Thinking of upgrading my reciver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-02-2008, 11:06 PM - Thread Starter
gamekiller's Avatar
MY FIRST POST. I have a NAD t744 reciver thinking of upgrading. Using B&W DM603 S3 floorstand, B&W LCR600 S3 center & unknown surround speakers. If I upgrade what whould be a reciver that will maximiz these speakers. New or old models just some ideas.
gamekiller is offline
post #2 of 7 Old 11-03-2008, 01:44 AM
toolwarrior's Avatar
It would be helpful if your could list your budget, the features you want, percent audio vs. movies you will use the receiver for, etc....
Then folks can give you better recommendations.
Rich
toolwarrior is offline
post #3 of 7 Old 11-03-2008, 11:28 AM - Thread Starter
gamekiller's Avatar
budget bettween $500-2500. Used for movies first, gaming & audio.hope that helps
post #4 of 7 Old 11-03-2008, 11:37 AM
LS2JSTS's Avatar
Do you like the B&W's and how they sound with the NAD?
Are you upgrading for HDMI and features or because you don't like the sound of the two together?
05-1.3H BJC-3808-1.3H BJC-5080
LS2JSTS is offline
post #5 of 7 Old 11-03-2008, 01:59 PM
Wow, if I had a budget that went that high, I would look at the Onkyo 876 or the 906 (about $400 more) if you want the streaming internet radio. Both have the better Reon processor for Video. Audio on both is also supposed to be superb.
Rich
post #6 of 7 Old 11-03-2008, 03:09 PM - Thread Starter
gamekiller's Avatar
I just sold my paradigm monitor 9 v5 and pick up the B&W's and love the sound and style. Sounds really good with the NAD but I need more power. I dont know if I should upgrade or just add an amp to the setup. I rather have a bigger reciver, then an amp with more wires. Im trying not to spend that much money. IF I CAN FIND A OLDER RECIVER THAT WILL BE GREAT. My brother has the 604 s2 B&W's he just upgraded with the ARCAM AVR280 and wow they sound amazing the differnce from NAD-ARCAM was crazy. Dont get me wrong NAD sound really good too. I went to a audio-video store and told me about this form LOVE it. They had a Rotel RSX-1058 for 899.99 but dont have much info on Rotel. Dont need HDMI.
post #7 of 7 Old 11-03-2008, 04:08 PM
LS2JSTS's Avatar
If you dont need to upgrade to HDMI, I would seriously look at adding an outboard amp. Maybe the new Rotel 15 series digital amps or something along those lines.
LS2JSTS is offline
