Parasound Owners Thread - Page 152 - AVS | Home Theater Discussions And Reviews
 177Likes
post #4531 of 4545 Old 06-25-2015, 06:56 AM
ChrisMc73's Avatar
Quoted: 141 Post(s)
Originally Posted by dbphd View Post
The simple setup I mentioned in the head exploding post, Oppo 95 to Parasound A23 to KEF LS50 speakers, is excellent for music and movies. If you substitute a 105 for the 95, it will also do Cable or Satellite TV via the HDMI connection in the rear; that's what I do with the more elaborate setup. A sub needn't be used to keep the setup even more simple. The SMS-1 bass manager I use has an automated mode in which you just connect its microphone and push three buttons on the remote. The SMS-1 measure tones it produces and makes the spectral adjustments. Or you can use a sub without acoustic room correction, as I suspect most people do.
db
Ok, so I'll consider your setup, it sounds good. I don't see that you can buy an Oppo 95 on their website, just the 103 and 105s. I'd probably just go for the 105 anyway, it has so much to offer. I'll look into your KEF speakers as well, the A23 looks perfect for your setup.
ChrisMc73 is offline
post #4532 of 4545 Old 06-25-2015, 11:10 AM
upsetter's Avatar
Quoted: 31 Post(s)
Originally Posted by BillP View Post
Yes. I have only a 2-channel system since music is my priority. I use the same system for movies, but don't care whether car doors slam in back of me (my critical listening is only for music; I don't critically listen to movie soundtracks, but rather critically watch movies). This way, I keep the system very simple: Parasound JC2/A21 2-channel combo driving a pair of Sonus Faber Olympica IIIs.
Bill, this is one nice setup you have. I can imagine how good it sounds. Did you ever try to add surround speakers (for 5.1 naturally recorded SACD, DVD-A oe BD-Audio?). It can give a new dimension to how realistic performance sounds.
ChrisMc73 likes this.
OPPO-105
Parasound Halo A23
Definitive Technology Mythos STS/Gems
upsetter is offline
post #4533 of 4545 Old 06-25-2015, 02:19 PM
artur9's Avatar
Quoted: 246 Post(s)
Liked: 84
Originally Posted by ChrisMc73 View Post
Which leads me to a question about my current setup. I have a lower end Denon 2313CI AVR, which has all my components going into it HDMI wise. I usually have to turn the volume up into the -56 to -60 range to get a good level, is this normal, or a sign of the weak amp in this lower end AVR?
There are many many reasons this could be the case. Simplest: What does -56 even mean in terms of power output? Is your room big? Are you sitting far away? Does your room have a lot of squishy stuff in it? Are you speakers inefficient? Are your speaker's impedance rating difficult for your AVR? Is your AVR plugged into the same circuit as your refrigerator? Are your speakers pointed at the seating area? Are your speakers broken? ...
TL;DR: Basically, there's no real way to answer your question they way you asked it.
BTW, supposedly, if everyone in New York City shouted at the same time it would only equal 100watts of power or something like that.
artur9 is offline
post #4534 of 4545 Old 06-25-2015, 03:21 PM
BillP's Avatar
Quoted: 149 Post(s)
Liked: 123
No, I haven't. It's always been a 2-channel system (for several decades). But I do enjoy the 2-channel layer on SACDs.
BillP is offline
post #4535 of 4545 Old 06-25-2015, 05:42 PM
highfigh's Avatar
Quoted: 347 Post(s)
Liked: 105
What does -56 mean? Same thing as 32 out of 100- not much, but it's more meaningful than the latter because it's a reference to the manufacturer's idea of WOT.
highfigh is offline
post #4536 of 4545 Old 06-26-2015, 02:20 AM
dbphd's Avatar
Quoted: 136 Post(s)
Liked: 67
It requires more than adding speakers. The JC-2 doesn't do surround processing. For surround, I use a Cary Cinema 12, the front LR of which are passed through a JC-2 BP to the JC-1 amps. The center goes directly from the Cary to a JC-1, surrounds and rears to A23s, and SW to a Velodyne SMS-1 that controls a pair of HGS-15s.
