Onkyo PR-SC886P Pre/Pro Official thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 05-28-2009, 05:19 PM
homeav's Avatar
Originally Posted by CCONKLIN1 View Post
gotcha beat. new one in MAY with 1.01...
Wow, seriously... brand new units with 1.01? I figured that recently shipped units would have recent versions.
I've read through a large portion of the firmware upgrade thread... Do the 886s suffer from the DTS bomb issue or not?
I know its been an issue in some other Onkyo AVRs (875?, 805?) - but I've never quite understood if a firmware upgrade on the 886s is only minor fixes (ie, most users will never notice that their firmware is old)?
I apologize if this is a little OT. Thanks in advance!
homeav is offline
Old 05-28-2009, 05:30 PM
CCONKLIN1's Avatar
just because they are "brand new" units does not mean they have not been sitting around the warehouse awhile. Pretty simple to update so I am now at 1.05 (although I hear there is a 1.06....)
CCONKLIN1 is offline
Old 05-28-2009, 05:31 PM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1442
Your post is not off topic as this is the 886 thread.
I have not checked the FW on the 886 I just got but I assume it is 1.01. I believe that the 886s shipping from shoponkyo have the latest DSP version. The DSP update is what corrected the DTS bomb issue. From what I have read the newer FWs 1.04/1.05 enable the use of Audyssey Pro and correct a Gamma issue with earlier FWs. But I never did see a definitive list of what the new FWs correct so if I am wrong please correct. So if my 886 has the newest DSP version that is good as I am not overly concerned about updating the FW.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 05-28-2009, 05:32 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
I do not believe that the DTS bomb is present in any version of xx6 firmware. The only difference I have noticed is that 1.01 did not respond to some of the IR commands that 1.04+ does... mainly the Audyssey & ISF related discrete commands. I had no specific problems with 1.01, and it did come with the latest DSP version.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
Old 05-28-2009, 05:47 PM
Bill Mac's Avatar
Liked: 1442
Originally Posted by jcalabria View Post
I do not believe that the DTS bomb is present in any version of xx6 firmware. The only difference I have noticed is that 1.01 did not respond to some of the IR commands that 1.04+ does... mainly the Audyssey related discrete commands. I had no specific problems with 1.01, and it did come with the latest DSP version.
When you mention Audyssey discrete commands does that provide accesss to directly enable or disable say the DynamicEQ/Volume without going into the setup menu? I would like to have that capability with my harmony 688 so if I am watching Cable I can program DynamicVolume to turn on with the Cable/Sat input. But then just use DynamicEQ with the Bluray input. If that is possible it would be cool.
Bill
Bill Mac is offline
Old 05-28-2009, 06:21 PM
Bill Mac's Avatar
Liked: 1442
I have been thinking of a way to use my Panasonic BD30 with the 886 in a way that I could enable the Reon for SD DVD and Bypass it for Bluray use. I was looking on Monoprice's site and found this switch.
My idea is to feed this switch with the HDMI output from the BD30 then use the two outputs to feed two different HDMI inputs with the 886. My thinking is I could setup HDMI input 1 for pass through (for Bluray) and HDMI input 2 with the Reon, upscaling, noise reduction etc. for SD DVD. Is this a crazy idea or could it work?
I am thinking both outputs of the switch are active and just one HDMI input on the 886 is active at a time. Feel free to poke holes in this idea if need be.
Bill
Bill Mac is offline
Old 05-28-2009, 06:33 PM
homeav's Avatar
Interesting that it sounds like the main firmware is older in shipping units... but the DSP firmware on units seems to be current.
homeav is offline
Old 05-28-2009, 06:43 PM
CCONKLIN1's Avatar
Bill
oohhhhhh, that frikkin' brilliant! I was wondering how I was going to feed my oppo for SD and blu ray without engaging the reon for playing blu ray. Buy it Bill and let me know if it works! It should!
Old 05-28-2009, 06:54 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
Bill
Yes it does!
All of the rather complete Onkyo IR code set can be found in the spreadsheet attached here. Commands listed in red require 1.04+ FW.
