Parasound Owners Thread - Page 153 - AVS Forum | Home Theater Discussions And Reviews
 180Likes
post #4561 of 4574 Old Today, 01:18 AM
Liked: 0
Parasound+oppo bd player+marantz receiver
Hi,
I'm posting this on behalf of a friend, who just bought the A23, with the intention of connecting an Oppo player to the XLR input for stereo music, and his Marantz surround receiver via the RCA cables. When both are connected at the same time, there is a major drop of volume and quality, and we're told by the local dealer it is normal and he should disconnect one when listening to the other.
I would just like to ask if there is a another way, aside form buying a dedicated pre amp to connect both at the same time.
Thank you!
obb2015 is offline
post #4562 of 4574 Old Today, 02:39 AM
Quoted: 13 Post(s)
Liked: 1
USB trigger from Oppo 105D to A21/P5
Originally Posted by RichB View Post
I bought the pars on digi-key and no longer use this method.
http://www.digikey.com/product-detail/en/PDS1-S5-S12-S/102-2753-ND/4009677
http://www.cui.com/product/resource/pds1-s.pdf
At this point, I recommend buying the Emotiva ET-3 part and make a USB to trigger cable:
https://emotiva.com/products/accessories/et-3
Digikey has these cables as well or you can hack up a standard cable you buy anywhere.
- Rich
Hello Rich,
thanks for your response, pls for some additional info:
Does it mean that you are using HA-1 for the triggering of A21/A51
How do you use Oppo105 to trigger the HA-1?
Why do you not use digi key modified solution any more, did you have any issue with sound quality or there occurred some other problems?
Does digi key modified work properly in the past with Oppo105D, I suppose?
Many Thanks and Best Regards
vienna
Papak Stari is online now
post #4563 of 4574 Old Today, 05:37 AM
RichB's Avatar
Quoted: 448 Post(s)
Liked: 313
Originally Posted by Papak Stari View Post
Hello Rich,
vienna
At one point, I had the 105D triggering the A51 and the A21 by making a USB to dual trigger cable.
The HA-1 trigger the A21 using standard cables.
So, when the HA-1 system was powered only A21 was trigger on.
When the 105D powered, the rear USB2 power triggered the A51 and the HA-1 on.
It turns out both A21 and A51 would trigger on the 5 volts provided by the USB port.
- Rich
Oppo Beta Group
Oppo BDP-105D | Oppo HA-1 | Oppo PM-1 | Parasound A21 + A21 + A51 | Revel Salon, Voice, Studio | Velodyne HGS-15
For Sale: Revel Salons and Revel Studios (together or separately)
RichB is online now
post #4564 of 4574 Old Today, 05:52 AM
Kal Rubinson's Avatar
Quoted: 257 Post(s)
Liked: 250
Originally Posted by obb2015 View Post
Hi,
Thank you!
This is normal since each input source, when connected at the same time, will shunt the other. Your options are:
1. Disconnect the unused source.
2. Get a preamp.
3. Get/build a switch.
WAFWarrior likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #4565 of 4574 Old Today, 06:26 AM
Quoted: 13 Post(s)
Liked: 1
- Rich
Hello Rich
many thanks for replay, I sent you PM
Best Regards
vienna
post #4566 of 4574 Unread Today, 07:28 AM
highfigh's Avatar
Quoted: 362 Post(s)
Liked: 105
Hi,
Thank you!
The XLR inputs are quasi-balanced and if you want to get everything out of them, your friend needs to flip the Balanced/Unbalanced switch. As the dealer recommends, connect one at a time- that's the reason preamps exist. BTW- the P5 works very well for this- I have one and use an A23 with it.
highfigh is offline
post #4567 of 4574 Unread Today, 08:46 AM
Liked: 0
thanks, he used that switch too, but it didn't help, and he'll probably get a P3, one of the shops here has it, they used it as a demo and clearing it at a discount.
he was hoping to use the oppo and marantz as pre-amps, but it won't work. Maybe getting an RCA selector, and just using both with RCA, not the XLR is a workable solution for now?
obb2015 is offline
post #4568 of 4574 Unread Today, 09:04 AM
Quoted: 72 Post(s)
You should not connect both XLR and RCA to the same A21 channel. The is not a toggle between inputs. It optimizes the handling of the XLR input.
- Rich
I know, that is why almost every day I am switching back and forth between balanced and unbalanced sources. and it is getting to be a pain. I am looking for a passive switch that I can go from rca/xlr source inputs to the xlr inputs on the A21 but could not find one. I have an XLR switch and I just ordered some rca male to XLR male cables to see if they will work.
I have an active preamp (Marantz av8801) but it is awful for 2 channel audio.
STIGUY2014 is online now
post #4569 of 4574 Unread Today, 12:28 PM
audio4life's Avatar
Liked: 215
What you need to end up doing is get a dedicated 2 channel system. With all of those amps surely you can spare one for a 2 channel system. Otherwise eventually you will damage something.
audio4life is online now
post #4570 of 4574 Unread Today, 01:09 PM
Quoted: 72 Post(s)
The cables that I have on order are the last try - I will not be trying active or transformer converters.
post #4571 of 4574 Unread Today, 02:22 PM
audio4life's Avatar
Liked: 215
It appears that we are miscommunicating.
post #4572 of 4574 Unread Today, 02:29 PM
jima4a's Avatar
Quoted: 127 Post(s)
Liked: 94
Perhaps a JC2BP would solve all your problems?
jima4a is online now
post #4573 of 4574 Unread Today, 02:52 PM
Quoted: 72 Post(s)
Dedicated 2 channel system is not possible. I like the way it is setup right now - everything is the way it should be other than switching between the rca and xlr inputs on the A21. As far as damaging something, if I'm feeding a low votage rca signal into the xlr inputs, what could get damaged?
post #4574 of 4574 Unread Today, 02:54 PM
Quoted: 72 Post(s)
JC2BP would be nice but I don't want to spend that much money just to fix the switching issue. Plus I am using Goldpoint level controls for volume which I am very very happy with. In fact it was these controls that made me never want to use an active preamp.
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
