"OFFICIAL" Pioneer MCACC thread - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #1471 of 6411 Old 10-24-2010, 07:10 PM
Pologuy's Avatar
Ok, well, it appears as though a few things may be going on here...
For one, I am getting no subwoofer action in my speakers no matter what I play a CD or a blu-ray...
And two, for some reason when I played a blu-ray it did not switch over to allow for HD audio...
Panasonic 65VT25 (09/17/10)
Pioneer Elite SC-37 AVR
Pioneer Elite BDP-09FD blu-ray player
Infinity Interludes IL60, IL50, IL36C, IL10
"I see stoopid people..."
Pologuy is offline
post #1472 of 6411 Old 10-24-2010, 07:40 PM
kevin_mahaney's Avatar
Liked: 26
I think sgupta is going to be your best friend with regards to your powered speaker dilemma (he was going through the same thing recently). As far as your other issue, are you saying that the receiver did not automatically switch to lossless audio? If so, the receiver remembers the last mode you used for each sound format. So, if you use THX Select2 Cinema mode for a DD 5.1 (lossy) format, it will use that as the default. In your case, when you play a Blu-Ray in, say, DTS-HD MA, and you select the Standard Surround mode of DTS-HD MA, it should remember that and use it as the default when it receives that format. Many Blu-Ray discs, however, do not default to the lossless codec and you have to switch it manually, which could also be the issue.
kevin_mahaney is online now
post #1473 of 6411 Old 10-24-2010, 08:42 PM
anbudan_prabha's Avatar
Originally Posted by info_dan View Post
If your "Cross-over" is the one in the AVR and the Low-pass filter is the one in the sub, then your setting is incorrect, you're applying two filters on the low frequencies, which is not a good thing and is probably the cause for the SW +10db.
On the sub itself, either turn off the low-pass filter completely if you can, or set it's low-pass filter to the highest value it can go.
Also, I suggest you try setting the AVR cross-over at 80 Hz first.
Once those two changes are made, re-run the MCACC.
Hope this helps, let us know the results!
Dan.
I am yet to try this and let you know soon. Meanwhile I did another change to see what happens.
As suggested, I have turned the volume in Subwoofer to 80% then I rerun the calibration where I noticed there is considerable better difference in the output. What I used to get volume ouput at -20 db it is outputting at -30 db level itself.Also I see it is more in sync and has better effect. After the calibration, this is where it stands now.
I also kept the mic in better position this time in top of the stick ( close to tripod ) instead of keeping it on the stool.
Also calibration changed the crossover settings to 150HZ from where I setup as 100 HZ. I think as Tallnick suggested, I may keep that way.
L +4.5db
R +2.5 db
C +4.0db
SR +3.0 db
SL -1.5 db
SW -1.5 db
anbudan_prabha is offline
post #1474 of 6411 Old 10-25-2010, 02:54 AM
TKO1's Avatar
Liked: 65
Originally Posted by CHP_VR View Post
What kind of problem, bsoko2?
Installing or getting it to communicate?
As far as the software for 2.2.. here is the system requirements:
Requirements for using the application on your PC
The computer must be a PC functioning with one of the following operating systems: Microsoft®
Windows® Vista Home Basic/Home Premium/Ultimate SP1, Windows® XP Professional/Home Edition
SP3 or Windows® 2000 Professional SP4.
The monitor must have a display resolution of 800 x 600 dots (SVGA) or greater.
An RS-232C port connector is necessary for graphical output. Refer to the PC's operating instructions
and/or the PC manufacturer for more information on making the proper port settings.
Does anyone know if there is a Windows 7 version of Advanced MCACC PC software? Or do these versions work on Windows 7.
TKO1 is offline
post #1475 of 6411 Old 10-25-2010, 12:42 PM
bsoko2's Avatar
Quoted: 72 Post(s)
Liked: 79
bsoko2 is offline
post #1476 of 6411 Old 10-25-2010, 02:26 PM
sgupta's Avatar
Quoted: 32 Post(s)
Yeah, these speakers with sub built in must act a bit differently than regular speakers, especially when connected via speaker wire only (as you can do it that way; OR with the LFE channel; with my Pioneer my LFE channel wasn't working, so I was using speaker wire only).
