Parasound Owners Thread - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 512Likes
post #3541 of 5698 Old 06-28-2014, 08:52 PM
enricoclaudio's Avatar
Quoted: 1509 Post(s)
Liked: 1656
It doesn't hurt to check on the fuse. Unplug the power, get a Phillips screwdriver and check on the fuse that is top of the power cord plug.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #3542 of 5698 Old 06-29-2014, 01:09 AM
musicalfox's Avatar
Quoted: 16 Post(s)
Will do, Enrico, thanks. But isn't a blown fuse usually an indicator of a more deep-seated problem? My understanding is that a fuse should last many years and at least the life of the product.
musicalfox is offline
post #3543 of 5698 Old 06-29-2014, 01:31 AM
Steve Zodiac's Avatar
A blown fuse may well be a sign of an internal problem, but there's always a chance that a replacement fuse may solve the problem and the amp may carry on working perfectly for many years to come. Just make sure you replace any fuse with one of the correct rating. Fuses can fail for no apparent reason.
Steve Zodiac is online now
post #3544 of 5698 Old 06-29-2014, 02:44 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I recently has a fuse go and since then (month and a half) I have not had a single issue. Of course knock on wood now but it has worked perfectly fine. This one always seemed to be (I have two A51 blacks) a little skittish. Now I have two reliable black beauties. Amazing how one little fuse can make or break an AMP!
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #3545 of 5698 Old 06-29-2014, 11:22 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1272 Post(s)
Liked: 873
Originally Posted by musicalfox View Post
Can anyone help? My HCA-2003 just suddenly decided not to turn on. No standby or green operation light. Would it be as simple as a fuse or something more serious? I would appreciate any responses, particularly if this is something I can test for before taking the unit into a service center. Thanks!
Contact Parasound tech support via email.
You never know, they might even answer today
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #3546 of 5698 Old 06-29-2014, 12:18 PM
musicalfox's Avatar
Quoted: 16 Post(s)
- Rich
Yes, actually I just shot Tony an e-mail last night, so hopefully I'll hear soon. I will also just swap out a fuse anyway and see if there's a result with that. Thanks for all your suggestions.
post #3547 of 5698 Old 06-29-2014, 03:18 PM
Jmouse007's Avatar
Quoted: 69 Post(s)
Liked: 64
Originally Posted by wse View Post
Quote:Originally Posted by Jmouse007
....... That is why the overwhelming majority of major motion picture studios, recording companies and primere Hollywood directors have chosen PARASOUND over everything else on the market.....
Where did you see that?
Simple answer: It is listed in writing on their web page aong with the names of nearly every, if not all, of the major motion picture studios in Hollywood! Needless to say, Parasound Halo amps and Parasound has an outstanding reputation throughout the motion picture and recording industry. These folks can afford to buy anything... They have chosen Parasound, which speaks volumes concerning the sound quality of their products verses the competition.
Jmouse007 is offline
post #3548 of 5698 Old 06-29-2014, 04:20 PM
Jmouse007's Avatar
Quoted: 69 Post(s)
Liked: 64
Originally Posted by BillP View Post
Jmouse, what preamp do you recommend pairing with the A21? I have a pure 2-channel system, and am thinking of upgrading from a Rotel amp and preamp to Halos. I am thinking A21 with the JC 2 (it's hard for me to justify two JC 1's instead of the A21, although the JC 2 seems to state how it's made to be paired with JC 1's). Thanks.
I would highly recommend the Onkyo PRSC 5509 preamp.
I have owned the Onkyo 5507, and then moved to the 5508. The 5508 has been rock solid, not one problem. I went with the 5508 because it has the updated Audyssey XT32 room correction. I couldn't believe how much better it is than the previous version on the 5507. Well, both the Onkyo PRSC 5508 and the 5509 have the Audessey XT32 BUT, Onkyo has foolishly dropped Audessey from their next generation of preamps so I can not recommend you buy it. Wait for the 5509 to go on sale and be one of the fortunate few. IF, you "must have" Atmos... Then go with Denon's next generation preamp. It will cost a lot more than the new Onkyo preamp with Atmos BUT, and here is where Onkyo shot themselves in the face, not only does the Denon have Atmos, it ALSO retains Audessey XT32 room correction!
If Onkyo wants to remain competitive they will need to bite the bullet and return Audessey XT32 or better in their next Gen preamp because the 1 calibration system they are now going with doesn't cut it. They dropped Audessey as a cost cutting feature because they would have needed to ad an additional processor to keep it, like Denon has done. They were unwilling to do so and as a result, many, including myself are predicting their sales will plummet (I certainly won't be buying one because Audessey XT32 is outstanding and I am not willing to give that feature ( found on the 5509) up.
