"OFFICIAL" Pioneer MCACC thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #721 of 6409 Old 06-19-2009, 08:00 AM
tex94's Avatar
Thank you. That makes sense.
tex94 is offline
post #722 of 6409 Old 06-19-2009, 08:43 AM
snownut's Avatar
I noticed that there are three settings with the manual MCACC setup for adjusting the standing wave. If I have my crossover set to 100hz and I have speakers set to small, should the filter channel be set to SW only? There are 3 options for filter channel, Main, SW or Center. Can anyone explain these?
SnowNut
snownut is offline
post #723 of 6409 Old 06-19-2009, 10:00 AM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
In terms of influencing what we hear at the listening position, the response of the room as it is excited by the speaker (e.g. standing waves) dominates from 20Hz to ~500 Hz. Above that the sound of the loudspeaker as it is modified by the room (e.g. reflections) dominates. Floyd Toole has laid this out nicely in his talks and papers, e.g. his 2001 article in Audio Critic
Given that it makes sense that standing wave control in MCACC targets frequencies above as well as within what would be consider 'subwoofer' frequencies -- frequencies handled by mains and center (and surrounds)
I don't recall right now -- does Pioneer say anywhere what the upper frequency bound of its standing wave control is? I presume its lower bound is 63Hz, as with its EQ setpoints. More comprehensive standing wave control would target frequencies lower than that too.
krabapple is offline
post #724 of 6409 Old 06-19-2009, 10:43 AM
snownut's Avatar
Thx, I sort of understand this stuff. I am wondering about the actual filter settings and how they function based on whether or not your speakers are set to small or large. Page 48 of the owner's manual describes how to adjust these settings. The discripton for "Main" is "all except center channel and subwoofer". Then you have choices for Center only or Subwoofer only. I don't have equipment to test anything, I am just trying to get a little more educated. I makes sense to me, if you are using a subwoofer for most of the bottom end, wouldn't you want the filter set to "SW"?
Does anyone know how to effectively use any of the 3 settings. It says you can apply a different filter setting per MCACC preset. I am guessing that if you had your system set for stereo use and only used the main speakers as larger, you would want the filter applied to "Main" then. (This is not my case BTW)
SnowNut
snownut is offline
post #725 of 6409 Old 06-19-2009, 03:25 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
But this presumes again that standing waves only matter in the part of the 'bottom end' that is output by the sub. Standing waves affect sound all the way up to 500 Hz, which means mains/C/sur too.
Standing wave control treats just three modes. I'm not sure what criteria Pioneer uses to determine which three modes to treat. Perhaps the biggest-amplitude (+ or - ) deviations from 'flat'? Or perhaps just the 'positive' deviations (not nulls) , because correcting those is easier than fixing a null? Either way, the selection criteria could end up only affecting the mains or center, if the selected modes aren't ones in the subwoofer range.
post #726 of 6409 Old 06-23-2009, 09:41 AM
bsoko2's Avatar
Quoted: 72 Post(s)
Liked: 79
Question: I reran MCACC and told it that I had THX speakers. Ran the setup for "All Channel Align" and when finished the speakers were set to small. Now in the past with just running MCACC it always set the speakers to large. My system can support low hz with mains Polk SDA SRS 2.3's @ 350 wpc and surrounds are Polk Monitor 12's @ 200 wpc. With the THX choice the speakers are more alive and dynamic and it is the best that I have ever been able to get from them. Now what I want to know, is choosing the THX for speaker setting does MCACC apply the THX filtering in the setup?
Thanx, Bill
bsoko2 is offline
post #727 of 6409 Old 06-23-2009, 10:06 AM
Macfan424's Avatar
Thanx, Bill
MCACC doesn't apply THX filtering, just THX speaker standards. Among these are that all are set to Small and crossed over to a sub at 80 Hz.
Macfan424 is offline
post #728 of 6409 Old 06-27-2009, 04:26 AM
pokeyron's Avatar
What should my sub settings be prior to running MCACC on my SC-05?
pokeyron is offline
post #729 of 6409 Old 06-27-2009, 08:24 AM
Gov
Gov's Avatar
Quoted: 118 Post(s)
Liked: 184
Have your sub gain around 30-40% before you run MCACC.
