"OFFICIAL" Pioneer MCACC thread - Page 195 - AVS | Home Theater Discussions And Reviews
 38Likes
post #5821 of 5842 Old 04-20-2015, 05:50 PM
scoobdude's Avatar
Quoted: 27 Post(s)
Liked: 27
The above description is incorrect about the subs getting full range. Here is how it works from my experience
Front large/sub yes/surround large
All frequencies to fronts/surround
Sub only gets the 0.1 of any audio below the xover
Front small/sub yes
Fronts/surrounds get all above xover
Sub gets all below xover for all channels
Front large/sub yes/surround small
Front is full range
Sub is 0.1 or anything below xover frequency for small speakers
Surround is anything above xover
Front large/sub plus/surround large
Front full range
Surrounds full range
The sub will never go above the cross over if one is set no matter if it's set to yes or plus
Hope that helps
P.s. Wish you could have different speaker settings on different mcacc profiles ensive:
scoobdude is offline
post #5822 of 5842 Old 04-26-2015, 07:35 PM
Blaine Morrissey's Avatar
Quoted: 56 Post(s)
Liked: 33
Does anyone know the specifics of how MCACC Pro handles dual subs? Does it adjust delays between the two to get the best results? How does it EQ them? By MCACC Pro I mean what the sc-85 and above have. it seems a lot of people are calling MCACC Advanced something it is not (pro).
Pioneer Elite SC-63 | OPPO BDP-103D | PSA v1500 | SVS PB 12 NSD/v | SVS AS-EQ1 | GR Research A/V-3 | Onix Rocket ELT DPA | Epson 3020 | Dragonfly 120 Screen | APC H15BLK
Blaine Morrissey is online now
post #5823 of 5842 Old 04-26-2015, 08:00 PM
OzHDHT's Avatar
Quoted: 156 Post(s)
Liked: 56
I haven't come across many MCACC experts anywhere, unlike the depth of knowledge on Audyssey by comparison. I have a system with SC-LX88 that runs a ML Motion based system with 2 x ML Dynamo 1000's. The results are very good with MCACC. How exactly it handles EQ'ing and delay vs say Audyssey I couldn't be sure. The subs aren't positioned symmetrically in this system either, there still at left and right sides of the room, however one is tucked in next cabinet and the other under a staircase. If I was to compare to a Steinway system with twin subs (symmetrical under screen 4 ft apart), that I also own elsewhere, the quality of the MCACC results does not compare badly at all. So to me that's saying something of MCACC's ability to deal with dual subs. If you really need a technical answer, you may need to try emailing Pioneer directly about it perhaps.
OzHDHT is offline
post #5824 of 5842 Old 04-26-2015, 08:10 PM
madnaxal78's Avatar
Hi There,
Need help as i bought pioneer VSX1123K AV receiver recently and when i try to set that up in my living room to the TV and to 5 in ceiling speakers. I was just following the instructions on quick setup and put HDMI cable out to out 1 on receiver and the input to one of the HDMIs on TV. selected receiver button and then home setup button to show MCACC on receiver but i don't see any thing getting displayed on TV and is keep on displaying no signal.
Initially i thought its a bad HDMI and i connected that HDMI to ROKU or BD player from TV and it detects it and shows on TV screen but when i connect the same HDMI to receiver i don't get anything.
I am new to receivers, please help. your help is much appreciated. TIA
madnaxal78 is offline
post #5825 of 5842 Old 04-27-2015, 02:33 AM
Quoted: 56 Post(s)
Liked: 33
Gotcha. If you read the MCACC Pro blurb on Pioneer's site it sounds pretty good. It is only on the SC-85 and up from what I can see. Main thing I would like to see when I upgrade from the SC-63 is the dual calibration. The SC-63 was labeled as 7.2 but in reality the .2 is really just a split .1, they are not independent. I found an SVS AS EQ1 to use for now. Here is MCACC Pro.....
