.
pcdo is online now
post #2 of 22 Old 10-26-2008, 05:17 PM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
Yup. Basically, two resistors per channel.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 22 Old 10-26-2008, 05:56 PM - Thread Starter
pcdo's Avatar
Quoted: 31 Post(s)
Liked: 99
Oh cool! So basically now I can turn my receiver without preouts to one with preouts for only $30. Excellent.
pcdo is online now
post #4 of 22 Old 10-26-2008, 06:27 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Note there is a 60 watt / channel limit on it. I assume that's due to the resistor's power handling capability.
"But this one goes up to 11"
MichaelJHuman is offline
post #5 of 22 Old 10-26-2008, 06:45 PM
Quoted: 771 Post(s)
Liked: 542
Yup. Gotta dissipate the heat.
Kal Rubinson
post #6 of 22 Old 10-26-2008, 08:03 PM - Thread Starter
pcdo's Avatar
Quoted: 31 Post(s)
Liked: 99
Hmmm...maybe this would work. But it looks kinda bare and open.
http://www.crutchfield.com/S-mFQywdu...spx?I=543ADP12
pcdo is online now
post #7 of 22 Old 10-27-2008, 06:03 AM
Quoted: 771 Post(s)
Liked: 542
Yup. $1 worth of resistors and $2 worth of connectors.
Kal Rubinson
post #8 of 22 Old 12-13-2008, 11:32 PM
Mr. Hanky's Avatar
Quoted: 124 Post(s)
Liked: 99
I was just going to post a topic asking about this. Specifically, what is the value of resistance I should use if I wanted to build wunna-dis-tings?
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #9 of 22 Old 12-14-2008, 11:48 AM
Quoted: 771 Post(s)
Liked: 542
Google "speaker to line schematic" or "speaker to line circuit." Here's a start: http://www.epanorama.net/circuits/speaker_to_line.html
Kal Rubinson
post #10 of 22 Old 12-14-2008, 10:05 PM
Mr. Hanky's Avatar
Quoted: 124 Post(s)
Liked: 99
Ok, thanks! I will check it out.
post #11 of 22 Old 12-14-2008, 11:32 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
Ummm, yeah it sorta gets you a set of preouts, in a Rube Goldberg kind of way. But it's not really the same thing as a actual preout from a AVR that actually has them or the output from a pre-pro/pre-amp.
All you are really doing is clamping down on the speaker outputs from the receivers own amps by running it through some resistors, to drop it's power output down to a level where it will not overload feeding a power amp.
Probably not the best thing in the world as far as keeping a audio signal as clean and unmolested as possible, but I guess if all you are looking for is a very cheap way to add a bigger power amp to a AVR without a set of preouts, it's also probably about the lowest cost way to do it without buying a new AVR.
Johnla is offline
post #12 of 22 Old 12-15-2008, 09:09 AM
Quoted: 771 Post(s)
Liked: 542
Agreed. It will work reliably but, if the user is trying to avoid using the built-in power amps, it is not ideal.
Kal Rubinson
post #13 of 22 Old 12-15-2008, 09:19 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
You understate old Rube's good work. ;-)
This is not nearly as arcane or inefficient as Rube's fertile imagination.
Agreed, but it may be closer than you think.
It's not clamping, it is tapping down. It is as benign as a volume control.
It has the secondary effect of operating the receiver's own amps into a more linear mode of operation than driving speakers.
For example, most receiver power amps will stay out of class-AB operation and be running pure class A. Bass extension can also improve.
The receiver's power supply will usually truely be loafing.
The benefits over just a larger receiver are many. Far less heat, far lighter, and possibly smaller. Paves the way to system refinements involving equalizers, electronic crossovers, etc.
Exactly. But a good power amp is also just a big op amp. Sort of like the output stage of a good preamp on steroids.
arnyk is offline
post #14 of 22 Old 12-15-2008, 07:24 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
And I'd wager to say that anyone who does something like this to a lower cost AVR without a set of preouts, is only doing so in order to hook up a more powerful external power amplifier to it to get a louder volume output for as cheap as possible. Yeah you have some basis behind your theories/claims, but these so called "system refinements" you mention are at best questionable when applied to a lower cost budget AVR, and are not what these kind of people are aiming for, what they want louder or more power for hard to drive speakers. I also doubt that many, if any, would notice any real improved bass extension at all with doing this. And that any improvements they will notice at all, will come solely from the larger and more powerful external power amps that they added.
Johnla is offline
post #15 of 22 Old 12-15-2008, 10:13 PM
Knucklehead90's Avatar
Quoted: 498 Post(s)
Liked: 430
How would tapping into the headphone output work? There isn't much power coming from that. Might be worth a try.
