"OFFICIAL" Pioneer MCACC thread - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
post #2701 of 6299 Old 12-12-2011, 02:36 PM
muad'dib's Avatar
Quoted: 146 Post(s)
Liked: 50
Originally Posted by Osamede View Post
Front aligned sounded best for me inTNT 3.1 setup.
Speaking of modes. What is best EQ for 7.1/9.1 setup??
I want the brightest/sweetest sound I can?
muad'dib is online now
post #2702 of 6299 Old 12-12-2011, 06:53 PM
jpeter1093's Avatar
Originally Posted by ccotenj View Post
placebo... as increasing all the channel levels by x db is exactly the same as increasing the master volume by x db...
I don't disagree, but could there be something to be said for having the higher input signal level to the amp stage?
jpeter1093 is offline
post #2703 of 6299 Old 12-12-2011, 08:29 PM
ccotenj's Avatar
Liked: 101
nope... you can't create voltage that isn't there...
- chris
ccotenj is offline
post #2704 of 6299 Old 12-12-2011, 10:52 PM
Gov
Gov's Avatar
Quoted: 117 Post(s)
Liked: 183
So I slid my center speaker to where the front baffle is about 1/2" over the top edge of the glass shelf. I reran the default auto MCACC "keeping my speaker settings" and I am still getting +8dB in the 125Hz band. This kind of concerns me since I sit 15 feet away and like to play movies -5 to -12dB MV from reference on my SC-05. I hope I am not putting to much strain on the receiver
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Wave Crest Audio HVL-1 (L/C/R), Pioneer SP-BS 22 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is online now
post #2705 of 6299 Old 12-13-2011, 02:01 AM
motrhed's Avatar
Gov: Standing wave possibly? Just for grins try moving the mic 2-3 feet forward, see if the 125Hz hump goes away.
motrhed is offline
post #2706 of 6299 Old 12-13-2011, 08:31 AM
LastButNotLeast's Avatar
Quoted: 1516 Post(s)
Liked: 1123
I just brought this up on the REW forum. The graphs below are the frequency response at my sitting position ("center") and ONE FOOT to the left and right.
You may want to run a series of sweeps (http://www.realtraps.com/test-cd.htm) and see if you can hear any dramatic peaks or nulls, and work from there using manual MCACC.
Or sit somewhere else.
Michael
edit: the RealTraps sweeps only go to 300Hz, so they're mostly for subs. Google led me to this, http://binkster.net/extras.shtml#cd, which includes higher test tones.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #2707 of 6299 Old 12-13-2011, 09:11 PM
DonH50's Avatar
Quoted: 1828 Post(s)
Liked: 1361
Thus the need for room treatment...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #2708 of 6299 Old 12-13-2011, 10:22 PM
Gov
Gov's Avatar
Quoted: 117 Post(s)
Liked: 183
Pretty sure that is my problem
Gov is online now
post #2709 of 6299 Old 12-14-2011, 12:44 PM
DonH50's Avatar
Liked: 1361
125 Hz sounds like a room mode to me. If you can't move the listening position you should be able to EQ it down, though that is getting to be a fairly large hump. Room treatment will tame it, but you may need a number of panels at 125 Hz (depends on size, thickness, placement, etc.)
Note 125 Hz has a wavelength of about 9', or a quarter-wave of about 2 1/4 feet. If you could move your listening position a couple of feet forward or back you might significantly reduce the hump. And potentially find a new one...
post #2710 of 6299 Old 12-20-2011, 01:48 AM
motrhed's Avatar
I'm not familiar with room treatment methods, what could you possibly do for bass frequencies? Obviously the mats they hang on walls in auditoriums would do nothing for bass, given the extremely long wavelength... The only think I can think of would be to put up big heavy panels at various locations in the room, a couple feet out from the walls, but that doesn't seem very desireable from a room aesthetics standpoint...
motrhed is offline
post #2711 of 6299 Old 12-20-2011, 08:14 AM
Gov
Gov's Avatar
Quoted: 117 Post(s)
Liked: 183
Well, since I cannot move my LP at all, I lowered the EQ to +5dB and changed the crossover from 80Hz to 100Hz. This seem to help clean up dialogue at near reference level with some male voices. I guess it makes sense.
