Dual simultaneous independent HDMI output receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-25-2009, 08:20 PM - Thread Starter
jwlake's Avatar
Hello all,
I've been reading a ton on the internet and I can't seem to figure out exactly which receiver will do what I want to do:
Inputs:
2 HR21 DTV DVRs
1 XBox 360
1 HTPC
Outputs:
1 50" Panasonic Plasma
1 24" LCD Panel
I'd like to have each display capable of showing any of the sources at any time. I.e. Both with HTPC, 1 with xbox and 1 with HR-20, etc etc.
From what I read:
Onkyo: None
Denon 4308: Maybe??
Marantz SR6003: Maybe??
Can anyone clear up the Maybe's for me? I'd prefer to not have to put a monoprice HDMI switch in front of the thing, I've had bad luck with the 4x2 switches in the past and would rather have a receiver do it all in one package.
Jim
jwlake is offline
post #2 of 14 Old 04-14-2009, 06:35 PM
ondaedg's Avatar
Are you powering speakers or just using the speakers built in the TVs?
ondaedg is offline
post #3 of 14 Old 04-14-2009, 07:38 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I did not think any receiver had independent HDMI outputs. I would be curious to know if there are any.
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 14 Old 08-10-2010, 02:33 PM
Taterific's Avatar
I'm looking to do the same thing with a 50" SXRD and a to be named 46" LCD TV with Inputs of 2x Xbox 360 HDMI, 1 PS3 HDMI, 1 DVR HDMI, 1 PC HDMI, and a few composite inputs. I want to be able to have the DVR on one TV while a 360 is on the other, and then tomorrow have the 360 on the first tv and the PS3 on the other, etc. I though the Denon 5308 would work but I've talked with crutchfield and they've said it wouldn't. Does anyone have any suggestions for me?
Taterific is offline
post #5 of 14 Old 08-10-2010, 03:47 PM
jdsmoothie's Avatar
Quoted: 12144 Post(s)
Liked: 5532
The Denon 4308 won't do it either. You would need an AVR that can send HDMI to Zone 2 which AFAIK there are none currently on the market.
jdsmoothie is offline
post #6 of 14 Old 08-10-2010, 04:15 PM
Knucklehead90's Avatar
Quoted: 387 Post(s)
Liked: 334
Why not get an hdmi signal splitter and buy whatever AVR you want? I use one although it is connected before my prepro and it's powered to boost the signal for a 45' cable run. Works great and I can have both tvs on at the same time with no video/audio degradation.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #7 of 14 Old 08-10-2010, 04:25 PM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 38
I don't think there is any out there.
I know some of the older Marantz couldn't even output the SAME source through HDMI 1 and 2 at the same time.
I use the SC-07 and it will output the same source over HDMI 1 and 2 alternatively you can output a zone 2 (different source) over component, but NOT HDMI.
As good as I have found.
Now there is still a limitation that you should know about if you accept the same source. At least with the Pioneer SC-07 (haven't checked on the newer models) If I use HDMI 1 for the HT and then the internal amplifiers then I cannot get sound through the TV on HDMI 2 alternatively sound through the hdmi to the tv then you cannot use the amps of the receiver. Pioneer said this was a HDMI limitation - I don't know if this is true or not....
I could use zone 2 for audio (analog only)
So to summarize -- buy two cheap HDMI receivers / use a splitter, but then you will have to run multiple HDMI's to each display or live with component for one display
mhdiab is offline
post #8 of 14 Old 08-10-2010, 04:26 PM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 38
The issue is independent sources
mhdiab is offline
post #9 of 14 Old 08-10-2010, 04:33 PM
RoboRay's Avatar
There are no receivers or processors (AFAIK) with built-in HDMI matrix switches.
RoboRay is offline
post #10 of 14 Old 08-10-2010, 05:43 PM
Quoted: 387 Post(s)
Liked: 334
Actually it's my reading comprehension.
But thanks for the correction.
***GO SEAHAWKS ***
post #11 of 14 Old 08-10-2010, 06:11 PM
Tulpa's Avatar
Liked: 61
This seems like such a niche need that I wouldn't expect anyone to have made something like this yet, if ever.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #12 of 14 Old 08-10-2010, 06:35 PM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 38
Well a long post didn't post properly so a small post will replace it
Lots of people with a multi-room setup would like this.
I kind of trick the system.
Room 1 ("Gym") -- TV for my treadmill. I am only going to use the cable box there so I split the cable signal and run one run directly to that TV and the second run goes to the receiver.
Room 2 (HT) -- gets the HDMI 1 from the receiver and can play any source
Room 3 -- (bar / pool table) gets component from the box to the receiver -- I could hook up the PS3 / dvd player to that as well but the issue with PS3 is I would need to change settings every time but I have the option there
So I can get independet sources on two displays in HD either using component for one TV or the HT needs to be used for movies / game and then the other TV's can use the cable box
mhdiab is offline
post #13 of 14 Old 08-10-2010, 06:41 PM
Tulpa's Avatar
Liked: 61
I get that there are uses for it, but I think most just opt for separate systems. Any receiver that features this will likely be flagship priced and cost more than some whole setups.
Tulpa is offline
post #14 of 14 Old 08-11-2010, 07:13 AM
Taterific's Avatar
Thanks for the info everyone.