Old 05-28-2009, 07:01 PM
Bill Mac's Avatar
Liked: 1442
Yes it does!
All of the rather complete Onkyo IR code set is in the attached Onkyo document. Commands listed red require 1.04+ FW.
Awesome! Do you know if these codes will work with Harmony remotes?
Thanks, Bill
Bill Mac is offline
Old 05-28-2009, 07:03 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
Bill
Now that you have the IR codes for setting output resolutions discretely...
...Why don't you just keep your preamp normally in Source mode and set your input picture controls for your SD DVDs... then when you play a Blu-ray just hit "Through" via a single IR command.... when the BD is done playing just thow it back to "Source" (again... single discrete command)and your SD tweaks will be restored.
That's how I had mine set up before I added the Oppo 980. I actually had two different H1 activities for DVD and BD playback even though it was the BD35 playing both.... the H1 added the "Through" command to the BD startup sequence and reset it to "Source" when the BD activity shut down.
Old 05-28-2009, 07:04 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
Thanks, Bill
Yep! Have 'em programmed in my H1 and also in my "backup" 550. My son also uses some of them on his Onkyo 806 with my old 880 remote.
Old 05-28-2009, 07:29 PM
Bill Mac's Avatar
Liked: 1442
Excellent! Now more questions. Are those codes in the Harmony data base? If not how do you transfer them to the remote. I am computer challenged but do fairly well programming the Harmony if the codes are there or learning from another remote. Thanks again!
Bill
Bill Mac is offline
Old 05-28-2009, 07:33 PM
Bill Mac's Avatar
Liked: 1442
That will work as well. But as I said in my previous post I have computer issues. The switch might be the cowards way out.
Bill
Bill Mac is offline
Old 05-28-2009, 07:51 PM
fedexA300pilot's Avatar
Originally Posted by midasmagoo View Post
My Xbox 360 is connected via HDMI not optical, but I haven't noticed a bass level different from the other connected components. If volume in general is louder you could use Source Setup --> IntelliVolume to lower the volume of just the Xbox, but I don't think there is a way to lower the bass level or change equalizer settings on just a single source.
You can lower a specific Surround setting's Sub db level...
When I used DD EX it would boom my sub, so I lowered the DD EX -10db for the sub and it works like a champ...
fedexA300pilot is offline
Old 05-28-2009, 08:13 PM
joealtus's Avatar
Originally Posted by fedexA300pilot View Post
What surround mode are you using?
It happened over multiple surround modes, PLIIx, THX Games, etc.
After doing some more experimenting, it appears that the cause is Dynamic EQ. Turning Audyssey off cures the issue. MultEQ XT alone also doesn't exhibit the issue.
I probably need to re-do my calibration and see if it persists.
joealtus is offline
Old 05-28-2009, 09:41 PM
lorjam's Avatar
Quoted: 113 Post(s)
Liked: 114
My new 886 is also 1.01. Does anyone know if 1.05 does anything other than update the IR codes? I have a USB>RS232 cable coming from monoprice, but I don't want to start messing with FW updates yet if that all it does.
JVC-RS4910, Samsung 64H5000, LG 60PA6550
Oppo 203, Oppo 93, Oppo 83SE, DirecTV HR44-200, Samsung DTB260F, Roku 3, Denon DP-1200
Marantz AV7702, Onkyo PR-SC5507, Onkyo TX-NR3008, McIntosh C26, DVDO Duo
Parasound A51, Parasound HCA-806A, Emotiva UPA-1s, Marantz MA500s, McIntosh MC2105
Paradigm Studio V4s & V5s, Hsu subs X2,
lorjam is offline
Old 05-28-2009, 09:47 PM
Fanaticalism's Avatar
Thank DJoel. It is much appreciated!
Fanaticalism is offline
Old 05-28-2009, 11:21 PM
John Clark's Avatar
Quoted: 86 Post(s)
Liked: 24
HAHAHAHAHAHAHAHAHAHA. No. I don't think anyone has gotten one with the latest firmware. All have been 1.01.
Best,
Chris
Earlier, I read of some people having real problems trying to upgrade the firmware on their 885's. Has that been worked out? And how difficult is it to install now? Thanks.
