Which receiver should I buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2009, 09:42 AM - Thread Starter
AbjectEvolution's Avatar
I currently own a PS3, Wii, and HD Cable Box that will go into the receiver and then into my 37" Vizio hdtv. I have a HTIB setup and so I will be replacing the two front speakers and center. I'm going to move my fronts to the rear and my rears to the sides.
Given this, which one of the following receivers should I buy? If you have another option, feel free to post it.
Yamaha 663
http://www.amazon.com/Yamaha-RX-V663...2469791&sr=1-1
Onkoy 706
http://www.amazon.com/Onkyo-TX-SR706...2469770&sr=8-1
Thanks in advance.
AbjectEvolution is offline
post #2 of 3 Old 01-20-2009, 10:37 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Didn't some people have issues with the Wii and Onkyo? You might want to look into that.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 3 Old 01-20-2009, 11:23 AM
scudpilot's Avatar
I'm also in the same boat and am torn between the Yamaha 663 and the Pioneer 1018. I really like the features and feedback for the Pioneer, but it is kind of ugly. I'll probably take some abuse for saying that but it is part of the purchase decision.
I have been scared away from Onkyo Receivers due to so many complaints of Humming through HDMI and also the very hot operation. I came really close recently to buying the Onkyo 606. For you wanting to use Wii, I would really do some research to find out all the pros and cons of the 2 receivers you are considering.
I am using mine for a Sony HDTV,Sony BluRay, and regular television broadcasts.
The one thing I liked about the Pioneer was that it has a USB port on the front to plug in an IPOD.
Let us know what you decide.
scudpilot is offline
