SET-UP HELP with bdp-s550 and denon 2807 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-19-2008, 11:29 AM - Thread Starter
habudab's Avatar
set-up help
i have a denon 2807 and i am thinking of upgrading my DVD player to a sony bdp-s550. how should i set this up so i get the best sound and video quality i can achieve.. thanks in advance for the help. what are the settings that i would need to set on the blu-ray to achieve these results.. and also how would i set it up???
thanks
habudab is offline
post #2 of 2 Old 12-20-2008, 05:31 PM
sgtjim57's Avatar
I ahve the same setup and am still attempting to make it work properly. Surround sound is fine, very little output from my sub though. Does your auto setup turn your sub down 12 DB when you run it?
Main System:Sony XBR 55 A1EEmotiva XPA-5 X-Ref 12 subDenon X4000Oppo BDP 93B & W N804 Mains, 603 Rear surrounds, LCR 600 Center, ASW 600 sub, B & W CDS6 S3 front heights
sgtjim57 is offline
