Panasonic SA-BX500 Small Light Powerful - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #211 of 711 Old 04-27-2009, 08:23 PM
cherry ghost's Avatar
Quoted: 18 Post(s)
The cheap Sony in my bedroom broke, so I'm moving my XR55 in there and bought a BX500 today for the main room. I'm confident I'll be happy with it.
cherry ghost is offline
post #212 of 711 Old 04-27-2009, 08:27 PM
SteveSatch's Avatar
Quoted: 33 Post(s)
Did you buy from J&R?
SteveSatch is offline
post #213 of 711 Old 04-27-2009, 08:28 PM
Quoted: 18 Post(s)
Yep, with 5% off from Live.com
post #214 of 711 Old 04-27-2009, 08:30 PM
SteveSatch's Avatar
Quoted: 33 Post(s)
That's my plan as well. Can you verify that the HDMI is version 1.3?
post #215 of 711 Old 04-27-2009, 09:22 PM
drnaive's Avatar
SABX500 has HDMI 1.3 and in addition it also supports deep color via HDMI. So full 1080P video pass through is not an issue.
drnaive is offline
post #216 of 711 Old 04-29-2009, 04:50 PM
SteveSatch's Avatar
Quoted: 33 Post(s)
Order placed and tracking shows I'll have them on Monday. I'll post if I can hear a difference between the XR-55.
post #217 of 711 Old 04-29-2009, 08:15 PM
smeg36's Avatar
Quoted: 109 Post(s)
Liked: 49
Has anyone heard both this and the Onkyo 606? I keep jumping back and forth between the two. The Onkyo would cost almost $100 more, but it does have more features. But aside from the Audyssey setup and Room EQ, I don't think I'd use any of the features. I don't do any video upconversion, all my devices are HDMI. I don't want to buy one until I have definitely decided between the two, but am concerned the J&R deal will end while I'm debating.
smeg36 is offline
post #218 of 711 Old 05-01-2009, 07:26 AM
eyerob's Avatar
Just ordered mine - price to good to pass up. Even if it sounds crap with my analog devices (underwhelming response on this question i posted earlier)- I can always get a dedicated stereo receiver for those later...
I'm getting this for home theater - which is all digital - I'll report back when I get it set up (still have to get my plasma too)
I'm so pleased I jumped as I'm afraid that they've stopped making them as these, the wireless speakers and the ipod docks are unavailable on the Panasonic site(but the EZ48 DVD recorder is 'backordered') - and it seems strange that one retailer has a bunch of them for a great price... - this is total speculation - no inside info here!
Kuro for (at least half) life!
eyerob is offline
post #219 of 711 Old 05-01-2009, 07:36 AM
bitpoh's Avatar
Any brave owner opened up the BX500 to see if it has TI Amp inside yet?
bitpoh is offline
post #220 of 711 Old 05-01-2009, 07:39 AM
SteveSatch's Avatar
Quoted: 33 Post(s)
The XR55 does sound better with the digital inputs so I'm sure the 500 will too. I don't think you'll see this receiver chaper than what it is now. Even is Panasonic comes out with something new, you won't be able to get it for under $300 delivered.
post #221 of 711 Old 05-02-2009, 01:48 AM
Chingu808's Avatar
Quoted: 48 Post(s)
Originally Posted by rob316 View Post
I have 2 questions one question is for anyone who upgraded from an XR55:
2 - I have a 6.1 Setup is there an option like the XR55 to choose 6.1 setup.
From the manual.
Use the terminal for the left surround back speaker when you place the speakers for 6.1 channel playback.
Chingu808 is offline
post #222 of 711 Old 05-02-2009, 07:11 AM
rutgersftw's Avatar
Ordered one to replace my Sony 820 that replaced my XR57 when one HDMI couldn't cut it anymore. The Sony never drove my speakers as well as the Panny, though, and if this one is even a touch more powerful than my 57 I should be in for a treat. For the price, why not? This was still $400+ when I got the Sony for $250. Now I've ebayed the old and brought in the new. Good times.
rutgersftw is offline
post #223 of 711 Old 05-02-2009, 09:20 AM
Dobby's Avatar
I'm considering upgrading to this receiver from an XR55. I'm having a hard time deciding between this and the new Pioneer VSX 819H which has many more features for the same price. A couple of questions:
Does this receiver make the same very loud clicking sounds when it switches from 2 channel to surround?
Does it have a dedicated button to switch to 6 channel analog or do you have to hold down the dvd input for 3 seconds like the XR55?
Dobby is offline
post #224 of 711 Old 05-02-2009, 03:35 PM
christoofar's Avatar
Quoted: 262 Post(s)
Liked: 166
I have two XR55s for HT and two XR55s for two channel systems. I'm thinking of picking up two BX500s for the HT rooms due to the newer prices. My older HD TVs do not have HDMI connections though, only component. I will eventually replace these TVs, but not until they fail. Is it worth it to pick up the BX500 even though my TVs can't use HDMI? Could I run HDMI from a PS3 to the Panny and a component to my TV to get the HD audio and have the picture go via component? If not, is it even worth it to upgrade the receivers?
OMG! A Panny Herder!
Heart in SoCal - Soul from the Motor City
AFTV2+ KODI 17=>SR6010=>Integra DTA-70.1=>Chane A1.4 x 3 + DCM OW-1s x 2 + 1 x RSL Speedwoofer10 S+ 1 x Yamaha YST-SW315
christoofar is offline
post #225 of 711 Old 05-03-2009, 09:12 AM
homersimpson2009's Avatar
Not getting DTS HD / True HD / or D+ with my BX500.
