"OFFICIAL" Pioneer MCACC thread - Page 194 - AVS | Home Theater Discussions And Reviews
 33Likes
post #5791 of 5804 Old 03-11-2015, 03:58 PM
OzHDHT's Avatar
Quoted: 113 Post(s)
Liked: 48
Originally Posted by jeep05 View Post
Can anybody answer this?
EQ in pretty much any RC system will be switched off when measuring. If anything as with other RC systems MCACC will be calculating a fresh auto-EQ from it's room measurements during the calibration process, so it will ignore any existing EQ.
OzHDHT is offline
post #5792 of 5804 Old 03-11-2015, 06:24 PM
jeep05's Avatar
Thank you for the explanation.
jeep05 is offline
post #5793 of 5804 Old 03-11-2015, 06:29 PM
jeep05's Avatar
Sounds as though i have been doing it wrong then.
jeep05 is offline
post #5794 of 5804 Old 03-14-2015, 04:38 PM
OzHDHT's Avatar
Quoted: 113 Post(s)
Liked: 48
Not sure why you would assume this considering I just pointed out its an automated process and the EQ won't be on when you run MCACC anyway. Pretty fool proof in that sense as long as you are paying attention the essentials like the one mic placement and using a tripod.
OzHDHT is offline
post #5795 of 5804 Old 03-14-2015, 07:39 PM
LJ25's Avatar
Quoted: 55 Post(s)
Could someone please help me choose a right time setting for MCACC Pro? I'm attaching the reverb measurements with EQ turned off in hopes that you guys can help me analyze it.
ID:	602705   Click image for larger version
ID:	602713   Click image for larger version
Steam ID: J-Rod0125.
PC Specs: Gigabyte Z87X-UD4H, Intel Core i7-4771, Nvidia GTX 970, Samsung 840 Pro SSD, Western Digital Black HDD, Corsair 8GB Ram, SeaSonic SSR-650RM.
HT: Samsung 60F5300B, Wharfedale Diamond 10.4 Fronts, Wharfedale 10.CS Center, Power Sound Audio XS15-SE, Pioneer Elite SC-82.
LJ25 is online now
post #5796 of 5804 Old 03-15-2015, 01:24 PM
LJ25's Avatar
Quoted: 55 Post(s)
Anyone?
LJ25 is online now
post #5797 of 5804 Old 03-17-2015, 06:56 AM
Stoney Jackson's Avatar
Quoted: 22 Post(s)
Liked: 36
I somehow have lost the microphone that came with my receiver (I blame the wife,) and I have since move my setup into another room. Pioneer wants like $40 for a new one! I see some on ebay but I'm worried that if its not the same as the one that came with the receiver it won't work properly. Can any mic be used to set up?
Stoney Jackson is offline
post #5798 of 5804 Old 03-17-2015, 11:38 AM
DonH50's Avatar
Quoted: 386 Post(s)
Liked: 351
Without knowing what is programmed into the AVR to compensate the mic it came with we have no way of knowing if any mic will work. Almost certainly "any" mic will not work, but chances are the same mic model is used for multiple models over multiple years. And probably for other manufacturer's models as well. That said, I'd probably just order the right one, as then you'll be sure.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5799 of 5804 Old 03-17-2015, 05:17 PM
OzHDHT's Avatar
Quoted: 113 Post(s)
Liked: 48
No most definitely not. Calibration mics are very specific to each brand of AVR. If you tried for example a mic from say an Audyssey equipped AVR from say Denon, it would have a distinct impact on the Pioneers measurements. The Pioneer would be expecting to see a specific mic profile that would be different from what say another system uses. This is a slightly more basic version of what Anthem do with their room correction mics when you buy say an MRX receiver and you have to actually load the calibration profile included with the software on CD for the specific precise calibration profile of mic you've been given. Just bite bullet and buy the correct mic, could be a lot worse - you could be replacing a UMIK-1 or a Dayton calibration mic @ $75 a pop.
OzHDHT is offline
post #5800 of 5804 Old 03-25-2015, 11:30 AM
CRAW's Avatar
Question
I recently reran MCACC (thanks again to Gamelover360's post) after getting some substantially taller speaker stands (32" Sanus) for my NHT Classic 3's, and now I really have to crank up my music to play music/movies (like -10db). Before I could listen comfortably at -20db. Did I do something wrong, or is this normal?
TYIA
CRAW is offline
post #5801 of 5804 Old 03-25-2015, 12:52 PM
scoobdude's Avatar
Quoted: 12 Post(s)
Liked: 26
I noticed mine being lower once I spread my mains out more due to a bigger screen (70" to now around 120" apart). I turn it all the way up to the same -10 for movies when before it was at -20. My speakers are alalways 90 degrees to the wall. So with the sound come dispersion not as over laping, I think this is partially the cause. Could also be more first reflections since closer to the side walls adding more volume.
Yours moved up, so maybe the mic can now hear them better and turned them down
Just a guess
scoobdude is offline
post #5802 of 5804 Old 03-25-2015, 02:38 PM
CRAW's Avatar
Just a guess
Yeah... That's logical. Thx
CRAW is offline
post #5803 of 5804 Old Yesterday, 10:04 PM
kiwijunglist's Avatar
Quoted: 44 Post(s)
I have a problem with my LFE channel.
I have pioneer SC LX87
When I set channel levels in mccac I can hear subwoofer output.
When I play test tracks for AC3 and DTS-HD there is no output during the LFE test.
IF I set speakers to small then I get subwoofer output during the other channels, but the subwoofer still remains silent during the LFE test. I can put my hand on the cone and there is no movement.
For some reason the pioneer receiver is ignoring the LFE channel. Is this a known issue? , it happens with both Dolby HD and PCM 5.1
If I set the subwoofer to off in mccac then the LFE channel is down mixed into the normal channels (ie 5.1 is correctly mixed into 5.0) , so the test discs are definitely working.
HTPC (MediaPortal) / Pioneer SC LX87 / Wharfedale Jade 7 Fronts, 5 Rears, 2c Center / DIY Sub
kiwijunglist is online now
post #5804 of 5804 Unread Today, 06:26 PM
Quoted: 44 Post(s)
Solved my problem.
When setting LFE ATT to AUTO in the icontrolav5 app it applies -20db attenuation to the lfe channel.
I set it to manual mode -0db and everything works fine however whenever i set LFE ATT to AUTO it jumps back to -20.
Not sure why it is doing this. Any ideas on how to fix this or why it does this?