Now, MCACC® (Multi-Channel Acoustic Calibration) is taken to a new level of performance with MCACC Pro. Designed by Pioneer for the Atmos-enabled Elite system, MCACC Pro calibrates sound output using a microphone to monitor the sound environment and an equalizer to optimize and precision-tune each speaker to the room. How advanced is MCACC Pro? So advanced that Pioneer engineers have included dual independent subwoofer outputs, each with individual EQ. Tailoring left- and right-channel low frequency response curves lets you achieve optimum subwoofer performance based on specific room placement, creating powerful bass response and seamless integration with your main speaker system. With the push of a button, it’s like having a professional acoustical engineer fine-tune your home theater system.
post #5826 of 5842 Old 04-27-2015, 09:10 AM
scoobdude's Avatar
Quoted: 27 Post(s)
Liked: 27
Looks like the Vsx1130 vsx90 have the dual sub calibrations. Also on one of those two product pages there is a pamphlet explaining the different versions of MCACC
post #5827 of 5842 Old 04-27-2015, 10:37 AM
Quoted: 56 Post(s)
Liked: 33
I prefer the amps in the SC series personally. I will check out th eproduct pages...if it's what I have seen in the past it didn't get into much detail.
post #5828 of 5842 Old 04-27-2015, 10:47 AM
Quoted: 56 Post(s)
Liked: 33
Ok, I just watched a video from the web site. It independently EQ's both subwoofers and adjusts phase between ALL channels..so I would assume it adjusts the two subs for the ideal sound. Now I want to switch to something with MCACC Pro
post #5829 of 5842 Old 04-27-2015, 11:06 AM
scoobdude's Avatar
Quoted: 27 Post(s)
Liked: 27
http://www.pioneerelectronics.com/ep..._Ref_Guide.pdf
There is the brochure.
I am waiting for news of dts:x and new SC models.
post #5830 of 5842 Old 04-27-2015, 07:16 PM
OzHDHT's Avatar
Quoted: 156 Post(s)
Liked: 56
Good find. I never really went searching for in depth data on MCACC Pro. Interesting read.
OzHDHT is offline
post #5831 of 5842 Old 04-28-2015, 02:06 AM
kiwijunglist's Avatar
Quoted: 61 Post(s)
Question:
For some strange reason mcacc always thinks my front speakers are out of phase with the center + rears.
Amp: Pioneer Elite SC LX87
Fronts: Wharfedale Jade 7 - 4 way - 1" tweeter / 3" mid / 6.5" mid woofer / 2x 8" woofers
Center: Wharfedale Jade 2c - 3 way - 1" tweeter / 3" mid / 2x 5.25" woofers
Rear: Wharfedale Jade 5 - 3 way - 1" tweeter / 3" mid / 2x6.5" woofer
Do you think my speakers might be wired wrong internally?
I have checked all my wiring and there are definitely no mistakes there.
I've tried repositioning the speakers and mic, and it always thinks my Jade 7s are out of phase with my Jade 5/2c.
HTPC (MediaPortal) / Pioneer SC LX87 / Wharfedale Jade 7 Fronts, 5 Rears, 2c Center / DIY Sub
kiwijunglist is offline
post #5832 of 5842 Old 04-28-2015, 05:55 AM
DonH50's Avatar
Quoted: 511 Post(s)
Liked: 408
Anything's possible but in most cases distance/reflections cause the signal to be inverted when measured. MCACC will correct it so I would ignore it (as the manual says) and move on.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5833 of 5842 Old 04-28-2015, 06:21 PM
LoudDad's Avatar
Originally Posted by kiwijunglist View Post
Question:
If you have rear-ported speakers, my guess would be reflections off your wall. As mentioned by the previous post, you can probably ignore the out of phase warning and mcacc will do its best. Ideally, if that is happening, I would think you would want to move them further out from the wall or put some absorption behind them.
Bill
LoudDad is offline
post #5834 of 5842 Old 04-28-2015, 11:26 PM
Quoted: 61 Post(s)
Not rear ported. I might try attach a small battery to the speakers and see which direction the cone moves.
If mcacc thinks the polarity is reversed does it reverse the signal or does it add delay?
post #5835 of 5842 Old 04-28-2015, 11:58 PM
OzHDHT's Avatar
Quoted: 156 Post(s)
Liked: 56
Question:
I've seen this happen reasonably often, despite there being no physical phase issue present. I can't recall, but I may have even happened last time ran MCACC with the Martin Logan Motion 7.2 system I've got hooked up to my Pioneer LX88. It's relatively common in other RC systems as well. I used to get it with a Revel centre in another room and system whenever I ran various Audyssey equipped processors to set up the room. However, that issue didn't manifest with RoomPerfect RC in that same configuration. So def as recommended tell it to ignore the anomaly.
OzHDHT is offline
post #5836 of 5842 Old 04-30-2015, 06:17 AM
Sean_S's Avatar
Here's my $.02:
Don't waste your time.
