H/K Receiver, Protect Mode, and shorts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-04-2008, 09:04 AM - Thread Starter
Bill Valley's Avatar
I have a H/K AVR 254. I recently had a problem with the receiver going into protect mode. I would hear a loud pop through the speakers and then the receiver would shut down. Eventually I lost the on-screen display. I tried soft reset, reset button on the back, everything recommended in FAQ's and could not get it to work. Harman/Kardon replaced the receiver no questions asked.
So now I have a new AVR 254 but I do not want to have the same problem. I believe there are 2 potential causes:
1. The receiver is seeing a short through the speakers. I had installed in wall speaker wire and terminals right before the trouble. Not sure if this is coincidence or not. I have checked resistance through all of the speakers/wires and get results between 6 and 8.5 Ohms. My in wall wiring does not register any resistance when the speakers are not connected. I think that confirms that I do not have a short, but would like feedback.
2. The receiver is getting too hot in my cabinet. I only have 3" above the reciever and less than 2" on either side. This was not a problem for my previous receiver but this is a much more powerful unit. Should I try to create more spacing for ventilation? And does this receiver really generate tons of heat? If I did have a short this sucker would run real hot and then shut down.....
Panasonic P50S1
PS3
Harman Kardon AVR 2600
HSU Research STF-2
Infinity Primus F/R/C
Running 5.1 (for now)
Bill Valley is offline
post #2 of 4 Old 04-08-2009, 08:02 AM
doltman's Avatar
Did you ever find a resolution to this problem? I have an Onkyo receiver hooked up to a HTPC with Coax surround sound. I just ran my wiring through the walls and hooked up terminal plates. The receiver seems to work fine on Stereo mode, but when I try to go into surround sound and the volume comes up much at all it says "Protect" on the receiver.
doltman is offline
post #3 of 4 Old 04-08-2009, 04:15 PM
Lordoftherings's Avatar
Maybe time to get rid of your HK for another brand, like Onkyo or Denon for example.
Bob
Lordoftherings is offline
post #4 of 4 Old 04-09-2009, 07:50 AM
Vcook's Avatar
does it shut down immediately? It sounds like a speaker short to me, wires touching.
Vcook is offline