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Ascend Acoustics CBM-170SE (L/R), Ascend Acoustics CMT-340SE-C, Wave Crest HVL-1 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #730 of 6409 Old 06-27-2009, 11:39 AM
pokeyron's Avatar
Thanks...what about the crossover? Sorry, I am new to this (and my SC-05).
pokeyron is offline
post #731 of 6409 Old 06-27-2009, 12:04 PM
Macfan424's Avatar
Turn the sub's crossover off if you can. If not, set it to the highest setting it has. Your 05 has it's own crossover, and it isn't desirable to have a second one active in the circuit.
If your initial setting of the sub's gain control is too high or too low, MCACC will tell you, and you can adjust it as needed.
post #732 of 6409 Old 06-27-2009, 12:45 PM
acrylamidetic's Avatar
Hey All:
Just bought the Pioneer VSX-819H from Best Buy. Hooked it up to recently purchased Energy Classic 5 pack. I do not currently have a subwoofer hooked up (that's the next purchase.)
When trying to run the Pioneer autocalibrate function (MCACC), at first it got through the front 3 speakrs (L, C, R) fine, but when it reached the SR it would start playing a few test tones then shut off completely. I troubleshooted by rearranging speakers and wires. Concluded it wasn't a speaker, so probably a wire (maybe shorting out?). So by rewiring I got it now so that it will play through the first round of test tones through all 5 speakers, but in the summary it comes up with an ERR message for the surround speakers even though both do play the test tones.
I have been unable to figure out from the manual or google what that means. Thinking the speakers were too close (probably ~ 4 feet from the mic) I moved them back a bit farther, and that didn't fix it.
Any ideas? Suggestions?
acrylamidetic is offline
post #733 of 6409 Old 06-27-2009, 02:22 PM
reaper12's Avatar
An Err message normally means that speaker cable is reversed. I think most modern receivers can handle this, but, the auto setup just lets know for your information that the wires might be reversed. On some speakers/setups it might give an err even with everything right. For instance, my last amp, a marantz sr8001 always gave an err for left speaker, even though everything was perfect.
To sum up, if you get an err during autocalibration and then have gone back and checked your speaker wire and your connections and everything looks ok, then I think it's safe enough to ignore the err message,.
reaper12 is offline
post #734 of 6409 Old 06-27-2009, 02:23 PM
GregLee's Avatar
Quoted: 867 Post(s)
Liked: 292
If you can hear the test tones but the receiver can't, it may be a problem with the microphone or its connection.
Greg Lee
GregLee is offline
post #735 of 6409 Old 06-29-2009, 06:10 AM
Maestro J's Avatar
Quoted: 75 Post(s)
Liked: 55
Hey guys - quick MCACC question - I have an SC-07 and I'm about to add an external amp to help drive my 4 ohm 5.0 speakers. After making all the connections, if I rerun the MCACC will it still calibrate based on what it's "hearing" from the new amp?
Maestro J is offline
post #736 of 6409 Old 06-29-2009, 07:50 AM
Macfan424's Avatar
Your SC-07 will drive 4 ohm speakers just fine. It is THX Ultra2 certified, and all Ultra certified amplifiers must be stable on all channels to 3.2 ohms, at least.
However, to answer your question, MCACC doesn't care whether you use the internal amps or external ones. It will provide accurate results either way.
post #737 of 6409 Old 06-29-2009, 03:13 PM
taxman48's Avatar
Quoted: 313 Post(s)
Liked: 305
Removing amp from 7.1 system:
I have a 2 ch. amp (for mains) that I just sold, getting a more powerful one.. Do I have to run MCACC again until I get a new amp? AVR is VSX-03, with a 7.1 system..thanks in advance
taxman48 is offline
post #738 of 6409 Old 06-29-2009, 04:26 PM
Macfan424's Avatar
There might be some difference, depending on the input sensitivity of your amp, but it's likely to be relatively small, so I don't think you'd "have to run MCACC again." Still, it only takes a couple of minutes, so why not?
post #739 of 6409 Old 07-05-2009, 07:56 PM
pokeyron's Avatar
O.k., just to make sure I have my terminology correct here..."Lowpass" (as on my Klipsch SUB-10) is the same as crossover, correct?
