"OFFICIAL" Pioneer MCACC thread - Page 214 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #6391 of 6404 Old 05-15-2017, 08:50 AM
citsur86's Avatar
Quoted: 1349 Post(s)
Liked: 536
Will soon be gain matching my soon to arrive second FV15HP sub with the one I already have and the guide I am using has Audyssey as an example. Audyssey EQs with test tones at 75db, making the desired gain matched subs outputting combined gain of 75db at MLP. Can anyone here tell me what db level MCACC uses during auto calibration? I have a Pioneer VSX-44 which I believe is the basic MCACC.
citsur86 is offline
post #6392 of 6404 Old 05-15-2017, 09:22 AM
LastButNotLeast's Avatar
Quoted: 1703 Post(s)
Liked: 1307
Combined gain will be higher (otherwise polarity is wrong).
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #6393 of 6404 Old 05-15-2017, 10:02 AM
citsur86's Avatar
Liked: 536
Michael
Right according to the guide - you want the output db for each sub (with mic at distance of 11% of cone diameter, so little less than 2" for 15" cone), to be same such that the combine output of both is 75db at MLP, for Audyssey. The reason is that when Audyssey runs its test tones, it does so at a volume of 75db. So my question was, what is the db volume at which MCACC outputs test tones during auto-calibration?
citsur86 is offline
post #6394 of 6404 Old 06-04-2017, 09:35 AM
opideegs's Avatar
Quoted: 41 Post(s)
Liked: 5
I recently purchased in 801 I'm using it in a 7.1.4 configuration my question is when my height 2 speakers are set to rear high Will they produce Dolby atmos affects. I have always had onkyo receivers so the MCACC stuff is new so far I am really enjoying
opideegs is offline
post #6395 of 6404 Old 06-05-2017, 05:24 AM
Smsoto0055's Avatar
Has anyone had an issue running avnavigator 2013 on their mac? I can not open the MCACC appi to view the graphs of my speaker readings. I connect to my receiver, I can download the file, but when I click on MCACC appi it just does not open.
Smsoto0055 is offline
post #6396 of 6404 Old 06-05-2017, 06:27 AM
Liked: 1307
The AVR is one of these?
Compatible AV receiver models (as of August 2013):
USA/Canada : SC-79, SC-77, SC-75, SC-1523, SC-1528, SC-72,
SC-1323, SC-1328, SC-71, SC-1223, SC-1228, VSX-70, VSX-1123,
VSX-1128, VSX-1028
South-America : SC-LX87, SC-LX77, SC-LX57, VSX-1123, VSX-923
Europe : SC-LX87, SC-LX77, SC-LX57, SC-2023, SC-1223,
VSX-1123, VSX-923
Asean : SC-LX87, SC-LX77, SC-LX57, SC-2023, SC-1223, VSX-1123,
VSX-923
Oceania : SC-LX87, SC-LX77, SC-LX57, SC-2023, SC-1223, VSX-1123,
VSX-923
Middle-East : SC-LX87, SC-LX77, SC-LX57, SC-2023, SC-1223, VSX-1123, VSX-923
East-Asia : SC-LX87, SC-LX77, SC-LX57, SC-1223, VSX-1123, VSX-923
Supported Mac OS: OS X 10.7 / 10.8
post #6397 of 6404 Old 06-05-2017, 06:32 AM
Liked: 1307
You will not be able to decode the Atmos information, but the AVR will generate sounds for those speakers, so you'll get "effects," just not Atmos.
post #6398 of 6404 Old 06-05-2017, 10:28 AM
Smsoto0055's Avatar
VSX-1128, VSX-1028
VSX-1123, VSX-923
VSX-923
VSX-923
Yes. It's the SC-75.
post #6399 of 6404 Old 06-05-2017, 11:32 AM
Liked: 1307
And the mac OS version?
(Can't help you beyond that, I'm afraid; I have a VSX-1121)
Michael
post #6400 of 6404 Old 06-05-2017, 12:01 PM
Smsoto0055's Avatar
Michael
Yep. Downloaded it directly from the SC-75's page. MCACC appi will open for a second and then shut down.
post #6401 of 6404 Old 06-07-2017, 05:19 PM
opideegs's Avatar
Quoted: 41 Post(s)
Liked: 5
So if I have them set to top rear they should work for atmos information?
opideegs is offline
post #6402 of 6404 Old 06-07-2017, 07:22 PM
Liked: 1307
Is it this one?
http://www.pioneer-audiovisual.eu/eu...ducts/sc-lx801
If so, it is Atmos capable and will calibrate and generate the appropriate sounds in your height speakers.
Sorry, I had trouble finding the exact model with the info you provided.
There's a forum for them here:
Pioneer SC-LX701 / SC-801 / SC-LX901 Receviers
and MCACC info here:
Michael
post #6403 of 6404 Old Yesterday, 11:23 PM
opideegs's Avatar
Quoted: 41 Post(s)
Liked: 5
Yes that's the receiver I've looked through the thread so I just wanted to make sure
opideegs is offline
post #6404 of 6404 Old Yesterday, 11:24 PM
opideegs's Avatar
Quoted: 41 Post(s)
Liked: 5
Thanks for the great info
opideegs is offline