Sources are a PS3 and a Toshiba HD-A2. The PS3 is outputting prologic II and the best I can get with the Toshiba is multi-ch LPCM. I am using HDMI cables to run them into the receiver... should I also be using optical cables for the digital audio?
homersimpson2009 is offline
post #226 of 711 Old 05-03-2009, 01:45 PM
gluvhand's Avatar
You're using two devices that decode internally. My best guess is you have the PS3 set to output bitstream and the HD-A2 set to output PCM. Switch the PS3 to output PCM as well. That's the only way to get the HD audio from these devices. If you bitstream you'll be getting the legacy codecs. Since the decoding is happening in-player your receiver will correctly show multi-ch PCM. If getting the DTS HD or True-HD lights to go on on the receiver is very important to you, you'll need players that will send the HD audio via bitstream and the reciever will decode them.
gluvhand is offline
post #227 of 711 Old 05-03-2009, 01:55 PM
Quoted: 262 Post(s)
Liked: 166
In for one thru Live.com/J&R = $285 shipped. Sweet!
post #228 of 711 Old 05-04-2009, 05:12 AM
mdm1699's Avatar
I am so frustrated with this receiver. I own and love the sa-xr55s. Zero problems. I got the BX500 from J&R but cannot get any sound from my subwoofer. I have a Sony 350 blu-ray that is bitstreaming and a Comcast digital cable box. Both are hooked up via HDMI. I have zero problems with the current settings and my Onkyo 705. However, I wanted the cooler running Panny. I tried running optical and the bass works fine. However, with my blu-ray player and cable box there is no sound from the subwoofer via HDMI. I tried the mic calibration, setting the sub channel volume to 25, gain on back of sub. The only time I get sound via HDMI is to set the speakers to small. However, I hate the sound of my mains when I do this. Please help.
mdm1699 is offline
post #229 of 711 Old 05-04-2009, 08:07 AM
rutgersftw's Avatar
That's weird. I don't have mine yet (out for delivery today) but it will have an X360/HD DVD, DVD player and a SA cable box into it via HDMI. I'll post if I have any trouble too.
post #230 of 711 Old 05-04-2009, 10:47 AM
Still no luck... I setting the Toshiba HD DVD to PCM and tried setting the PS3 to automatic. Still seems to outputting in surround sound...
post #231 of 711 Old 05-04-2009, 10:58 AM
gluvhand's Avatar
After you connected the PS3 to the receiver for the first time did you run the audio set up of the PS3 again? Also, set it to PCM only. You can switch it to bitstream for SD DVD if you choose to later.
gluvhand is offline
post #232 of 711 Old 05-04-2009, 11:02 AM
gluvhand's Avatar
The reason, I'm guessing, that it works with the speakers set to small, is that the receiver will do the bass mangement witht the speakers set to small. When set to large it's looking for the source to do the management. Did you try seeing what happens when you have the 350 decode internally instead of bitstreaming?
gluvhand is offline
post #233 of 711 Old 05-04-2009, 11:12 AM
mdm1699's Avatar
The 350 does not decode internally. Also, the fact that I get no bass with my comcast dvr via hdmi tells me that the unit may be flawed. When I switch everything back to my onkyo(I really hate the heat it gives off in my apt) everything works fine. Just no bass from HDMI sources.
mdm1699 is offline
post #234 of 711 Old 05-04-2009, 03:30 PM
gluvhand's Avatar
The 350 does internally decode TrueHD and DD+ and passes them thru HDMI. It bitstreams the DTS HD codecs. If you have the time, try it out. I have a feeling what I said earlier about bass management may be the issue. Also, is there a setting for what type of audio is associated with the HDMI inputs? Does something need to be switched?
gluvhand is offline
post #235 of 711 Old 05-04-2009, 04:44 PM
rutgersftw's Avatar
I just plugged mine in. Sub is active via HDMI. Bit miffed by the universal crossover (i. e. can't set my fronts to 80 and my center to 100), auto set up failed three times before I gave up and measured, and the whole menu interface is the definition of quirky - but having owned a 57, I expected most of this.
The sound? Clean and muscular. My current fronts aren't bi-wirable, unfortunately, but it sounds like the receiver is no longer the weakest link in my setup.
post #236 of 711 Old 05-04-2009, 08:38 PM
mdm1699's Avatar
I returned it to the store today. The unit must have been flawed because I tried Transformers blu-ray and got no bass. I wonder if I should get a replacement. Anyone else having bass problems? Why can't it work like my 55s. The sound is perfect with my Bostons.
mdm1699 is offline
post #237 of 711 Old 05-04-2009, 08:41 PM
mdm1699's Avatar
I need the bitstreaming for DTS HD. I did try the Digital/PCM/Auto settings for the HDMI inputs. I will try a replacement.
mdm1699 is offline
post #238 of 711 Old 05-05-2009, 04:37 AM
rutgersftw's Avatar
Good luck with the replacement. I'm driving Bostons with mine too, and the sound is phenomenal.
One thing - my XR57 was dead quiet when I put my ear to the tweeter. Now I've got a crackly, low-level hiss like with any other amp. Noise is slightly lower with HDMI inputs than with my CD player hooked via analog. Anyone else notice this?
post #239 of 711 Old 05-05-2009, 05:25 PM
rutgersftw's Avatar
OK, I've been unplugging, replugging, rerouting, and generally doing everything in my power to combat this high frequency whine/feedback/digital distortion I get at any volume, anywhere in the room. Any ideas on how to combat this, if this is normal, or if my receiver is messed up?
Help please!
post #240 of 711 Old 05-05-2009, 06:08 PM
Dobby's Avatar
So nobody can answer these simple questions about this receiver?
Dobby is offline
