"Official" All amps sound the same thread - Page 89 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2641 of 2642 Old 04-29-2014, 08:54 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Originally Posted by RichardTS View Post
OK. Then I have a challenge for you. I have a set of speakers that are famously hard to drive. Further investigation finds that these hard to drive speakers actually have an impedance dip in the 50-100 Hz range that goes down to around 2 ohms although they are nominally rated at 8 ohms. You have to choose from one of two amps. One amp is rated at 100 watts per channel at 8 ohms, 200 watts per channel at 4 ohms and 305 watts per channel at 2 ohms. The other amp is rated at 125 watts per channel at 8 ohms and 165 watts per channel at 6 ohms with no 4 ohm rating available.
Which amp would best drive these notoriously difficult speakers and why?
Depending on your preferences for listening loudness and the spectral content of the music or drama you are listening to, it might not make any difference at all. In general running an amp at say 6 dB below clipping cuts the current drain enough so that you could drive a speaker with half the impedance if the speaker were causing current limiting at clipping. Most amplifiers clip first due to running out of internal voltage supply, not current limiting. Voltage clipping is in general less disturbing to listen to than current limiting.
arnyk is offline
post #2642 of 2642 Old 04-30-2014, 08:11 PM - Thread Starter
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 150
I have questioned that, if only because of looking at Yamaha amp circuits. I have seen rails of 70V. No way that's going to clip unless the rails sag a lot. And I figured if the rails sagged it was, putting it non technically, due to current limiting. I could certainly be wrong.
"But this one goes up to 11"
MichaelJHuman is offline