Also, I originally wasn't seeing lossless either, and found out my Blu Ray player (Sony BDP-S770) had a "mix" setting enabled by default for interactive secondary audio. Apparently that particular player can't handle lossless + interactive audio, so turning that control off got DTS HD Hi-Res working.
sgupta is offline
post #1477 of 6411 Old 10-25-2010, 02:33 PM
sgupta's Avatar
Quoted: 32 Post(s)
If I recall correctly, you're hooked up with speaker wire only, correct? This won't allow you to run the subwoofer "test tone" as that relies on the LFE, but you should still be feeling bass coming through a strong movie or bassy soundtrack.
- Are your front speakers being set to Large by MCACC? (If not, try setting them manually).
- Is Subwoofer set to OFF in MCACC? As it needs to be if you're running them as full range with no LFE.
- If your speakers have powered subs, make sure they're plugged in. After doing some rearranging, I found my right sub wasn't working, and it turned out the plug (underneath the base of the speaker) had slipped out, but the cord management made it seem like it was still connected.
- If you need to verify your subs are working, even if you don't want to use it down the road, try using an RCA cable and making the LFE connection (either individually or with a splitter) if your subs support it. This should let you use test tones and at least verify your subs are working. Running LFE is not entirely necessary, but it does have a few advantages (and should also mean you don't have to turn the LFE knob to max anymore).
sgupta is offline
post #1478 of 6411 Old 10-25-2010, 04:16 PM
Defcon's Avatar
Quoted: 1164 Post(s)
Liked: 615
I wonder how much difference these auto calibration routines make? Obviously if there is a situation with mismatched speakers or placement I can see it making an improvement.
But say I have 5 identical speakers in close to ideal position in a normal living room, and receiver is set to defaults. How much difference in sound would I notice after running MCACC/Audyssey?
Defcon is offline
post #1479 of 6411 Old 10-25-2010, 05:00 PM
ccotenj's Avatar
Liked: 101
in a perfect room, with perfect setup, they wouldn't be "necessary"...
but very few "living rooms" are "perfect rooms"... in reality, very few "dedicated rooms" are "perfect rooms"...
at the very least, the auto level setting and time delay setting are pretty much invaluable to most people... i bet not 1% out of the "normal population" even knows what a spl meter is, let alone actually has one...
- chris
ccotenj is offline
post #1480 of 6411 Old 10-26-2010, 04:22 PM
bsoko2's Avatar
Quoted: 72 Post(s)
Liked: 79
Anybody - I dropped the mic to my SC-37 and it doesn't work properly anymore. Pioneer is backordered a month on getting a new one to me. Does anybody have a suggestion on what might work. Tried a mic from a '94 and it was terrible on the treble. I have a SMS-1 and was wondering about using that mic but no adapter that I can find to go from XLR to mic jack. Is there anyone near me in Olympia that I could borrow SC series mic to calibrate my system.
Thanks, Bill
bsoko2 is offline
post #1481 of 6411 Old 10-26-2010, 06:01 PM
m-heat's Avatar
XLR->RCA->mono 1/8 and you might be good.
It's my understanding that you can use any mic
Picture without sound is surveillance.
m-heat is offline
post #1482 of 6411 Old 10-26-2010, 08:00 PM
bsoko2's Avatar
Quoted: 72 Post(s)
Liked: 79
Tried a mic from the Pio '94 and it was terrible.
bsoko2 is offline
post #1483 of 6411 Old 10-26-2010, 08:42 PM
Blacklac's Avatar
Hello all. I am looking to get a new AVR for my bedroom setup, which is 2.1. Does MCACC work fine for a 2.1 setup? I apologize if this has been talked about before, I searched 2.1 and stereo and didn't really see anything about 2.1 setups.
Blacklac is offline
post #1484 of 6411 Old 10-27-2010, 05:36 AM
ccotenj's Avatar
Liked: 101
yes.
- chris
ccotenj is offline
post #1485 of 6411 Old 10-27-2010, 06:30 AM
Blacklac's Avatar
Originally Posted by ccotenj View Post
yes.
Thank you.
Blacklac is offline
post #1486 of 6411 Old 10-27-2010, 08:12 AM
m-heat's Avatar
Any cheap mic will limit your results. Pioneer is a great brand buy the mic they give you is free.
m-heat is offline
post #1487 of 6411 Old 10-27-2010, 12:11 PM
xMEATx's Avatar
Can I set my speakers to small and still set my sub x over to around 60? I think my center sounds a little light to me, if they are x ed & 80. Thanks
xMEATx is offline
post #1488 of 6411 Old 10-27-2010, 12:15 PM
ccotenj's Avatar
Liked: 101
you could set them xover to 50 if you like and give that a shot...
dunno how much it's gonna help the "lightness" of your center channel though...