Moving your mic location slightly might make it go away, it did for me on a speaker that was coming back as "out of phase". (This meant to me that the in and out of phase signals' energy at my listening position were roughly the same. Not sure if MCACC can completely correct this situation.) Also, it means that mine and your speakers may not be placed optimally in the room for the MLP, due to reflections.
I think the warning is there to remind the user to use due diligence and verify the wiring before it continues measuring. I think you have done that.
Go ahead and let MCACC do it's thing. My understanding is that if it detects that the out of phase signal is predominant in a frequency range it will adjust the phase of the speaker(s) signal (more of a fine tuning is possible than just flipping the polarity of a speaker or individual driver). So, it will likely be successful in its goal.
Sean
Sean_S is offline
post #5837 of 5842 Old 04-30-2015, 01:45 PM
LoudDad's Avatar
I don't know for sure, but I highly doubt it would reverse the signal. You still have a positive and negative connection to the speaker and I don't think MCACC has anything to do with switching the physical outputs. I would think it just does volume correction, time delay and some EQ.
FYI ... this warning also did happen to me in the past and I did double-check all wiring and it was correct. Then I ran it again and the warning didn't appear. Before I ran it the second time I turned up the volume knob, but not sure if your volume setting is used or not when you run the MCACC calibration (seems like it shouldn't be).
LoudDad is offline
post #5838 of 5842 Old 05-06-2015, 02:00 PM
Quoted: 13 Post(s)
Liked: 0
So can someone explain what Time Position i need to select i have done the reverb measurement test and look at the reverb view graph but they dont make sense to me at all and there broken down into graphs for each speaker, what am i actually looking for to decide what Time Position setting i need to select?
BlockABoots is offline
post #5839 of 5842 Old 05-09-2015, 03:51 AM
Quoted: 13 Post(s)
Liked: 0
Anyone?
post #5840 of 5842 Old 05-14-2015, 11:32 AM
Sean_S's Avatar
Originally Posted by BlockABoots View Post
Anyone?
If you select an earlier time you're correcting more just for the speakers; a later time and your correcting more for the room. If your room has many modes, you may want a later time. The graph is to aid in determining this.
E.g., if you have a near ideal listening space with few room modes and reflections, you have a situation where you can let MCACC more precisely EQ/filter/delay/etc the direct sound from the speakers-- and therefore you would decrease the time to whichever delay is the amount of time it takes the direct radiating sound of drivers to reach your listening position.
If your room is horrible, you would want MCACC to take that into account, therefore you set the delay to be longer so that it captures the modes/reverberations at your listening position and corrects for them. It's a give and take.
Pioneer's default is sort of in the middle, which is logical.
Hope this helps.
Sean
2therock likes this.
Sean_S is offline
post #5841 of 5842 Old Today, 11:13 AM
adrummingdude's Avatar
Quoted: 128 Post(s)
Liked: 48
I'm in the same boat as you, looking to possibly upgrade from my SC-65 after purchasing a second sub and being underwhelmed by the lack of independent adjustment for it. Plus, I would like some different crossover options to really fine tune.
After perusing the sc87/89 manual, I couldn't find the answer to what crossover points the units use. Are the MCACC crossover options still 50 80 100 150 and 200? Or have the (hopefully) added some others? Are we able with these units to cross over mains differently than surrounds or center (like Audyssey) or are all speakers still bound to the same crossover point?
It looks like MCACC and sub equalization is the same in both the 87 and 89, yeah? Does it do distance calculation for two subs as well?
I don't know why the manual doesn't discuss these things in greater detail. It's as if the manuals are written to a 12 year old's level of comprehension. It probably wouldn't be a bad assumption by the manufacturer to understand that the $3000 AVR customer might be a bit more of a power user than a $500 AVR customer, and tailor the literature as such.
B&W CM9 S2, B&W CMC2 S2, DefTech XTR-20BP, Dual SVS SB-2000, Parasound Halo A21, Pioneer Elite SC-65, Samsung UN55F8000, Apple Mac Mini, Iomega NAS
adrummingdude is offline
post #5842 of 5842 Old Today, 06:12 PM
Quoted: 56 Post(s)
Liked: 33
I would like to know all that as well! I wish i could set different crossover points for each speaker also. Ugh. I do like the SVS EQ1 results for the dual subs, dumb that they don't still make it. Maybe check out an anti-mode 2.0, power sound audio carries them now i suspect it will manage dual subs better than MCACC Pro.