As for "Atmos"... I am not going to rush to jump on that band wagon... It may just be a gimmick to drum up lagging A/V sales. I already have a tremendous sounding 9.2 surround Home Theater. With Atmos you literally have to relocate your existing speaker set up (front-height ambient speakers don't work properly with Atmos) and add additional speakers to the ceiling! No thanks... I will wait for that to all shake out. "early adopters" with money to burn can be the ginny pigs.
Also, DTS is coming out with a new audio processor code mix... Again, I will sit that one out until it all shakes out.
Now the one thing that the 5509 doesn't do is 4K. But the simple answer to that is to get a Bluray player like the OPPO 103, 105 or Sony BDPS790, with two HDMI outs and run the audio to your 5509 and the 4K video directly to your 4K projector or TV. This is the route most on aVS are taking until the standards for HDMI 2.0 (and beyond) are finally and firmly established. Otherwise you end up, like those poor saps who bought the Sony 1,000 4K projector for $25,000 dollars who later found their 4k projectors were already obsolete because they couldn't play native 4k movies! They had to spend an additional nearly THREE GRAND in order to "upgrade" their 4k projectors to play native 4k,
which they were enitially promised they could do in written advertising in the first place!
So, wait until 4k and HDMI 2.0 (and beyond = 2.1, 2.2...) standards are finally agreed upon AND working/functioning properly in the real world before jumping on a "4K 'ready'" preamp and stick with what works. And what works is the feature laden Onkyo PRSC 5509.
For what it is worth, that is my advice. Hope it proves helpful.
post #3549 of 5698 Old 06-29-2014, 04:43 PM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Thanks, Jmouse, but I am only interested in a 2-channel preamp (the 5509 looks like a 9.2 AVR). I saw on the Onkyo website that they do make a 2-channel preamp. I wonder how it compares to the JC2 Halo. I already have the Oppo 105 (great player).
BillP is online now
post #3550 of 5698 Old 06-30-2014, 07:03 AM
Jmouse007's Avatar
Quoted: 69 Post(s)
Liked: 64
Sorry, I misunderstood. If you are exclusively interested in a 2-channel preamp, then go with the JC2 Hal, it will sound nothing short of outstanding with your Halo A21 and OPPO 105!
post #3551 of 5698 Old 06-30-2014, 09:41 AM
Liked: 1656
I have a Halo P5 paired with my Oppo 105D and it sounds AMAZING! I can't imagine how good the JC2 + Oppo 105 combo will sound!
post #3552 of 5698 Old 06-30-2014, 04:54 PM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Of course I'll also have to upgrade my speakers. Thinking of the Sonus Faber Olympica III's.
ohrbrcko likes this.
BillP is online now
post #3553 of 5698 Old 07-02-2014, 10:13 AM
Doctor Morbius's Avatar
Quoted: 139 Post(s)
Liked: 126
I broke down and ordered a Parasound Zdac. It is due to be delivered this afternoon. I'll play around with it for a couple of days and report back.
postrokfan likes this.
Doctor Morbius is offline
post #3554 of 5698 Old 07-11-2014, 08:33 AM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
Parasound JC2 vs Marantz 8801?
A friend of mine who recently purchased a Marantz 8801 is wondering if 2 channel listening would be improved by adding a JC2. Has anyone here compared these, strictly in terms of SQ?
For reference he also has an A21 amp and Salk SS8 speakers. BTW, he's not a member of AVS, hence me posting this for him.
Saturn94 is offline
post #3555 of 5698 Old 07-11-2014, 08:38 AM
jima4a's Avatar
Quoted: 298 Post(s)
Liked: 155
I do not have nor heard the 8801 so this is strictly based on 2nd hand information but my belief is yes. By accounts the 8801 is quite good musically but your friend's system could benefit from the JC2 for two channel.
jima4a is online now
post #3556 of 5698 Old 07-11-2014, 09:41 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 184
A friend of mine bought a PS Audio Directstream and brought it over with his PerfectWave. Got to listen to those 2 and a Bel Canto 2.5 DAC. I saw the Perfectwave dropped $1500 and ordered one. Sounds wonderful and actually a nice improvement over the 8801. The 8801 does surround sound very well, 2 channel-DAC all the way.
http://www.psaudio.com/products/perfectwave-dac/
8801, Perfectwave DAC, A21 and Dali Epicon 6 speakers.
Life is enjoyable with good quality
Dr_Mark is offline
post #3557 of 5698 Old 07-11-2014, 11:02 AM
Liked: 1656
I don't have the Marantz 8801 nor the JC2 but I do have a Marantz SR7008 and a Parasound Halo P5. I can tell you that for stereo the combination between the P5 and the Oppo 105D is unbeatable. I don't care what other people say but Audyssey could be good for movies or multichannel music but for stereo nothing is better than a good stereo preamp like the P5 or the JC2. I got the P5 instead of the JC2 because the HT bypass with two independent subwoofer in/out.
post #3558 of 5698 Old 07-13-2014, 08:33 PM
whitecamaross's Avatar
Quoted: 18 Post(s)
I have a lexicon rx7 monster power amplifier that I'm sure a lot of you have heard of. I have always been curious about the halo a51 (black) so maybe someone here is interested in working something out with this beast and their halo a51. ?
