Parasound Owners Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 427Likes
post #4861 of 5459 Old 02-01-2016, 04:18 PM
Quoted: 334 Post(s)
Liked: 50
Originally Posted by artur9 View Post
Sure. Just don't use the RCA stereo outs. I used to use the optical out on my Connect all the time.
Actually after some research I Might use the Bluesound Node 2 or Auralic Aries Mini to connect to my parasound ..
For some reasons I thought you had to use the USB input on the parasound to use the DAC..
blackjack616 is online now
post #4862 of 5459 Old 02-01-2016, 04:27 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
If you send audio to it via any digital input, the DAC converts the signal to analog. If you use the analog inputs, the DAC doesn't get used because the signal is already analog...
gsr is offline
post #4863 of 5459 Old 02-01-2016, 05:30 PM
Quoted: 334 Post(s)
Liked: 50
thanks for this; i'll just use the coaxial then. I'm guessing the parasound DAC is far superior to the DAC in the blue sound node 2?
Supported DAC Sampling Rates
USB: up to 384 kHz / 32-bit PCM
Coax/Opt: up to 192 kHz / 24-bit PCM
Does this mean USB is better and would produce better sound quality?
post #4864 of 5459 Old 02-02-2016, 10:53 PM
RobDec's Avatar
Quoted: 135 Post(s)
AMP draw
Hi
Still researching the A51 and A21. Im curious what the amp draw is for these two units? I have a 20 amp dedicated line. And the Parasound amps will be replacing 2 Krell KAV 250a/3 and 1 KAV 250a. My amp draw is 6 amps with my current system, but just want to know if I may be in trouble?
Thank You,
Rob
RobDec is offline
post #4865 of 5459 Old 02-03-2016, 08:06 AM
Liked: 1
Originally Posted by RobDec View Post
Hi
Thank You,
Rob
I have the A21 a P5 preamp and cambridge752 bd as well as HSU sub all on 1 15amp line with no problems at all. The A21 barely gets warm and sounds great in this 2 channel system. It replaced my Krell KAV 250A that also sounded great.
I moved the Krell 250A to my 5.2 system along with the Krell KAV 250A/3. The/3 is on a 20amp line along with a sub , nad dac,cambridge 752bd and 46" TV no problems. The 2 channel KAV is on a 15 amp line along with a sub , Anthem MRX310, Roku , and the lights in that room no problems. For awhile the everything was on the 20amp line with no problems. So while I don't have the A51 I think you'll be safe. PS IMHO the A21 and KAV250A both sound great in my two channel room. If I had to pick one over the other it would be tuff sound wise. The krell may have a little stronger bass... my ears my system. Hope some of this helps.
uthiker is offline
post #4866 of 5459 Old 02-05-2016, 01:33 PM
adrummingdude's Avatar
Quoted: 405 Post(s)
Liked: 270
Hey guys,
I'm selling my A21, along with my B&W CM and SVS setup. If interested, head over to the classifieds or PM me.
HT: B&W CM9 S2 - Martin Logan SLM-XL - DefTech XTR-20BP - Dual SVS SB-2000 - Parasound Halo A21 and A51 - Marantz AV7702 MKii - Samsung UN65JS8500
2CH: Sonus Faber Cremona Auditor M - Parasound Halo A23 - Bluesound Node 2 - Iomega NAS
WAF is currently at DEFCON RED
adrummingdude is offline
post #4867 of 5459 Old 02-05-2016, 01:42 PM
RobDec's Avatar
Quoted: 135 Post(s)
Thanks uthiker,
That's interesting. I was hoping there would be a big difference between the Krells and the A51 and A21 combo. Maybe ill expand my search to other amps.
Rob
RobDec is offline
post #4868 of 5459 Old 02-05-2016, 08:17 PM
artur9's Avatar
Quoted: 543 Post(s)
Liked: 185
Thanks uthiker,
Rob
If you're looking for a very different sound you could try a Belles. I have a Krell integrated and the A52 and a boxed up Belles. The Krell and the Parasound are more alike than different but the Belles...wooo boy! is that a different thing. I am very tempted to put in back in but don't relish the rewiring.
artur9 is offline
post #4869 of 5459 Old 02-05-2016, 09:11 PM
seanh1978's Avatar
Quoted: 17 Post(s)
I have a Jc3+ that I've owned for about a year with no problems
. I was using s sounds its zephyr cart with the recommended 47K load setting on the Jc3+, worked flawlessly for a year.
