Onkyo PR-SC886P Pre/Pro Official thread - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2881 of 3270 Old 04-29-2010, 11:14 AM
beekermartin's Avatar
Quoted: 80 Post(s)
Originally Posted by Kal Rubinson View Post
Why would "direct" add bass? Switching to "stereo" is likely to invoke bass management and, therefore, employ the subwoofer. It would also, if you have set it up, invoke AudysseyEQ to flatten the response. Is it possible that your perception that "Direct had excessive and inaccurate bass compared to stereo" is due to the uncorrected modes in your room?
I think it has more to do with my main speakers. They have two 8" self powered woofers. I am guessing that since Audyssey is not used in direct mode the main's woofers are running full range and playing more bass than in stereo.
I have them crossed over at 40hz even knowing Audyssey sets them as large. Every post I have read says that is what I should set them to. Running them at full range is not recommended even knowing they are capable of @20hz.
beekermartin is offline
post #2882 of 3270 Old 04-29-2010, 11:17 AM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Yup. I never think, unless given a reason to do so, about such odd-ball arrangements.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #2883 of 3270 Old 04-29-2010, 11:24 AM
Quoted: 80 Post(s)
My mains are fairly unusual compared to conventional speakers, Mirage OM-5s. They are quite capable in the bass department. I used them as full range without a sub for a long time. I now have a MFW-15 which is much more powerful in the very low hz range.
Do you agree that I should not run them as full range? I debated this decision for a long time but the final decision was to cross them at 40hz. The lowest setting that the 886 allows.
post #2884 of 3270 Old 04-29-2010, 11:26 AM
Quoted: 678 Post(s)
Liked: 461
Do you agree that I should not run them as full range? I debated this decision for a long time but the finally decision was to cross them at 40hz. The lowest setting that the 886 allows.
I do agree and suggest you might want even to experiment with higher crossovers. What you get is Audyssey's better bass correction in the subwoofer channel.
Kal Rubinson
post #2885 of 3270 Old 04-29-2010, 11:34 AM
Quoted: 80 Post(s)
I have thought about trying that. What is a good way to test different cross over settings?
Audyssey also set my center channel to full range, Mirage OM-C2. I set that to cross over at 60hz.
post #2886 of 3270 Old 04-29-2010, 12:21 PM
Quoted: 678 Post(s)
Liked: 461
There are two ways:
1. Measure FR and decay with REW/ETF/TEF/XTZ/etc.
2. Listen
Kal Rubinson
post #2887 of 3270 Old 04-29-2010, 12:25 PM
Quoted: 80 Post(s)
There are two ways:
2. Listen
LOL.
I don't have access to an special audio testing equipment so my only option is to listen. What would you recommend I listen to? A test disc, movie, music, etc???
post #2888 of 3270 Old 05-23-2010, 04:19 PM
beatboy77's Avatar
Does anyone know where I could get an 885 or 886? I have looked everywhere online (Ebay, Audiogon, etc.) and they are gone.
Hey, if anyone has one of these and is looking to upgrade to the latest, please PM me and I will purchase
Josh
hidefpreview
beatboy77 is offline
post #2889 of 3270 Old 05-23-2010, 04:31 PM
rtart's Avatar
Quoted: 35 Post(s)
Liked: 64
Josh
They are hard to find. I considered an Emotiva UMC-1, but think I'll stay with my 885. It works, and does all I need it to do, and no drama. You can try a UMC-1 for 30 days and return it if you don't like it.
Other than that, just set up a saved search on ebay and one will come along eventually.
I'm finding that I'm smarter than I thought, but dumber than I need to be.
PSN ID: rtart, alt Ginsuyou2
rtart is offline
post #2890 of 3270 Old 05-24-2010, 11:11 AM
neekos's Avatar
Quoted: 61 Post(s)
Liked: 58
Kal:
What would be the best scenario to listen to music through the 886? I have a 5.1 system currently and would like to maximize the potential of my cd collection, some of which are SACD's but most are standard cd's.
neekos is online now
post #2891 of 3270 Old 05-24-2010, 11:17 AM
Quoted: 80 Post(s)
I was thinking about selling my 886 and getting the UMC-1. Unfortunately the UMC-1 has had way to many problems for me to consider replacing the 886 with it. The 886 has worked perfectly since the day I installed it. I would hate to replace it with something that most likely won't be as reliable. I understand the UMC-1 might offer slightly better SQ but even that is debatable. I am using all digital sources via HDMI and the 886 sounds excellent in my setup.
post #2892 of 3270 Old 05-24-2010, 11:17 AM
Quoted: 678 Post(s)
Liked: 461
LOL.
Hard to say. I do not believe in listening to test discs as these are intended for instrumental measurements. I have little experience judging these things from movies since I do not know what the mass is supposed to sound like. OTOH, I have lots of experience with recordings that I have heard on a number of systems (mine and others) over the years and these are the ones I use. They tell me what sounds different as I make adjustments and I combine these observations with measurements to make a determination.
Kal Rubinson
post #2893 of 3270 Old 05-24-2010, 11:19 AM
Quoted: 678 Post(s)
Liked: 461
Originally Posted by neekos View Post
Kal:
I do not understand your question. Do you want to know how to connect up things? Do you want to know what processing formats to use? What other equipment do you have?
