Is there any way to know how many watts you are actually using on your receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-18-2008, 06:48 AM - Thread Starter
blued888's Avatar
Is there any way to know how many watts you are actually using on your receiver, at your own usual listening levels? I mean the power output to the speakers.
Eclectic Electronics: A blog containing technology news, information about home theater, digital photography and more.
blued888 is offline
post #2 of 11 Old 11-18-2008, 07:25 AM
penngray's Avatar
Liked: 42
You need the following.....
1. Speaker sensitivity at 1m/1w
2. Distance from speakers.
3. SPL measuring tool
Then you can get something in the ballpark.
penngray is offline
post #3 of 11 Old 11-18-2008, 07:41 AM
Michael Sargent's Avatar
Quoted: 179 Post(s)
Liked: 163
Put a voltmeter across the speaker terminals. Get an average reading on the AC Voltage scale. Then calculate power as:
Power = ( Voltage * Voltage ) / SpeakerResistance
Voltage would be in Volts. SpeakerResistance would be in Ohm (ie. 8 Ohms).
For example, if you read 4 volts, then 4*4/8 is 2 watts.
Mike
Michael Sargent is offline
post #4 of 11 Old 11-18-2008, 07:44 AM
RXPorlando's Avatar
On the (rockford fosgate) web site you can use there formula and punch in the millia amps from your speaker terminals and it converts it to watts being used.
I use this formula for setting my truck amps. It should work just as well with home recievers.
RXPorlando is offline
post #5 of 11 Old 11-18-2008, 08:31 AM
garrettmoore's Avatar
Get a Kill A Watt: http://www.p3international.com/produ.../P4400-CE.html
Plug receiver in, turn on, and mute. This is your base wattage the receiver draws to run the tuner, scaler, display, fans, and anything else.
Turn speakers on to volume you're interested in.
New wattage - base wattage = speaker power usage.
By the way, Killawatts are pretty useful in general.
garrettmoore is offline
post #6 of 11 Old 11-18-2008, 09:16 AM
penngray's Avatar
Liked: 42
I like the killawatts devices! Definitely gives you and idea what equipment costs you the most!
penngray is offline
post #7 of 11 Old 11-18-2008, 09:46 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
They make an inline wattmeter for use with amps and receivers. You can google it.
Remember that a kill a watt meter won't take into account amp efficiency. It's going to be close to 50% for class AB receivers. Efficiency goes up as power goes up, actually.
"But this one goes up to 11"
MichaelJHuman is offline
post #8 of 11 Old 11-20-2008, 07:42 AM
Quoted: 179 Post(s)
Liked: 163
P.S. Don't be surprised if you find that at a comfortable listening level you are putting out a lot less that 1 watt per speaker. Most speakers will kick out something around 90 dB for 1 watt (at 1 meter) and 90 dB is pretty loud.
post #9 of 11 Old 11-20-2008, 09:32 AM
Kendrid's Avatar
And what's funny is that many people think they need a 200w/channel amp when they never use more than a couple.
Kevin
Kendrid is offline
post #10 of 11 Old 11-20-2008, 09:36 AM - Thread Starter
blued888's Avatar
Actually found this via search engine. Might do it on a breadboard if I feel like it, otherwise I'll just do the V^2/R thing.
I know I don't because I've never needed anything more than the receiver itself.
blued888 is offline
post #11 of 11 Old 11-20-2008, 11:56 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 88
But then, most people sit more than a meter away, and the sound level goes down exponentially with distance.
And if you want bass, it will soak up more watts.
But it's still true that most people aren't using a lot of watts, especially for a nearfield or desktop system.
buzzy_ is offline
