"OFFICIAL" Pioneer MCACC thread - Page 196 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #5851 of 5861 Old 06-28-2015, 04:52 PM
OzHDHT's Avatar
Quoted: 201 Post(s)
Liked: 70
ArchonX, great guide there. I have 2 new front Martin Logans and a new center going into my system that has a LX-88 in it this week. Going to use your workflow for it. I tend to agree with you about the quality of MCACC Pro, with the exception of when you get to much more expensive systems that use say RoomPerfect (and I suspect Dirac Live) as I've got in another other room setup.
Originally Posted by JAMES MCHUGHES View Post
Archon
Loved the info you just posted in the room. How about positions of mic placement after main seat I would like to hear your thoughts
But there's only 1 mic position with MCACC Pro, unlike other RC systems.
OzHDHT is offline
post #5852 of 5861 Old 06-28-2015, 04:58 PM
JAMES MCHUGHES's Avatar
Quoted: 92 Post(s)
Liked: 39
I have the pioneer sc79
Archonx's workflow would not work with my receiver ?
JAMES MCHUGHES is offline
post #5853 of 5861 Old 06-28-2015, 07:02 PM
OzHDHT's Avatar
Quoted: 201 Post(s)
Liked: 70
Care to clarify? I won't be able to redo my system till later in the week. From reading his workflow, I can't see why it wouldn't handle the LX-88 in my system.
OzHDHT is offline
post #5854 of 5861 Old 06-28-2015, 07:13 PM
Quoted: 92 Post(s)
Liked: 39
That's my question I thought it should also. Just thinking it may be for mcacc pro ?
post #5855 of 5861 Old 06-29-2015, 05:22 PM
OzHDHT's Avatar
Quoted: 201 Post(s)
Liked: 70
I wasn't across which models didn't have MCACC Pro, but I see the SC-79 seems to lack it. In which case, its most probably not a workflow for you - you're better off with the original tips from page 1.
OzHDHT is offline
post #5856 of 5861 Old 06-29-2015, 06:11 PM
Quoted: 92 Post(s)
Liked: 39
From page 1 ?
post #5857 of 5861 Old 06-30-2015, 10:14 AM
68bullitt's Avatar
Liked: 0
Hello All,
I recently purchased a used Pioneer SC 68 and am having some problems setting up MCACC. I hope this is the right place to post this question. I've searched on the forum as well as the web in general but haven't found anything to help me. If this is has been discussed please let me know, I don't want to waste any ones time.
The first time I ran Full Auto MCACC I got a few errors saying the speaker wire were reversed, I checked to make sure then proceeded. The results across the front three channels was much better than my old system but I could not hear the surrounds (5.1)unless I climb a ladder to get close to the speakers. So I decided to change the direction the surrounds were pointing and rerun MCACC, and the fun began!
The program starts out alright, but gives different front left, right or, center speaker reverse polarity errors. Then when I tell it to continue, it does but it drops the sub and both surrounds from the test. The speakers are all M & K, LCR-35 across the front three channels, two LCR-25's for the surrounds and a sub.
I know this must be user error, any input will be appreciated.
Thank You
John
68bullitt is offline
post #5858 of 5861 Old 06-30-2015, 06:09 PM
OzHDHT's Avatar
Quoted: 201 Post(s)
Liked: 70
From page 1 ?
Ahh yeah the tips on page 1, the very first post...
OzHDHT is offline
post #5859 of 5861 Old 06-30-2015, 07:36 PM
DonH50's Avatar
Quoted: 581 Post(s)
Liked: 436
Originally Posted by 68bullitt View Post
The first time I ran Full Auto MCACC I got a few errors saying the speaker wire were reversed,<elided>
This is common and nothing to worry about. Depending upon the test tone frequency, speaker design and distance, and room interaction MCACC (or any program) may think your speakers are reversed in polarity. Check the wires and if they are OK then just move on as it says in the manual. MCACC will deal with it. Nothing to worry about and not user error (unless the speakers really are wired wrongly but it will even compensate that).
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5860 of 5861 Old 07-01-2015, 12:12 PM
68bullitt's Avatar
Liked: 0
Thank You DonH50, that's what I thought.
What about it dropping the sub and surrounds? Any ideas about that?
John
post #5861 of 5861 Unread Today, 10:05 AM
zoetmb's Avatar
Quoted: 31 Post(s)
Liked: 42
John
You should really only get supposed phase errors on the surrounds (and largely because they face each other) or if you use dipoles, those will generate phase errors because they're sending both an in-phase and an out-of-phase signal.
It should not drop anything, but in MCACC, go into manual level mode and you can manually test each speaker. As long as you get a signal to each speaker (in turn) during that test, ignore everything else. Also, manually run the phase test. It will play two speakers at a time both in-phase and out-of-phase. You're looking for a solid (rather than diffuse) image in-between each set of two speakers during the in-phase test. If it sounds diffuse during the in-phase test, then either wires are reversed or the particular speaker is internally wired backwards. Just reverse the wiring. (At least I'm pretty sure that the MCACC setup has that phase test - I might be thinking about a test disc I have instead.)
zoetmb is online now
