"OFFICIAL" Pioneer MCACC thread - Page 185 - AVS Forum
 7Likes
post #5521 of 5531 Old 07-03-2014, 02:32 PM
JamesP1701's Avatar
Hi all
Plan on reading the thread in detail tomorrow, but in the meantime, as someone who has come from Audyssey and setting my LX57 up with a B and W series, can you give any tips as to setting up MCACC?
Many thanks,
James
JamesP1701 is offline
post #5522 of 5531 Old 07-03-2014, 02:45 PM
dazz87's Avatar
Liked: 27
Originally Posted by walterappleby View Post
Hopefully you've already double checked this but make sure you have the sub cable hooked up to the proper connector on the receiver. You need to use the Subwoofer connection in the PRE OUT section... not the one in the MULTI CH IN section. Also, try setting the sub power to "On" NOT "Auto".
Yes I had the sub connection to the Pre Out section and not the Multi Ch section. I am going to try a new cable and a factory reset and hopefully it works or its time to look for a new receiver........
dazz87 is offline
post #5523 of 5531 Old 07-09-2014, 03:38 PM
tang7969's Avatar
Liked: 37
Does anybody have a link for a tripod that I could use for my MCACC mic? Tia
-46" SAMSUNG
-ENERGY RC-50'S
-ENERGY RC-LCR
-ENERGY RC-10'S
-SVS PC12 PLUS
-PIONEER ELITE SC-25
-OPPO BDP 103D
http://www.avsforum.com/g/a/1459339/default/
tang7969 is online now
post #5524 of 5531 Old 07-09-2014, 04:17 PM
NYC Guy's Avatar
Any camera tripod should work ok.
NYC Guy is offline
post #5525 of 5531 Old 07-09-2014, 04:17 PM
DonH50's Avatar
Quoted: 64 Post(s)
Liked: 224
Any camera tripod will work.
Edit: Beat by seconds by a guy from NYC, I'm ruined!
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5526 of 5531 Old 07-09-2014, 04:48 PM
tang7969's Avatar
Liked: 37
Thank you. I'm assuming then I'm good with this??http://www.ebay.com/itm/40-Light-wei...item19e95a2fff
-46" SAMSUNG
-ENERGY RC-50'S
-ENERGY RC-LCR
-ENERGY RC-10'S
-SVS PC12 PLUS
-OPPO BDP 103D
post #5527 of 5531 Old 07-09-2014, 05:03 PM
DonH50's Avatar
Quoted: 64 Post(s)
Liked: 224
fine
DonH50 is offline
post #5528 of 5531 Old 07-09-2014, 08:45 PM
NYC Guy's Avatar
You snooze, you lose!
NYC Guy is offline
post #5529 of 5531 Old 07-09-2014, 08:49 PM
NYC Guy's Avatar
I recommend that you buy one that you will also use with a camera and not this one time MCACC setup. If you have an inexpensive point and shoot model this $10 one is perfect. If you use a DSLR you might want to invest in a tripod that is a little more sturdy.
NYC Guy is offline
post #5530 of 5531 Old 07-10-2014, 06:59 AM
DonH50's Avatar
Quoted: 64 Post(s)
Liked: 224
Gitzo is good but may be a little pricey for just the MCACC mic...
pacman9270 likes this.
DonH50 is offline
post #5531 of 5531 Old 07-10-2014, 09:22 PM
devildog1063's Avatar
Liked: 0
For all, to hard reset the Pioneer 1522k when you have a flashing mcacc light press and hold the enter button on the receiver and the tune button at the same time.
devildog1063 is offline
User Tag List
