Good 7ch Amp for a Marantz AV8003? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-14-2009, 09:30 PM - Thread Starter
f16wolly's Avatar
Anybody have any opinions on a good matching 7-channel Amp for the AV8003? I'm reluctant to get the paired MM8003 because the 8th channel seems like a waste to me. I'm running an NHT Evolution T6 speaker system (6 ohm). I've taken a brief look at B&K, Parasound and Sherbourn. If I can get something for under $2000, sweet...but I budgeted up to $3K. Let me know. Thanks in advance!
-John
f16wolly is offline
post #2 of 11 Old 01-14-2009, 10:58 PM
cansp6's Avatar
The MM8003 is not discrete so if you're not using the full 8 channels the "extra" power will be split among the channels you do use.
Personally, I would look for a used Theta Dreadnaught, Pass Labs X300.5, a BAT or a Gemstone.
cansp6 is offline
post #3 of 11 Old 01-15-2009, 03:35 AM
Cattledog's Avatar
Quoted: 23 Post(s)
You can get the MM8003 for $1700
http://www.accessories4less.com/make...e-Audio/1.html
The amp is fantastic.
Reality Based.
Cattledog is offline
post #4 of 11 Old 01-15-2009, 07:27 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
You may want to give the Emotiva line a look also.
http://emotiva.com/mps2.shtm
phantom52 is online now
post #5 of 11 Old 01-21-2009, 11:57 PM - Thread Starter
f16wolly's Avatar
Thanks for your inputs, gang. The Emotiva looks quite tempting. I think the suggestions by cansp6 are going to be a bit out of the price range, even if I can find 'em used. Anyone else care to throw in?
-John
f16wolly is offline
post #6 of 11 Old 01-22-2009, 12:20 AM
CETA1's Avatar
NAD M25 Masters
CETA1 is offline
post #7 of 11 Old 01-22-2009, 03:08 AM
dotVIBE's Avatar
The Emotiva MPS-2 is a fantastic amplifier.
Those with more of a HT bent sometimes double up on Emotiva amplifiers, and get the XPA-2 and XPA-5 combination if they want serious power to their mains. Still a bargain at $1600 for the two IMO.
dotVIBE is offline
post #8 of 11 Old 01-22-2009, 03:49 AM
Cattledog's Avatar
Quoted: 23 Post(s)
Wildwest (authorized dealer) has an open box MM8003.
http://cgi.ebay.com/Marantz-MM8003-8...3A1%7C294%3A50
Reality Based.
post #9 of 11 Old 01-22-2009, 04:21 AM
dcrna's Avatar
Parasound Halo A51 if you can find one pre-owned.
dcrna is offline
post #10 of 11 Old 01-22-2009, 09:24 AM
runnin''s Avatar
Liked: 45
Anthem pv-7 or Adcom 7607, both running 125 x 7 watts.
runnin' is offline
post #11 of 11 Old 01-22-2009, 09:30 AM
dsmith901's Avatar
For HT the Sherwood Newcastle A-965 is a terrific value that typically sells for about $1k (msrp $1.5K). Check out David Rich's technical review:
http://www.sherwoodusa.com/pdf/A965_from_TSS_review.pdf
"The truth is out there!"
dsmith901 is offline