I play most SACDs as stereo, because I prefer the sound with the Ayre C-5xeMP to that with the Oppo 105 or Sony XA5400ES, but I enjoy Blu-ray DTS-HD MA and Dolby True HD music discs in surround, especially opera. It does add a sense of ambience.
db
dbphd is offline
post #4537 of 4545 Old 06-26-2015, 11:48 AM
merrymaid520's Avatar
Quoted: 47 Post(s)
Liked: 30
Looks like Im keeping my P7! The P5 is for sale if anyones interested
Pm me for details.
merrymaid520 is online now
post #4538 of 4545 Old 06-27-2015, 11:39 AM
audio4life's Avatar
Liked: 207
I take it you compared the two and preferred the P7? I guess the DAC section wasn't needed, but other than that, what tipped the scales in favor of the P7 for you?
audio4life is offline
post #4539 of 4545 Old 06-27-2015, 03:30 PM
Liked: 1
Pm me for details.
hello
what was the difference sq regarding phone stage between p5 and p7?
best regards
vienna
Papak Stari is offline
post #4540 of 4545 Old 06-28-2015, 10:42 AM
Quoted: 47 Post(s)
Liked: 30
Yes, I was able to A/B them in my setup as best I could manage (and as quick as possible).
I must acknowledge the two likely would sound much more similar than different if one were to not hear them side by side. Anyway, the P7 sounded a bit more natural and refined. Slightly less edgy maybe? The tracks I tested sounded a bit more realistic with a very smooth overall sound....tough to put into words. . The P5 sold quickly. I had no need for its internal DAC either. Oh, the P7 has much better volume adjustment as well!
Edit - Forgot to mention, I also plan to dive more into High Res Multi Ch material with the P7! I just bought a ton of stuff
post #4541 of 4545 Old 06-28-2015, 11:17 AM
dbphd's Avatar
Quoted: 136 Post(s)
Liked: 67
3rd JC-1 is different
I installed a 3rd JC-1 yesterday. It drives the center channel, and the sound of the 8 Ω KEF R600C now matches that of the 4 Ω 107/2s quite well. But this JC-1 seems different from the pair I’m using to drive the 107/2s. In high bias mode it runs hot to the touch, whereas the pair that drive the 107/2s are just warm to the touch. If I set the bias of the new JC-1 to low, it is also just warm to the touch. Reviews and a couple of posts have noted that the amps run hot, but I thought the 107/2s might be an easy load and coupled with the moderate levels of music I prefer may have accounted for the mild warmth. Now I wonder if the pair of amps I bought to drive the 107/2s may be running in low bias mode even though the switch is set to high bias. Those amps sound great driving the 107/2s. Would I notice any difference in sound between high and low bias at moderate levels?
Also, the blue light of the new amp is much brighter than that of the other two amps and is bright whether powered up or not — the red lights of all the amps follow the same pattern of being bright when on and going to dim when off.
Any advice or comments from those more familiar with the JC-1 amps would be appreciated.
db
dbphd is offline
post #4542 of 4545 Old 06-28-2015, 11:54 AM
audio4life's Avatar
Liked: 207
I would contact Parasound with your observations. Perhaps the amp just needs to break in a little, give it 100 hours and see how it is. Hopefully some owners can report.
Edit: Here's a thought, perhaps you could connect one of your existing amps to the center, and the new JC1 to the 107/2. See if the new amp still heats up and the other JC1 still runs cooler.
post #4543 of 4545 Old Yesterday, 06:57 PM
Quoted: 47 Post(s)
Liked: 30
Proof of my recent parasound preamp shootout
post #4544 of 4545 Old Today, 03:55 AM
highfigh's Avatar
Quoted: 347 Post(s)
Liked: 105
You're not giving the AVR or power amp much breathing room- do they run hot in that cabinet?
highfigh is offline
post #4545 of 4545 Unread Today, 08:47 AM
Quoted: 47 Post(s)
Liked: 30
The front and rear is completely open. They do not get hot at all and I have never had a problem. The middle amp and Yamaha pre have a few inches minimum on all sides. The pic might be a bit deceiving.
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
