Parasound Owners Thread - Page 179 - AVS Forum | Home Theater Discussions And Reviews
 388Likes
post #5341 of 5349 Old Yesterday, 04:11 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 936 Post(s)
Liked: 779
Originally Posted by DesiMunda View Post
Question : I am looking to introduce subwoofer for music at low/moderate volumes. I have A21 connected to Marantz 7702 pre amp using XLR cables in 2 channel only setup at the moment. Is there any way I can incorporate velodyne subwoofer in the setup without making main speakers as - small.
Thought - Can I user - L/R "Loop" RCA output of A21 and connect to RCA input terminals of velodyne sub ? This way I can use crossover of velodyne sub and it will always be engaged.
What do you think of this ?
Why is it that you don't want to configure your main speakers as "small"? That's part of the process of integrating a subwoofer into the system. The "small" selection doesn't mean your speakers are now considered tiny, it means that the crossover has been turned on and the frequency you (or an Audyssey calibration) have selected now defines the transition point where content below the crossover point gradually transitions over to the subwoofer.
You could use the loop outputs on the A21 instead of setting the speakers to small, but then you would end up with double bass as the full bass content will then go to both your main speakers AND your subwoofer, which really isn't desirable.
Edit: To clarify the last point.
gsr is online now
post #5342 of 5349 Old Yesterday, 05:56 PM
DesiMunda's Avatar
Originally Posted by gsr View Post
Why is it that you don't want to configure your main speakers as "small"? That's part of the process of integrating a subwoofer into the system. The "small" selection doesn't mean your speakers are now considered tiny, it means that the crossover has been turned on and the frequency you (or an Audyssey calibration) have selected now defines the transition point where content below the crossover point gradually transitions over to the subwoofer. You could use the loop outputs on the A21, but then you would end up with double bass as the full bass content will then go to both your main speakers AND your subwoofer, which really isn't desirable.
Thank You for nice explanation. So this is what i am thinking of doing now. Please validate.
Change speaker setting to "small" connect "loop" RCA output of parasound to sub input. Run Audyssey calibration and tweak crossover settings if needed.
DesiMunda is offline
post #5343 of 5349 Old Yesterday, 06:00 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 936 Post(s)
Liked: 779
Change speaker setting to "small" connect "loop" RCA output of parasound to sub input. Run Audyssey calibration and tweak crossover settings on pre/pro if needed.
Um, no that definitely won't work. When you set the speaker to small, the pre-out for that speaker will have the crossover applied, which means that hooking the subwoofer to the loop outputs from the A21 means the subwoofer won't be getting much content to work with.
Change the speaker setting to small and leave your amp hooked up as it currently is. Connect your subwoofer to the subwoofer output on the Marantz 7702. Then run an Audyssey calibration and then tweak any settings that need to be tweaked.
gsr is online now
post #5344 of 5349 Old Yesterday, 06:25 PM
DesiMunda's Avatar
thanks; will try as you suggested.
post #5345 of 5349 Old Yesterday, 08:09 PM
artur9's Avatar
Quoted: 511 Post(s)
Liked: 163
Does the Velodyne have "high level" inputs? You'd run speaker wire from the amp to the Velodyne then some more speaker wire to the L/R speakers.
artur9 is offline
post #5346 of 5349 Old Yesterday, 08:50 PM
DesiMunda's Avatar
Thanks for your suggestions. It has output and input RCA connection; Don't know how much sound distortion they may add and that's why do not want to run additional cable wires out of subwoofers.
post #5347 of 5349 Old Today, 10:38 AM
Yveke's Avatar
Liked: 1
Go into AV7702 bass or subwoofer(can't remember) section and select LFE + MAIN, with the option to select bass management crossover even if speakers are set to full range.
Note that some say this can cause "booming" issues due to double bass, but you're the best judge on how it sounds to you.
No need to loop anything connection wise, just a config option.
Rgds,
Yves.
2 x BK 400xxls - KEF R900 R600c R700 - ATI 4002 signature - ATI 2005 - Parasound P5 - Marantz AV7702 - Dune HD Solo 4K - xbox360 - Asset UPnP from PC - Pioneer LX5090 - Epson TW3600EW
Yveke is offline
post #5348 of 5349 Old Today, 12:38 PM
DesiMunda's Avatar
Rgds,
Yves.
Thanks Yves. That's exactly audyssey did configure for me last night.
So far I do not notice "booming".
Planning to test this for few days and go from there.
post #5349 of 5349 Old Today, 06:38 PM
dlynch34's Avatar
Quoted: 221 Post(s)
Liked: 82
just got a demo unit (A21)... coming from emotiva so far im not noticing much difference perhaps a tad more laid back than my emotiva mono blocks.... have to let it settle in and see how I feel about it with more listening..
Don
Marantz AV8802a,Parasound Halo A21, Emotiva XPA-1l x4,Emotiva MPS-2. Rhythmik DIY 15inch x2, Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,JVC RS400, DIY 125" 2:35 Elite Screen cinegray 3d .
dlynch34 is online now
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