Gov is online now
post #2712 of 6299 Old 12-20-2011, 12:35 PM
DonH50's Avatar
Liked: 1361
The amount of bass absorption depends upon the panel material and placement. I use a number of 4" panels plus a few 6" spaced about 2" from the wall and they helped a lot to well below 100 Hz, probably down to 50 Hz or so. The panels don't suddenly stop working, but the roll-off is steeper with thinner panels. You can treat a room to absorb LF content, but it takes a lot of panels (I have a lot - there are definite trades to that approach).
Diffusion is more difficult at LF because the diffracting elements do need to be a significant fraction of the wavelength.
Check out the articles on sites like Ethan's: www.realtraps.com
post #2713 of 6299 Old 12-21-2011, 07:50 PM
Liked: 1123
Good thing he works for the company:
"Indeed, I have 40 RealTraps in my own living room home theater, but I also use the one-band cut-only EQ built into my SVS PB12-Plus/2 subwoofer to tame the worst modal peak around 40 Hz by a few dB."
RealTraps are $550 each!
That's a serious hobby.
post #2714 of 6299 Old 12-21-2011, 09:51 PM
DonH50's Avatar
Liked: 1361
You can roll your own or get kits. I have, um (counting), 26 in my room and the cost was about $3k. Building your own would be much cheaper; I figured I could do it for under $1k but liked the kits. About 15 - 20% of the cost of my system is room treatment, which does not seem unreasonable to me.
post #2715 of 6299 Old 12-22-2011, 07:58 AM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
yes, that is correct...
in the hundreds (thousands?) of times i ran mcacc, i never had it set speakers to anything but large...
This is interesting, with the mic on a stand, and me outside the room during the calibration I get pretty consistant results from one cal run to another... but depending on setting the speakers large/small and keeping the speaker setting for the calibration, the standing wave compensation curve changes quite a bit and the 63Hz EQ changes accordingly.
With speakers set to large I get a deep notch in the standing wave and the 63Hz EQ is set to minimum.
With speakers set to small the notch is -5 and the 63Hz is set to -4.
I thought this was due to the sub woofer location verses the main speaker location relative to the mic position.
I do not have any documentation on how the calibration algorithm is coded but if its available I am interested in this kind of stuff.
Charlie
chashint is offline
post #2716 of 6299 Old 12-22-2011, 03:43 PM
Liked: 1123
Nor to me. But 5 x (40 x $550) would be one HECK of a home theater!
Got a link for the kits?
Michael
post #2717 of 6299 Old 12-22-2011, 09:30 PM
norml4721's Avatar
Hello Guys :
Just purchased vsx-52 and trying to wrap my head around the MCAAP cal. I am getting a headache from all the posts Soooo Mannnnny.
Should I set all speaker settings to small ?
should I set sub to plus ?
I have a 5.1 set up with two remote speakers in seperate room. The front left and right speakers are towers the rest are bookshelf and center and sub etc.
read things like double bass. Is that bad ?
I ran an auto cal then tweeked db level on some of the speakers. Right now I have fronts set to large and all others set to small left sub setting the same , whatever default is.
This receiver is replacing an older Denon 5.1 and it seems like the Denon was much brighter and not as muddy/mudled without any adjustments neccesary.
I like this receiver a lot but seems like factory settings are for elevator music..
Do I have to increase all speaker DB levels or what ?
New owner os VSX-52,
Thanks for inputs,
Also newbie to AVS,
norml4721
norml4721 is offline
post #2718 of 6299 Old 12-23-2011, 07:03 AM
bmurray716's Avatar
Set all speakers to small and crossover on the sub to 80. Do not set for plus as this sends low end to sub (good) and fronts (bad). Enjoy your new AVR. If you want to match the sound of your old AVR you can, but MCACC usually does better job of setting things up with a good cal.
