"OFFICIAL" Pioneer MCACC thread - Page 197 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #5881 of 5884 Old Yesterday, 08:14 AM
therealdjnugz's Avatar
Quoted: 67 Post(s)
Liked: 25
I just realized that I might of been doing the calibrations with the mic at the wrong height. I've been placing the mic at ear level. However, the back of my couch is higher than ear level. Should I raise the mic higher so it's above the back of my couch and rerun MCACC?
Epson 5025ub Projector
Pioneer VSX-1123-K Receiver
SVS Prime Towers Front Left/Right
SVS Prime Center
Polk Audio TSI 100 Side/Rear Surrounds
Bic F12 Subwoofer x 3 (next upgrade)
therealdjnugz is online now
post #5882 of 5884 Old Yesterday, 07:39 PM
OzHDHT's Avatar
Quoted: 225 Post(s)
Liked: 91
If I were you definitely re-run it in the case of a hi-back couch. Otherwise you're creating a physical sound barrier for your surrounds which will skew your measurements.
OzHDHT is online now
post #5883 of 5884 Old Yesterday, 11:29 PM
Quoted: 67 Post(s)
Liked: 25
I re-ran it and it sounds better. I was a little worried about the mic being higher than ear level, but I reprogrammed the speaker distances. Each speaker was exactly three inches off, but the subwoofer was exactly the same. I also took the three standing waves measurements a couple feet spread apart. It sounded a little hollow before if that makes sense. Anyways I'm happy with the results and think I'm done with MCACC until I get an external amp.
OzHDHT likes this.
SVS Prime Center
post #5884 of 5884 Old Yesterday, 11:34 PM
OzHDHT's Avatar
Quoted: 225 Post(s)
Liked: 91
Good to hear. Nothing wrong with manually sorting the speaker distances, I always double check the auto measurements with any RC system. Within 3" won't result in much audible difference in delay setting though.
