Panasonic SA-BX500 Small Light Powerful - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 06-13-2013, 02:53 PM
drnaive's Avatar
Mine is still going strong. However I'm thinking to upgrade to an Onkyo 818. 3 hdmi in and just 1 out aint cutting it for me anymore.
drnaive is offline
Old 06-13-2013, 03:10 PM
fookoo_2010's Avatar
Quoted: 231 Post(s)
Liked: 80
It has had more than its useful run. You will find XT32 simply amazing.
fookoo_2010 is offline
Old 06-13-2013, 03:46 PM
Goes to 11's Avatar
Liked: 25
Mine is still going strong, too, and I'll probably use it until it breaks. Agree about only 3 HDMI inputs, so I bought one of these.
http://www.amazon.com/gp/product/B0088AP6IK/ref=oh_details_o09_s00_i01?ie=UTF8&psc=1
I haven't gotten around to trying it yet, though, still running an HDMI straight to the TV.
It would be great if somebody would post a list of currently-available receivers that use similar amplification to SA-BX500. I think there is a fairly recent Pioneer Elite. I think there was a Sherwood, but probably long enough ago that it's disco'd.
Goes to 11 is offline
Old 06-15-2013, 02:22 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Originally Posted by Goes to 11 View Post
It would be great if somebody would post a list of currently-available receivers that use similar amplification to SA-BX500. I think there is a fairly recent Pioneer ...
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/SC-1222-K
Class D3 Amps. Check Amazon or Newegg.
However, not sure I would exclude other contenders (Denon, Onkyo, etc.) just because they have different types of amps inside. For instance, WRAT certainly puts out the power.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
Old 07-09-2013, 04:55 AM
maluszynski's Avatar
Folks,
I just bought a used sa-bx500 mainly to play audio from a computer. (I know, kinda overkill but I got it cheap). I am trying to connect through a regular old RCA to headphone jack cable that I have tried to connect to multiple inputs CD/tv/aux but I get no sound. What am I doing wrong? The radio works.
Cheers
Chris
maluszynski is offline
Old 07-09-2013, 11:54 AM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Originally Posted by maluszynski View Post
Folks,
Cheers
Chris
From computer, use Aux out (line level) not headphone out (usually amped).
On computer, be sure it's not set to "Digital" ... unless you want to use its SPDIF (which is what I would use anyway).
Try another analog input device (old VCR, DVD Player) and test all RCA Inputs.
Old 07-09-2013, 12:03 PM
Goes to 11's Avatar
Liked: 25
Tesla said exactly what I was starting to post. Only thing I can add is that if another line-level output device works (so you know the SA-BX500 is functional), and if a headphone output is your only option from the computer, you might be able to make it work by going into audio control on the computer and turning headphone output volume way, way down. I would start at about 5, on a scale of 0 - 100.
Old 02-01-2014, 06:46 PM
tensleep's Avatar
I'm aware about newer receivers stating they are 3D compatible. But i was hoping for someone with direct experience on this receiver who could say they have definitely done this or definitely ruled it out.
I've made this receiver do things not on the spec sheet and was hoping this would be another undocumented capability.
For the dual ouput BD play my intention would be to have one output go to the TV which could provide the EDID answer back to the movie that yes 3D is compatible, and the other output to the SA-BX500 to receive lossless audio. Wouldn't that work?
If a dual output BD player won't work or can't be found, what about a 3D compatible HDMI splitter? Something like monoprice item 8204 or 7522? Ideally someone with SA-BX500 is doing the same thing and has already found a compatible splitter.
End Quote
Check out the Panasonic DMP-BDT500 - it will do what you want. Question for the gurus - should I be using the 8 channel analog output of this blue ray player into my SA-BX500 or should I keep it all digital?
Silence is Golden
but Duct Tape is Silver
tensleep is offline
Old 02-01-2014, 07:05 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Digital (over HDMI) will give you 1080p, bitstreamed HD-Audio, Lip-Sync, multi-channel PCM, and more.
Old 09-07-2015, 03:39 PM
tensleep's Avatar
Gonna bump this thread to the top - who else is still running this receiver besides me? It has served me very well, along with my Panasonic Plasma TV and BluRay Player. I just picked up a pair of Velodyne DLS-5000R for the bottom end and relieved some of the pressure off of the SA-BX500. However, I am going to start looking for a new receiver soon. I may not get anything, but I am curious about a higher quality AVR. What have some of you graduated to from this receiver?