LG 42LB5600, Sony BDP-S590, Pioneer VSX-516, JBL LX22, Definitive Technology ProCenter 1000, Polk DSWPro400, Polk OWM3, Logitech Squeezbox Classic, Squeezebox Radio
bmurray716 is offline
post #2719 of 6299 Old 12-23-2011, 08:34 AM
Kurolicious's Avatar
Quoted: 31 Post(s)
I would not recommend setting the crossover on your sub to 80hz if you're setting the speakers to Small on the AVR with a crossover of 80hz. You'll have dual crossovers occurring in this scenario.
Set the crossover on the sub to the maximum setting and let the AVR handle the bass management.
Kurolicious is offline
post #2720 of 6299 Old 12-23-2011, 09:11 AM
norml4721's Avatar
Thanks for the input guys. When you say set the crossover on the sub to highest possible . Do you mean the crossover setting on the sub itself or the xover setting on the speaker nsetup menu ?
Also when you say highest possible do you mean more than 100Hz. This is the highest that I ever have set my sub crossover ?
I have 8 J.M. Labs, speakers in my home theater 5.1 and 2 remotes on sp. B dinning room. Also have an older Pioneer Elite Plasma display, I cant believe the picture quality improvement using the Marvell video processor in the 52 thru HDMI.
Thanks for all your help guys and have a Happy Holiday
norml4721
post #2721 of 6299 Old 12-23-2011, 09:33 AM
millerrh's Avatar
norml4721
They mean set the crossover in the AVR at 80 Hz, but the one on your sub (physical knob) should be cranked to the max or bypassed entirely if you sub has a dedicated LFE in that doesn't use the sub's crossover. This way the only crossover is the one the AVR is dictating and your sub is also not applying a second crossover at the same point.
millerrh is offline
post #2722 of 6299 Old 12-25-2011, 10:29 PM
65Cobra427SC's Avatar
I just purchased an HSU VtF-15H sub as a replacement for the one in my system now. The HSU has five different "hybrid operating modes" which I'm anxious to try out, but wasn't sure how to go about comparing them and properly incorporate the best one into my system since my experience with MCACC thus far has been (embarrassingly) limited to running Full Auto
After much reading I put tother the following process...
(1) Run "Full Auto MCACC"
(2) Enter MCACC Manual Setup
(3) Change LCR Size to SMALL
(4) Enter "Auto MCACC"
(5) Select Custom
(6) Select "Keep SP Settings"
(7) Finish & Exit MCACC
(8) Setup HSU VTF-15H Subwoofer
(9) Run "Auto MCACC" Again
Step (8) is fairly vague since I'm not sure if I should repeat steps (4)-(7) as I test each of the five subwoofer modes. I'm also not sure how to properly adjust the volume knob on a sub when using MCACC. Finally, I got the idea I should set the crossover knob on the sub to it's max setting with front speakers set to Small when using MCACC.
My Current System...
Panasonic TC-P60ST30 Plasma TV
Pioneer SC-27 Receiver
Parasound 5250v.2 (5x250) Amplifier
Paradigm W5/W5C LCR Speakers
Definitive Technology (cheap) Rear Speakers (Next to get replaced)
Any help would be appreciated including suggestions on what else to read that could help. Thanks.
65Cobra427SC is offline
post #2723 of 6299 Old 12-26-2011, 04:51 PM
Liked: 1123
MCACC won't do anything to/for the sub.