Kal Rubinson
post #2894 of 3270 Old 05-24-2010, 12:01 PM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1444
beekermartin,
I agree 100% that keeping your 886 is the wise move. I tried the UMC-1 but held onto my 886 to see if the UMC-1 would stay in my system. Well the UMC-1 went back and the 886 is back in my system. There is a member over at the Emotiva Lounge that sold his 886 before getting the UMC-1. From his initial posts he was not very happy that he sold his 886.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #2895 of 3270 Old 05-24-2010, 05:35 PM
neekos's Avatar
Quoted: 61 Post(s)
Liked: 58
What will give the best stereo sound output. The balanced in, the stereo inputs, via hdmi ?
post #2896 of 3270 Old 05-24-2010, 05:41 PM
Quoted: 678 Post(s)
Liked: 461
Assuming that the 886 is identical to the 9.8 in its audio processing, I would definitely go with the HDMI.
Kal Rubinson
post #2897 of 3270 Old 05-24-2010, 06:03 PM
neekos's Avatar
Quoted: 61 Post(s)
Liked: 58
ok, thanks
post #2898 of 3270 Old 05-25-2010, 06:35 PM
Decepticon07's Avatar
I have one like new willing to sell. It has box, manual, and everything else. Any interest, just pm me with an offer. Just listed it on ebay as well.
Bears... Beets... Battlestar Galactica.
Decepticon07 is offline
post #2899 of 3270 Old 05-31-2010, 08:52 AM
neekos's Avatar
Quoted: 61 Post(s)
Liked: 58
Kal:
My understanding is that the stereo inputs of the 886 still goes through a A/D D/A conversion. Please correct me if I'm wrong.
So to get the best stereo sound from a good cd source, wouldn't the balanced inputs be the best option? or do these inputs also employ conversion as well ? If so, what about hooking up the cd source to the multi channel input of the 886?
I find it hard to believe that many people are saying that these units don't do analog well considering the many input possibilities.
post #2900 of 3270 Old 05-31-2010, 02:02 PM
Quoted: 678 Post(s)
Liked: 461
Kal:
It has nothing to do with A/D/A conversions as you can bypass that with the MCH analog inputs. The issue, for me, is that the analog input stages of the Integra are less competent than I would wish, whether you convert them or not.
Kal Rubinson
post #2901 of 3270 Old 05-31-2010, 04:12 PM
beatboy77's Avatar
Does anyone have a set of rack mount ears for the 886 which they are not using. If you are willing to sell them to me, please send me a PM.
Josh
hidefpreview
post #2902 of 3270 Old 05-31-2010, 04:53 PM
neekos's Avatar
Quoted: 61 Post(s)
Liked: 58
Gotcha, thanks
post #2903 of 3270 Old 06-05-2010, 08:19 PM
wildchild22's Avatar
Quoted: 28 Post(s)
I am wondering what the max pass though resolution with component video is when you are letting the 886 convert it to hdmi?
I cannot get 1080p to pass though but 1080i converts to hdmi, this I tested with a ps3 and xbox 360. Is there something I am missing.
wildchild22 is offline
post #2904 of 3270 Old 06-05-2010, 10:48 PM
Quoted: 80 Post(s)
That is a very interesting question. Since so few components actually allow 1080p via component I am going to assume the 886 does not. The only devices that I know of that will output 1080p via component are the two you mentioned. I would read the 886 manual and see if it says what the maximum component resolution input and output is. I am willing to bet it is 1080i.
Why do you need 1080p over component from the PS3? All PS3s have HDMI so I would recommend you use HDMI with the PS3. I assume you want it for the Xbox because you have an earlier version that doesn't have HDMI. I would recommend you output 1080i from the Xbox and allow the 886 to upconvert it 1080p via HDMI to your display. The 886 HQV scalling chip does an excellent job and will most likely look as good as 1080p directly from the Xbox.
post #2905 of 3270 Old 06-21-2010, 05:55 PM
brucest's Avatar
Does anyone know if the 886 can be upgraded to the 886P or alternately whether it can accept digital feed per ehternet?
brucest is offline
post #2906 of 3270 Old 06-21-2010, 05:57 PM
brucest's Avatar
Does anyone know if the 886 cab be upgraded to the 886P or alternately can be made to accept digital audio via Ethernet?
brucest is offline
post #2907 of 3270 Old 06-21-2010, 06:18 PM
LarryChanin's Avatar
Hi Bruce,
I believe that the "P" designation stands for professional and all that means is that the rack mount ears are included with the prepro.
The ethernet port on this device is only for installer type home automation equipment and remote controllers. It can't be used to download firmware updates, or any other content.
Larry
LarryChanin is offline
post #2908 of 3270 Old 06-21-2010, 06:44 PM
Bill Mac's Avatar
Liked: 1444
Originally Posted by LarryChanin View Post
Hi Bruce,
Larry
Larry,
You are correct. The refurbished 886 (actually brand new) I got from shoponkyo was a non P model which did not include the rack ears. So other than not having rack ears everything else is exactly the same between the P and non P models.
Bill
post #2909 of 3270 Old 06-22-2010, 04:21 PM
brucest's Avatar
Thanks for the response. I thought I saw this on a website for 886p but I didn't notice that the capability while mentioned, was indicated as non existant.
Is there a video card you'd recommend to feed digital audio and video from a computer?
brucest is offline
post #2910 of 3270 Old 06-28-2010, 09:12 PM
Woodlike's Avatar
Sorry to ask a question that is probably in this thread somewhere, but I haven't had a chance to follow recently and I'm swamped with work. I'm wondering if there is a way to save speaker level setting changes? I'd also like to have different speaker levels for different inputs and listening modes. For example, I tend to like a little more sub level when I'm listening to a CD, but I like to go back to the Audyssey level settings when I'm watching a Blu-Ray.
I understand how to make these changes, but I don't like having to make them every time I turn on the preamp. Any help is appreciated.
Woodlike is offline