- chris
ccotenj is offline
post #1489 of 6411 Old 10-28-2010, 11:45 AM
r3v3nant's Avatar
Quoted: 33 Post(s)
Liked: 41
when you guys talk about MCACC letting the user determine the sub EQ settings, how do you do that? I went through the whole thing and didn't find where I could tweak the sub EQ settings, just distance, level, and x-over freq... when you "tweak the sub settings" are those the only settings you are tweaking??
Listening: Outlaw Audio 950 | Pioneer Elite DV-47ai | 2x Marantz MA-700 + 2x MA-6100 | Energy RC-70 bi-amped + Outlaw Ultra-X12
HT: Pioneer Elite SC-71 AVR | LG 60PV450 plasma | all BIC 7 speaker surround + Klipsch sub-12hg | Sony BDP-S350 | WD TV
r3v3nant is offline
post #1490 of 6411 Old 10-28-2010, 11:58 AM
ccotenj's Avatar
Liked: 101
that would be all you can set for the sub... distance and trim level...
i think when people say "tinker with the sub eq", they are indicating that they are using some type of external equalizer (bfd, sms-1, svs-aq, etc) for their sub...
- chris
ccotenj is offline
post #1491 of 6411 Old 10-29-2010, 06:23 AM
bmurray716's Avatar
would adjusting the standing wave filter settings on the sw be considered another adjustment beside the ones you mentioned?
LG 42LB5600, Sony BDP-S590, Pioneer VSX-1019 AH-K, JBL LX22, Definitive Technology ProCenter 1000, Polk DSWPro400, Polk OWM3, Logitech Squeezbox Classic, Squeezebox Radio
bmurray716 is offline
post #1492 of 6411 Old 10-29-2010, 07:04 AM
ccotenj's Avatar
Liked: 101
yup. good catch there...
- chris
ccotenj is offline
post #1493 of 6411 Old 10-29-2010, 09:30 AM
StuBerger's Avatar
Quoted: 14 Post(s)
That was my question up a few pages...I heard that the Standing Wave really shouldn't be used on a quality sub...is this true?
Those are my principles, and if you don't like them... well, I have others.
StuBerger is offline
post #1494 of 6411 Old 10-29-2010, 11:38 AM
ccotenj's Avatar
Liked: 101
no, not true. standing waves are a function of the room.
- chris
ccotenj is offline
post #1495 of 6411 Old 10-30-2010, 10:47 AM
meg3020's Avatar
hi everyone, i just upgraded (I thought) my front speakers from HTD Middy Compact Speakers to Polk Monitor 60 II . I'm using a JBL PSW1000 sub. I ran the MCACC, change all speaker to small and re-ran MCACC. But I could not tell any sound improvement, its lacking some punch or something. I want to hear glass when its broken. Could someone give me a little advice on which one to adjust to start with? Thanks.
P.S.
CCOTENJ, I like your speakers, they look great.
New to Audio/Video
meg3020 is offline
post #1496 of 6411 Old 10-30-2010, 10:55 AM
ccotenj's Avatar
Liked: 101
thanks meg, appreciate it...
let's start by making sure that your microphone positioning is correct... here is a link to some instructions on that...
clicky
also make sure it's as quiet as possible when you run it...
try that and see what you get...
- chris
ccotenj is offline
post #1497 of 6411 Old 10-30-2010, 01:05 PM
bsoko2's Avatar
Quoted: 72 Post(s)
Liked: 79
clicky
I don't fully agree with the instructions. You can do a manual fine tune to the distance and db for better accuracy. I do it after MCACC has done it's thing. Sometimes MCACC is dead one and other times a few of the speakers are off from what manual fine tuning gives you.
bsoko2 is offline
post #1498 of 6411 Old 10-30-2010, 01:07 PM
ccotenj's Avatar
Liked: 101
good for you...
why don't we get meg started in the right direction FIRST, then we can move on to fine tuning?
- chris
ccotenj is offline
post #1499 of 6411 Old 10-31-2010, 09:32 AM
StuBerger's Avatar
Quoted: 14 Post(s)
Hey, all of you MCACC tweakers...have a great Halloween...BOO!
post #1500 of 6411 Old 10-31-2010, 10:49 AM
simple man's Avatar
Quoted: 24 Post(s)
You too Stu
simple man is offline