Whats the power requirements of a good set of phones?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #16 of 22 Old 03-22-2017, 12:34 PM
mattlach's Avatar
Quoted: 125 Post(s)
Liked: 52
Hmm..
So, what about using one of these to attach a powered/active sub without high level inputs to a 2 channel amp without a pre-amp output?
Would putting one of these resistive devices on the same amp outputs as the left and right speakers cause any wacky impedance crap going on, or should it work pretty well, much as if the sub had its own built in high level input?
Livingroom: 65" Panasonic Plasma, Denon AVR-x3300w, Fronts: RBH SX-6300 Towers powered via Emotiva UPA-2, Center: RBH 441-se, Surrounds: RBH 41-se Sub: Dual SVS PC13-Ultra, Source: Custom Kodi Box
Desk: DAC: Schiit Modi Multibit
Headphones: Schiit Jotunheim -> Sennheiser HD650 & Beyerdynamic DT770 Pro
Speakers (2.1): Denon AVR-x1300W -> RBH 41-se & SVS SB12-NSD
mattlach is offline
post #17 of 22 Old 03-23-2017, 01:52 PM
Jrunr's Avatar
Quoted: 75 Post(s)
Originally Posted by mattlach View Post
Hmm..
Well, there is always this for the person who doesn't want to deal with an external converter...
https://www.monoprice.com/product?c_...seq=1&format=2
An amp with a built in converter. I always wondered how good these amps are though...
Jrunr is offline
post #18 of 22 Old 03-23-2017, 03:38 PM
Quoted: 771 Post(s)
Liked: 542
No name, pig in a poke. Also, I am guessing that it uses the same type of resistor-based voltage already discussed.
Kal Rubinson
post #19 of 22 Old 03-24-2017, 07:12 AM
Axememan's Avatar
Quoted: 36 Post(s)
Liked: 34
This should work.When I had my Sony Rx I looked into this before I ended up just getting an Onkyo TX-NR838 with Preouts
BEHRINGER ULTRA-DI PRO DI800 *Allows direct connection to speaker outputs with up to 3,000 Watts*
Professional Mains/Phantom Powered 8-Channel DI-Box
  • Professional and multi-purpose 8-channel direct injection box for stage and studio applications
  • Provides impedance and signal matching for the direct connection of instruments to mixers and amplifiers
  • Ultra-flat frequency response due to servo-balanced operation
  • Optional mains or phantom-powered operation
  • Allows direct connection to speaker outputs with up to 3,000 Watts
  • +20 dB gain switch for pre-amplification of low-level signals
  • Switchable input attenuation allows input levels of up to +40 dB
  • Ground Lift switch eliminates typical ground loop problems
  • Link output for easy connection to further equipment
  • 1/4" TRS and gold-plated XLR connectors
  • Illuminated switches for secure operation in dark stage environments
  • Shielded toroidal mains transformer for minimal noise interference
  • High-quality components and exceptionally rugged construction ensure long life
Axememan is offline
post #20 of 22 Old 03-24-2017, 07:15 AM
Axememan's Avatar
Quoted: 36 Post(s)
Liked: 34
Its $120.00 on all of the sites.not to expensive
Axememan is offline
post #21 of 22 Old 03-24-2017, 09:54 AM
jcmccorm's Avatar
Quoted: 126 Post(s)
Liked: 89
I'm pretty sure that, as a DI box, this thing just converts unbalanced signals to balanced (ie. microphone to mixer) and wouldn't handle the voltages associated with speaker-level signals.
Cary
PS. Well it *does* say it allows hookup to speaker outputs, but, I think that might mean the balanced output from a powered PA speaker.
PPS Edited because I got DI direction wrong.
PPPS Well at this point I shoulod just delete my post but I'll keep it to remind me of my shame. Curious, I looked up this box at Behringer's site and got the product page. Yup, it says you can connect to your amp's speaker output, engage their -30db attenuator, and get a regular balanced output. Cool.
Axememan likes this.
jcmccorm is offline
post #22 of 22 Old 03-24-2017, 01:52 PM
Axememan's Avatar
Quoted: 36 Post(s)
Liked: 34
Cary
I almost pulled the trigger on one but last minute a guy I work with said he would by my Sony[6 mos old with extended warranty I got it from BB],so,with me planning on spending 120.00 plus bucks on the Behringer, I figured with a few more dollars[couple of hundred] I could get the Onkyo[from Crutchfield..I like those guys at Crutchfield].But,I looked into all kinds of ways to add external amperage to a NON Preout Receiver.Found/stumbled on it while looking for stereo sound setup in a Mancave with a 90's Sony Receiver.
Axememan is offline
