Can't Connect Wii to Sony STR-DG820 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-26-2008, 09:09 PM - Thread Starter
victoraruba's Avatar
Just got a Wii, tried to hook it up to the Sony STR-DG820, but getting no picture. I have a cable box and blu-ray hooked up via HDMI and an HDMI out to the TV... those things work fine, but when I connect the Wii to VIDEO 1, no picture and no sound either through analog audio inputs. BTW, I did hook it up directly to the TV and it worked fine, anyone know what I'm doing wrong?
victoraruba is offline
post #2 of 5 Old 12-26-2008, 11:41 PM
gunbunnysoulja's Avatar
Just curious, are you sure you put the cables in the Video 1 "INPUTS", opposed to OUTPUTS?
gunbunnysoulja is offline
post #3 of 5 Old 12-27-2008, 01:24 AM - Thread Starter
Yes, for sure. I think after doing some research I found the 820 won't pass component video through the HDMI to the TV... does anyone know if this is true? And if so, is there a workaround?
post #4 of 5 Old 12-27-2008, 01:44 AM
cozmo1976's Avatar
Connect component cables from the receiver to the tv (as well as hdmi) - you will have to switch the input on the receiver and the tv though. That is what I had to do with my pioneer receiver, since it doesn't pass analog to hdmi either.
cozmo1976 is offline
post #5 of 5 Old 12-27-2008, 01:54 AM - Thread Starter
Thanks for the suggestion, but that won't work for our setup. The LCD is wall mounted with HDMI and power hidden behind drywall, only thing I can access easily is the yellow/red/white cables on the side. I'll just unplug those when no one is playing Wii.
