"Official" All amps sound the same thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 2642 Old 02-15-2009, 07:25 AM
penngray's Avatar
Liked: 43
I don't think AVS means it to be literally meant as a science forum. It is a forum for people interested in Home Theater and from all walks of life. I think they chose the word "science" just to be catchy and it is not an actual scientific forum for scientists of audio.
I do think Science is part of this site, I have been in involved with more forums then ANYONE else here. From HTPC building, Home Theater building, acoustical treatments/DIY screens, Speaker and Sub building, Home Audio/video distribution, Audio theory and so on.
The core of all threads is the science behind any and all of the technologies. People know about monoprice.com because of the science behind understanding how cables/wires are built. People know you do not have to fortune on getting a great sound room....examples....
People want to spend $10K on an amp or even $3K, I would say people are not educated at all about the science if they didnt treat their room first, if people understood the science more then would know this but we still have ignorant audiophiles boasting about their $10K+ setups and they have zero treatments, that is laughable!
People know that spending hundreds or thousand just on wire/cable is dump because of science!
People know that they should spend more on the speakers then they should on AVRs and Pro amps because of science, those who do not are not educated enough and we need to do better!
The reason things are done right around here is because of science and not fluffy exaggerations of individual experience!
You can choose to ignore science or think it just a catchy phrase for the website owners or you can realize that science helps the rest of us build better systems then you have
penngray is offline
post #632 of 2642 Old 02-15-2009, 07:32 AM
penngray's Avatar
Liked: 43
Originally Posted by ^kev View Post
That is what I am starting to think.
They to the "amps sounding the same" opinion is the actual build specs.
Its really simple, if two companies build amps with the idea that those amps will not color (distort) sound then both amps will sound the same when playing sound at about 90 dB or close to 1W of power.
The key is the fact that two companies need to actually worry about NOT distorting the sound. Undistorted sound will sound the same no matter what price tag/label/color or name is on the box!
penngray is offline
post #633 of 2642 Old 02-19-2009, 04:45 PM
cynan's Avatar
Sure it will.
But just like various driver/enclosure/crossover designs and configurations can alter the final sound waves that emanate from a pair of speakers, different amplifier components/circuitry can have an (albeit more subtle) effect on the signal that gets relayed to said speakers.
It has been said here that amplifier can realistically only degrade signal quality if it is pushed past reference levels. This, in my opinion, is a moot point. The fact is that more expensive amplifiers can (in general) be pushed to much higher power levels without distorting, which not only allows one to play sources at higher decibel levels, but also experience a fuller dynamic range (which are becoming more and more limited due to the introduction of recordings engineered to be "loud" all the time, and designed to be more "resistant" to compression for playing on digital audio players - but this is whole other topic). In the same vein, more powerful amplifiers enable one to get more out of less efficient speakers.
The problem is that when you increase power, you also increase the potential for signal noise. This is why more expensive amplifiers have more stringent (expensive) capacitors and components such as torroid power supplies (at least in A/B class amps) while cheaper ones do not.
Therefore, the advantage of a more expensive amplifier is mainly signal noise reduction at higher power (ie, microphonics imparted by input capacitors to RF interference from power circuitry which surrounds the signal path). I would agree that the vast majority of modern amplifiers (even the ones in budget AVRs) have undergone enough iterations to make these sources of noise negligible at their reference decibel levels. But not everyone wants to be limited by the reference decibel levels of a budget 50 wpc A/B amplifier.
Then there is the age old question of amplifier class. While all A/B amplifiers may sound similar at reference volumes, what about tubes or T-class amps? In the case of the latter, does the use of a transistor to "sample" and create, what is in effect a digital-like signal produce a different signature than other designs? They supposedly sound more like tube amplifiers - a function of their relatively low current requirements due to their "sampling" technique.
I currently own a run of the mill, recent Denon AVR. I have been wondering for a while whether different amplifier designs could really make a perceptible difference in my music listening. Recently I came across a T-class amplifier that, unlike the low wattage limitations of other models, is rated at 60wpc. As it was reasonably affordable, I decided to order one (Virtue Audio). I can't wait to do some A/B testing between this amp and my Denon...
cynan is offline
post #634 of 2642 Old 02-19-2009, 04:54 PM - Thread Starter
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Let us know what you hear
I wanted to AB my Mackie vs. my Yamaha but I could not find an affordable amplifier switcher. And I don't trust my hearing comparisons if it takes too long to switch from one amp to another.
"But this one goes up to 11"
MichaelJHuman is offline
post #635 of 2642 Old 02-19-2009, 05:00 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Since amps do a significant part of their work at low powers, I'm more interested in the 'noise' under those conditions.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #636 of 2642 Old 02-19-2009, 05:38 PM
TPnBobcats's Avatar
Conduct a decently randomized double blind testing and I'll be fascinated to hear the results.