So when you say to turn it off (which I can't do) or set it to the highest setting, the lowpass starts at 40 and goes up to 120. So I should set it at 120, right?
And there is a switch for phase; at 0 or 180. Which is more desirable?
Again, thanks for putting up with all of my questions.
pokeyron is offline
post #740 of 6409 Old 07-06-2009, 04:56 AM
info_dan's Avatar
Correct, Lowpass at 120, phase at 0, let the receiver do the work.
Dan.
info_dan is offline
post #741 of 6409 Old 07-06-2009, 06:49 PM
Kool-aid23's Avatar
Quoted: 14 Post(s)
Hi, I hope someone can help me understand what I can control with MCACC. I've been reading several threads regarding standing waves and some have suggested just turning it off for the subwoofer only. I've read my manual and other threads but I haven't been able to learn how to do so. So is it possible just to turn off standing waves for the subwoofer only, and if so, how do I do it?
Kool-aid23 is online now
post #742 of 6409 Old 07-06-2009, 07:19 PM
Myth's Avatar
this may sound strange, but i was wondering if newer pioneers have a 360 input preset. i understand that you can't rename a lot of these. just curious
i'm about ready to pull the trigger on the VSX-819.
Windows 7 Home Premium, Intel Core i7 920@2.67ghz, 1.5TB HDDx2, 8GB DDR3@1066mhz, Nvidia Geforce GT220
Myth is offline
post #743 of 6409 Old 07-06-2009, 07:44 PM
CT_Wiebe's Avatar
Myth -- Pardon my ignorance, but what is a "360 input"?
I've never heard of that, or any kind of input signal described in those terms.
- Claus {non-Santa model}
CT_Wiebe is offline
post #744 of 6409 Old 07-06-2009, 07:45 PM
Myth's Avatar
can i change hdmi 1 to xbox 360?
Myth is offline
post #745 of 6409 Old 07-06-2009, 07:51 PM
CT_Wiebe's Avatar
Myth -- AFIK, no AVR has any presets for specific devices (Xbox, PS3, etc.). Yes, you can connect an X-Box 360 to any of the HDMI inputs, including HDMI #1.
You do not need to "change" anything (literally speaking). You do need to set your Xbox 360 to output it's video (and audio) to send its output as HDMI (PCM or Bitstream, for the audio part - that all depends on the Xbox 360). When you want to listen & watch the Xbox 360, you just select the HDMI #1 input.
CT_Wiebe is offline
post #746 of 6409 Old 07-06-2009, 07:53 PM
Myth's Avatar
hmm then i'm not sure about the pioneer now
Myth is offline
post #747 of 6409 Old 07-06-2009, 08:13 PM
Stew4msu's Avatar
Why?
Stew4msu is offline
post #748 of 6409 Old 07-06-2009, 08:15 PM
Myth's Avatar
Originally Posted by Stew4msu View Post
Why?
i took a look at the official thread here, and i left it with mixed thoughts.(based off of mixed reviews) i will probably still get it, and if it's crap, i'll return it. do you have the unit? is it good for you?
Myth is offline
post #749 of 6409 Old 07-06-2009, 08:19 PM
CT_Wiebe's Avatar
I agree. It's the same for any other manufacturer's AVRs, as well. The interfaces all work the same way.
Are you talking about "Renaming an Input", so you can remember what it is?
CT_Wiebe is offline
post #750 of 6409 Old 07-06-2009, 08:20 PM
Myth's Avatar
Originally Posted by CT_Wiebe View Post
I agree. It's the same for any other manufacturer's AVRs, as well. The interfaces are all the same.
Are you talking about "Renaming an input" so you can remember what it is?
yes, i am curious if you can rename them.
Myth is offline