For serious sub info, start here:
http://www.hometheatershack.com/roomeq/
Without test equipment (and an eq for the sub), you may as well try all the settings you have and pick the one that "sounds" best to you. If you want to be a little more scientific, use these test sweeps:
post #2724 of 6299 Old 12-27-2011, 09:14 AM
Legairre's Avatar
Quoted: 493 Post(s)
Liked: 279
(5) Select Custom
• Panasonic TC-P60ST30 Plasma TV
• Pioneer SC-27 Receiver
• Parasound 5250v.2 (5x250) Amplifier
• Paradigm W5/W5C LCR Speakers
• Definitive Technology (cheap) Rear Speakers (Next to get replaced)
• HSU VTF-15H Subwoofer
I think you're pretty close on the MCACC workflow. I use the MCACC workflow from th efirst post of this thread and it works great. It's the same as yours except it it had the EQ reverb testing included that makes a big difference.
Read down about half way through the first post and you'll see the workflow.http://www.avsforum.com/avs-vb/showthread.php?t=1112470
BTW like others have said MCACC doesn't EQ the su,b only the other speakers down to 62Hz. Many of us use a dedicated sub EQ to handle the bass. I use the SMS-1 http://www.hometheaterhifi.com/volum...05-part-1.html
You can find them new on amazon for $350, but there are also cheaper ways EQ your sub like using the Behringer 1124 & REW but it's has a learning curve and setup time.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #2725 of 6299 Old 12-27-2011, 10:47 AM
^^^^ Thanks for the replies. I'll definitely take a look at the links. Looks like I have a lot of reading to do. Ahhh, just when I thought my head was ready to explode there's even more to learn
Just to clarify... since the MCACC sends test tones to the sub, it must be checking the delay and setting the distance but does it do anything else with the sub?
post #2726 of 6299 Old 12-27-2011, 10:59 AM
Legairre's Avatar
Quoted: 493 Post(s)
Liked: 279
Yes it sets the sub delay, distance and also the level.
post #2727 of 6299 Old 12-27-2011, 11:11 AM
^^^^ Perfect... makes a lot of sense. Already reading the other threads and making progress. Even figured out when I set the front left & right speakers to small, my sub will start working in stereo. This is going to be great. Thanks.
post #2728 of 6299 Old 12-28-2011, 11:05 AM
Retro-Marus's Avatar
And it applies a standing-wave-correction for frequencies above 63 Hz, doesn't it? At least I have an entry for the sub in the standing-wave-section of my SC-LX72 that allows me to manipulate 2 or 3 frequencies with a parametric EQ.
But for any room-mode-related problems below 63 Hz MCACC istn't any help at all.
Cheers,
Markus
Retro-Marus is offline
post #2729 of 6299 Old 12-28-2011, 01:46 PM
Legairre's Avatar
Quoted: 493 Post(s)
Liked: 279
Cheers,
Markus
Yes 92 & 94 it will both apply standing wave correction, but as you said only down to 63Hz.
post #2730 of 6299 Old 12-29-2011, 03:52 PM
derrickdj1's Avatar
Quoted: 891 Post(s)
Liked: 598
MCACC does not adjust frequencies\\ below 63Hz due to the length of the sound waves below that mark. The waves can be 2-4x as long as the room and will cause problems with the delay settings for the other speakers/frequencies. That is what reverb measurements and correction are for in MCACC. Most of what we hear, or Presence frequencies are in the 3.5-5kHz range. Few musical instruments produce frequencies below 40Hz. The pipe organ is one exception. So, sub equalization is not a key factor in getting your HT to sound good. That is also why musical sub, or sealed subs do not have has low of extension as ported subs. Low extension sub frequency does not necessarily mean louder. The low extension does give us the bone shaking experience when watching movies. Large vs Small settings for speaker is based on the speaker's frequency response and not how large or small the speaker is. Also having some speakers set to large with a sub can have a double effect where frequencies overlap or phase issues between the speakers. I paid good money for my tower speakers, and yes they are set to small, for HT. My x-over is set at 100 due to the frequency range of the surround speakers. The sub cannot be localized in my setup. Using the mic in three positions may gives the best room correction measurements to the avr. The long sound waves measured in MCACC for a sub reflects why the sub distances are commonly not the true physical distance, so nothing to loose sleep over.
derrickdj1 is offline