TPnBobcats is offline
post #637 of 2642 Old 02-19-2009, 05:44 PM
Bob Lee (QSC)'s Avatar
Liked: 25
Certainly anything can be designed and built incompetently. They don't need to be, though.
Bob Lee
Technical Communications Developer
QSC Audio Products, LLC
Costa Mesa, Calif.
Fellow, Audio Engineering Society
Bob Lee (QSC) is offline
post #638 of 2642 Old 02-19-2009, 05:53 PM
milaz001's Avatar
And please level match.
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.
milaz001 is offline
post #639 of 2642 Old 02-19-2009, 06:00 PM
syswei's Avatar
I posted a couple of weeks ago a suggestion that anyone serious about comparing amps might want to borrow this fellow's ABX box:
http://www.avsforum.com/avs-vb/showt...5#post15034395
(you pay the shipping). I don't know if the ABX box includes level-matching...maybe Bob Lee can illuminate us?
syswei is offline
post #640 of 2642 Old 02-19-2009, 07:41 PM
syswei's Avatar
For the technically minded amongst you:
http://www.sonicdesign.se/amptest.htm
syswei is offline
post #641 of 2642 Old 02-19-2009, 10:46 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 148
I did not have time to read that article fully, it's late, and I drank a few adult beverages. But it looks very interesting, and I am going to try to come back and read it tomorrow.
post #642 of 2642 Old 02-20-2009, 12:12 AM
J.Harker's Avatar
I see plenty of "fluffy exaggerations" around here.
What I meant is that AVS is not just a forum for University educated scientific types just because it has the word science in the forum title.
J.Harker is offline
post #643 of 2642 Old 02-20-2009, 07:01 AM
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
Why would you think that?
Common sense?
eljr is offline
post #644 of 2642 Old 02-20-2009, 10:27 AM
J.Harker's Avatar
Originally Posted by CETA1 View Post
My order of what makes a different sound.
1. Speakers
2. Amp
3. Room
4. Source
5. Cables (yup)
Looking forward to my own little compare here!
Rick
Nope, room acoustics and room treatments makes far more difference in SQ than the amp.
J.Harker is offline
post #645 of 2642 Old 02-20-2009, 10:54 AM
Easyaspie's Avatar
For Pete's sake!
More threads than anybody? What kind of study did you do to come to that conclusion?
Monoprice? Science? BS! How about prices cheaper than dirt? Period!
Easyaspie is offline
post #646 of 2642 Old 02-20-2009, 11:40 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
So the few reasons to buy an external amp are:
1) You like listening at VERY loud levels
2) You have hard to drive 4 Ohm speakers (does this include all 4ohm, or are there exceptions). I ask this because I have 4 Ohm speakers (Vienna Acoustic Mozart Grands) which are 90 db sensitive.
3) You like to spend money on equipment you think you need :P
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #647 of 2642 Old 02-20-2009, 12:17 PM
TPnBobcats's Avatar
The science comes into things, in that it tells us that horrifically expensive cables give you no advantage.
AVR amps will drive 4 ohm speakers even if they tell you they aren't rated for them. So you can use them.
It's mostly that they don't do a good job of driving 4 ohm speakers and that typically external amps have an even greater power advantage over AVR amps, when driving 4 ohm speakers.
An ideal Amp should double it's output when the resistance of the load is halved. According to the equation Power = V^2/R (voltage squared divided by resistance). Most amps won't quite achieve this for other reasons, but a good external amp will increase it's output by a greater % than the amps in most AVRs.
Ex. The Emotiva XPA-5 I have, increases it's output from 200 wpc to 350 wpc, a 75% increase. By way of contrast, AVRs could be as low as 10%-25%, though it can be substantially higher. So it might go from 100 wpc to 130 wpc. Meaning that the XPA-5 is nearly x3 the power with 4 ohm speakers vs x2 for 8 ohm speakers.
IIRC one of the THX certs requires that the amps be able to drive 4 ohm speakers.
post #648 of 2642 Old 02-20-2009, 02:50 PM
Easyaspie's Avatar
Yet most people believe that expensive cables are better. That is wrong, but it is the perception.
You like to live in your own little world, so I'll let you in on a little secret. If you haven't been on AVS forums or don't know somebody who has, you haven't heard of Monoprice. It's that simple. AVS users are probably their main buyers, with the occasional googler finding them. We sure as hell are the ones who continually tell new posters to buy from them. When you see a poll on the Electronic House newsletter asking about cable purchases, it's ALWAYS the "pros over at AVS" , then they'll quote a poster who recommends Monoprice. Most everybody else gets their stuff from some parts supplier advertising on Amazon, or pays too much at BB.
This forum is supposed to be about people sharing some expiriences and ideas, it doesn't ALWAYS have to be scientific in nature.
post #649 of 2642 Old 02-20-2009, 03:03 PM
TPnBobcats's Avatar
If you can lower your nose enough to read this.
Thank you for condescending, to tell me how I live my life. It's extremely patronizing of you.