John
John Clark is offline
Old 05-28-2009, 11:38 PM
John Clark's Avatar
Quoted: 86 Post(s)
Liked: 24
What is the warranty on the refurbished units? I went out to the Shop Onkyo site, and it simply says that warranties apply to new, not refurbished equipment. Does that mean there is no warranty on the refurbs at all?
John
Old 05-28-2009, 11:40 PM
Magnus_CA's Avatar
John
You get a year.
Magnus_CA is offline
Old 05-29-2009, 08:44 AM
Snowbound's Avatar
I currently am using the 805 as my pre / pro with a Emotiva XPA 5 amp. If I purchase the new 886 will I notice an improvement in sound quality or jut more features etc..? Of course I am thinking about waiting on the UMC 1 as well just weighing my options.
Snowbound is offline
Old 05-29-2009, 09:11 AM
nukequazar's Avatar
Quoted: 18 Post(s)
John
One year, and then for $85 you can add two more years. And I believe you have until the end of the first year to decide about buying the extended warranty.
nukequazar is offline
Old 05-29-2009, 10:18 AM
Bill Mac's Avatar
Liked: 1442
Just updated the FW on my 886 to 1.04. It went without issue and for someone with my lack of computer skills is a minor miracle. Thanks to gurkey for posting the updated FW's and keeping the thread up to date. Also thanks to rickardl for the detailed instructions in the 876 thread on the update of the FW. I needed those instructions as I could not get the instructions to open as part of the 1.04 download. So if anyone is concerned about updating their 886 fear not because if I can do it anyone can.
Bill
Bill Mac is offline
Old 05-29-2009, 10:28 AM
Bill Mac's Avatar
Liked: 1442
Yes it does!
I opened the attachment and I do not have a clue on how to proceed with getting the codes for Audyssey functions. I just see a bunch of numbers and letters. Is there a certain procedure to do this? Thanks in advance for any advice.
Bill
Bill Mac is offline
Old 05-29-2009, 10:30 AM
ketzer7's Avatar
Bill
Bill,
Did you only update the firmware, or also the DSP as well? From my reading of the firmware upgrade thread, it seemed to suggest you only need the "jig" device for updating if you have a unit with loader version 1.00, is that correct?
For xx6 units or those with loaded 1.01 or newer, you can just upgrade the firmware directly through the serial port for the main firmware and through TOSLINK 1 for the DSP? Did I read that thread correctly? Thanks!
ketzer7 is offline
Old 05-29-2009, 10:32 AM
CCONKLIN1's Avatar
You just keep waiting on that UMC......My son may be married with children by the time that things comes out! (he's 6 currently)
I, too, was using a 805 as a prepro and there is a definite step up in sound quality to the 885 AND 886, at least for HDMI sources. In my own little world that thing that TOTALLY makes the 886 worth it is the newer audyysey dynamic eq and volume features. If you listen at anywhere LESS than reference levels you will totally love it as the sound fields are much much more engaging than those of the 885 and 805. Once again, my two cents..
Old 05-29-2009, 10:34 AM
CCONKLIN1's Avatar
Bill
Bill, why 1.04 and not 1.05?
Best,
Chris
Ps told you it was simple...even for you!
Old 05-29-2009, 10:36 AM
ketzer7's Avatar
Does anyone happen to be using a Wyred 4 Sound amp with their 886? If so, any comments on performance/likes/dislikes with the setup?
I'm looking at picking up an 886 and possibly running it with a W4S Mini MC7 amp for my current revamped HT room as a hold over until I can finish my dedicated HT room in the basement and upgrade the amp and speakers to something a little more powerful.
Just seeing if anyone has feedback about whether this will be a decent setup with a set of 7.1 Paradigm speakers.
Oh yeah, was looking at ordering the 886 from markertek.com since they seemed to have a good price and many positive customer reviews, anyone have experience with them?
ketzer7 is offline
Old 05-29-2009, 11:48 AM
JJust's Avatar
Exactly what is the difference between the PR-SC885P and the PR-SC886P ? All I see is ISF. Is that it?
JJust is offline