Just upgraded to a Lyra etna MC cart, had it professionally installed, the recommended load for my cart is 100K. So I changed the Jc3+ load setting switch to 47k variable a load setting to 100k and it sounds like I'm playing an iPod
No low frequencies at all. Tried different loads on the dial, same problem. Switch back to fixed 47k as originally and sounds normal but not amazing. Installer said I'm not getting the full effect of the new cart because I can't send the proper load to it and that my Jc3+ is faulty. Anyone else ever this type of issue ?
seanh1978 is offline
post #4870 of 5459 Old 02-05-2016, 09:11 PM
seanh1978's Avatar
Quoted: 17 Post(s)
post #4871 of 5459 Old 02-07-2016, 06:09 PM
Chriscorv58's Avatar
Quoted: 122 Post(s)
Liked: 82
I am currently using a parasound a21 for my mains and an old Acurus a250 for my center channel a 4ohm speaker. It is not even close to the same league as the A21. I found a local guy selling an A21 I'd love to purchase it for my center and my Acurus for rears.
I think it would be a total waste to have a 2 channel amp driving my center channel, Parasound site doesn't say anything about the a21 being bridged to a 4 ohm speaker, just the specs of 700 watts bridged mono 8ohm.
Am I going to run into trouble using this A21 as a bridged mono amp for a 4 ohm speaker? yes I can buy an A31, but I've listened to one using 2 channel and I was not as impressed with it as my a21. The A21 for my center would be much much cheaper than a jc1.
I'm sure this has been asked before but Google did not bring up any results.
Sent from my SM-N910V using Tapatalk
wilbur_the_goose likes this.
Sony 940c 75" Display, Marantz AV8801, HTPC, JTR 215RM Mains & JTR 210RM Center, DIY Surrounds, Crown Xti & Cdi Amps, Seaton Submersive HP+ Master and Slave.
Chriscorv58 is offline
post #4872 of 5459 Old 02-07-2016, 06:32 PM
dbphd's Avatar
Quoted: 388 Post(s)
Liked: 143
Send an email to richard@parasound.com. He's very good about responding in a timely manner.
dbphd is offline
post #4873 of 5459 Old 02-07-2016, 06:47 PM
Quoted: 122 Post(s)
Liked: 82
Thank you, just did. I'll post back at findings.
post #4874 of 5459 Old 02-07-2016, 09:52 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Obviously getting a response from Richard means more than anything I can say but I am pretty sure the A21 does not play nice with 4 ohm speakers bridged. I would highly suggest an A31 for center and surrounds. I agree the A21 is a better amp which is important for L&R, I just think it is less important for the center and surrounds in multichannel. But that is just my opinion, take it as such.
RichB and audiofan1 like this.
jima4a is offline
post #4875 of 5459 Old 02-08-2016, 05:06 AM
artur9's Avatar
Quoted: 543 Post(s)
Liked: 185
I use 2 centers so using an A21 to drive both would be sweet!
Can you get another center? Mine are above and below the screen so no horizontal combing issues here.
artur9 is offline
post #4876 of 5459 Old 02-08-2016, 07:07 AM
Quoted: 122 Post(s)
Liked: 82
That is cool idea but my center is huge, and in a living room. It would start to look like a dorm room.
JTR Sound 210RM center, I wish I could find a jc 1 for around 2k that would fix all my problems.
post #4877 of 5459 Old 02-08-2016, 10:25 AM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
If your speaker is 4 ohmns do not bridge it.
I use an A51 channel or the Voice2 and that works well. If you want to use both channels, then bi-amp is a better choice.
- Rich
audiofan1 likes this.
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #4878 of 5459 Old 02-08-2016, 11:42 AM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Yup! no bridging into 4ohms with the A21 lest you want to have it repaired
audiofan1 is offline
post #4879 of 5459 Old 02-08-2016, 01:50 PM
dbphd's Avatar
Quoted: 388 Post(s)
Liked: 143
I'm now using JC 1s for LCR that replaced a Proceed HPA 3 (3 mono blocks 250 watts@8Ω, 500 watts@4Ω). The HPAs are fine Mark Levinson amps in an industrial case. If it's of interest, I have an HPA 2 and HPA 3 that I'd be willing to sell for $500 a channel. One caveat: They're heavy; each weighs about 100 pounds.
dbphd is offline
post #4880 of 5459 Old 02-09-2016, 02:58 PM
Quoted: 182 Post(s)
Liked: 42
I have 2 A21's that I am using to bi-amp my speakers and I am very happy with the sound in my living area. I am looking to upgrade the amp (Onkyo integrated A9070, only using it as an amp) in my bedroom and JC1's come into mind however the size and the power they produce will be an overkill. I am looking for JC1 sound quality in a smaller package that can produce 20-30 wpc class A power. Any recommendations please?