Message me if interested.
whitecamaross is offline
post #3559 of 5698 Old 07-14-2014, 06:23 AM
Hifi4Hobby's Avatar
I have the JC2bp with A21 and AV8801 so perhaps i can share some of my thoughts. In pure 2 channels listening, JC2 will be the best choice over the AV8801 anytime hence that's the reason why i added the JC2bp for the more serious music listening.
As for the JC2bp matching to either JC1 or A21, with my own experience, I find the JC1 with the given same volume on JC2, music is louder but the sound characteristic is similar to A21 so unless you really need the extra power, the A21 should do just fine and a vertical bi-amp using 2 x A21 might yield some interesting result too especially if you play around with the A21 individual channel gain which you cant with the JC1.
Then if JC2 is worth getting over the P5 or other pre at this price range, i would say, yes. Unless you need sub management which P5 has and JC2 doesnt, you'll be better off with the sonic superiority of JC2. I simply love the fact that it has no digital display with simplicity that is easy to appreciate.
Hope this helps.
enricoclaudio likes this.
Hifi4Hobby is offline
post #3560 of 5698 Old 07-14-2014, 12:34 PM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
All the feedback is helpful. Keep it coming.
Saturn94 is offline
post #3561 of 5698 Old 07-14-2014, 01:23 PM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I am adding a Black A21 with my two Black A51s... To help assist with Dolby Atmos.
Love Parasound!
post #3562 of 5698 Old 07-17-2014, 10:21 AM
ohrbrcko's Avatar
Quoted: 39 Post(s)
Liked: 39
Newest Parasound Owner
Well after months and months of going back and forth, I decided to invest in a Parasound A-21. I came close to selecting the Emotiva XPS-2 or even 3 but I wanted take my system up a notch or two in quality and perceived performance. Additionally, Parasound has a proven record of great customer support and exceptionally reliable products. I expect delivery of the A-21 tomorrow. I hope to have it all hooked up early next week as I am awaiting interconnects and a power cord from Audio Art.
joerod likes this.
ohrbrcko is offline
post #3563 of 5698 Old 07-17-2014, 02:24 PM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 240
Originally Posted by ohrbrcko View Post
... I decided to invest in a Parasound A-21....
Congrats but you left off the most important info. What color?
Also, what speakers are you using with it?
Congrats again.
artur9 is offline
post #3564 of 5698 Old 07-17-2014, 02:43 PM
babylon5fan's Avatar
Last Best Hope for D/AC-1000
  • Moved the D/AC to another system and after plugging it in the Data error red light came on. No other cables were plugged in. Decided to plug in the digi cable and rca's and yep, no sound. Got ahold of Parasound and they told me they had never heard of that error/problem before and it was not going to be cheap to hopefully scope out and fix. Any thoughts here as for the kind of money they are talking about I would rather just get another cheaper D/AC since shipping along is going to be pricey
babylon5fan is offline
post #3565 of 5698 Old 07-17-2014, 02:46 PM
ohrbrcko's Avatar
Quoted: 39 Post(s)
Liked: 39
Congrats again.
I got the A-21 in black and I am using Monitor Audio Silver 10s.
ohrbrcko is offline
post #3566 of 5698 Old 07-17-2014, 04:11 PM
NextLevel217's Avatar
Quoted: 76 Post(s)
Liked: 34
Can't wait
I just ordered an A21 and A31 to go with a Yamaha cx-a5000 and Oppo 105d. Can't wait to hear this set up
NextLevel217 is offline
post #3567 of 5698 Old 07-17-2014, 04:15 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
Verfy nice gear.
What are your speakers?
- Rich
RichB is online now
post #3568 of 5698 Old 07-17-2014, 07:30 PM
merrymaid520's Avatar
Quoted: 60 Post(s)
Liked: 31
Verfy nice gear.
- Rich
I just got my Yamaha cx a5000 running with an A21 and 7 ch outlaw amp. Sounds damn good! You will like the setup
merrymaid520 is offline
post #3569 of 5698 Old 07-18-2014, 07:59 AM
Quoted: 76 Post(s)
Liked: 34
I have Paradigm sig 8's c5 center adp3's and dual seaton submersives.
RichB and WAFWarrior like this.
post #3570 of 5698 Old 07-19-2014, 05:52 AM
ohrbrcko's Avatar
Quoted: 39 Post(s)
Liked: 39
The A-21 has arrived...hope to be able to install it on Monday (still waiting on cables to arrive). It is really an impressive looking piece of hardware. Just fits in my rack.
ohrbrcko is offline
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