Clearly all your opinions are absolutely correct and anyone who disagrees with you is deranged or ignorant.
Yeah, monoprice gets recommended because people here know they produce a decent product at a reasonable price and they advertise on the site so they are easy to find.
I'm missing the part where I said they walk on water and heal the sick.
Nor do I recall anyone saying someone was stupid because they bought a similar product at a similar price somewhere else.
post #650 of 2642 Old 02-20-2009, 03:10 PM
eljr's Avatar
Liked: 8025
Emotiva, Oppo and monoprice all rock!
now what speakers to get......
eljr is offline
post #651 of 2642 Old 02-20-2009, 03:13 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Why Emotiva speakers of course!
Chu Gai is offline
post #652 of 2642 Old 02-20-2009, 03:39 PM
eljr's Avatar
Liked: 8025
But they have not gotten the press (here) the other named items have
Bose?
eljr is offline
post #653 of 2642 Old 02-20-2009, 03:46 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
apparently somebody else lives in their own little world or do people not read CNET now, eh?
CNET HDMI CABLE BUYING RECOMMENDATIONS
The editors at CNET are so confident that cheap HDMI cables offer identical performance, we've been using inexpensive Monoprice HDMI cables in the CNET Home Theater Lab for more than a year with no issues. That's saying a lot, especially when you consider that our video experts are constantly swapping in new products and changing configurations, which means our cables take much more abuse than they would in a normal home theater. We're also accustomed to making long cable runs, and many of our cables from Monoprice are 15 feet long.
Here are a few of our favorite resellers, all of which offer solid return policies in case you do get a bum cable.
Monoprice.com sells all other kinds of quality AV cables at very reasonable prices. As we mentioned before, we use Monoprice cables in CNET Labs, and several CNET editors use Monoprice in their personal home theaters as well.
nice try though!
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #654 of 2642 Old 02-20-2009, 04:05 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 148
What are Bobcat and easy arguing about? Lol
You both seem to be saying, yeah monoprice cables are inexpensive and work as good as more expensive cables. Yet you two are arguing. Maybe you should agree about WHAT you are arguing about?
Seems Penn started you arguing by posting something I did not even understand about monoprice being science. I am really confused. I see no real point for an argument from those parties.
I could start a real argument here - define audio reviewer terms.
Let's start with soundstage. How can a soundstage have depth in a two channel system? How can it have height? Seems impossible.
How about warmth? Does warmth mean highs are rolled off? Or is warmth the opposite of brightness, and brightness is some form of distortion?
How about 'digital sounding'? Do some class D amps sound 'digital'? Meaning, do they have a characteristic sound imparted by the fact that they sample the input signal? Or are reviewers biased by their perception of class D amps being digital?
post #655 of 2642 Old 02-20-2009, 05:56 PM
Ugly1's Avatar
Just to be clear. All amplifiers are always distorting when amplifying. It is merely a question of how much under a given set of circumstances.
Ugly1 is offline
post #656 of 2642 Old 02-21-2009, 08:35 AM
Easyaspie's Avatar
Finally, you get it. Thank-you.
Just kidding. I didn't mean to argue about something so trivial. I just think that Monoprice wouldn't have nearly the sales they do if it wasn't for those of us on these forums. Word of mouth is what makes their sales.
post #657 of 2642 Old 02-23-2009, 11:32 AM
Liked: 25
If it's a QSC ABX comparator, then it has a built-in 1 kHz sine wave oscillator and digital voltmeter, specifically for the purpose of matching gains.
Bob Lee
Costa Mesa, Calif.
post #658 of 2642 Old 02-26-2009, 03:35 PM
syswei's Avatar
Thanks, Bob.
syswei is offline
post #659 of 2642 Old 02-26-2009, 06:33 PM
classical's Avatar
Originally Posted by mcnarus View Post
You ask, we deliver.
There's an article about this at Tom Nousaine's website. Here is the link:
"Can You Trust Your Ears?" (PDF file), Stereo Review, August 1997.
classical is offline
post #660 of 2642 Old 03-19-2009, 01:51 PM
popup's Avatar
If I used my Synth to create a sound that I have in my head and get a rasping sound that has a crispy, high frequency buzz to it and design the the sound using my headphones to hear what is going on. I sculpt it to my original idea perfectly.
If I then play it through my amp and speakers, it sounds more muffled and the sound is not the same and not what I wanted. The headphones cost £10 and the amp and speakers cost lots. If I then change my interconnect, it gets closer than the other (remember, I know what sound I wanted and can use the headphones and the speakers at the same time and cup the phones on and off to check), producing a more crispy sound that is closer but still a way off - the room?. If I plug the same headphones into the amp instead and listen again, it is closer but still not right by some degree.
My questions are these.
1. What sound is the Synth really making and what do you need to be able to hear that?!
2. Which setup should i trust and use to design my sound the way I want it and will everyone have to buy the same quipment as me to hear it as intended?
popup is offline