STIGUY2014 is offline
post #4881 of 5459 Old 02-09-2016, 04:06 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
No other Parasound amp, regardless of size, is going to match the JC-1 for quality. Their other amps are excellent, but the JC-1's are special.
As far as amps from other companies that would be comparable AND smaller, nothing comes immediately to mind. I suspect you may have better luck starting a new thread and including more details about your system (such as what speakers you have).
gsr is offline
post #4882 of 5459 Old 02-10-2016, 02:01 PM
stewey76's Avatar
Quoted: 44 Post(s)
Is audio advisors the only authorized online dealer for parasound amps? I am hoping to find an authorized dealer online where i can get an A31 for cheaper than $3k if possible.
stewey76 is offline
post #4883 of 5459 Old 02-10-2016, 03:35 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Call JD or Mike with AVS sales.
JD (585) 645-1006
Mike (585) 671-2968
stewey76 likes this.
jima4a is offline
post #4884 of 5459 Old 02-10-2016, 05:07 PM
upsetter's Avatar
Quoted: 56 Post(s)
8-10 watts of class A in A21 should be more than enough in most cases. A21 though is bulky as well. The only class A amps I know which have manageable size are from Nelson Pass First Watt. They can do up to 25-40wt, but that is max - so it will work only with sensitive speakers. Look also at Luxman L-550AX. Other option might be efficient low current class A voltage amp complemented with current dumping (a.k.a feedforward correction). These are e.g. AHB2 (which I own) and Devialet 120.
STIGUY2014 likes this.
Source/Dac/Pre: OPPO-105
Fronts: Benchmark AHB2 -> DefTech Mythos ST-Ls
Surrounds: Parasound Halo A23 -> DefTech Mythos Gems
upsetter is offline
post #4885 of 5459 Old 02-10-2016, 06:18 PM
EZ-Rhino's Avatar
Quoted: 16 Post(s)
Liked: 32
Safe & Sound is an authorized dealer. They have an A31 B-Stock for $2,635 with full warranty, free shipping and lifetime technical support. I just bought a JC2 from them.
http://www.safeandsoundhq.com/produc...asound-B-Stock
EZ-Rhino is offline
post #4886 of 5459 Old 02-11-2016, 03:26 PM
stewey76's Avatar
Quoted: 44 Post(s)
Thanks for this. Ordered this afternoon. Didn't get my loyalty points. How much are the points worth? Probably going to get an A21 or two in the future.
stewey76 is offline
post #4887 of 5459 Old 02-11-2016, 03:41 PM
Quoted: 182 Post(s)
Liked: 42
Someday I would like to invest in a pair of JC1's although they take up quite a bit of room. I would love a Luxman or Accuphase amp/integrated but I can't justify the price that the 1 or 2 US dealers charge. A while back I requested a quote for an Accuphase amp from a dealer and it came back over 2 times the price of what they are sold in Japan. For right now, I ordered a Yamaha S2000 integrated at a good price to keep me going in my hobby.
post #4888 of 5459 Old 02-11-2016, 07:27 PM
EZ-Rhino's Avatar
Quoted: 16 Post(s)
Liked: 32
Congratulations. I received 3,395 loyalty points (one point per dollar spent) for my JC2 but I don't know what can be done with them. I assume you can use them for money off on future purchases. Maybe someone with more experience with S&S can answer this question. Did you register a new account when you bought your A31? I would contact them.
EZ-Rhino is offline
post #4889 of 5459 Old 02-12-2016, 07:07 AM
stewey76's Avatar
Quoted: 44 Post(s)
I registered but called on the phone to verify the stock and ended up ordering over the phone. Oh well. Not a big deal.
stewey76 is offline
post #4890 of 5459 Old 02-15-2016, 09:11 AM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
I assume you have a VPI table if you were using a Zephyr cartridge. Perhaps the new cartridge needs a little tweaking or some break in time. My VPI classic 2 with the unipivot arm took some time to get the Zephyr the way I like it to sound. I am not using the JC3 but a Musical Surroundings Phenomina 2 plus which has a ton of settings. It is connected to a Prasound JC 2 and A21. I would think the JC3 is a much better phono stage so maybe you need to work with the new cartridge even if it was pro installed. The Zephyr is a moving iron that works like an MM, but the Lyra is an MC and an expensive one too. No way they can sound the same.
gene9p is offline
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