Silence is Golden
tensleep is offline
Old 09-07-2015, 04:05 PM
SteveSatch's Avatar
Quoted: 32 Post(s)
I still use mine and see no reason to replace it. I seem to do fine without fancy room correction and I don't think I need the latest HDMI cords until I get Ultra 4K TV and I don't need that : )
tensleep likes this.
SteveSatch is offline
Old 09-07-2015, 04:30 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
I'm still running mine and it works fine.
However, it's in my secondary work-out room with older "Component and SPDIF wired" devices. Since no HDMI, I could not imagine running it in my main home-theater room.
As you can see I went with Onkyo. If it ever blows-up, I'll get a Denon (with slightly more power ... as I can afford).
Old 09-07-2015, 06:00 PM
tensleep's Avatar
Mine has 3 HDMI inputs, one HDMI output. What model is your Panasonic
receiver?
Silence is Golden
tensleep is offline
Old 09-07-2015, 06:24 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
receiver?
Man, sorry ... wrong thread.
I thought I was answering in the SA-HE200 thread. A generation before this one with no HDMI.
Old 09-07-2015, 08:37 PM
tensleep's Avatar
That's cool - HDMI is too easy not to make the move. Since Panasonic doesn't make decent AVRs anymore, I will have to shop around for another good value when this one is done. But, as others have said, so far so good.
Silence is Golden
tensleep is offline
Old 09-07-2015, 10:02 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
I really like my Onkyo (sounds great and clear even at max.). After my model, yearly generations went through a rough-patch reliability-wise.
I can't really talk to differences since I don't have this one to compare. Both Onkyo and Denon have nice websites for feature charts.
I think that's how I got subscribed here ... trying to stay with Panasonic years ago (see my gear).
Old 09-24-2015, 12:35 PM
Goes to 11's Avatar
Liked: 25
You have gotten a few replies, but this thread---like Panasonic AVRs, unfortunately---has gone moribund. I "upgraded" mine a few years ago to a Yamaha RX-V773 mainly because I needed another HDMI input (and NewEgg was blowing the Yamaha out), and was kinda disappointed. To me it seemed like the Panasonic had a punchier sound that I enjoyed, but trying to describe sound is not easy and it's all subjective. I am still using the Panny in a second location and it is serving me well.
One of the replies gives a thumbs up to Onkyo. My Panasonic was the replacement for an Onkyo that I liked a lot (but had no HDMI). Because of my experience with Onkyo I talked a friend into buying a TX-NR509 a few years ago. It ended up being one of the lemons with a bad HDMI board and died about a month after the warranty expired. Nevertheless, Onkyo recognized the problem and had a program in place to repair it, paying all of the shipping, so kudos to them for that.
Old 02-16-2016, 12:36 PM
Goes to 11's Avatar
Liked: 25
This is my month to post to incredibly old, dead threads. Here goes. Anybody know how to force the SA-BX500 to put out plain old 2-channel stereo (preferably 2.1 using the sub for bass) when it is getting a 5.1 source over HDMI? I think I used to be able to do that, but now can't recall how. And, yes, I've RTFM, but I can't find a clue.
Old 02-17-2016, 08:03 AM
SteveSatch's Avatar
Quoted: 32 Post(s)
What happens when you surround off button?
Old 02-17-2016, 09:41 AM
Goes to 11's Avatar
Liked: 25
I did try that. The sound that would be directed to the center channel (mainly dialog) just disappears. What I am doing right now as a work-around is using 5-channel party mode, but that (as I understand it) puts the same mono out of each speaker. I'd rather have a stereo effect derived from the 5.1.
I haven't re-run speaker set-up since disconnecting the center, and rear surrounds. I'm going to try that and see if the AVR then "knows" it can only do 2.1 channel.
And why did I disconnect those speakers, you might ask? Right now I'm trying to use the AVR for stereo only. Going back to a full HT may be a while -- crawl space wires to run, etc.
Old 02-17-2016, 03:27 PM
Goes to 11's Avatar
Liked: 25
I have now re-run the auto speaker setup using the test mic. Now when playing a 5.1 source, on the left side of the LCD display right above where it says "Speakers A" it also displays "2-channel mix." So, it appears that it will only downmix 5.1 to 2-channel stereo when it has had set-up run with only 2 front speakers and a sub attached. It sounds right, too, so appears this solved the problem.
